data (#23) - Planarize function? (#284) - Message List
ArcGIS has a function that automatically splits intersecting lines called Planarize. This can be a useful function when your data is not a perfect topology as step before assign_vertex_id. You can execute it on a limited basis for classes of roads that typically intersect at grade level (excluding highways and other limited access roads, for example).
Is something like planarize available in PostGIS, but under a different name?
Thanks, Jordan
Message #1009
Hi Jordan,
At first, sorry for the spam that made it into your topic.
To your question: Not that I'm aware of such a function. But it might useful for cases as you explained.
osm2pgrouting has some similar problem, because "ways" in the OSM model often include more than one road link as we need for routing.
daniel08/11/09 11:11:36 (16 months ago)
