dijkstra (#16) - Error function "assign_vertex_id" (#280) - Message List
Enter your message here...
Hi, everybody!
I am working the project for my graduation. When i prepare data for dijkstra algorithm , i run function "assign_vertex_id" for data table "duong_pho_line"
"SELECT assign_vertex_id('duong_pho_line', 0.001, 'the_geom', 'gid'); UPDATE duong_pho_line SET length = length(the_geom);"
But having announce :
"ERROR: cannot EXECUTE a null querystring SQL state: 22004 Context: PL/pgSQL function "assign_vertex_id" line 65 at EXECUTE statement"
My table data is : CREATE TABLE duong_pho_line (
gid serial NOT NULL, id character varying(250), "type" character varying(250), the_geom geometry, )
I dont know what is the reason. My time is not much!
Please help me for fixed problem! Thanks! All information contact to Email : tuongvan10121987@…
Message #983
We discussed this situation few times here already, if you search through the forum, you will for sure find those topics.
In few words - check geometry_column entry for your 'duong_pho_line' table, check your data projection units (0.001 might be to small value for meters or miles).
anton07/13/09 10:18:00 (17 months ago)
