demo (#22) - Example http://wrs.postlbs.org/lab/wrs_tools_box_demo/ (#119) - Message List
Hello, I can´t view the file proxy.php. How can I get it? Sombody has it? Thanks
pete16es
03/05/08 12:56:10 (3 years ago)
Message #439
To make a cross-domain AJAX request we need that "proxy.php" file. Otherwise it is not necessary. I customized a simple example, which I found in internet (as far as I remember it was an example made by Yahoo, Author: Jason Levitt). That's how it looks like:
<?php // PHP Proxy example for Yahoo! Web services. // Responds to both HTTP GET and POST requests // // Author: Jason Levitt // December 7th, 2005 // // Allowed hostname (api.local and api.travel are also possible here) define ('HOSTNAME', 'http://host.name.domain/'); $url = HOSTNAME.$_POST['path']; // Open the Curl session $session = curl_init($url); if (isset($_POST)) { $postvars = ''; foreach ($_POST as $key=>$value) { $postvars .= $key.'='.stripslashes($value).'&'; } } curl_setopt ($session, CURLOPT_POST, true); curl_setopt ($session, CURLOPT_POSTFIELDS, $postvars); // Don't return HTTP headers. Do return the contents of the call curl_setopt($session, CURLOPT_HEADER, false); curl_setopt($session, CURLOPT_RETURNTRANSFER, true); // Make the call $response = curl_exec($session); $format = explode('.',$_POST['path']); // The web service returns XML. Set the Content-Type appropriately //error_log($format[1]); switch($format[1]){ case "kml": header('Content-type: application/vnd.google-earth.kml+xml'); break; case "gml": header("Content-Type: text/xml"); break; case "xml": header("Content-Type: text/xml"); break; case "json": header("Content-Type: application/jsonrequest"); break; case "geojson": header("Content-Type: application/jsonrequest"); break; case "wkt": header("Content-Type: text/plain"); break; case "html": header("Content-Type: text/html"); break; default: header("Content-Type: text/plain"); break; } //header("Content-Type: text/xml"); echo $response; curl_close($session); ?>
daniel03/06/08 10:02:22 (3 years ago)
