ossim-plugins
potrace
src
lists.h
Go to the documentation of this file.
1
/* Copyright (C) 2001-2015 Peter Selinger.
2
This file is part of Potrace. It is free software and it is covered
3
by the GNU General Public License. See the file COPYING for details. */
4
5
6
#ifndef _PS_LISTS_H
7
#define _PS_LISTS_H
8
9
/* here we define some general list macros. Because they are macros,
10
they should work on any datatype with a "->next" component. Some of
11
them use a "hook". If elt and list are of type t* then hook is of
12
type t**. A hook stands for an insertion point in the list, i.e.,
13
either before the first element, or between two elements, or after
14
the last element. If an operation "sets the hook" for an element,
15
then the hook is set to just before the element. One can insert
16
something at a hook. One can also unlink at a hook: this means,
17
unlink the element just after the hook. By "to unlink", we mean the
18
element is removed from the list, but not deleted. Thus, it and its
19
components still need to be freed. */
20
21
/* Note: these macros are somewhat experimental. Only the ones that
22
are actually *used* have been tested. So be careful to test any
23
that you use. Looking at the output of the preprocessor, "gcc -E"
24
(possibly piped though "indent"), might help too. Also: these
25
macros define some internal (local) variables that start with
26
"_". */
27
28
/* we enclose macro definitions whose body consists of more than one
29
statement in MACRO_BEGIN and MACRO_END, rather than '{' and '}'. The
30
reason is that we want to be able to use the macro in a context
31
such as "if (...) macro(...); else ...". If we didn't use this obscure
32
trick, we'd have to omit the ";" in such cases. */
33
34
#define MACRO_BEGIN do {
35
#define MACRO_END } while (0)
36
37
38
/* macros for singly-linked lists */
39
40
/* traverse list. At the end, elt is set to NULL. */
41
#define list_forall(elt, list) for (elt=list; elt!=NULL; elt=elt->next)
42
43
/* set elt to the first element of list satisfying boolean condition
44
c, or NULL if not found */
45
#define list_find(elt, list, c) \
46
MACRO_BEGIN list_forall(elt, list) if (c) break; MACRO_END
47
48
/* like forall, except also set hook for elt. */
49
#define list_forall2(elt, list, hook) \
50
for (elt=list, hook=&list; elt!=NULL; hook=&elt->next, elt=elt->next)
51
52
/* same as list_find, except also set hook for elt. */
53
#define list_find2(elt, list, c, hook) \
54
MACRO_BEGIN list_forall2(elt, list, hook) if (c) break; MACRO_END
55
56
/* same, except only use hook. */
57
#define _list_forall_hook(list, hook) \
58
for (hook=&list; *hook!=NULL; hook=&(*hook)->next)
59
60
/* same, except only use hook. Note: c may only refer to *hook, not elt. */
61
#define _list_find_hook(list, c, hook) \
62
MACRO_BEGIN _list_forall_hook(list, hook) if (c) break; MACRO_END
63
64
/* insert element after hook */
65
#define list_insert_athook(elt, hook) \
66
MACRO_BEGIN elt->next = *hook; *hook = elt; MACRO_END
67
68
/* insert element before hook */
69
#define list_insert_beforehook(elt, hook) \
70
MACRO_BEGIN elt->next = *hook; *hook = elt; hook=&elt->next; MACRO_END
71
72
/* unlink element after hook, let elt be unlinked element, or NULL.
73
hook remains. */
74
#define list_unlink_athook(list, elt, hook) \
75
MACRO_BEGIN \
76
elt = hook ? *hook : NULL; if (elt) { *hook = elt->next; elt->next = NULL; }\
77
MACRO_END
78
79
/* unlink the specific element, if it is in the list. Otherwise, set
80
elt to NULL */
81
#define list_unlink(listtype, list, elt) \
82
MACRO_BEGIN \
83
listtype **_hook; \
84
_list_find_hook(list, *_hook==elt, _hook); \
85
list_unlink_athook(list, elt, _hook); \
86
MACRO_END
87
88
/* prepend elt to list */
89
#define list_prepend(list, elt) \
90
MACRO_BEGIN elt->next = list; list = elt; MACRO_END
91
92
/* append elt to list. */
93
#define list_append(listtype, list, elt) \
94
MACRO_BEGIN \
95
listtype **_hook; \
96
_list_forall_hook(list, _hook) {} \
97
list_insert_athook(elt, _hook); \
98
MACRO_END
99
100
/* unlink the first element that satisfies the condition. */
101
#define list_unlink_cond(listtype, list, elt, c) \
102
MACRO_BEGIN \
103
listtype **_hook; \
104
list_find2(elt, list, c, _hook); \
105
106
MACRO_END
107
108
/* let elt be the nth element of the list, starting to count from 0.
109
Return NULL if out of bounds. */
110
#define list_nth(elt, list, n) \
111
MACRO_BEGIN \
112
int _x;
/* only evaluate n once */
113
for (_x=(n), elt=list; _x && elt; _x--, elt=elt->next) {} \
114
MACRO_END
115
116
117
118
#define list_nth_hook(elt, list, n, hook) \
119
MACRO_BEGIN \
120
int _x;
121
for (_x=(n), elt=list, hook=&list; _x && elt; _x--, hook=&elt->next, elt=elt->next) {} \
122
MACRO_END
123
124
/* set n to the length of the list */
125
#define list_length(listtype, list, n) \
126
MACRO_BEGIN \
127
listtype *_elt; \
128
n=0; \
129
list_forall(_elt, list) \
130
n++; \
131
MACRO_END
132
133
/* set n to the index of the first element satisfying cond, or -1 if
134
none found. Also set elt to the element, or NULL if none found. */
135
#define list_index(list, n, elt, c) \
136
MACRO_BEGIN \
137
n=0; \
138
list_forall(elt, list) { \
139
if (c) break; \
140
n++; \
141
142
if (!elt) \
143
n=-1; \
144
MACRO_END
145
146
/* set n to the number of elements in the list that satisfy condition c */
147
#define list_count(list, n, elt, c) \
148
MACRO_BEGIN \
149
n=0; \
150
151
if (c) n++; \
152
153
MACRO_END
154
155
/* let elt be each element of the list, unlinked. At the end, set list=NULL. */
156
#define list_forall_unlink(elt, list) \
157
for (elt=list; elt ? (list=elt->next, elt->next=NULL), 1 : 0; elt=list)
158
159
/* reverse a list (efficient) */
160
#define list_reverse(listtype, list) \
161
MACRO_BEGIN \
162
listtype *_list1=NULL, *elt; \
163
164
list_prepend(_list1, elt); \
165
list = _list1; \
166
MACRO_END
167
168
/* insert the element ELT just before the first element TMP of the
169
list for which COND holds. Here COND must be a condition of ELT and
170
TMP. Typical usage is to insert an element into an ordered list:
171
for instance, list_insert_ordered(listtype, list, elt, tmp,
172
elt->size <= tmp->size). Note: if we give a "less than or equal"
173
condition, the new element will be inserted just before a sequence
174
of equal elements. If we give a "less than" condition, the new
175
element will be inserted just after a list of equal elements.
176
Note: it is much more efficient to construct a list with
177
list_prepend and then order it with list_merge_sort, than to
178
construct it with list_insert_ordered. */
179
#define list_insert_ordered(listtype, list, elt, tmp, cond) \
180
MACRO_BEGIN \
181
listtype **_hook; \
182
_list_find_hook(list, (tmp=*_hook, (cond)), _hook); \
183
184
MACRO_END
185
186
/* sort the given list, according to the comparison condition.
187
Typical usage is list_sort(listtype, list, a, b, a->size <
188
b->size). Note: if we give "less than or equal" condition, each
189
segment of equal elements will be reversed in order. If we give a
190
"less than" condition, each segment of equal elements will retain
191
the original order. The latter is slower but sometimes
192
prettier. Average running time: n*n/2. */
193
#define list_sort(listtype, list, a, b, cond) \
194
MACRO_BEGIN \
195
listtype *_newlist=NULL; \
196
list_forall_unlink(a, list) \
197
list_insert_ordered(listtype, _newlist, a, b, cond); \
198
list = _newlist; \
199
MACRO_END
200
201
/* a much faster sort algorithm (merge sort, n log n worst case). It
202
is required that the list type has an additional, unused next1
203
component. Note there is no curious reversal of order of equal
204
elements as for list_sort. */
205
206
#define list_mergesort(listtype, list, a, b, cond) \
207
MACRO_BEGIN \
208
listtype *_elt, **_hook1; \
209
210
for (_elt=list; _elt; _elt=_elt->next1) { \
211
_elt->next1 = _elt->next; \
212
_elt->next = NULL; \
213
214
do { \
215
_hook1 = &(list); \
216
while ((a = *_hook1) != NULL && (b = a->next1) != NULL ) { \
217
_elt = b->next1; \
218
_list_merge_cond(listtype, a, b, cond, *_hook1); \
219
_hook1 = &((*_hook1)->next1); \
220
*_hook1 = _elt; \
221
222
} while (_hook1 != &(list)); \
223
MACRO_END
224
225
/* merge two sorted lists. Store result at &result */
226
#define _list_merge_cond(listtype, a, b, cond, result) \
227
MACRO_BEGIN \
228
listtype **_hook; \
229
_hook = &(result); \
230
while (1) { \
231
if (a==NULL) { \
232
*_hook = b; \
233
break; \
234
} else if (b==NULL) { \
235
*_hook = a; \
236
break; \
237
} else if (cond) { \
238
*_hook = a; \
239
_hook = &(a->next); \
240
a = a->next; \
241
} else { \
242
*_hook = b; \
243
_hook = &(b->next); \
244
b = b->next; \
245
246
247
MACRO_END
248
249
250
/* macros for doubly-linked lists */
251
252
#define dlist_append(head, end, elt) \
253
MACRO_BEGIN \
254
elt->prev = end; \
255
elt->next = NULL; \
256
if (end) { \
257
end->next = elt; \
258
} else { \
259
head = elt; \
260
261
end = elt; \
262
MACRO_END
263
264
265
#define dlist_forall_unlink(elt, head, end) \
266
for (elt=head; elt ? (head=elt->next, elt->next=NULL, elt->prev=NULL), 1 : (end=NULL, 0); elt=head)
267
268
/* unlink the first element of the list */
269
#define dlist_unlink_first(head, end, elt) \
270
MACRO_BEGIN \
271
elt = head; \
272
if (head) { \
273
head = head->next; \
274
if (head) { \
275
head->prev = NULL; \
276
} else { \
277
end = NULL; \
278
279
elt->prev = NULL; \
280
elt->next = NULL; \
281
282
MACRO_END
283
284
#endif
/* _PS_LISTS_H */
285
Generated on Fri Aug 3 2018 08:46:44 for OSSIM - Open Source Software Image Map by
