Public Member Functions | Private Attributes | List of all members
ossimGeoPdfInfo Class Reference
GeoPdf info class. More...
#include <ossimGeoPdfInfo.h>
Inheritance diagram for ossimGeoPdfInfo:
ossimInfoBase ossimReferenced
 ossimGeoPdfInfo ()
 default constructor More...
virtual ~ossimGeoPdfInfo ()
 virtual destructor More...
virtual bool open (const ossimFilename &file)
 open method. More...
virtual bool open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString)
 Print method. More...
bool isOpen ()
- Public Member Functions inherited from ossimInfoBase
 ossimInfoBase ()
void setProcessOverviewFlag (bool flag)
 Sets the overview flag. More...
bool getProcessOverviewFlag () const
 Method to get the overview flag. More...
virtual bool getKeywordlist (ossimKeywordlist &kwl) const
 Method to dump info to a keyword list. More...
virtual bool getKeywordlist (ossimKeywordlist &kwl, ossim_uint32 entryIndex) const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
ossimFilename theFile
PoDoFo::PdfMemDocument * m_PdfMemDocument
Additional Inherited Members
- Protected Member Functions inherited from ossimInfoBase
virtual ~ossimInfoBase ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimInfoBase
bool theOverviewFlag
Detailed Description
GeoPdf info class.
Encapsulates the GeoPdf functionality.
Definition at line 34 of file ossimGeoPdfInfo.h.
◆ ossimGeoPdfInfo()
ossimGeoPdfInfo::ossimGeoPdfInfo ( )
default constructor
Definition at line 33 of file ossimGeoPdfInfo.cpp.
34  : ossimInfoBase(),
35  theFile(),
36  m_PdfMemDocument(NULL)
37 {
38 }
ossimInfoBase()
default constructor
◆ ~ossimGeoPdfInfo()
ossimGeoPdfInfo::~ossimGeoPdfInfo ( )
virtual
virtual destructor
Definition at line 40 of file ossimGeoPdfInfo.cpp.
References m_PdfMemDocument.
41 {
42  if (m_PdfMemDocument != NULL)
43  {
44  delete m_PdfMemDocument;
45  m_PdfMemDocument = 0;
46  }
47 }
Member Function Documentation
◆ isOpen()
bool ossimGeoPdfInfo::isOpen ( )
Definition at line 72 of file ossimGeoPdfInfo.cpp.
References ossimString::downcase(), ossimFilename::ext(), and theFile.
Referenced by open().
73 {
74  ossimString ext = theFile.ext().downcase();
75
76  if(ext == "pdf")
77  {
78  return true;
79  }
80  else
81  {
82  return false;
83  }
84 }
ossimString ext() const
◆ open() [1/2]
bool ossimGeoPdfInfo::open ( const ossimFilename file)
virtual
open method.
Parameters
fileFile name to open.
Returns
true on success false on error.
Reimplemented from ossimInfoBase.
Definition at line 49 of file ossimGeoPdfInfo.cpp.
References ossimString::c_str(), isOpen(), m_PdfMemDocument, and theFile.
50 {
51  theFile = file;
52  if (isOpen())
53  {
54  PoDoFo::PdfError::EnableDebug(false); //do not print out debug info
55  m_PdfMemDocument = new PoDoFo::PdfMemDocument(theFile.c_str());
56
57  if (m_PdfMemDocument == NULL)
58  {
59  return false;
60  }
61  return true;
62  }
63  return false;
64 }
const char * c_str() const
Definition: ossimString.h:396
◆ open() [2/2]
bool ossimGeoPdfInfo::open ( std::shared_ptr< ossim::istream > &  str,
const std::string &  connectionString
virtual
open method.
Parameters
strFile name to open.
Returns
Definition at line 66 of file ossimGeoPdfInfo.cpp.
68 {
69  return false;
70 }
◆ print()
std::ostream & ossimGeoPdfInfo::print ( std::ostream &  out) const
virtual
Print method.
Parameters
outStream to print to.
Returns
std::ostream&
Implements ossimInfoBase.
Definition at line 86 of file ossimGeoPdfInfo.cpp.
References ossimString::c_str(), ossimString::empty(), m_PdfMemDocument, ossimString::substitute(), ossimString::toString(), and ossimString::trim().
87 {
88  static const char MODULE[] = "ossimGeoPdfInfo::print";
89
90  int count = m_PdfMemDocument->GetPageCount();
91  PoDoFo::PdfString author = m_PdfMemDocument->GetInfo()->GetAuthor();
92  PoDoFo::PdfString creator = m_PdfMemDocument->GetInfo()->GetCreator();
93  PoDoFo::PdfString title = m_PdfMemDocument->GetInfo()->GetTitle();
94  PoDoFo::PdfString subject = m_PdfMemDocument->GetInfo()->GetSubject();
95  PoDoFo::PdfString keywords = m_PdfMemDocument->GetInfo()->GetKeywords();
96  PoDoFo::PdfString producer = m_PdfMemDocument->GetInfo()->GetProducer();
97
98
99  ossimString createDate;
100  ossimString modifyDate;
101  PoDoFo::PdfObject* obj = m_PdfMemDocument->GetInfo()->GetObject();
102  if (obj->IsDictionary())
103  {
104  PoDoFo::PdfDictionary pdfDictionary = obj->GetDictionary();
105
106  PoDoFo::TKeyMap keyMap = pdfDictionary.GetKeys();
107  PoDoFo::TKeyMap::iterator it = keyMap.begin();
108  while (it != keyMap.end())
109  {
110  ossimString refName = ossimString(it->first.GetName());
111  PoDoFo::PdfObject* refObj = it->second;
112
113  std::string objStr;
114  refObj->ToString(objStr);
115
116  if (refName == "CreationDate")
117  {
118  createDate = ossimString(objStr);
119  createDate = createDate.substitute("(", "", true).trim();
120  createDate = createDate.substitute(")", "", true).trim();
121  createDate = createDate.substitute("D:", "", true).trim();
122  }
123  else if (refName == "ModDate")
124  {
125  modifyDate = ossimString(objStr);
126  modifyDate = modifyDate.substitute("(", "", true).trim();
127  modifyDate = modifyDate.substitute(")", "", true).trim();
128  modifyDate = modifyDate.substitute("D:", "", true).trim();
129  }
130  it++;
131  }
132  }
133
134  try
135  {
136  m_PdfMemDocument->FreeObjectMemory(obj);
137  }
138  catch (...)
139  {
140  }
141
142  ossimString authorStr = author.GetString();
143  ossimString creatorStr = creator.GetString();
144  ossimString titleStr = title.GetString();
145  ossimString producerStr = producer.GetString();
146  ossimString subjectStr = subject.GetString();
147  ossimString keywordsStr = keywords.GetString();
148
149  ossimString prefix = "geopdf.";
150
151  out << prefix << "pagecount: "
152  << ossimString::toString(count).c_str() << "\n";
153
154  if (!authorStr.empty())
155  {
156  out << prefix << "author: "
157  << authorStr.c_str() << "\n";
158  }
159
160  if (!creatorStr.empty())
161  {
162  out << prefix << "creator: "
163  << creatorStr.c_str() << "\n";
164  }
165
166  if (!titleStr.empty())
167  {
168  out << prefix << "title: "
169  << titleStr.c_str() << "\n";
170  }
171
172  if (!producerStr.empty())
173  {
174  out << prefix << "producer: "
175  << producerStr.c_str() << "\n";
176  }
177
178  if (!subjectStr.empty())
179  {
180  out << prefix << "subject: "
181  << subjectStr.c_str() << "\n";
182  }
183
184  if (!keywordsStr.empty())
185  {
186  out << prefix << "keywords: "
187  << keywordsStr.c_str() << "\n";
188  }
189
190  if (!createDate.empty())
191  {
192  out << prefix << "creationdate: "
193  << createDate.c_str() << "\n";
194  }
195
196  if (!modifyDate.empty())
197  {
198  out << prefix << "modificationdate: "
199  << modifyDate.c_str() << "\n";
200  }
201
202  if (traceDebug())
203  {
205  << MODULE << " DEBUG Entered...\n";
206  }
207  return out;
208 }
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
Numeric to string methods.
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
bool empty() const
Definition: ossimString.h:411
Member Data Documentation
◆ m_PdfMemDocument
PoDoFo::PdfMemDocument* ossimGeoPdfInfo::m_PdfMemDocument
private
Definition at line 69 of file ossimGeoPdfInfo.h.
Referenced by open(), print(), and ~ossimGeoPdfInfo().
◆ theFile
ossimFilename ossimGeoPdfInfo::theFile
private
Definition at line 68 of file ossimGeoPdfInfo.h.
Referenced by isOpen(), and open().
