shootingstar (#18) - Big doubt (#231) - Message List
Big doubt
if you have a directed graph with reverse cost i wouldn't want the algorithm to do u-turns using the same edge (as it has reverse cost) to calculate the best route, as normally you can't make u-turns at the end of the street for example, will i have to add a rule to avoid this?.Thank you a lot.
alvaro
03/06/09 02:34:48 (21 months ago)
