bitops.h
Go to the documentation of this file.
1 /* Copyright (C) 2001-2015 Peter Selinger.
2  This file is part of Potrace. It is free software and it is covered
3  by the GNU General Public License. See the file COPYING for details. */
4
5
6 /* bits.h: this file defines some macros for bit manipulations. We
7  provide a generic implementation, as well as machine- and
8  compiler-specific fast implementations */
9
10 /* lobit: return the position of the rightmost "1" bit of an int, or
11  32 if none. hibit: return 1 + the position of the leftmost "1" bit
12  of an int, or 0 if none. Note: these functions work on 32-bit
13  integers. */
14
15 #ifndef BITOPS_H
16 #define BITOPS_H
17
18 #ifdef HAVE_CONFIG_H
19 #include <config.h>
20 #endif
21
22 /* ---------------------------------------------------------------------- */
23 /* machine specific macros */
24
25 #if defined(HAVE_I386)
26
27 static inline unsigned int lobit(unsigned int x) {
28  unsigned int res;
29  asm ("bsf %1,%0\n\t"
30  "jnz 0f\n\t"
31  "movl $32,%0\n"
32  "0:"
33  : "=r" (res)
34  : "r" (x)
35  : "cc");
36  return res;
37 }
38
39 static inline unsigned int hibit(unsigned int x) {
40  unsigned int res;
41
42  asm ("bsr %1,%0\n\t"
43  "jnz 0f\n\t"
44  "movl $-1,%0\n"
45  "0:"
46  : "=r" (res)
47  : "r" (x)
48  : "cc");
49  return res+1;
50 }
51
52 /* ---------------------------------------------------------------------- */
53 #else /* generic macros */
54
55 static inline unsigned int lobit(unsigned int x) {
56  unsigned int res = 32;
57  while (x & 0xffffff) {
58  x <<= 8;
59  res -= 8;
60  }
61  while (x) {
62  x <<= 1;
63  res -= 1;
64  }
65  return res;
66 }
67
68 static inline unsigned int hibit(unsigned int x) {
69  unsigned int res = 0;
70  while (x > 0xff) {
71  x >>= 8;
72  res += 8;
73  }
74  while (x) {
75  x >>= 1;
76  res += 1;
77  }
78  return res;
79 }
80
81 #endif
82
83 #endif /* BITOPS_H */
ossim_uint32 x
