Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ossimDiscreteConvolutionKernel Class Reference
#include <ossimDiscreteConvolutionKernel.h>
Inheritance diagram for ossimDiscreteConvolutionKernel:
ossimDiscrete3x3HatFilter ossimDiscreteNearestNeighbor
 ossimDiscreteConvolutionKernel (long width, long height, bool doWeightedAverage=true)
 ossimDiscreteConvolutionKernel (const NEWMAT::Matrix &kernel, bool doWeightedAverage=true)
virtual ~ossimDiscreteConvolutionKernel ()
virtual void setKernel (const NEWMAT::Matrix &kernel)
virtual void convolve (const float *data, double &result, float nullPixel=OSSIM_DEFAULT_NULL_PIX_FLOAT) const
virtual void convolveSubImage (const float *data, long dataWidth, double &result, float nullPixel=OSSIM_DEFAULT_NULL_PIX_FLOAT) const
virtual void convolve (const double *data, double &result, double nullPixel=OSSIM_DEFAULT_NULL_PIX_DOUBLE) const
virtual void convolveSubImage (const double *data, long dataWidth, double &result, double nullPixel=OSSIM_DEFAULT_NULL_PIX_DOUBLE) const
virtual void convolve (const short *data, double &result, ossim_sint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_SINT16) const
virtual void convolveSubImage (const short *data, long dataWidth, double &result, ossim_sint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_SINT16) const
virtual void convolve (const unsigned short *data, double &result, ossim_uint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT16) const
virtual void convolveSubImage (const unsigned short *data, long dataWidth, double &result, ossim_uint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT16) const
virtual void convolve (const unsigned char *data, double &result, ossim_uint8 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT8) const
virtual void convolveSubImage (const unsigned char *data, long dataWidth, double &result, ossim_uint8 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT8) const
virtual void buildConvolution (double, double)
virtual long getWidth () const
virtual long getHeight () const
const NEWMAT::Matrix & getKernel () const
static void buildSymmetric (const std::vector< float > &coefficients, NEWMAT::Matrix &result)
static void buildSymmetric (float *coefficients, long size, NEWMAT::Matrix &result)
NEWMAT::Matrix * theKernel
long theWidth
long theHeight
bool theComputeWeightedAverageFlag
Detailed Description
Definition at line 19 of file ossimDiscreteConvolutionKernel.h.
◆ ossimDiscreteConvolutionKernel() [1/2]
ossimDiscreteConvolutionKernel::ossimDiscreteConvolutionKernel ( long  width,
long  height,
bool  doWeightedAverage = true
◆ ossimDiscreteConvolutionKernel() [2/2]
ossimDiscreteConvolutionKernel::ossimDiscreteConvolutionKernel ( const NEWMAT::Matrix &  kernel,
◆ ~ossimDiscreteConvolutionKernel()
ossimDiscreteConvolutionKernel::~ossimDiscreteConvolutionKernel ( )
virtual
Definition at line 36 of file ossimDiscreteConvolutionKernel.cpp.
References theKernel.
37 {
38  if(theKernel)
39  {
40  delete theKernel;
41  theKernel = 0;
42  }
43 }
Member Function Documentation
◆ buildConvolution()
virtual void ossimDiscreteConvolutionKernel::buildConvolution ( double  ,
double
inlinevirtual
This is used to allow me to continually adjust a convolution kernel based on where it center lies on a pixel. The xLocation and yLocation are all from the center of pixel. If I am convolving at full resolution then xLocation and yLocation should both be 0. Let's pretend that we contract an image by .5 scale factor or zooming out by a factor of 2. Then we actually of it .5 off from cneter of pixel in both the x and y direction. This information can be used to allow a kernel to adjust it's waits accordingly.
Typically if the xLocation and yLocation is directly on the center indicated by 0 vor both then the kernel defaults to 1 in the middle and all other weights are zero.
Reimplemented in ossimDiscreteNearestNeighbor, and ossimDiscrete3x3HatFilter.
Definition at line 113 of file ossimDiscreteConvolutionKernel.h.
115  {}
◆ buildSymmetric() [1/2]
void ossimDiscreteConvolutionKernel::buildSymmetric ( const std::vector< float > &  coefficients,
NEWMAT::Matrix &  result
static
Definition at line 45 of file ossimDiscreteConvolutionKernel.cpp.
References size.
47 {
48  ossim_uint32 size = (ossim_uint32)coefficients.size();
49  if(size > 0)
50  {
51
52  NEWMAT::RowVector row(size);
53  NEWMAT::ColumnVector col(size);
54  for(ossim_uint32 index = 0; index < size; ++index)
55  {
56  row[index] = coefficients[index];
57  col[index] = coefficients[index];
58  }
59  result = col*row;
60  }
61 }
yy_size_t size
unsigned int ossim_uint32
◆ buildSymmetric() [2/2]
void ossimDiscreteConvolutionKernel::buildSymmetric ( float *  coefficients,
long  size,
static
Definition at line 63 of file ossimDiscreteConvolutionKernel.cpp.
References size.
66 {
67  if(size > 0)
68  {
69  NEWMAT::RowVector row(size);
70  NEWMAT::ColumnVector col(size);
71  for(long index = 0; index < size; ++index)
72  {
73  row[index] = coefficients[index];
74  col[index] = coefficients[index];
75  }
76  result = col*row;
77  }
78 }
yy_size_t size
◆ convolve() [1/5]
void ossimDiscreteConvolutionKernel::convolve ( const float *  data,
double &  result,
float  nullPixel = OSSIM_DEFAULT_NULL_PIX_FLOAT
) const
virtual
Will expect a data buffer of size width*height and is row ordered.
Reimplemented in ossimDiscrete3x3HatFilter.
Definition at line 91 of file ossimDiscreteConvolutionKernel.cpp.
References theComputeWeightedAverageFlag, theHeight, and theWidth.
94 {
95  result = 0;
96
98  {
99  double divisor = 0.0;
100  for(long row=0; row < theHeight; ++row)
101  {
102  for(long col=0; col < theWidth; ++col)
103  {
104  if(*data != nullPixel)
105  {
106  divisor += (*theKernel)[row][col];
107  result += ((*theKernel)[row][col] * (*data));
108  }
109  ++data;
110  }
111  }
112  if(divisor > 0)
113  {
114  result /= divisor;
115  }
116  }
117  else
118  {
119  for(long row=0; row < theHeight; ++row)
120  {
121  for(long col=0; col < theWidth; ++col)
122  {
123  if(*data != nullPixel)
124  {
125  result += ((*theKernel)[row][col] * (*data));
126  }
127  ++data;
128  }
129  }
130  }
131 }
◆ convolve() [2/5]
void ossimDiscreteConvolutionKernel::convolve ( const double *  data,
double &  result,
double  nullPixel = OSSIM_DEFAULT_NULL_PIX_DOUBLE
) const
virtual
Definition at line 453 of file ossimDiscreteConvolutionKernel.cpp.
456 {
457  result = 0;
458
460  {
461  double divisor = 0.0;
462  for(long row=0; row < theHeight; ++row)
463  {
464  for(long col=0; col < theWidth; ++col)
465  {
466  if(*data != nullPixel)
467  {
468  divisor += (*theKernel)[row][col];
469  result += ((*theKernel)[row][col] * (*data));
470  }
471  ++data;
472  }
473  }
474  if(divisor > 0)
475  {
476  result /= divisor;
477  }
478  }
479  else
480  {
481  for(long row=0; row < theHeight; ++row)
482  {
483  for(long col=0; col < theWidth; ++col)
484  {
485  if(*data != nullPixel)
486  {
487  result += ((*theKernel)[row][col] * (*data));
488  }
489  ++data;
490  }
491  }
492  }
493 }
◆ convolve() [3/5]
void ossimDiscreteConvolutionKernel::convolve ( const short *  data,
double &  result,
ossim_sint16  nullPixel = OSSIM_DEFAULT_NULL_PIX_SINT16
) const
virtual
Definition at line 362 of file ossimDiscreteConvolutionKernel.cpp.
365 {
366  result = 0;
367
369  {
370  double divisor = 0.0;
371  for(long row=0; row < theHeight; ++row)
372  {
373  for(long col=0; col < theWidth; ++col)
374  {
375  if(*data != nullPixel)
376  {
377  divisor += (*theKernel)[row][col];
378  result += ((*theKernel)[row][col] * (*data));
379  }
380  ++data;
381  }
382  }
383  if(divisor > 0)
384  {
385  result /= divisor;
386  }
387  }
388  else
389  {
390  for(long row=0; row < theHeight; ++row)
391  {
392  for(long col=0; col < theWidth; ++col)
393  {
394  if(*data != nullPixel)
395  {
396  result += ((*theKernel)[row][col] * (*data));
397  }
398  ++data;
399  }
400  }
401  }
402 }
◆ convolve() [4/5]
void ossimDiscreteConvolutionKernel::convolve ( const unsigned short *  data,
double &  result,
ossim_uint16  nullPixel = OSSIM_DEFAULT_NULL_PIX_UINT16
) const
virtual
Definition at line 272 of file ossimDiscreteConvolutionKernel.cpp.
275 {
276  result = 0;
277
279  {
280  double divisor = 0.0;
281  for(long row=0; row < theHeight; ++row)
282  {
283  for(long col=0; col < theWidth; ++col)
284  {
285  if(*data != nullPixel)
286  {
287  divisor += (*theKernel)[row][col];
288  result += ((*theKernel)[row][col] * (*data));
289  }
290  ++data;
291  }
292  }
293  if(divisor > 0)
294  {
295  result /= divisor;
296  }
297  }
298  else
299  {
300  for(long row=0; row < theHeight; ++row)
301  {
302  for(long col=0; col < theWidth; ++col)
303  {
304  if(*data != nullPixel)
305  {
306  result += ((*theKernel)[row][col] * (*data));
307  }
308  ++data;
309  }
310  }
311  }
312 }
◆ convolve() [5/5]
void ossimDiscreteConvolutionKernel::convolve ( const unsigned char *  data,
double &  result,
ossim_uint8  nullPixel = OSSIM_DEFAULT_NULL_PIX_UINT8
) const
virtual
Definition at line 181 of file ossimDiscreteConvolutionKernel.cpp.
184 {
185  result = 0;
186
188  {
189  double divisor = 0.0;
190  for(long row=0; row < theHeight; ++row)
191  {
192  for(long col=0; col < theWidth; ++col)
193  {
194  if(*data != nullPixel)
195  {
196  divisor += (*theKernel)[row][col];
197  result += ((*theKernel)[row][col] * (*data));
198  }
199  ++data;
200  }
201  }
202  if(divisor > 0)
203  {
204  result /= divisor;
205  }
206  }
207  else
208  {
209  for(long row=0; row < theHeight; ++row)
210  {
211  for(long col=0; col < theWidth; ++col)
212  {
213  if(*data != nullPixel)
214  {
215  result += ((*theKernel)[row][col] * (*data));
216  }
217  ++data;
218  }
219  }
220  }
221 }
◆ convolveSubImage() [1/5]
void ossimDiscreteConvolutionKernel::convolveSubImage ( const float *  data,
long  dataWidth,
double &  result,
) const
virtual
Definition at line 133 of file ossimDiscreteConvolutionKernel.cpp.
Referenced by ossimConvolutionSource::convolve(), and ossimTilePatch::fillTileTemplate().
137 {
138  const float* dataStart = 0;
139  result = 0;
140
142  {
143  double divisor = 0.0;
144  for(long row=0; row < theHeight; ++row)
145  {
146  dataStart=data;
147  for(long col=0; col < theWidth; ++col)
148  {
149  if(*dataStart != nullPixel)
150  {
151  divisor += (*theKernel)[row][col];
152  result += ((*theKernel)[row][col] * (*dataStart));
153  }
154  ++dataStart;
155  }
156  data+=dataWidth;
157  }
158  if(divisor > 0)
159  {
160  result /= divisor;
161  }
162  }
163  else
164  {
165  for(long row=0; row < theHeight; ++row)
166  {
167  dataStart=data;
168  for(long col=0; col < theWidth; ++col)
169  {
170  if(*dataStart != nullPixel)
171  {
172  result += ((*theKernel)[row][col] * (*dataStart));
173  }
174  ++dataStart;
175  }
176  data+=dataWidth;
177  }
178  }
179 }
◆ convolveSubImage() [2/5]
void ossimDiscreteConvolutionKernel::convolveSubImage ( const double *  data,
long  dataWidth,
double &  result,
) const
virtual
Definition at line 495 of file ossimDiscreteConvolutionKernel.cpp.
499 {
500  const double* dataStart = 0;
501  result = 0;
502
504  {
505  double divisor = 0.0;
506  for(long row=0; row < theHeight; ++row)
507  {
508  dataStart=data;
509  for(long col=0; col < theWidth; ++col)
510  {
511  if(*dataStart != nullPixel)
512  {
513  divisor += (*theKernel)[row][col];
514  result += ((*theKernel)[row][col] * (*dataStart));
515  }
516  ++dataStart;
517  }
518  data+=dataWidth;
519  }
520  if(divisor > 0)
521  {
522  result /= divisor;
523  }
524  }
525  else
526  {
527  for(long row=0; row < theHeight; ++row)
528  {
529  dataStart=data;
530  for(long col=0; col < theWidth; ++col)
531  {
532  if(*dataStart != nullPixel)
533  {
534  result += ((*theKernel)[row][col] * (*dataStart));
535  }
536  ++dataStart;
537  }
538  data+=dataWidth;
539  }
540  }
541 }
◆ convolveSubImage() [3/5]
void ossimDiscreteConvolutionKernel::convolveSubImage ( const short *  data,
long  dataWidth,
double &  result,
) const
virtual
Definition at line 404 of file ossimDiscreteConvolutionKernel.cpp.
408 {
409  const ossim_sint16* dataStart = 0;
410  result = 0;
411
413  {
414  double divisor = 0.0;
415  for(long row=0; row < theHeight; ++row)
416  {
417  dataStart=data;
418  for(long col=0; col < theWidth; ++col)
419  {
420  if(*dataStart != nullPixel)
421  {
422  divisor += (*theKernel)[row][col];
423  result += ((*theKernel)[row][col] * (*dataStart));
424  }
425  ++dataStart;
426  }
427  data+=dataWidth;
428  }
429  if(divisor > 0)
430  {
431  result /= divisor;
432  }
433  }
434  else
435  {
436  for(long row=0; row < theHeight; ++row)
437  {
438  dataStart=data;
439  for(long col=0; col < theWidth; ++col)
440  {
441  if(*dataStart != nullPixel)
442  {
443  result += ((*theKernel)[row][col] * (*dataStart));
444  }
445  ++dataStart;
446  }
447  data+=dataWidth;
448  }
449  }
450 }
signed short ossim_sint16
◆ convolveSubImage() [4/5]
void ossimDiscreteConvolutionKernel::convolveSubImage ( const unsigned short *  data,
long  dataWidth,
double &  result,
) const
virtual
Definition at line 314 of file ossimDiscreteConvolutionKernel.cpp.
318 {
319  const ossim_uint16* dataStart = 0;
320  result = 0;
321
323  {
324  double divisor = 0.0;
325  for(long row=0; row < theHeight; ++row)
326  {
327  dataStart=data;
328  for(long col=0; col < theWidth; ++col)
329  {
330  if(*dataStart != nullPixel)
331  {
332  divisor += (*theKernel)[row][col];
333  result += ((*theKernel)[row][col] * (*dataStart));
334  }
335  ++dataStart;
336  }
337  data+=dataWidth;
338  }
339  if(divisor > 0)
340  {
341  result /= divisor;
342  }
343  }
344  else
345  {
346  for(long row=0; row < theHeight; ++row)
347  {
348  dataStart=data;
349  for(long col=0; col < theWidth; ++col)
350  {
351  if(*dataStart != nullPixel)
352  {
353  result += ((*theKernel)[row][col] * (*dataStart));
354  }
355  ++dataStart;
356  }
357  data+=dataWidth;
358  }
359  }
360 }
unsigned short ossim_uint16
◆ convolveSubImage() [5/5]
void ossimDiscreteConvolutionKernel::convolveSubImage ( const unsigned char *  data,
long  dataWidth,
double &  result,
) const
virtual
this allows you to pass a subImage to the convolution engine. It needs to know the width of the buffer so it can increment to the next element.
Definition at line 223 of file ossimDiscreteConvolutionKernel.cpp.
227 {
228  const ossim_uint8* dataStart = 0;
229  result = 0;
230
232  {
233  double divisor = 0.0;
234  for(long row=0; row < theHeight; ++row)
235  {
236  dataStart=data;
237  for(long col=0; col < theWidth; ++col)
238  {
239  if(*dataStart != nullPixel)
240  {
241  divisor += (*theKernel)[row][col];
242  result += ((*theKernel)[row][col] * (*dataStart));
243  }
244  ++dataStart;
245  }
246  data+=dataWidth;
247  }
248  if(divisor > 0)
249  {
250  result /= divisor;
251  }
252  }
253  else
254  {
255  for(long row=0; row < theHeight; ++row)
256  {
257  dataStart=data;
258  for(long col=0; col < theWidth; ++col)
259  {
260  if(*dataStart != nullPixel)
261  {
262  result += ((*theKernel)[row][col] * (*dataStart));
263  }
264  ++dataStart;
265  }
266  data+=dataWidth;
267  }
268  }
269 }
unsigned char ossim_uint8
◆ getHeight()
virtual long ossimDiscreteConvolutionKernel::getHeight ( ) const
inlinevirtual
◆ getKernel()
const NEWMAT::Matrix& ossimDiscreteConvolutionKernel::getKernel ( ) const
inline
Definition at line 124 of file ossimDiscreteConvolutionKernel.h.
125  {
126  return *theKernel;
127  }
◆ getWidth()
virtual long ossimDiscreteConvolutionKernel::getWidth ( ) const
inlinevirtual
◆ setKernel()
void ossimDiscreteConvolutionKernel::setKernel ( const NEWMAT::Matrix &  kernel)
virtual
Definition at line 80 of file ossimDiscreteConvolutionKernel.cpp.
References theHeight, theKernel, and theWidth.
81 {
82  if(theKernel)
83  {
84  theKernel = new NEWMAT::Matrix;
85  }
86  *theKernel = kernel;
87  theWidth = theKernel->Ncols();
88  theHeight = theKernel->Nrows();
89 }
Member Data Documentation
◆ theComputeWeightedAverageFlag
bool ossimDiscreteConvolutionKernel::theComputeWeightedAverageFlag
protected
Definition at line 132 of file ossimDiscreteConvolutionKernel.h.
Referenced by convolve(), and convolveSubImage().
◆ theHeight
long ossimDiscreteConvolutionKernel::theHeight
protected
◆ theKernel
NEWMAT::Matrix* ossimDiscreteConvolutionKernel::theKernel
protected
◆ theWidth
long ossimDiscreteConvolutionKernel::theWidth
protected
