JsonConfig.h
Go to the documentation of this file.
1 //**************************************************************************************************
2 //
3 // OSSIM Open Source Geospatial Data Processing Library
4 // See top level LICENSE.txt file for license information
5 //
6 //**************************************************************************************************
7
8 #pragma once
9
10 #include <ostream>
14 #include <vector>
15 #include <map>
16
17 namespace ossim
18 {
19 // Forward decl defined after JsonParam
20 class JsonParam;
21
65 {
66 public:
68  JsonConfig();
69
70  JsonConfig(const ossimFilename& configFile);
71
73  virtual ~JsonConfig();
74
76  bool open(const ossimFilename& configFile);
77
79  virtual void loadJSON(const Json::Value& params_json_node);
80
82  virtual void saveJSON(Json::Value& params_json_node) const;
83
85  JsonParam& getParameter(const char* paramName);
86
88  void setParameter(const JsonParam& p);
89
91  bool diagnosticLevel(unsigned int level) const;
92
94  friend std::ostream& operator<<(std::ostream& out, const JsonConfig& obj);
95
96  bool paramExists(const char* paramName) const;
97
98 protected:
99  JsonConfig(const JsonConfig& /*hide_this*/) {}
100
101  bool getBoolValue(bool& rtn_val, const std::string& json_value) const;
102
103  std::map<std::string, JsonParam> m_paramsMap;
105 };
106
107
113 {
114 public:
115  enum ParamType {
117  BOOL=1,
118  INT=2,
119  UINT=3,
120  FLOAT=4,
123  };
124
126
127  JsonParam(const ossimString& argname,
128  const ossimString& arglabel,
129  const ossimString& argdescr,
130  ParamType argparamType,
131  void* value);
132
133  JsonParam(const JsonParam& copy);
134
136
138  bool loadJSON(const Json::Value& json_node);
139
140  void saveJSON(Json::Value& json_node) const;
141
142  const ossimString& name() const { return _name; }
143  const ossimString& label() const { return _label; }
144  const ossimString& descr() const { return _descr; }
145  ParamType type() const { return _type; }
146
147  bool isBool() const {return (_type == BOOL); }
148  bool asBool() const;
149
150  bool isUint() const {return (_type == UINT); }
151  unsigned int asUint() const;
152
153  bool isInt() const {return (_type == INT);}
154  int asInt() const;
155
156  bool isFloat() const {return (_type == FLOAT);}
157  double asFloat() const;
158
159  bool isString() const {return (_type == STRING);}
160  std::string asString() const;
161
162  bool isVector() const {return (_type == VECTOR);}
163  void asVector(std::vector<double>& v) const;
164
165  bool operator==(const JsonParam& p) const { return (p._name == _name); }
166
168  friend std::ostream& operator<<(std::ostream& out, const JsonParam& obj);
169
170 private:
171  void setValue(void* value);
172  void resetValue();
173
178  void* _value;
179  std::vector<ossimString> _allowedValues; // only used for multiple-choice string parameters
180 };
181
182
183 }
const ossimString & descr() const
Definition: JsonConfig.h:144
void setValue(void *value)
Definition: JsonConfig.cpp:47
const ossimString & label() const
Definition: JsonConfig.h:143
JsonConfig(const JsonConfig &)
Definition: JsonConfig.h:99
This code was derived from https://gist.github.com/mshockwave.
Definition: Barrier.h:8
Base class for maintaining parameters affecting the runtime configuration of OSSIM executables...
Definition: JsonConfig.h:64
Definition: JsonConfig.cpp:278
Definition: JsonConfig.cpp:264
void asVector(std::vector< double > &v) const
Definition: JsonConfig.cpp:292
std::vector< ossimString > _allowedValues
Definition: JsonConfig.h:179
ossimString _name
Definition: JsonConfig.h:174
std::map< std::string, JsonParam > m_paramsMap
Definition: JsonConfig.h:103
Definition: JsonConfig.h:145
Definition: JsonConfig.cpp:285
Represents a single configuration parameter.
Definition: JsonConfig.h:112
void saveJSON(Json::Value &json_node) const
Definition: JsonConfig.cpp:192
Definition: JsonConfig.h:159
ParamType _type
Definition: JsonConfig.h:177
bool asBool() const
Definition: JsonConfig.cpp:257
bool operator==(const JsonParam &p) const
Definition: JsonConfig.h:165
const ossimString & name() const
Definition: JsonConfig.h:142
bool isInt() const
Definition: JsonConfig.h:153
ossimString _label
Definition: JsonConfig.h:175
friend std::ostream & operator<<(std::ostream &out, const JsonParam &obj)
Outputs JSON to output stream provided.
Definition: JsonConfig.cpp:299
bool loadJSON(const Json::Value &json_node)
Initializes from a JSON node.
Definition: JsonConfig.cpp:111
Pure virtual interface for classes implementing JSON-based load/save state.
Definition: JsonInterface.h:19
#define OSSIM_DLL
bool isBool() const
Definition: JsonConfig.h:147
ossimString _descr
Definition: JsonConfig.h:176
int asInt() const
Definition: JsonConfig.cpp:271
Definition: JsonConfig.h:162
bool isUint() const
Definition: JsonConfig.h:150
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
static JsonParam s_nullParam
Definition: JsonConfig.h:104
Definition: JsonConfig.h:156
