Public Member Functions | Static Public Member Functions | Private Member Functions | List of all members
ossimGeoPdfInfoFactory Class Reference
Info factory. More...
#include <ossimGeoPdfInfoFactory.h>
Inheritance diagram for ossimGeoPdfInfoFactory:
ossimInfoFactoryInterface
virtual ~ossimGeoPdfInfoFactory ()
 virtual destructor More...
virtual std::shared_ptr< ossimInfoBasecreate (const ossimFilename &file) const
 create method. More...
virtual std::shared_ptr< ossimInfoBasecreate (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) const
- Public Member Functions inherited from ossimInfoFactoryInterface
 ossimInfoFactoryInterface ()
 default constructor More...
virtual ~ossimInfoFactoryInterface ()
static ossimGeoPdfInfoFactoryinstance ()
 hidden from use default constructor More...
 ossimGeoPdfInfoFactory (const ossimGeoPdfInfoFactory &obj)
 hidden from use copy constructor More...
const ossimGeoPdfInfoFactoryoperator= (const ossimGeoPdfInfoFactory &rhs)
 hidden from use operator = More...
Detailed Description
Info factory.
Definition at line 26 of file ossimGeoPdfInfoFactory.h.
◆ ~ossimGeoPdfInfoFactory()
ossimGeoPdfInfoFactory::~ossimGeoPdfInfoFactory ( )
virtual
virtual destructor
Definition at line 22 of file ossimGeoPdfInfoFactory.cpp.
23 {}
◆ ossimGeoPdfInfoFactory() [1/2]
ossimGeoPdfInfoFactory::ossimGeoPdfInfoFactory ( )
private
Definition at line 55 of file ossimGeoPdfInfoFactory.cpp.
56 {}
◆ ossimGeoPdfInfoFactory() [2/2]
ossimGeoPdfInfoFactory::ossimGeoPdfInfoFactory ( const ossimGeoPdfInfoFactory obj)
private
Definition at line 58 of file ossimGeoPdfInfoFactory.cpp.
59 {}
Member Function Documentation
◆ create() [1/2]
std::shared_ptr< ossimInfoBase > ossimGeoPdfInfoFactory::create ( const ossimFilename file) const
virtual
create method.
Parameters
fileSome file you want info for.
Returns
ossimInfoBase* on success 0 on failure. Caller is responsible for memory.
Implements ossimInfoFactoryInterface.
Definition at line 41 of file ossimGeoPdfInfoFactory.cpp.
42 {
43  std::shared_ptr<ossimInfoBase> result;
44
45  result = std::make_shared<ossimGeoPdfInfo>();
46  if ( result->open(file) )
47  {
48  return result;
49  }
50  result.reset();
51
52  return result;
53 }
◆ create() [2/2]
std::shared_ptr< ossimInfoBase > ossimGeoPdfInfoFactory::create ( std::shared_ptr< ossim::istream > &  str,
const std::string &  connectionString
) const
virtual
Definition at line 32 of file ossimGeoPdfInfoFactory.cpp.
34 {
35  std::shared_ptr<ossimInfoBase> result;
36
37
38  return result;
39 }
◆ instance()
ossimGeoPdfInfoFactory * ossimGeoPdfInfoFactory::instance ( )
static
Definition at line 25 of file ossimGeoPdfInfoFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
26 {
27  static ossimGeoPdfInfoFactory sharedInstance;
28
29  return &sharedInstance;
30 }
◆ operator=()
const ossimGeoPdfInfoFactory & ossimGeoPdfInfoFactory::operator= ( const ossimGeoPdfInfoFactory rhs)
private
Definition at line 61 of file ossimGeoPdfInfoFactory.cpp.
63 {
64  return *this;
65 }
