values.h
Go to the documentation of this file.
1 /* Old compatibility names for <limits.h> and <float.h> constants.
2  Copyright (C) 1995, 1996, 1997 Free Software Foundation, Inc.
3  This file is part of the GNU C Library.
4
5  The GNU C Library is free software; you can redistribute it and/or
6  modify it under the terms of the GNU Library General Public License as
7  published by the Free Software Foundation; either version 2 of the
8  License, or (at your option) any later version.
9
10  The GNU C Library is distributed in the hope that it will be useful,
11  but WITHOUT ANY WARRANTY; without even the implied warranty of
12  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
13  Library General Public License for more details.
14
15  You should have received a copy of the GNU Library General Public
16  License along with the GNU C Library; see the file COPYING.LIB. If not,
17  write to the Free Software Foundation, Inc., 51 Franklin Street,
18  Fifth Floor, Boston, MA 02110-1301 USA */
19
20 /* This interface is obsolete. New programs should use
21  <limits.h> and/or <float.h> instead of <values.h>. */
22
23 #ifndef _VALUES_H
24 #define _VALUES_H 1
25
26 #include <limits.h>
27 #ifdef __cplusplus
28 extern "C" {
29 #endif
30
31 #ifdef MAXSHORT
32 #undef MAXSHORT
33 #endif
34 #ifdef MAXFLOAT
35 #undef MAXFLOAT
36 #endif
37
38 #define _TYPEBITS(type) (sizeof (type) * CHAR_BIT)
39
40 #define CHARBITS _TYPEBITS (char)
41 #define SHORTBITS _TYPEBITS (short int)
42 #define INTBITS _TYPEBITS (int)
43 #define LONGBITS _TYPEBITS (long int)
44 #define PTRBITS _TYPEBITS (char *)
45 #define DOUBLEBITS _TYPEBITS (double)
46 #define FLOATBITS _TYPEBITS (float)
47
48 #ifndef MINSHORT
49 # define MINSHORT SHRT_MIN
50 #endif
51 #ifndef MININT
52 # define MININT INT_MIN
53 #endif
54 #ifndef MINLONG
55 # define MINLONG LONG_MIN
56 #endif
57
58 #ifndef MAXSHORT
59 # define MAXSHORT SHRT_MAX
60 #endif
61 #ifndef MAXINT
62 # define MAXINT INT_MAX
63 #endif
64 #ifndef MAXLONG
65 # define MAXLONG LONG_MAX
66 #endif
67
68 #define HIBITS MINSHORT
69 #define HIBITL MINLONG
70
71
72 #include <float.h>
73
74 #define MAXDOUBLE DBL_MAX
75 #define MAXFLOAT FLT_MAX
76 #define MINDOUBLE DBL_MIN
77 #define MINFLOAT FLT_MIN
78 #define DMINEXP DBL_MIN_EXP
79 #define FMINEXP FLT_MIN_EXP
80 #define DMAXEXP DBL_MAX_EXP
81 #define FMAXEXP FLT_MAX_EXP
82
83
84 #ifdef __USE_MISC
85 /* Some systems define this name instead of CHAR_BIT or CHARBITS. */
86 # define BITSPERBYTE CHAR_BIT
87 #endif
88 #ifdef __cplusplus
89 }
90 #endif
91
92 #endif /* values.h */
