shootingstar (#18) - Strange issue with shotting star (#296) - Message List
Hi there,
This is my first topic and I am stuck with a strange issue with shooting star. Can you, please, help with this?
IMAGE 1 : http://123.252.207.93/forum/U-TurnOK.png
IMAGE 2 : http://123.252.207.93/forum/U-TurnWrong.png
I am using pgRouting 1.03.
IMAGE 1, shows the route which I am getting correctly as per my knowledge. IMAGE 2, shows the route which I suppose is incorrect, because it takes me through oneway ( portion marked with blue circle) and this is not the only case where it happens...
Between these two scenarios, the only thing that I have changed is the location of the END point, even that too slightly.
My problem is that I am not able to get the same route as IMAGE 1 which follows the Actual Route Direction
I have set the reverse cost = 1000000 and to_cost = "driving time" for all the oneways.
Please help me out with this....
Thank You In Advance...
Message #1075
Hello,
It looks like you are using 'smart' wrapper of Shooting*, right? Can you please confirm it?
It would be also perfect if you could post here a small piece of your data around the place on you pictures.
Anton.
anton09/15/09 10:31:55 (14 months ago) -
Message #1205
It seems to be this bug: http://pgrouting.postlbs.org/ticket/190. I have same problem.
carlofrancesco11/10/09 21:14:23 (12 months ago)
