osm2pgrouting (#24) - oneway (#305) - Message List
i think that oneway check is wrong i am not a c/c++ man but c# anyway i think it only checks if the oneway key eksists and the sets the way as oneway
it should check for the value of the tag not only if the key esists a way can have a tag of oneway=no or oneway=0 then it is not a onewaystreet and it can also have oneway=-1 then it is oneway in the oppesit way it is drawn
  • Message #1144
    hey Lifo, see topic 279 - there is a patch which adds the osm_id to you data - than you can join your osm_line data and use all the attributes like "oneway" for your cost function. That worked fine for me...
