Public Member Functions | Private Attributes | List of all members
ossimGDoptimizer Class Reference
Simple Gradient Descent optimizer for ossim. More...
#include <ossimGDoptimizer.h>
 ossimGDoptimizer ()
 Public Copy constructor. More...
 ossimGDoptimizer (const ossimGDoptimizer &src)
 ~ossimGDoptimizer ()
 Destroys the object !DOES NOT DELETE FUNCTION! More...
 ossimGDoptimizer (ossimTerm *function)
 Public Constructor with a preset function. More...
bool setFunction (ossimTerm *function)
 Sets the function to be optimized. More...
std::vector< ossim_float64optimize (std::vector< ossim_float64 > startPoint, ossim_float64 gamma=0.001, ossim_float64 precision=0.0001, ossim_uint32 maxEpoch=10000) const
 Optimizes the function. More...
Private Attributes
ossimTermm_func
Detailed Description
Author
Dylan Thomas Cannisi
Date
07/24/2017
   See top level LICENSE.txt file.
Definition at line 19 of file ossimGDoptimizer.h.
◆ ossimGDoptimizer() [1/3]
ossimGDoptimizer::ossimGDoptimizer ( )
Author
Date
07/24/2017
Definition at line 17 of file ossimGDoptimizer.cpp.
References m_func.
17  {
18  m_func = nullptr;
19 }
ossimTerm * m_func
◆ ossimGDoptimizer() [2/3]
ossimGDoptimizer::ossimGDoptimizer ( const ossimGDoptimizer src)
Parameters
[in]srcThe object to be copied (copies pointer not a copy of function)
Definition at line 27 of file ossimGDoptimizer.cpp.
References m_func.
27  {
28  m_func = src.m_func;
29 }
ossimTerm * m_func
◆ ~ossimGDoptimizer()
ossimGDoptimizer::~ossimGDoptimizer ( )
Definition at line 35 of file ossimGDoptimizer.cpp.
35  {
36 }
◆ ossimGDoptimizer() [3/3]
ossimGDoptimizer::ossimGDoptimizer ( ossimTerm function)
Parameters
functionThe function to be optimized
Definition at line 44 of file ossimGDoptimizer.cpp.
References m_func.
44  {
45  m_func = function;
46 }
ossimTerm * m_func
Member Function Documentation
◆ optimize()
std::vector< ossim_float64 > ossimGDoptimizer::optimize ( std::vector< ossim_float64 point,
ossim_float64  gamma = 0.001,
ossim_float64  precision = 0.0001,
ossim_uint32  maxEpoch = 10000
) const
Parameters
[in]startPointThe start point at which the algorithm starts its descent
[in]gammaDetermins the step size as a function of the gradient
[in]precisionThe stopping point at which the algorithm will no longer descend
[in]maxEpochThe stopping point to limit infinite loops.
Returns
the optimial minima
Definition at line 76 of file ossimGDoptimizer.cpp.
References ossimTerm::derivative(), and m_func.
76  {
77
78  ossim_uint32 iter = 0;
79  ossim_float64 step = 10000;
80
81  std::vector<ossimTerm*> derivative;
82  for(size_t i = 0; i < point.size(); ++i){
83  derivative.push_back(m_func->derivative(i));
84  }
85
86  std::vector<ossim_float64> prevPoint;
87  while(step > precision && iter < maxEpoch){
88  step = 0;
89  prevPoint = point;
90  for(size_t i = 0; i < point.size(); ++i){
91  point[i] += -gamma * derivative[i]->evaluate(point);
92  step += pow(point[i]-prevPoint[i], 2);
93  }
94  step = sqrt(step);
95  }
96
97  for(size_t i = 0; i < derivative.size(); ++i){
98  delete derivative[i];
99  }
100
101 return point;
102 }
virtual ossimTerm * derivative(const ossim_uint32 &variable) const =0
Calculates the derivative of the term.
double ossim_float64
unsigned int ossim_uint32
ossimTerm * m_func
◆ setFunction()
bool ossimGDoptimizer::setFunction ( ossimTerm function)
Parameters
Returns
whether or not the optimizer already contained a function
Definition at line 56 of file ossimGDoptimizer.cpp.
References m_func.
56  {
57  bool retVal = false;
58
59  if(m_func != nullptr) retVal = true;
60  m_func = function;
61
62 return retVal;
63 }
ossimTerm * m_func
Member Data Documentation
◆ m_func
ossimTerm* ossimGDoptimizer::m_func
private
Definition at line 68 of file ossimGDoptimizer.h.
Referenced by optimize(), ossimGDoptimizer(), and setFunction().
