Functions | Variables
ossimPdfWriter.cpp File Reference
#include <ossim/imaging/ossimPdfWriter.h>
#include <ossim/base/ossimBooleanProperty.h>
#include <ossim/base/ossimCommon.h>
#include <ossim/base/ossimKeywordNames.h>
#include <ossim/base/ossimTrace.h>
#include <ossim/base/ossimDpt.h>
#include <ossim/base/ossimEndian.h>
#include <ossim/base/ossimIpt.h>
#include <ossim/base/ossimIrect.h>
#include <ossim/base/ossimKeywordlist.h>
#include <ossim/base/ossimScalarTypeLut.h>
#include <ossim/base/ossimString.h>
#include <ossim/base/ossimStringProperty.h>
#include <ossim/base/ossimNumericProperty.h>
#include <ossim/imaging/ossimBandSelector.h>
#include <ossim/imaging/ossimGeneralRasterWriter.h>
#include <ossim/imaging/ossimImageData.h>
#include <ossim/imaging/ossimImageGeometry.h>
#include <ossim/imaging/ossimImageSource.h>
#include <ossim/imaging/ossimImageWriterFactoryRegistry.h>
#include <ossim/imaging/ossimJpegMemDest.h>
#include <ossim/imaging/ossimScalarRemapper.h>
#include <ossim/projection/ossimMapProjection.h>
#include <ossim/projection/ossimUtmProjection.h>
#include <ctime>
#include <fstream>
#include <iomanip>
#include <ostream>
#include <sstream>
#include <string>
#include <vector>
#include <jpeglib.h>
Go to the source code of this file.
Functions
RTTI_DEF1(ossimPdfWriter, "ossimPdfWriter", ossimImageFileWriter) static ossimTrace traceDebug("ossimPdfWriter if (traceLog())
xref push_back ((std::streamoff) str->tellp())
 os2<< xref.size()<< " 0 obj % Resource dictionary for page.< "<</ProcSet[/PDF/ImageB/ImageC]\"<< "/XObject<</Basemap_Form "<<(xref.size()+TILES+1)<< " 0 R ";ossim_uint32 objIndex=static_cast< ossim_uint32 > (xref.size()+1)
 for (x=0;x< TW;++x)
str write (os2.str().data(), os2.str().size())
 while (tileNumber< TILES)
 if (tileNumber==TILES)
 if (status)
Variables
std::ostringstream os2
ossim_uint32 x
ossim_uint32 y
os2<< "> n<< " > nendobj n
ossim_uint32 tileNumber = 0
std::vector< ossimIrectoutputTileRects
return status
Function Documentation
◆ for()
for ( )
Definition at line 521 of file ossimPdfWriter.cpp.
References ossimPdfWriter::getTileString(), os2, x, and y.
522  {
523  for ( y = 0; y < TH; ++y )
524  {
525  os2 << getTileString( x, y ) << " " << objIndex << " 0 R ";
526
527  ++objIndex;
528  }
529
530  }
ossim_uint32 x
ossim_uint32 y
◆ if() [1/3]
if ( traceLog()  )
Definition at line 498 of file ossimPdfWriter.cpp.
499  {
500  ossimNotify(ossimNotifyLevel_DEBUG) << os1.str() << "\n";
501  }
◆ if() [2/3]
if ( tileNumber  = = TILES)
Definition at line 588 of file ossimPdfWriter.cpp.
References status.
589  {
590  status = true;
591  }
return status
◆ if() [3/3]
if ( status  )
Definition at line 593 of file ossimPdfWriter.cpp.
References ossimPdfWriter::getLowerLeftPageOffset(), ossimPdfWriter::getTileString(), ossimIrect::ll(), ossimIrect::lr(), outputTileRects, ossimImageWriter::theAreaOfInterest, tileNumber, ossimIpt::x, x, ossimIpt::y, and y.
594  {
595  //---
596  // XObect Form for image tiles:
597  //---
598
599  // Capture position:
600  xref.push_back( (std::streamoff)str->tellp() );
601
602  ossimIpt llPageOffset;
603  getLowerLeftPageOffset( theAreaOfInterest, llPageOffset );
604
605  std::ostringstream os3;
606
607  // Tile loop - ontents for each ile:
608  tileNumber = 0;
609  ossim_uint32 x;
610  ossim_uint32 y;
611  for ( x = 0; x < TW; ++x )
612  {
613  for ( y = 0; y < TH; ++y )
614  {
615  //---
616  // PDF space is positive y = up, positive x = right.
617  // ossim image space is positive y down.
618  // 0, 0 is lower left corner in pdf space so "y of 0" in pdf space is
619  // theAreaOfInterest.ll().y in image space.
620  //---
621  ossim_int32 width = outputTileRects[tileNumber].width();
622
623  ossim_int32 height = outputTileRects[tileNumber].height();
624
625  ossim_int32 llOffsetX =
626  llPageOffset.x + outputTileRects[tileNumber].ll().x - theAreaOfInterest.ll().x;
627
628  ossim_int32 llOffsetY = llPageOffset.y + theAreaOfInterest.lr().y -
629  outputTileRects[tileNumber].ll().y;
630
631  os3 << " q\n" // Save graphics state
632  << " " << width << " 0 0 " << height << " "
633  << llOffsetX << " " << llOffsetY << " cm\n"
634  << " " << getTileString( x, y ) << " Do\n"
635  << " Q\n"; // Restore graphics state.
636  ++tileNumber;
637  }
638  }
639
640  std::ostringstream os4;
641  os4 << xref.size() << " 0 obj % /XObject/Form dictionary for image tiles.\n"
642  << " << /Type /XObject\n"
643  << " /Subtype /Form\n"
644  << " /Length " << os3.str().size() << "\n"
645  << " /BBox["
646  << llPageOffset.x << " " << llPageOffset.y << " "
647  << WIDTH << " " << HEIGHT << "]\n"
648  << " >>\n"
649  << "stream\n";
650
651  // Write the content stream to tmp stream.
652  os4.write( os3.str().data(), os3.str().size() );
653
654  os4 << "\n"
655  << "endstream\n"
656  << "endobj\n";
657
658  // Write the tmp stream to output stream.
659  str->write( os4.str().data(), os4.str().size() );
660
661  if ( traceLog() )
662  {
664  << os4.str() << "\n";
665  }
666
667  //---
668  // Contents of page:
669  //---
670
671  // Capture position:
672  xref.push_back( (std::streamoff)str->tellp() );
673
674  std::ostringstream os5;
675  os5 << "/Basemap_Form Do";
676
677  std::ostringstream os6;
678  os6 << xref.size() << " 0 obj % Contents of page.\n"
679  << " << /Length " << os5.str().size() << " >>\n"
680  << "stream\n";
681
682  os6.write( os5.str().data(), os5.str().size() );
683  os6 << "\n"
684  << "endstream\n"
685  << "endobj\n";
686
687  str->write( os6.str().data(), os6.str().size() );
688  if ( traceLog() )
689  {
690  ossimNotify(ossimNotifyLevel_DEBUG) << os6.str() << "\n";
691  }
692
693  m_mutex.lock(); // Code not thread safe.
694
695  // Document Information dictionary:
696  writeInfo( str, xref );
697
698  m_mutex.unlock();
699
700  //---
701  // Cross reference tables:
702  //---
703
704  // Capture start of xref for the second to last line:
705  std::streamoff xrefOffset = (std::streamoff)m_str->tellp();
706
707  writeXref( m_str, xref );
708
709  //---
710  // Trailer:
711  //---
712  writeTrailer( m_str, static_cast<ossim_uint32>(xref.size()+1), xrefOffset );
713  }
ossim_uint32 x
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
ossim_uint32 y
unsigned int ossim_uint32
std::vector< ossimIrect > outputTileRects
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
int ossim_int32
◆ os2<< xref.size()<< " 0 obj % Resource dictionary for page.< "<</ProcSet[/PDF/ImageB/ImageC]\"<< "/XObject<</Basemap_Form "<<(xref.size()+TILES+1)<< " 0 R ";ossim_uint32 objIndex=static_cast< ossim_uint32 >()
os2<< xref.size()<< " 0 obj % Resource dictionary for page.\<< "<</ProcSet[/PDF/ImageB/ImageC]\"<< "/XObject<</Basemap_Form "<<(xref.size()+TILES+1)<< " 0 R ";ossim_uint32 objIndex=static_cast< ossim_uint32 > ( xref.size()+  1)
◆ push_back()
xref push_back ( (std::streamoff) str->tellp()  )
◆ while()
while ( )
Definition at line 547 of file ossimPdfWriter.cpp.
References ossimPdfWriter::getImageType(), ossimImageSourceSequencer::getNextTile(), ossimPdfWriter::JPEG, ossimNotify(), ossimNotifyLevel_WARN, outputTileRects, ossimPdfWriter::RAW, ossimImageFileWriter::setPercentComplete(), status, ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theInputConnection, tileNumber, ossimPdfWriter::writeJpegTile(), and ossimPdfWriter::writeRawTile().
548  {
549  ossimRefPtr<ossimImageData> id = theInputConnection->getNextTile();
550  if( id.valid() )
551  {
552  // To hold output tile rect clamped to AOI.
553  ossimIrect outputTileRect;
554
555  switch ( getImageType() )
556  {
557  case ossimPdfWriter::RAW:
558  {
559  writeRawTile( str, xref, id.get(), theAreaOfInterest, outputTileRect );
560  break;
561  }
563  default:
564  {
565  writeJpegTile( str, xref, id.get(), theAreaOfInterest, outputTileRect );
566  break;
567  }
568  }
569
570  // Capture tile rect:
571  outputTileRects.push_back( outputTileRect );
572  }
573  else
574  {
576  << "ossimPdfWriter::writeImage ERROR:"
577  << "\nNULL Tile encountered, tile number=" << tileNumber
578  << std::endl;
579  status = false;
580  break;
581  }
582
583  ++tileNumber;
584
585  setPercentComplete( tileNumber / TILES * 100.0 );
586  }
return status
◆ write()
str write ( os2.  str).data(,
os2.  str).size(
Variable Documentation
◆ n
Definition at line 532 of file ossimPdfWriter.cpp.
Referenced by aatan2(), ossimToolServer::acknowledgeRcvd(), ossimLocalTm::addDays(), ossimLocalTm::addHours(), BaseException::AddInt(), ossimLocalTm::addMinutes(), RectMatrixRowCol::AddScaled(), ossimLocalTm::addSeconds(), ossimString::append(), ossimplugins::JulianDate::AsGMSTDateTime(), ossimRationalNumber::assign(), ossimString::assign(), ossimString::at(), BandMatrix::BandMatrix(), ossimBngProjection::Break_BNG_String(), ComplexScale(), ossimKMeansClustering::computeKmeans(), ossimImageToPlaneNormalFilter::computeNormalsTemplate(), ossimAdjustmentExecutive::computeResidualStatistics(), ossimNewZealandMapGridProjection::Convert_Geodetic_To_NZMG(), ossimNewZealandMapGridProjection::Convert_NZMG_To_Geodetic(), ossimImageDataHelper::copyInputToThis(), DCT_II(), DCT_II_inverse(), DCT_inverse(), RectMatrixRowCol::Divide(), RectMatrixCol::Down(), RectMatrixRowCol::DownDiag(), RectMatrixDiag::DownDiag(), ossimEsriShapeFileFilter::drawAnnotations(), ossimRgbImage::drawFilledPolygon(), ossimRgbImage::drawPolygon(), DST_II(), DST_II_inverse(), DST_inverse(), ossimCeosData::dumpPdr16HistRec(), Matrix::element(), SymmetricMatrix::element(), UpperTriangularMatrix::element(), LowerTriangularMatrix::element(), DiagonalMatrix::element(), RowVector::element(), BandMatrix::element(), UpperBandMatrix::element(), LowerBandMatrix::element(), SymmetricBandMatrix::element(), ossimRegExp::end(), ossimString::erase(), ossimToolClient::execute(), FFT(), FFT2(), FFT2I(), FFTI(), ossimImageDataHelper::fill(), ossimString::find(), ossimJobQueue::findByNameOrPointer(), ossimplugins::ossim::findFirstNode(), ossimAdjustableParameterInterface::findParameterIdxContainingDescription(), ossimAdjustableParameterInterface::findParameterIdxGivenDescription(), ossim::gcd(), ossim::gcd< int >(), BandMatrix::GetCol(), ossimVpfTable::getColumnValueAsString(), RTTITypeinfo::getname(), ossimBitMaskTileSource::getNumberOfSamples(), ATP::ossimDescriptorSource::getTile(), IdentityMatrix::IdentityMatrix(), ossimplugins::Equation::IndiceMax(), ossimplugins::Equation::IndiceMin(), ossim::lcm(), RectMatrixRow::Left(), ossim::JsonParam::loadJSON(), ossimEsriShapeFileFilter::loadPoint(), ossimplugins::SarSensor::localisationSAR(), ossimAdjustableParameterInterface::lockAllParameters(), BandLUMatrix::ludcmp(), main(), MLE_D_FI::MakeCovariance(), Matrix::Matrix(), ossimDatum::molodenskyShift(), RectMatrixRowCol::Negate(), ossimVpfBoundingRecordTable::openTable(), Matrix::operator()(), SymmetricMatrix::operator()(), UpperTriangularMatrix::operator()(), LowerTriangularMatrix::operator()(), DiagonalMatrix::operator()(), RowVector::operator()(), BandMatrix::operator()(), UpperBandMatrix::operator()(), LowerBandMatrix::operator()(), SymmetricBandMatrix::operator()(), RectMatrixRowCol::operator*(), GeneralMatrix::operator<<(), GetSubMatrix::operator<<(), MatrixInput::operator<<(), ossimRationalNumber::operator=(), ossimPolyArea2d::operator=(), ossimNormRgbVector::operator=(), ossimRgbVector::operator=(), ossimPolyLine::operator=(), ossimSensorModel::optimizeFit(), ossimArgumentParser::ossimArgumentParser(), ossimDirectoryData::ossimDirectoryData(), ossimPolyLine::ossimPolyLine(), ossimPool< T >::ossimPool(), ossimRgbVector::ossimRgbVector(), ossimNitfProjectionFactory::parseMgrsString(), ossimNitfFile::print(), ossimVpfTable::print(), ossimToolServer::processOssimRequest(), QRZ(), QRZT(), RealFFT(), ossimToolClient::receiveFile(), ossimToolClient::receiveText(), ossimString::replace(), ossimString::reserve(), RectMatrixRowCol::Reset(), SquareMatrix::ReSize(), nricMatrix::ReSize(), SymmetricMatrix::ReSize(), UpperTriangularMatrix::ReSize(), LowerTriangularMatrix::ReSize(), DiagonalMatrix::ReSize(), BandMatrix::ReSize(), UpperBandMatrix::ReSize(), LowerBandMatrix::ReSize(), SymmetricBandMatrix::ReSize(), IdentityMatrix::ReSize(), BandMatrix::RestoreCol(), GeneralMatrix::ReverseElements(), ossimString::rfind(), RectMatrixRow::Right(), Rotate(), RTTITypeinfo::RTTITypeinfo(), ossimToolServer::runCommand(), ossimFftw3Filter::runFft(), ossimTwoColorView::runNative8(), ossimTwoColorView::runNorm(), RTTITypeinfo::same(), ossim::JsonParam::saveJSON(), ossimNitfFile::saveState(), ossimToolServer::sendFile(), ossimByteStreamBuffer::setbuf(), ossim::BlockStreamBuffer::setbuf(), ossimLocalTm::setDateFromJulian(), OssimPolyArea2dPrivate::setGeometry(), ossimTieMeasurementGenerator::setImageList(), ossimRectilinearDataObject::setNumberOfDataComponents(), ossimShapeDatabaseRecord::setNumberOfFields(), ossimDDFFieldDefn::SetRepeatingFlag(), SimpleIntArray::Size(), ossimRegExp::start(), ossimToolServer::startListening(), ossimString::substr(), RectMatrixRowCol::SumSquare(), SVD(), SymmetricBandMatrix::SymmetricBandMatrix(), ossimImageRenderer::ossimRendererSubRectInfo::transformViewToImage(), ossimAdjustableParameterInterface::unlockAllParameters(), RectMatrixCol::Up(), UpdateQRZ(), UpdateQRZT(), RectMatrixRowCol::UpDiag(), RectMatrixDiag::UpDiag(), ossimToolServer::writeSocket(), ossim::CurlStreamBuffer::xsgetn(), ossim::S3StreamBuffer::xsgetn(), ossimLogFileBufferStream< char >::xsputn(), RectMatrixRowCol::Zero(), and MatrixInput::~MatrixInput().
◆ os2
◆ outputTileRects
std::vector<ossimIrect> outputTileRects
Definition at line 546 of file ossimPdfWriter.cpp.
Referenced by if(), and while().
◆ status
return status
Definition at line 717 of file ossimPdfWriter.cpp.
Referenced by ossimJ2kTlmRecord::accumulate(), ossimGpkgWriter::addLevels(), ossimGmlSupportData::addLineSamps(), ossimGmlSupportData::addScale(), ossimGmlSupportData::addTie(), ossimEquationCombiner::applyClamp(), ossimMeanMedianFilter::applyMean(), ossimMeanMedianFilter::applyMeanNullCenterOnly(), ossimMeanMedianFilter::applyMedian(), ossimMeanMedianFilter::applyMedianNullCenterOnly(), ossimEquationCombiner::applyOp(), ossimImageStatisticsSource::computeStatisticsTemplate(), ossimConvolutionSource::convolve(), ossim::copyOpjImage(), ossim::copyOpjSrgbImage(), ossimGpkgTileRecord::createTable(), ossimGpkgNsgTileMatrixExtentRecord::createTable(), ossimGpkgContentsRecord::createTable(), ossimGpkgTileMatrixSetRecord::createTable(), ossimGpkgSpatialRefSysRecord::createTable(), ossimGpkgTileMatrixRecord::createTable(), ossimGpkgWriter::createTables(), ossimDilationFilter::doDilation(), ossimErosionFilter::doErosion(), ossimShorelineTool::execute(), ossimBatchTest::execute(), ossimImageUtil::executeCommands(), ossimCcfTileSource::fillBuffer(), ossimImageRenderer::fillTile(), ossimTilePatch::fillTileTemplate(), ossimNullPixelFlip::flipPixels(), ossimImageGeometry::getCornerGpts(), ossimGpkgWriter::getFilename(), ossim_gpkg::getGpkgRecord(), ossimGmlSupportData::getImageGeometryFromRectifiedGrid(), ossimGmlSupportData::getImageGeometryFromSeonsorModel(), ossimH5ImageHandler::getLatLonDatasets(), ossimOrthoImageMosaic::getNextTile(), ossimImageCombiner::getNextTile(), ossimTiffInfo::getOffset(), ossimKakaduNitfReader::getOverviewTile(), ossimOpjJp2Reader::getOverviewTile(), ossimKakaduJ2kReader::getOverviewTile(), ossimKakaduJp2Reader::getOverviewTile(), ossimImageHandler::getOverviewTile(), ossimGpkgWriter::getRect(), ossim_gpkg::getSrsRecord(), ossim_gpkg::getTableRows(), ossimDespeckleFilter::getTile(), ossimNullPixelFlip::getTile(), ossimImageHandlerMtAdaptor::getTile(), ossimUsgsDemTileSource::getTile(), ossimTiledImagePatch::getTile(), ossimImageSource::getTile(), ossimJpegTileSource::getTile(), ossimBandClipFilter::getTile(), ossimGpkgReader::getTile(), ossimHdf5ImageHandler::getTile(), ossimCcfTileSource::getTile(), ossimHdfReader::getTile(), ossimDtedTileSource::getTile(), ossimH5ImageHandler::getTile(), ossimPngReader::getTile(), ossimAdrgTileSource::getTile(), ossimImageCacheTileSource::getTile(), ossimLasReader::getTile(), ossimTiffTileSource::getTile(), ossimGeoPdfReader::getTile(), ossimRpfCacheTileSource::getTile(), ossimBumpShadeTileSource::getTile(), ossimCibCadrgTileSource::getTile(), ossim_gpkg::getTileEntry(), ossimJ2kTlmRecord::getTileLength(), ossimTiffInfo::getValue(), ossimH5GridModel::getWktFootprint(), if(), ossimGpkgContentsRecord::init(), ossimGpkgNsgTileMatrixExtentRecord::init(), ossimGpkgTileMatrixSetRecord::init(), ossimGpkgTileRecord::init(), ossimGpkgSpatialRefSysRecord::init(), ossimGpkgTileMatrixRecord::init(), ossimGmlSupportData::initialize(), ossimRsmida::initialize(), ossimRsmpia::initialize(), ossimRsmpca::initialize(), ossimNitfRsmModel::initializeModel(), ossimGpkgNsgTileMatrixExtentRecord::insert(), ossimGpkgContentsRecord::insert(), ossimGpkgTileMatrixSetRecord::insert(), ossimGpkgSpatialRefSysRecord::insert(), ossimGpkgTileMatrixRecord::insert(), ossimGpkgWriter::isValidZoomLevelRowCol(), ossimTiffTileSource::loadFromU16Strip(), ossimMultiThreadSequencer::loadState(), ossimGeoAnnotationEllipseObject::loadState(), ossimGeoAnnotationMultiPolyLineObject::loadState(), ossimGdalOgrVectorAnnotation::loadState(), ossimGeoAnnotationPolyObject::loadState(), ossimGeoAnnotationFontObject::loadState(), ossimPixelFlipper::loadState(), ossimImageSourceSequencer::loadState(), ossimTiffTileSource::loadTile(), main(), ossimNitfProjectionFactory::makeUtm(), ossimGeoidManager::open(), ossimWriter::open(), ossimGpkgWriter::open(), ossimGpkgReader::open(), ossimTiffWriter::openTiff(), ossim::opj_decode(), ossimNitfRsmModel::parseFile(), ossimRpfReplaceUpdateRecord::parseStream(), printDataStatus(), ossimBatchTest::processCommands(), ossimKeywordlist::readPreprocDirective(), ossimEnviCgModel::saveState(), ossimH5GridModel::saveState(), ossimPngWriter::setCompressionLevel(), ossimGpkgWriter::setCompressionLevel(), ossimDataObject::setDataObjectStatus(), ossimDms::setDegrees(), ossimImageUtil::setErrorStatus(), ossimH5GridModel::setGridNodes(), ossimTiledImagePatch::setInputTileSize(), ossimTiffTileSource::setTiffDirectory(), ossimJ2kTlmRecord::setTileLength(), ossimRpfReplaceUpdateRecord::setUpdateStatus(), ossimIgen::slaveSetup(), ossimThinPlateSpline::solve(), ossim_sqlite::tableExists(), ossimImageSourceSequencer::updateTileDimensions(), ossimRsmModel::validate(), while(), ATP::AtpAnnotatedImage::write(), ossimGmlSupportData::write(), ossimGpkgWriter::writeCodecTile(), ossimGpkgWriter::writeEntry(), ossimGeomFileWriter::writeFile(), ossimWriter::writeFile(), ossimNitfWriterBase::writeGeometry(), ossimGpkgWriter::writeGpkgContentsTable(), ossimGpkgWriter::writeGpkgNsgTileMatrixExtentTable(), ossimGpkgWriter::writeGpkgTileMatrixSetTable(), ossimGpkgWriter::writeGpkgTileMatrixTable(), ossimImageFileWriter::writeMetaDataFiles(), ossimWriter::writeMinMaxTiffTags(), ossimWriter::writeSMinSMaxTiffTags(), ossimWriter::writeStream(), ossimWriter::writeStreamTtbs(), ossimWriter::writeTiffTags(), and ossimGpkgWriter::writeTile().
◆ tileNumber
◆ x
Definition at line 519 of file ossimPdfWriter.cpp.
Referenced by ossim::acosd(), MatrixRowCol::Add(), ossimPointObservation::addMeasurement(), ossimPolygon::addPoint(), ossimPolyLine::addPoint(), ossimActiveEdgeTable::addPolygon(), ossimPotraceTool::Path::addPotraceCurve(), MatrixRowCol::AddScaled(), ossim::almostEqual(), ossimMeanMedianFilter::applyMean(), ossimMeanMedianFilter::applyMeanNullCenterOnly(), ossimMeanMedianFilter::applyMedian(), ossimMeanMedianFilter::applyMedianNullCenterOnly(), ossimGeoAnnotationPolyLineObject::applyScale(), ossimAnnotationEllipseObject::applyScale(), ossimGeoAnnotationLineObject::applyScale(), ossimGeoAnnotationGdBitmapFont::applyScale(), ossimAnnotationMultiPolyLineObject::applyScale(), ossimGeoAnnotationEllipseObject::applyScale(), ossimAnnotationMultiPolyObject::applyScale(), ossimAnnotationPolyObject::applyScale(), ossimAnnotationGdBitmapFont::applyScale(), ossimAnnotationLineObject::applyScale(), ossimAnnotationMultiEllipseObject::applyScale(), ossimGeoAnnotationPolyObject::applyScale(), ossimAnnotationMultiLineObject::applyScale(), ossimAnnotationFontObject::applyScale(), ossimGeoAnnotationFontObject::applyScale(), ossimEquationCombiner::applyShift(), ossim::asind(), BaseMatrix::AsScalar(), ossim::atan2d(), ossimPositionQualityEvaluator::atan3(), ossim::atand(), blockDirection(), ossimBitMaskWriter::buildOverviews(), ossimVpfAnnotationFeatureInfo::buildPointFeature(), ossimFilterTable::buildTable(), ossimNitfImageHeader::checkForGeographicTiePointTruncation(), ossim::clamp(), ossimPixelFlipper::clipTile(), ossimBitMaskWriter::close(), ComplexScale(), ossimImageRenderer::computeClosestResLevel(), ossimImageHistogramSource::computeFastModeHistogram(), ossimFixedTileCache::computeId(), ossimEllipsoid::computeLocalToWorldTransformFromXYZ(), ossimImageToPlaneNormalFilter::computeNormalsTemplate(), ossimLocalCorrelationFusion::computeRegression(), ossimNitfProjectionFactory::computeScaleInMeters(), ossimCylEquAreaProjection::Convert_Cyl_Eq_Area_To_Geodetic(), ossimCylEquAreaProjection::Convert_Geodetic_To_Cyl_Eq_Area(), ossimTransCylEquAreaProjection::Convert_Geodetic_To_Trans_Cyl_Eq_Area(), ossimTransCylEquAreaProjection::Convert_Trans_Cyl_Eq_Area_To_Geodetic(), ossimBngProjection::Convert_Transverse_Mercator_To_BNG(), ossimConvolutionSource::convolve(), ossim::cosd(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), ossimplugins::ossimSpot6DimapSupportData::createDpt(), ossimplugins::ossimPleiadesDimapSupportData::createDpt(), ossimSpotDimapSupportData::createDpt(), ossimFormosatDimapSupportData::createDpt(), ossimSrtmElevationDatabase::createId(), ossimDtedElevationDatabase::createId(), ossimplugins::ossimSpot6DimapSupportData::createIpt(), ossimplugins::ossimPleiadesDimapSupportData::createIpt(), ossimMatrix3x3::createScaleMatrix(), ossimMatrix4x4::createScaleMatrix(), ossimMatrix4x4::createTranslationMatrix(), ossimHdf5GridModel::crossesDateline(), DCT_II(), DCT_II_inverse(), DCT_inverse(), ossim::degreesToRadians(), ossimDespeckleFilter::despeckle(), ossimDilationFilter::doDilation(), ossimErosionFilter::doErosion(), DowndateCholesky(), ossimRsmModel::dPoly_dHgt(), ossimRsmModel::dPoly_dLat(), ossimRsmModel::dPoly_dLon(), ossimRgbImage::drawArc(), ossimRgbImage::drawEllipse(), ossimRgbImage::drawFilledArc(), ossimRgbImage::drawFilledEllipse(), ossimRgbImage::drawFilledPolygon(), ossimRgbImage::drawFilledRectangle(), ossimRgbImage::drawLine(), ossimRgbImage::drawPolygon(), DST_II(), DST_II_inverse(), DST_inverse(), ossimElevRemapper::elevRemap(), ossimTopographicCorrectionFilter::executeTopographicCorrectionMinnaertTemplate(), ossimTopographicCorrectionFilter::executeTopographicCorrectionTemplate(), ossimPositionQualityEvaluator::extractErrorEllipse(), ossimDblGrid::extrapolate(), ossimRgbImage::fastPlotPixel(), ossimAdrgTileSource::fillBuffer(), ossimTiledElevationDatabase::fillGrid(), ossimJpegTileSource::fillTile(), ossimPngReader::fillTile(), ossimTilePatch::fillTileTemplate(), ossimCcfTileSource::fillUcharBuffer(), ossimCcfTileSource::fillUshortBuffer(), ossimDemGrid::fillUTM(), ossimBoxFilter::filter(), ossimSincFilter::filter(), ossimBesselOrderOneFilter::filter(), ossimBesselFilter::filter(), ossimBlackmanFilter::filter(), ossimBlackmanSincFilter::filter(), ossimBlackmanBesselFilter::filter(), ossimCatromFilter::filter(), ossimCubicFilter::filter(), ossimGaussianFilter::filter(), ossimHanningFilter::filter(), ossimHammingFilter::filter(), ossimHermiteFilter::filter(), ossimLanczosFilter::filter(), ossimMagicFilter::filter(), ossimMitchellFilter::filter(), ossimQuadraticFilter::filter(), ossimTriangleFilter::filter(), ATP::ossimCorrelationSource::findFeatures(), FindMaximum2::Fit(), ossimNullPixelFlip::flipPixels(), ossimplugins::fnint(), for(), ossimBitMaskWriter::generateMask(), ossimResampler::generateWeightTable(), ossimSarModel::getArpPos(), ossimSarModel::getArpVel(), ossimPolyLine::getBounds(), ossimFilterTable::getClosestWeights(), ossimVpfTable::getColumnValueAsString(), ossimGdalTileSource::getDecimationFactor(), ossimDemGrid::getElevation(), ossimPolygon::getFloatBounds(), ossimDemGrid::getGroundCoords(), ossimGdalTileSource::getImageRectangle(), ossimFgdcXmlDoc::getImageSize(), ossimPolygon::getIntegerBounds(), ossimPolyLine::getIntegerBounds(), ossimFilterResampler::getKernelSupport(), ossimPolygon::getMinimumBoundingRect(), ossimDblGrid::getNode(), ossimGdalTileSource::getNumberOfLines(), ossimOpjJp2Reader::getNumberOfLines(), ossimGdalTileSource::getNumberOfSamples(), ossimOpjJp2Reader::getNumberOfSamples(), ossimRsmModel::getPcaIndex(), ossimNitfTileSource::getPosition(), ossimSpotDimapSupportData::getPositionEcf(), ossimFormosatDimapSupportData::getPositionEcf(), ossim::Quaternion::getRotate(), ossimNadconGridFile::getShiftAtLatLon(), ossimScaleFilter::getSupport(), ossimIntensityAdjustmentFilter::getTile(), ATP::ossimCorrelationSource::getTile(), ossimSFIMFusion::getTile(), ossimRectangleCutFilter::getTile(), ossimLocalCorrelationFusion::getTile(), ossimTiledImagePatch::getTile(), ossimBitMaskTileSource::getTile(), ossimKakaduJ2kReader::getTile(), ossimPointCloudImageHandler::getTile(), ossimBumpShadeTileSource::getTile(), ossimImageElevationHandler::getTile(), ossimKakaduJpipHandler::getTileAtRes(), ossimGdalTileSource::getTileBlockRead(), ossimJ2kTlmRecord::getTileCount(), ossimGpkgReader::getTileIndexes(), ossimImageSourceSequencer::getTileOrigin(), ossimPdfWriter::getTileString(), ossimWatermarkFilter::getUniformDenseRects(), ossimWatermarkFilter::getUniformSparceRects(), ossimImageHandler::getValidImageVertices(), ossimSpotDimapSupportData::getVelocityEcf(), ossimFormosatDimapSupportData::getVelocityEcf(), ossimGeoAnnotationEllipseObject::getWidthHeightInPixels(), ossimH5GridModel::getWktFootprint(), ossimDemPoint::getXY(), ossimVpfAnnotationFeatureInfo::getXy(), GivensRotation(), GivensRotationR(), ossimFpt::hasNans(), ossimIpt::hasNans(), ossimDpt3d::hasNans(), ossimDpt::hasNans(), ossimplugins::HermiteInterpolator::HermiteInterpolator(), if(), ossimImageViewAffineTransform::imageSpaceScale(), ossimImageViewAffineTransform::imageSpaceScaleX(), ossimDblGrid::index(), ossimplugins::inint(), ossim::inInterval(), ossimDrect::initBoundingRect(), ossimHdf5GridModel::initialize(), ossimBilinearProjection::initializeBilinear(), ossimImageToPlaneNormalFilter::initializeTile(), ossimLasReader::initValues(), ossim::inOpenInterval(), ossimplugins::HermiteInterpolator::Interpolate(), ossimAtCorrGridRemapper::interpolate(), ossim::IntFloatBitCoercion::IntFloatBitCoercion(), ossim::inverseLerp(), isBlocked(), ossimIpt::isNan(), ossimDpt::isNan(), ossimPolyArea2d::isPointWithin(), ossimImageData::isPointWithin(), ossimNitfProjectionFactory::isSkewed(), ossimImageData::isWithin(), ossimImageSharpenFilter::laplacianOfGaussian(), ossimEllipsoid::latLonHeightToXYZ(), ATP::AtpGenerator::layoutSearchTileRects(), ossimDpt3d::length(), ossimDpt::length(), ossimIpt::length(), ossimDpt3d::length2(), ossim::lerp(), ossimAdjMapModel::lineSampleHeightToWorld(), ossimKakaduNitfReader::loadBlock(), ossimNitfTileSource::loadBlockFromCache(), ossimEnviCgModel::loadEnviGeocFile(), ossimEastingNorthingCutter::loadState(), ossimTilingRect::loadState(), ossimQuadTreeWarpVertex::loadState(), ossimGeoAnnotationMultiPolyLineObject::loadState(), ossimTiling::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimNitfTileSource::loadTile(), ossimKakaduJ2kReader::loadTile(), ossimKakaduJ2kReader::loadTileFromCache(), ossimplugins::SarSensor::localisationSAR(), ossimRsmModel::lowOrderPolynomial(), BandLUMatrix::ludcmp(), ossimNitfProjectionFactory::makeEuiDistant(), ossimFpt::makeNan(), ossimIpt::makeNan(), ossimDpt3d::makeNan(), ossimDpt::makeNan(), ossim::Quaternion::makeRotate(), ossimDpt::mean(), ossimBilinearProjection::midLineSamplePt(), ossimVrect::midPoint(), ossimIrect::midPoint(), ossimDrect::midPoint(), MatrixRowCol::NegAdd(), ossimTiffWorld::open(), ossimDemHeader::open(), ossimFpt::operator!=(), ossimIpt::operator!=(), ossimDpt3d::operator!=(), ossimDpt3d::operator*(), ossimDpt::operator*(), ossimIpt::operator*(), LogAndSign::operator*=(), ossimDpt3d::operator*=(), ossimDpt::operator*=(), ossim::Quaternion::operator*=(), ossimDpt3d::operator+(), ossimDpt::operator+(), ossimIpt::operator+(), ossimDpt3d::operator+=(), ossimDpt::operator+=(), ossimIpt::operator+=(), ossimDpt3d::operator-(), ossimDpt::operator-(), ossimIpt::operator-(), ossimDpt3d::operator-=(), ossimDpt::operator-=(), ossimIpt::operator-=(), ossimDpt3d::operator/(), ossimDpt::operator/(), ossimIpt::operator/(), ossimDpt3d::operator/=(), operator<<(), ossimHsvVector::operator=(), ossimDpt3d::operator==(), ossimIpt::operator==(), ossimFpt::operator==(), ossimDpt::operator==(), operator>>(), ossimDpt3d::operator^(), ossimColumnVector3d::ossimColumnVector3d(), ossimColumnVector4d::ossimColumnVector4d(), ossimDemPoint::ossimDemPoint(), ossimDrect::ossimDrect(), ossimHsvVector::ossimHsvVector(), ossimIrect::ossimIrect(), ossimViewshedTool::paintReticle(), ossimLocalTm::pMonth(), ossimIrect::pointWithin(), ossimDrect::pointWithin(), ossimRsmModel::polynomial(), ossimFpt3d::print(), ossimVpfTable::print(), ossimLocalTm::printDate(), ossimplugins::Equation::Proche(), ossimFpt3d::pt2d(), ossim::quaderp(), ossim::Quaternion::Quaternion(), ossim::radiansToDegrees(), ossimVpfAnnotationFeatureInfo::readEdge(), ossimFfL7::readGeomRecord(), ossimResampler::resampleFullTile(), ossimResampler::resamplePartialTile(), ossimResampler::resampleTile(), ossimResampler::resampleTileNearestNeighbor(), GeneralMatrix::ReverseElements(), ossim::round(), ossimToolServer::runCommand(), ossimFftw3Filter::runFft(), ossimFftFilter::runFft(), ossimScaleFilter::runHorizontalFilterTemplate(), ossimEdgeFilter::runLaplacianFilter(), ossimEdgeFilter::runLocalMax8Filter(), ossimEdgeFilter::runPrewittFilter(), ossimEdgeFilter::runRobertsFilter(), ossimEdgeFilter::runSimpleFilter(), ossimEdgeFilter::runSobelFilter(), ossimScaleFilter::runVerticalFilterTemplate(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), ossimHistogram::Scale(), ossimImageViewAffineTransform::scale(), ossimImageViewAffineTransform::scaleX(), ossimHdf5ImageDataset::scanForMinMax(), R1_R1::Set(), ossim::Quaternion::set(), ossimBonneProjection::Set_Bonne_Parameters(), ossimCassiniProjection::Set_Cassini_Parameters(), ossimplugins::Coordinate::set_coordinates(), ossimIrect::set_llx(), ossimDrect::set_llx(), ossimIrect::set_lrx(), ossimDrect::set_lrx(), ossimTransCylEquAreaProjection::Set_Trans_Cyl_Eq_Area_Parameters(), ossimIrect::set_ulx(), ossimDrect::set_ulx(), ossimIrect::set_urx(), ossimDrect::set_urx(), ossimDemGrid::setElevation(), ossim2dBilinearTransform::setFromPoints(), ossim2dTo2dMatrixTransform::setFromPoints(), OssimPolyArea2dPrivate::setGeometry(), ossimH5GridModel::setGridNodes(), ossimMapCompositionSource::setMeterSpacing(), ossimDblGrid::setNode(), ossimAdjustableParameterInfo::setOffset(), ossimRpcSolver::setupSystemOfEquations(), ossimRpcSolver::setupWeightMatrix(), ossimS16ImageData::setValue(), ossimU15ImageData::setValue(), ossimU11ImageData::setValue(), ossimU14ImageData::setValue(), ossimU13ImageData::setValue(), ossimU12ImageData::setValue(), ossimU8ImageData::setValue(), ossimU16ImageData::setValue(), ossimImageData::setValue(), ossimDemPoint::setX(), ossimDemPoint::setXY(), ossim::sgn(), ossim::sgn< ossim_float32 >(), sign(), ossimFilter::Sinc(), ossim::sind(), ossimRgbImage::slowPlotPixel(), ossimplugins::Equation::Solve4(), ossimRpcSolver::solveCoefficients(), ossimRpcSolver::solveInitialCoefficients(), ossimRpcProjection::solveLeastSquares(), ossimSensorModel::solveLeastSquares(), ossim::square(), square(), SVD(), ossim::tand(), ossimIrect::toRect(), ossimDrect::toRect(), ossimGeoPolyCutter::transformVertices(), ossimJpeg12NitfReader::uncompressJpegBlock(), ossimOpjNitfReader::uncompressJpegBlock(), ossimNitfTileSource::uncompressJpegBlock(), ossimSmacCallibrationSystem::undistort(), ossimVpfExtent::within(), ossimPpjFrameSensor::worldToLineSample(), ossimRsmModel::worldToLineSample(), ossimplugins::ossimTileMapModel::worldToLineSample(), ossim::wrap(), x2lon_d(), x2lon_m(), ossimEllipsoid::XYZToLatLonHeight(), and ossimThinPlateSpline::~ossimThinPlateSpline().
◆ y
Definition at line 520 of file ossimPdfWriter.cpp.
Referenced by ossimPointObservation::addMeasurement(), ossimPolygon::addPoint(), ossimPolyLine::addPoint(), ossimActiveEdgeTable::addPolygon(), ossimPotraceTool::Path::addPotraceCurve(), ossim::almostEqual(), ossimMeanMedianFilter::applyMean(), ossimMeanMedianFilter::applyMeanNullCenterOnly(), ossimMeanMedianFilter::applyMedian(), ossimMeanMedianFilter::applyMedianNullCenterOnly(), ossimGeoAnnotationPolyLineObject::applyScale(), ossimGeoAnnotationGdBitmapFont::applyScale(), ossimGeoAnnotationLineObject::applyScale(), ossimAnnotationEllipseObject::applyScale(), ossimAnnotationMultiPolyLineObject::applyScale(), ossimGeoAnnotationEllipseObject::applyScale(), ossimAnnotationPolyObject::applyScale(), ossimAnnotationMultiPolyObject::applyScale(), ossimAnnotationGdBitmapFont::applyScale(), ossimAnnotationMultiEllipseObject::applyScale(), ossimAnnotationLineObject::applyScale(), ossimGeoAnnotationPolyObject::applyScale(), ossimAnnotationMultiLineObject::applyScale(), ossimAnnotationFontObject::applyScale(), ossimGeoAnnotationFontObject::applyScale(), ossimEquationCombiner::applyShift(), ossim::atan2d(), ossimPositionQualityEvaluator::atan3(), blockDirection(), ossimBitMaskWriter::buildOverviews(), ossimVpfAnnotationFeatureInfo::buildPointFeature(), ossimFilterTable::buildTable(), ossimNitfImageHeader::checkForGeographicTiePointTruncation(), ossimPixelFlipper::clipTile(), ossimBitMaskWriter::close(), ComplexScale(), ossimImageHistogramSource::computeFastModeHistogram(), ossimFixedTileCache::computeId(), ossimEllipsoid::computeLocalToWorldTransformFromXYZ(), ossimImageToPlaneNormalFilter::computeNormalsTemplate(), ossimLocalCorrelationFusion::computeRegression(), ossimNitfProjectionFactory::computeScaleInMeters(), ossimBngProjection::Convert_Transverse_Mercator_To_BNG(), ATP::convertToIpl(), ossimConvolutionSource::convolve(), ossimImageDataHelper::copyInputToThis(), ATP::copyIplToOid(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), ossimplugins::ossimSpot6DimapSupportData::createDpt(), ossimplugins::ossimPleiadesDimapSupportData::createDpt(), ossimFormosatDimapSupportData::createDpt(), ossimSpotDimapSupportData::createDpt(), ossimSrtmElevationDatabase::createId(), ossimDtedElevationDatabase::createId(), ossimplugins::ossimSpot6DimapSupportData::createIpt(), ossimplugins::ossimPleiadesDimapSupportData::createIpt(), ossimMatrix3x3::createScaleMatrix(), ossimMatrix4x4::createScaleMatrix(), ossimMatrix4x4::createTranslationMatrix(), ossimHdf5GridModel::crossesDateline(), DCT_II(), DCT_II_inverse(), DCT_inverse(), ossimPngCodec::decode(), ossimDespeckleFilter::despeckle(), ossimDilationFilter::doDilation(), ossimErosionFilter::doErosion(), ossimRsmModel::dPoly_dHgt(), ossimRsmModel::dPoly_dLat(), ossimRsmModel::dPoly_dLon(), ossimRgbImage::drawArc(), ossimRgbImage::drawFilledArc(), ossimRgbImage::drawFilledPolygon(), ossimRgbImage::drawFilledRectangle(), ossimRgbImage::drawLine(), ossimRgbImage::drawPolygon(), DST_II(), DST_II_inverse(), DST_inverse(), ossimElevRemapper::elevRemap(), ossimPngCodec::encode(), ossimTopographicCorrectionFilter::executeTopographicCorrectionMinnaertTemplate(), ossimTopographicCorrectionFilter::executeTopographicCorrectionTemplate(), ossimPositionQualityEvaluator::extractErrorEllipse(), ossimDblGrid::extrapolate(), ossimRgbImage::fastPlotPixel(), ossimImageDataHelper::fill(), ossimAdrgTileSource::fillBuffer(), ossimTiledElevationDatabase::fillGrid(), ossimTilePatch::fillTileTemplate(), ossimCcfTileSource::fillUcharBuffer(), ossimCcfTileSource::fillUshortBuffer(), ossimDemGrid::fillUTM(), ATP::ossimCorrelationSource::findFeatures(), ossimNullPixelFlip::flipPixels(), for(), ossimBitMaskWriter::generateMask(), ossimFfL7::getAcquisitionDate(), ossimSarModel::getArpPos(), ossimSarModel::getArpVel(), ossimPolyLine::getBounds(), ossimFilterTable::getClosestWeights(), ossimVpfTable::getColumnValueAsString(), ossimDemGrid::getElevation(), ossimPolygon::getFloatBounds(), ossimDemGrid::getGroundCoords(), ossimGdalTileSource::getImageRectangle(), ossimFgdcXmlDoc::getImageSize(), ossimPolygon::getIntegerBounds(), ossimPolyLine::getIntegerBounds(), ossimFilterResampler::getKernelSupport(), ossimPolygon::getMinimumBoundingRect(), ossimActiveEdgeTableHelper::getNextLineSegment(), ossimDblGrid::getNode(), ossimGdalTileSource::getNumberOfLines(), ossimOpjJp2Reader::getNumberOfLines(), ossimGdalTileSource::getNumberOfSamples(), ossimOpjJp2Reader::getNumberOfSamples(), ossimRsmModel::getPcaIndex(), ossimNitfTileSource::getPosition(), ossimSpotDimapSupportData::getPositionEcf(), ossimFormosatDimapSupportData::getPositionEcf(), ossim::Quaternion::getRotate(), ossimNadconGridFile::getShiftAtLatLon(), ossimScaleFilter::getSupport(), ossimIntensityAdjustmentFilter::getTile(), ATP::ossimCorrelationSource::getTile(), ossimSFIMFusion::getTile(), ossimRectangleCutFilter::getTile(), ossimLocalCorrelationFusion::getTile(), ossimTiledImagePatch::getTile(), ossimBitMaskTileSource::getTile(), ossimKakaduJ2kReader::getTile(), ossimPointCloudImageHandler::getTile(), ossimBumpShadeTileSource::getTile(), ossimImageElevationHandler::getTile(), ossimKakaduJpipHandler::getTileAtRes(), ossimGdalTileSource::getTileBlockRead(), ossimGpkgReader::getTileIndexes(), ossimImageSourceSequencer::getTileOrigin(), ossimPdfWriter::getTileString(), ossimWatermarkFilter::getUniformDenseRects(), ossimWatermarkFilter::getUniformSparceRects(), ossimSpotDimapSupportData::getVelocityEcf(), ossimFormosatDimapSupportData::getVelocityEcf(), ossimGeoAnnotationEllipseObject::getWidthHeightInPixels(), ossimH5GridModel::getWktFootprint(), ossimDemPoint::getXY(), ossimVpfAnnotationFeatureInfo::getXy(), GivensRotation(), GivensRotationR(), ossimFpt::hasNans(), ossimIpt::hasNans(), ossimDpt3d::hasNans(), ossimDpt::hasNans(), ossimplugins::HermiteInterpolator::HermiteInterpolator(), if(), ossimImageViewAffineTransform::imageSpaceScale(), ossimImageViewAffineTransform::imageSpaceScaleY(), ossimDblGrid::index(), ossimDrect::initBoundingRect(), ossimBilinearProjection::initializeBilinear(), ossimImageToPlaneNormalFilter::initializeTile(), ossimLasReader::initValues(), ossimplugins::HermiteInterpolator::Interpolate(), ossimAtCorrGridRemapper::interpolate(), isBlocked(), ossimIpt::isNan(), ossimDpt::isNan(), ossimPolyArea2d::isPointWithin(), ossimPolygon::isPointWithin(), ossimImageData::isPointWithin(), ossimNitfProjectionFactory::isSkewed(), ossimImageData::isWithin(), ossimImageSharpenFilter::laplacianOfGaussian(), ossimEllipsoid::latLonHeightToXYZ(), ATP::AtpGenerator::layoutSearchTileRects(), ossimDpt3d::length(), ossimDpt::length(), ossimIpt::length(), ossimDpt3d::length2(), ossimAdjMapModel::lineSampleHeightToWorld(), ossimplugins::ossimTileMapModel::lineSampleHeightToWorld(), ossimKakaduNitfReader::loadBlock(), ossimNitfTileSource::loadBlockFromCache(), ossimEnviCgModel::loadEnviGeocFile(), ossimEastingNorthingCutter::loadState(), ossimTilingRect::loadState(), ossimQuadTreeWarpVertex::loadState(), ossimGeoAnnotationMultiPolyLineObject::loadState(), ossimTiling::loadState(), ossimSpotDimapSupportData::loadState(), ossimFormosatDimapSupportData::loadState(), ossimNitfTileSource::loadTile(), ossimKakaduJ2kReader::loadTile(), ossimKakaduJ2kReader::loadTileFromCache(), ossimplugins::SarSensor::localisationSAR(), ossimRsmModel::lowOrderPolynomial(), ossimIpt::makeNan(), ossimFpt::makeNan(), ossimDpt3d::makeNan(), ossimDpt::makeNan(), ossim::Quaternion::makeRotate(), ossimDpt::mean(), ossimBilinearProjection::midLineSamplePt(), ossimVrect::midPoint(), ossimIrect::midPoint(), ossimDrect::midPoint(), ossimTiffWorld::open(), ossimDemHeader::open(), R1_R1::operator Real(), ossimIpt::operator!=(), ossimFpt::operator!=(), ossimDpt3d::operator!=(), ossimDpt3d::operator*(), ossimDpt::operator*(), ossimIpt::operator*(), ossimDpt3d::operator*=(), ossimDpt::operator*=(), ossim::Quaternion::operator*=(), ossimDpt3d::operator+(), ossimDpt::operator+(), ossimIpt::operator+(), ossimDpt3d::operator+=(), ossimDpt::operator+=(), ossimIpt::operator+=(), ossimDpt3d::operator-(), ossimDpt::operator-(), ossimIpt::operator-(), ossimDpt3d::operator-=(), ossimDpt::operator-=(), ossimIpt::operator-=(), ossimDpt3d::operator/(), ossimDpt::operator/(), ossimIpt::operator/(), ossimDpt3d::operator/=(), operator<<(), ossimDpt3d::operator==(), ossimFpt::operator==(), ossimIpt::operator==(), ossimDpt::operator==(), operator>>(), ossimDpt3d::operator^(), ossimColumnVector3d::ossimColumnVector3d(), ossimColumnVector4d::ossimColumnVector4d(), ossimDemPoint::ossimDemPoint(), ossimDrect::ossimDrect(), ossimIrect::ossimIrect(), ossimViewshedTool::paintReticle(), ossimIrect::pointWithin(), ossimDrect::pointWithin(), ossimRsmModel::polynomial(), ossimFpt3d::print(), ossimVpfTable::print(), ossimplugins::Equation::Proche(), ossimFpt3d::pt2d(), ossim::Quaternion::Quaternion(), ossimVpfAnnotationFeatureInfo::readEdge(), ossimFfL7::readGeomRecord(), ossimResampler::resampleTile(), ossimResampler::resampleTileNearestNeighbor(), ossimFftw3Filter::runFft(), ossimFftFilter::runFft(), ossimScaleFilter::runHorizontalFilterTemplate(), ossimEdgeFilter::runLaplacianFilter(), ossimEdgeFilter::runLocalMax8Filter(), ossimEdgeFilter::runPrewittFilter(), ossimEdgeFilter::runRobertsFilter(), ossimEdgeFilter::runSimpleFilter(), ossimEdgeFilter::runSobelFilter(), ossimScaleFilter::runVerticalFilterTemplate(), ossimSpotDimapSupportData::saveState(), ossimFormosatDimapSupportData::saveState(), ossimImageViewAffineTransform::scale(), ossimImageViewAffineTransform::scaleY(), ossimHdf5ImageDataset::scanForMinMax(), ossim::Quaternion::set(), ossimplugins::Coordinate::set_coordinates(), ossimIrect::set_lly(), ossimDrect::set_lly(), ossimIrect::set_lry(), ossimDrect::set_lry(), ossimIrect::set_uly(), ossimDrect::set_uly(), ossimIrect::set_ury(), ossimDrect::set_ury(), ossimDemGrid::setElevation(), ossim2dBilinearTransform::setFromPoints(), ossim2dTo2dMatrixTransform::setFromPoints(), OssimPolyArea2dPrivate::setGeometry(), ossimH5GridModel::setGridNodes(), ossimMapCompositionSource::setMeterSpacing(), ossimDblGrid::setNode(), ossimSonomaSensor::setRollPitchHeading(), ossimIpodSensor::setRollPitchYaw(), ossimSkyBoxLearSensor::setRollPitchYaw(), ossimRpcSolver::setupSystemOfEquations(), ossimRpcSolver::setupWeightMatrix(), ossimS16ImageData::setValue(), ossimU12ImageData::setValue(), ossimU11ImageData::setValue(), ossimU15ImageData::setValue(), ossimU13ImageData::setValue(), ossimU14ImageData::setValue(), ossimU8ImageData::setValue(), ossimU16ImageData::setValue(), ossimImageData::setValue(), ossimDemPoint::setXY(), ossimDemPoint::setY(), sign(), ossimRgbImage::slowPlotPixel(), ossimplugins::Equation::Solve4(), ossimQuadrilateralMap::solveCoefficients(), ossimRpcSolver::solveCoefficients(), ossimRpcSolver::solveInitialCoefficients(), SVD(), ossimIrect::toRect(), ossimDrect::toRect(), ossimGeoPolyCutter::transformVertices(), ossimJpeg12NitfReader::uncompressJpegBlock(), ossimOpjNitfReader::uncompressJpegBlock(), ossimNitfTileSource::uncompressJpegBlock(), ossimSmacCallibrationSystem::undistort(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), ossimSonomaSensor::updateModel(), ossimVpfExtent::within(), ossimPpjFrameSensor::worldToLineSample(), ossimRsmModel::worldToLineSample(), ossimplugins::ossimTileMapModel::worldToLineSample(), ossimEllipsoid::XYZToLatLonHeight(), y2lat_d(), y2lat_m(), and ossimThinPlateSpline::~ossimThinPlateSpline().
