Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimDemToolFactory Class Reference
#include <ossimDemToolFactory.h>
Inheritance diagram for ossimDemToolFactory:
ossimToolFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimDemToolFactory ()
virtual ossimToolcreateTool (const std::string &typeName) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
virtual void getCapabilities (std::map< std::string, std::string > &capabilities) const
 Appends map with available utilities along with descriptions as <name, decription> pairs. More...
virtual std::map< std::string, std::string > getCapabilities () const
- Public Member Functions inherited from ossimToolFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimToolcreateTool (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimDemToolFactoryinstance ()
 ossimDemToolFactory (const ossimDemToolFactory &)
void operator= (const ossimDemToolFactory &)
virtual ~ossimReferenced ()
static ossimDemToolFactorys_instance = 0
 static instance of this class More...
Detailed Description
Definition at line 19 of file ossimDemToolFactory.h.
◆ ~ossimDemToolFactory()
ossimDemToolFactory::~ossimDemToolFactory ( )
virtual
Definition at line 26 of file ossimDemToolFactory.cpp.
References ossimToolRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
27 {
29 }
static ossimToolRegistry * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
◆ ossimDemToolFactory() [1/2]
ossimDemToolFactory::ossimDemToolFactory ( )
protected
Definition at line 22 of file ossimDemToolFactory.cpp.
23 {
24 }
◆ ossimDemToolFactory() [2/2]
ossimDemToolFactory::ossimDemToolFactory ( const ossimDemToolFactory )
protected
Member Function Documentation
◆ createTool()
ossimTool * ossimDemToolFactory::createTool ( const std::string &  typeName) const
virtual
Implements ossimToolFactoryBase.
Definition at line 31 of file ossimDemToolFactory.cpp.
References ossimString::downcase().
32 {
33  ossimString utilName (argName);
34  utilName.downcase();
35
36  if ((utilName == "dem") || (argName == "ossimDemTool"))
37  return new ossimDemTool;
38
39  return 0;
40 }
◆ getCapabilities() [1/2]
void ossimDemToolFactory::getCapabilities ( std::map< std::string, std::string > &  capabilities) const
virtual
The names are the human-readable name of the utility/service, typically the utility's class name without the "ossim" prefix nor "Util" suffix, all lowercase.
Definition at line 42 of file ossimDemToolFactory.cpp.
References ossimDemTool::DESCRIPTION.
43 {
44  capabilities.insert(pair<string, string>("dem", ossimDemTool::DESCRIPTION));
45 }
static const char * DESCRIPTION
Definition: ossimDemTool.h:25
◆ getCapabilities() [2/2]
std::map< std::string, std::string > ossimDemToolFactory::getCapabilities ( ) const
virtual
Definition at line 47 of file ossimDemToolFactory.cpp.
48 {
49  std::map<std::string, std::string> result;
50  getCapabilities(result);
51  return result;
52 }
virtual std::map< std::string, std::string > getCapabilities() const
◆ getTypeNameList()
void ossimDemToolFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 54 of file ossimDemToolFactory.cpp.
55 {
56  typeList.push_back("ossimDemTool");
57 }
◆ instance()
ossimDemToolFactory * ossimDemToolFactory::instance ( )
static
Definition at line 15 of file ossimDemToolFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
16 {
17  if (!s_instance)
19  return s_instance;
20 }
static ossimDemToolFactory * s_instance
◆ operator=()
void ossimDemToolFactory::operator= ( const ossimDemToolFactory )
protected
Member Data Documentation
◆ s_instance
ossimDemToolFactory * ossimDemToolFactory::s_instance = 0
staticprotected
Definition at line 36 of file ossimDemToolFactory.h.
