Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ATP::ossimAtpToolFactory Class Reference
#include <ossimAtpToolFactory.h>
Inheritance diagram for ATP::ossimAtpToolFactory:
ossimToolFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimAtpToolFactory ()
virtual ossimToolcreateTool (const std::string &typeName) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
virtual void getCapabilities (std::map< std::string, std::string > &capabilities) const
 Appends map with available utilities along with descriptions as <name, decription> pairs. More...
virtual std::map< std::string, std::string > getCapabilities () const
- Public Member Functions inherited from ossimToolFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimToolcreateTool (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimAtpToolFactoryinstance ()
 ossimAtpToolFactory (const ossimAtpToolFactory &)
void operator= (const ossimAtpToolFactory &)
virtual ~ossimReferenced ()
static ossimAtpToolFactorys_instance = 0
 static instance of this class More...
Detailed Description
Definition at line 20 of file ossimAtpToolFactory.h.
◆ ~ossimAtpToolFactory()
ATP::ossimAtpToolFactory::~ossimAtpToolFactory ( )
virtual
Definition at line 29 of file ossimAtpToolFactory.cpp.
References ossimToolRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
30 {
32 }
static ossimToolRegistry * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
◆ ossimAtpToolFactory() [1/2]
ATP::ossimAtpToolFactory::ossimAtpToolFactory ( )
protected
Definition at line 25 of file ossimAtpToolFactory.cpp.
26 {
27 }
◆ ossimAtpToolFactory() [2/2]
ATP::ossimAtpToolFactory::ossimAtpToolFactory ( const ossimAtpToolFactory )
protected
Member Function Documentation
◆ createTool()
ossimTool * ATP::ossimAtpToolFactory::createTool ( const std::string &  typeName) const
virtual
Implements ossimToolFactoryBase.
Definition at line 34 of file ossimAtpToolFactory.cpp.
References ossimString::downcase().
35 {
36  ossimString utilName (argName);
37  utilName.downcase();
38
39  if ((utilName == "atp") || (argName == "ossimAtpTool"))
40  return new ossimAtpTool;
41
42  return 0;
43 }
◆ getCapabilities() [1/2]
void ATP::ossimAtpToolFactory::getCapabilities ( std::map< std::string, std::string > &  capabilities) const
virtual
The names are the human-readable name of the utility/service, typically the utility's class name without the "ossim" prefix nor "Util" suffix, all lowercase.
Definition at line 45 of file ossimAtpToolFactory.cpp.
46 {
47  capabilities.insert(pair<string, string>("atp", ossimAtpTool::DESCRIPTION));
48 }
static const char * DESCRIPTION
Definition: ossimAtpTool.h:25
◆ getCapabilities() [2/2]
std::map< std::string, std::string > ATP::ossimAtpToolFactory::getCapabilities ( ) const
virtual
Definition at line 50 of file ossimAtpToolFactory.cpp.
51 {
52  std::map<std::string, std::string> result;
53  getCapabilities(result);
54  return result;
55 }
virtual std::map< std::string, std::string > getCapabilities() const
◆ getTypeNameList()
void ATP::ossimAtpToolFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 57 of file ossimAtpToolFactory.cpp.
58 {
59  typeList.push_back("ossimAtpTool");
60 }
◆ instance()
ossimAtpToolFactory * ATP::ossimAtpToolFactory::instance ( )
static
Definition at line 18 of file ossimAtpToolFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
19 {
20  if (!s_instance)
22  return s_instance;
23 }
static ossimAtpToolFactory * s_instance
◆ operator=()
void ATP::ossimAtpToolFactory::operator= ( const ossimAtpToolFactory )
protected
Member Data Documentation
◆ s_instance
ossimAtpToolFactory * ATP::ossimAtpToolFactory::s_instance = 0
staticprotected
Definition at line 37 of file ossimAtpToolFactory.h.
