Public Member Functions | Protected Member Functions | List of all members
ossimCustomEditorWindow Class Referenceabstract
#include <ossimCustomEditorWindow.h>
Inheritance diagram for ossimCustomEditorWindow:
ossimObject ossimReferenced
virtual void * getWindow ()=0
virtual void setParent (void *parent)=0
virtual void * getParent ()=0
virtual bool setObjectToEdit (ossimObject *obj)=0
virtual bool canEdit (ossimObject *obj) const =0
virtual ossimObjectgetObject ()=0
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimCustomEditorWindow ()
 ossimCustomEditorWindow (const ossimCustomEditorWindow &)
void operator= (const ossimCustomEditorWindow &)
virtual ~ossimReferenced ()
Detailed Description
Definition at line 14 of file ossimCustomEditorWindow.h.
◆ ossimCustomEditorWindow() [1/2]
ossimCustomEditorWindow::ossimCustomEditorWindow ( )
inlineprotected
Definition at line 51 of file ossimCustomEditorWindow.h.
51 {}
◆ ossimCustomEditorWindow() [2/2]
ossimCustomEditorWindow::ossimCustomEditorWindow ( const ossimCustomEditorWindow )
inlineprotected
Definition at line 52 of file ossimCustomEditorWindow.h.
52 {}
Member Function Documentation
◆ canEdit()
virtual bool ossimCustomEditorWindow::canEdit ( ossimObject obj) const
pure virtual
Just asks if I can edit the passed in object.
◆ getObject()
virtual ossimObject* ossimCustomEditorWindow::getObject ( )
pure virtual
Returns the object we are editing.
◆ getParent()
virtual void* ossimCustomEditorWindow::getParent ( )
pure virtual
Will return the parent of the managed wxWindow
◆ getWindow()
virtual void* ossimCustomEditorWindow::getWindow ( )
pure virtual
Returns the system dependent window. If you are in wx it will probalby be some type of wxWindow*.
◆ operator=()
void ossimCustomEditorWindow::operator= ( const ossimCustomEditorWindow )
inlineprotected
Definition at line 53 of file ossimCustomEditorWindow.h.
53 {}
◆ setObjectToEdit()
virtual bool ossimCustomEditorWindow::setObjectToEdit ( ossimObject obj)
pure virtual
WIll set the object to edit. If this editor does not know anything about the passed in obj it will return false.
◆ setParent()
virtual void ossimCustomEditorWindow::setParent ( void *  parent)
pure virtual
This is the parent window. If the parent can be set by the derived classes it will return true.
The documentation for this class was generated from the following file:
