Public Member Functions | Protected Attributes | List of all members
ossimBufferedInputStream Class Reference
Alows one to create a buffered input stream. More...
#include <ossimIoStream.h>
Inheritance diagram for ossimBufferedInputStream:
 ossimBufferedInputStream (std::shared_ptr< ossim::istream > in, ossim_uint32 bufferSize=1024)
 will use the read buffer of the passed in input stream and will set the buffer based on the buffer size passed in More...
virtual ~ossimBufferedInputStream ()
std::vector< char > m_buffer
 We have a buffer that we allocate so it does not loose scope through the life of this stream. More...
std::shared_ptr< ossim::istreamm_inputStream
 We will save the input stream we set the buffer to. More...
Detailed Description
Definition at line 184 of file ossimIoStream.h.
◆ ossimBufferedInputStream()
ossimBufferedInputStream::ossimBufferedInputStream ( std::shared_ptr< ossim::istream in,
ossim_uint32  bufferSize = 1024
inline
Definition at line 191 of file ossimIoStream.h.
192  :ossim::istream(in->rdbuf()),
193  m_inputStream(in)
194  {
195  if(bufferSize > 0)
196  {
197  m_buffer.resize(bufferSize);
198  rdbuf()->pubsetbuf(&m_buffer.front(), m_buffer.size());
199  }
200  }
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
We have a buffer that we allocate so it does not loose scope through the life of this stream...
std::shared_ptr< ossim::istream > m_inputStream
◆ ~ossimBufferedInputStream()
virtual ossimBufferedInputStream::~ossimBufferedInputStream ( )
inlinevirtual
Definition at line 201 of file ossimIoStream.h.
202  {
203  m_inputStream = 0;
204  }
Member Data Documentation
◆ m_buffer
std::vector<char> ossimBufferedInputStream::m_buffer
protected
Definition at line 210 of file ossimIoStream.h.
◆ m_inputStream
std::shared_ptr<ossim::istream> ossimBufferedInputStream::m_inputStream
protected
Definition at line 215 of file ossimIoStream.h.
The documentation for this class was generated from the following file:
