bitmap.h
Go to the documentation of this file.
1 /* Copyright (C) 2001-2015 Peter Selinger.
2  This file is part of Potrace. It is free software and it is covered
3  by the GNU General Public License. See the file COPYING for details. */
4
5 #ifndef BITMAP_H
6 #define BITMAP_H
7
8 #include <string.h>
9 #include <stdlib.h>
10 #include <errno.h>
11 #include <stddef.h>
12
13 /* The bitmap type is defined in potracelib.h */
14 #include "potracelib.h"
15
16 /* The present file defines some convenient macros and static inline
17  functions for accessing bitmaps. Since they only produce inline
18  code, they can be conveniently shared by the library and frontends,
19  if desired */
20
21 /* ---------------------------------------------------------------------- */
22 /* some measurements */
23
24 #define BM_WORDSIZE ((int)sizeof(potrace_word))
25 #define BM_WORDBITS (8*BM_WORDSIZE)
26 #define BM_HIBIT (((potrace_word)1)<<(BM_WORDBITS-1))
27 #define BM_ALLBITS (~(potrace_word)0)
28
29 /* macros for accessing pixel at index (x,y). U* macros omit the
30  bounds check. */
31
32 #define bm_scanline(bm, y) ((bm)->map + (ptrdiff_t)(y)*(ptrdiff_t)(bm)->dy)
33 #define bm_index(bm, x, y) (&bm_scanline(bm, y)[(x)/BM_WORDBITS])
34 #define bm_mask(x) (BM_HIBIT >> ((x) & (BM_WORDBITS-1)))
35 #define bm_range(x, a) ((int)(x) >= 0 && (int)(x) < (a))
36 #define bm_safe(bm, x, y) (bm_range(x, (bm)->w) && bm_range(y, (bm)->h))
37 #define BM_UGET(bm, x, y) ((*bm_index(bm, x, y) & bm_mask(x)) != 0)
38 #define BM_USET(bm, x, y) (*bm_index(bm, x, y) |= bm_mask(x))
39 #define BM_UCLR(bm, x, y) (*bm_index(bm, x, y) &= ~bm_mask(x))
40 #define BM_UINV(bm, x, y) (*bm_index(bm, x, y) ^= bm_mask(x))
41 #define BM_UPUT(bm, x, y, b) ((b) ? BM_USET(bm, x, y) : BM_UCLR(bm, x, y))
42 #define BM_GET(bm, x, y) (bm_safe(bm, x, y) ? BM_UGET(bm, x, y) : 0)
43 #define BM_SET(bm, x, y) (bm_safe(bm, x, y) ? BM_USET(bm, x, y) : 0)
44 #define BM_CLR(bm, x, y) (bm_safe(bm, x, y) ? BM_UCLR(bm, x, y) : 0)
45 #define BM_INV(bm, x, y) (bm_safe(bm, x, y) ? BM_UINV(bm, x, y) : 0)
46 #define BM_PUT(bm, x, y, b) (bm_safe(bm, x, y) ? BM_UPUT(bm, x, y, b) : 0)
47
48 /* free the given bitmap. Leaves errno untouched. */
49 static inline void bm_free(potrace_bitmap_t *bm) {
50  if (bm) {
51  free(bm->map);
52  }
53  free(bm);
54 }
55
56 /* return new un-initialized bitmap. NULL with errno on error.
57  Assumes w, h >= 0. */
58 static inline potrace_bitmap_t *bm_new(int w, int h) {
59  potrace_bitmap_t *bm;
60  int dy = w == 0 ? 0 : (w - 1) / BM_WORDBITS + 1;
61  ptrdiff_t size = (ptrdiff_t)dy * (ptrdiff_t)h * (ptrdiff_t)BM_WORDSIZE;
62
63  /* check for overflow error */
64  if (size < 0 || (h != 0 && dy != 0 && size / h / dy != BM_WORDSIZE)) {
65  errno = ENOMEM;
66  return NULL;
67  }
68
69  bm = (potrace_bitmap_t *) malloc(sizeof(potrace_bitmap_t));
70  if (!bm) {
71  return NULL;
72  }
73  bm->w = w;
74  bm->h = h;
75  bm->dy = dy;
76  bm->map = (potrace_word *) malloc(size);
77  if (!bm->map) {
78  free(bm);
79  return NULL;
80  }
81  return bm;
82 }
83
84 /* clear the given bitmap. Set all bits to c. */
85 static inline void bm_clear(potrace_bitmap_t *bm, int c) {
86  /* Note: if the bitmap was created with bm_new, then it is
87  guaranteed that size will fit into the ptrdiff_t type. */
88  ptrdiff_t size = (ptrdiff_t)bm->dy * (ptrdiff_t)bm->h * (ptrdiff_t)BM_WORDSIZE;
89  memset(bm->map, c ? -1 : 0, size);
90 }
91
92 /* duplicate the given bitmap. Return NULL on error with errno set. */
93 static inline potrace_bitmap_t *bm_dup(const potrace_bitmap_t *bm) {
94  potrace_bitmap_t *bm1 = bm_new(bm->w, bm->h);
95  ptrdiff_t size = (ptrdiff_t)bm->dy * (ptrdiff_t)bm->h * (ptrdiff_t)BM_WORDSIZE;
96  if (!bm1) {
97  return NULL;
98  }
99  memcpy(bm1->map, bm->map, size);
100  return bm1;
101 }
102
103 /* invert the given bitmap. */
104 static inline void bm_invert(potrace_bitmap_t *bm) {
105  ptrdiff_t i;
106  ptrdiff_t size = (ptrdiff_t)bm->dy * (ptrdiff_t)bm->h;
107
108  for (i = 0; i < size; i++) {
109  bm->map[i] ^= BM_ALLBITS;
110  }
111 }
112
113 #endif /* BITMAP_H */
#define BM_WORDSIZE
Definition: bitmap.h:24
potrace_word * map
Definition: potracelib.h:58
unsigned long potrace_word
Definition: potracelib.h:49
yy_size_t size
#define BM_WORDBITS
Definition: bitmap.h:25
#define BM_ALLBITS
Definition: bitmap.h:27
