shootingstar (#18) - 'rule' doesn't work … (#278) - Message List
hi i got some problem with the restriction turn with shooting*.
my table (tbl_tmp_segment_routier)looks like this :
id - source - target - cost - reverse_cost - rule - to_cost
54400028 - 275 - 283 - 10176.629 - 1000000 - "54400036" - 1000000
54400104 - 337 - 342 - 17585.972 - 1000000 - "54400144" - 1000000
54400394 - 477 - 464 - 5901.509 - 1000000 - "54400398" - 1000000 54400408 - 522 - 506 - 20293.212 - 1000000 - "54400417" - 1000000
54400385 - 509 - 507 - 6836.598 - 1000000 - "54400388" - 1000000
54400448 - 532 - 531 - 32548.028 - 1000000 - "54400445, 54400446" - 1000000
54401353 - 634 - 757 - 4821.117 - 1000000 - "54401376, 54401355" - 1000000
.... where id = int, source = int, target = int, cost = double precision, reverse_cost = double precision, rule = text and to_cost = double precision
my request looks like this :
INSERT INTO shooting_path1_1
(id, vertex_id, cost, reverse_cost, vitesse_circulation, the_geom)
SELECT id, vertex_id, shot.cost, reverse_cost, vitesse_circulation, the_geom
FROM shortest_path_shooting_star('
SELECT sr.id::int4, source::int4, target::int4,cost::float8, reverse_cost::float8,sr.x1, sr.y1, sr.x2, sr.y2, rule, to_cost::float8 FROM tbl_tmp_seg_routier AS sr ORDER BY sr.id DESC',
SOURCE_ID,
TARGET_ID,
TRUE, TRUE) AS shot JOIN tbl_tmp_seg_routier AS sr ON sr.id = shot.edge_id;
SOURCE_ID and TARGET_ID = one of the ids in the table tbl_tmp_seg_routier i cut this part because there is some joins with other table and it come a little long. I guess it's more readable like this.
i don't know what i doing wrong but no restriction turn are respected. however, The one-way are
and i got a other question, i see somewhere in my research there a function shooting* who trim the start and end edge Can i have it somewhere on the site ?
Message #985
has anyone a hint or idea ? and it's ok for the last question (trim). I done my own function.
marcandre07/21/09 03:59:24 (16 months ago) -
Message #986
Can you please provide few examples of your paths with queries? Also please note that your to_cost values are comparable with cost values, while they should be SIGNIFICANTLY higher if you really want to restrict turns.
anton07/21/09 10:05:56 (16 months ago) -
Message #989
i tried to put a picture with my post but it did not work. What do i put on the bracket ? Image(*HERE*) ?
so here is my table and request for the routing
my road's table :
id x1 y1 x2 y2 cost reverse_co source target rule to_cost 54400047 445285,938 5034184,363 445282,591 5034266,259 10000000 5901,444695 332 343 54400044 100000000 54400062 445282,591 5034266,259 445278,15 5034426,193 10000000 11520,399196 343 353 54400059 100000000 54400091 445359,024 5034460,517 445290,668 5034341,892 10000000 9958,299027 381 351 54400105 100000000 54400028 445265,6 5034035,828 445303,065 5034167,456 10176,629057 10000000 319 326 54400036 100000000 54400104 445295,102 5034427,3 445289,178 5034671,256 17585,972086 10000000 380 385 54400144 100000000 54400037 445303,065 5034167,456 445300,96 5034184,343 1225,220325 10000000 326 333 54400044, 54400046 100000000 54400037 445303,065 5034167,456 445300,96 5034184,343 1225,220325 10000000 326 333 54400044, 54400035 100000000 54400045 445300,96 5034184,343 445295,553 5034267,106 5971,63749 10000000 333 341 54400059, 54400047 100000000 54400030 445246,349 5034054,599 445287,176 5034165,417 10000000 8683,553489 322 328 54400027, 54400028 100000000 54400090 445290,668 5034341,892 445295,102 5034427,3 6159,377435 10000000 351 380 54400103, 54400062 100000000 54400090 445290,668 5034341,892 445295,102 5034427,3 6159,377435 10000000 351 380 54400105 10000000 54400035 445287,176 5034165,417 445285,938 5034184,363 10000000 1367,0009 328 332 0 54400036 445303,065 5034167,456 445287,176 5034165,417 1153,404739 1153,404739 326 328 0 54400038 445405,445 5034179,152 445303,065 5034167,456 7419,309444 7419,309444 324 326 0 54400044 445300,96 5034184,343 445285,938 5034184,363 1081,606885 1081,606885 333 332 0 54400046 445285,938 5034184,363 445204,107 5034180,018 5900,127391 5900,127391 332 342 0 54400059 445295,553 5034267,106 445282,591 5034266,259 935,316988 935,316988 341 343 0 54400060 445295,553 5034267,106 445290,668 5034341,892 5398,72837 5398,72837 341 351 0 54400061 445282,591 5034266,259 445199,697 5034262,846 5973,372932 5973,372932 343 352 0 54400103 445295,102 5034427,3 445278,15 5034426,193 1223,108168 1223,108168 380 353 0 54400105 445359,024 5034460,517 445295,102 5034427,3 5253,962324 5253,962324 381 380 0 54400106 445278,15 5034426,193 445153,377 5034420,044 8994,594096 8994,594096 353 329 0 54400107 445278,15 5034426,193 445276,215 5034670,409 10000000 17607,571012 353 386 0
my request :
SELECT id, vertex_id, shot.cost, reverse_cost, sr.source, sr.target, the_geom INTO shooting_pathXX FROM shortest_path_shooting_star(' SELECT sr.id::int4, source::int4, target::int4, cost::float8, reverse_cost::float8, sr.x1, sr.y1, sr.x2, sr.y2, rule, to_cost::float8 FROM tbl_tmp_seg_routier AS sr ORDER BY sr.id DESC', 54400103::int4, 54400045::int4, TRUE, TRUE) AS shot JOIN tbl_tmp_seg_routier AS sr ON sr.id = shot.edge_id;
and the result :
id vertex_id cost reverse_cost source target 54400103 1146 1223.1081678975 1223.1081678975 380 353 54400062 1143 11520.3991956127 11520.3991956127 343 353 54400059 1195 935.316987517814 935.316987517814 341 343 54400045 1198 10000000 10000000 333 341
as you can see, the result did not respect the turn restriction of the road "54400062". I increased the cost of a restriction, 1 000 000 to 100 000 000 and i got the same result.
a hint or idea of what i'm doing wrong ?
marcandre07/23/09 02:50:51 (16 months ago)-
Message #991
An image would be nice. What about posting your question with a link to this forum topic on the pgRouting mailing list?
You can attach your image there to your mail. I also believe that more people will be aware of your question then.In case you can't find the link to the list: http://lists.postlbs.org/mailman/listinfo
daniel07/23/09 13:32:39 (16 months ago)-
Message #992
Now I got it!
There is no any restriction on edge 54400062 in your data set.
Look, you have a rule for edge 54400090 which is '54400103, 54400062'. It means that way 54400103->54400062->54400090 is restricted.
Please read http://pgrouting.postlbs.org/wiki/ShootingStar - rule setting is described there.
anton07/23/09 13:52:53 (16 months ago)-
Message #993
ahhhhh barnack (french swear) !
I was doing the opposite. So, i must write the edge from which i can't come and not, like i'm doing, the edge from which i can't turn.
Small translation error on my part.
Now it's more clearthanks a lot lot lot guys !
marcandre07/23/09 22:13:47 (16 months ago)
