Public Member Functions | Private Attributes | Friends | List of all members
ossimGeoidNgsHeader Class Reference
#include <ossimGeoidNgsHeader.h>
 ossimGeoidNgsHeader ()
 ossimGeoidNgsHeader (const ossimFilename &fileName, ossimByteOrder byteOrder=OSSIM_LITTLE_ENDIAN)
bool initialize (const ossimFilename &fileName, ossimByteOrder byteOrder=OSSIM_LITTLE_ENDIAN)
double southernMostLat () const
double westernMostLon () const
double latDelta () const
double lonDelta () const
int rows () const
int cols () const
int dataType () const
bool pointWithin (double lat, double lon) const
const ossimFilenamefilename () const
int headerSize () const
int dataTypeSize () const
double getHeightDelta (double lat, double lon) const
Private Attributes
ossimFilename theFilename
ossimByteOrder theByteOrder
double theSouthernMostLatitude
double theWesternMostLongitude
double theLatDelta
double theLonDelta
int theRows
int theCols
int theDataType
Friends
OSSIM_DLL std::ostream & operator<< (std::ostream &out, const ossimGeoidNgsHeader &data)
Detailed Description
Definition at line 16 of file ossimGeoidNgsHeader.h.
◆ ossimGeoidNgsHeader() [1/2]
ossimGeoidNgsHeader::ossimGeoidNgsHeader ( )
◆ ossimGeoidNgsHeader() [2/2]
ossimGeoidNgsHeader::ossimGeoidNgsHeader ( const ossimFilename fileName,
ossimByteOrder  byteOrder = OSSIM_LITTLE_ENDIAN
Definition at line 38 of file ossimGeoidNgsHeader.cpp.
References ossim::byteOrder(), and initialize().
40 {
41  initialize(fileName, byteOrder);
42 }
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
bool initialize(const ossimFilename &fileName, ossimByteOrder byteOrder=OSSIM_LITTLE_ENDIAN)
Member Function Documentation
◆ cols()
int ossimGeoidNgsHeader::cols ( ) const
inline
Definition at line 33 of file ossimGeoidNgsHeader.h.
Referenced by initialize().
◆ dataType()
int ossimGeoidNgsHeader::dataType ( ) const
inline
Definition at line 34 of file ossimGeoidNgsHeader.h.
◆ dataTypeSize()
int ossimGeoidNgsHeader::dataTypeSize ( ) const
inline
Definition at line 39 of file ossimGeoidNgsHeader.h.
Referenced by getHeightDelta().
39 {return theDataType==1?4:0;}
◆ filename()
const ossimFilename& ossimGeoidNgsHeader::filename ( ) const
inline
Definition at line 36 of file ossimGeoidNgsHeader.h.
36 {return theFilename;}
◆ getHeightDelta()
double ossimGeoidNgsHeader::getHeightDelta ( double  lat,
double  lon
) const
Returns
Height delta or ossim::nan() if not found.
Definition at line 108 of file ossimGeoidNgsHeader.cpp.
References dataTypeSize(), filename(), FLT_EPSILON, ossimEndian::getSystemEndianType(), headerSize(), ossim::nan(), ossimNotify(), ossimNotifyLevel_FATAL, ossimEndian::swap(), theByteOrder, theCols, theFilename, theLatDelta, theLonDelta, theSouthernMostLatitude, and theWesternMostLongitude.
110 {
111  float result=0.0;
112
113  // note the headers go from 0 to 360 degrees starting at the prime meridian.
114  // ours goes from -180 to 180 degrees. We will need to shift
115  //
116  if(lon < 0.0) lon += 360;
117  double latSpaces = (lat - theSouthernMostLatitude)/theLatDelta;
118  double lonSpaces = (lon - theWesternMostLongitude)/theLonDelta;
119
120  if(latSpaces < -FLT_EPSILON) return ossim::nan();
121  if(lonSpaces < -FLT_EPSILON) return ossim::nan();
122
123  long latSpace0 = (long)std::floor(latSpaces);
124  long latSpace1 = latSpace0 + 1;
125  long lonSpace0 = (long)std::floor(lonSpaces);
126  long lonSpace1 = lonSpace0 + 1;
127
128  ifstream input(filename().c_str(), ios::in|ios::binary);
129  if(!input)
130  {
131  ossimNotify(ossimNotifyLevel_FATAL) << "FATAL: " << "ossimGeoidNgsHeader::getGeoidHeight, " << "unable to open file: " << theFilename << "\n";
132  return 0;
133  }
134
135  long offset00 = (long)(headerSize() + (latSpace0*theCols + lonSpace0)*dataTypeSize());
136  long offset01 = (long)(headerSize() + (latSpace0*theCols + lonSpace1)*dataTypeSize());
137  long offset11 = (long)(headerSize() + (latSpace1*theCols + lonSpace1)*dataTypeSize());
138  long offset10 = (long)(headerSize() + (latSpace1*theCols + lonSpace0)*dataTypeSize());
139
140  double tLat = latSpaces - floor(latSpaces);
141  double tLon = lonSpaces - floor(lonSpaces);
142
143
144  float v00;
145  float v01;
146  float v11;
147  float v10;
148
149  input.seekg(offset00,ios::beg);
150  input.read((char*)&v00, 4);
151
152  input.seekg(offset01,ios::beg);
153  input.read((char*)&v01, 4);
154
155  input.seekg(offset11,ios::beg);
156  input.read((char*)&v11, 4);
157
158  input.seekg(offset10,ios::beg);
159  input.read((char*)&v10, 4);
160  ossimEndian endian;
161  if(endian.getSystemEndianType() != theByteOrder)
162  {
163  endian.swap(v00);
164  endian.swap(v01);
165  endian.swap(v11);
166  endian.swap(v10);
167  }
168  double bottom = (v00 + (v01 - v00)*tLat);
169  double top = (v10 + (v11 - v10)*tLat);
170  result = bottom + (top - bottom)*tLon;
171
172  return result;
173
174 }
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
double nan()
Definition: ossimCommon.h:135
const ossimFilename & filename() const
#define FLT_EPSILON
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ headerSize()
int ossimGeoidNgsHeader::headerSize ( ) const
inline
Definition at line 38 of file ossimGeoidNgsHeader.h.
38 {return 44;}
◆ initialize()
bool ossimGeoidNgsHeader::initialize ( const ossimFilename fileName,
Definition at line 44 of file ossimGeoidNgsHeader.cpp.
References ossim::byteOrder(), ossimString::c_str(), cols(), FLT_EPSILON, ossimEndian::getSystemEndianType(), rows(), ossimEndian::swap(), theByteOrder, theCols, theDataType, theFilename, theLatDelta, theLonDelta, theRows, theSouthernMostLatitude, and theWesternMostLongitude.
Referenced by ossimGeoidNgs::addFile(), and ossimGeoidNgsHeader().
46 {
47  ifstream input(fileName.c_str(), ios::in|ios::binary);
48  if(!input)
49  {
50 // cerr << MODULE << " Cannot open geoid file in " << fileName.c_str()
51 // << endl;
52  return false;
53  }
54
56  double latOrigin = 0.0;
57  double lonOrigin = 0.0;
58  double latSpacing = 0.0;
59  double lonSpacing = 0.0;
60  int rows = 0;
61  int cols = 0;
62  int type = 0;
63
64  input.read((char*)&latOrigin, 8);
65  input.read((char*)&lonOrigin, 8);
66  input.read((char*)&latSpacing, 8);
67  input.read((char*)&lonSpacing, 8);
68  input.read((char*)&rows, 4);
69  input.read((char*)&cols, 4);
70  input.read((char*)&type, 4);
71
72  ossimEndian endian;
73
74  if(endian.getSystemEndianType() != byteOrder)
75  {
76  endian.swap(latOrigin);
77  endian.swap(lonOrigin);
78  endian.swap(latSpacing);
79  endian.swap(lonSpacing);
80  endian.swap(rows);
81  endian.swap(cols);
82  endian.swap(type);
83  }
84
85  theFilename = fileName;
86  theSouthernMostLatitude = latOrigin;
87  theWesternMostLongitude = lonOrigin;
88  theLatDelta = latSpacing;
89  theLonDelta = lonSpacing;
90  theRows = rows;
91  theCols = cols;
92  theDataType = type;
93
94  return ((theSouthernMostLatitude >= -FLT_EPSILON)&&
95  (theSouthernMostLatitude <= 90.0)&&
97  (theWesternMostLongitude <= 360.0));
98 }
#define FLT_EPSILON
const char * c_str() const
Definition: ossimString.h:396
◆ latDelta()
double ossimGeoidNgsHeader::latDelta ( ) const
inline
Definition at line 30 of file ossimGeoidNgsHeader.h.
30 {return theLatDelta;}
◆ lonDelta()
double ossimGeoidNgsHeader::lonDelta ( ) const
inline
Definition at line 31 of file ossimGeoidNgsHeader.h.
31 {return theLonDelta;}
◆ pointWithin()
bool ossimGeoidNgsHeader::pointWithin ( double  lat,
double  lon
) const
◆ rows()
int ossimGeoidNgsHeader::rows ( ) const
inline
Definition at line 32 of file ossimGeoidNgsHeader.h.
◆ southernMostLat()
double ossimGeoidNgsHeader::southernMostLat ( ) const
inline
Definition at line 28 of file ossimGeoidNgsHeader.h.
◆ westernMostLon()
double ossimGeoidNgsHeader::westernMostLon ( ) const
inline
Definition at line 29 of file ossimGeoidNgsHeader.h.
◆ operator<<
OSSIM_DLL std::ostream& operator<< ( std::ostream &  out,
const ossimGeoidNgsHeader data
friend
Member Data Documentation
◆ theByteOrder
ossimByteOrder ossimGeoidNgsHeader::theByteOrder
private
Definition at line 46 of file ossimGeoidNgsHeader.h.
Referenced by getHeightDelta(), and initialize().
◆ theCols
int ossimGeoidNgsHeader::theCols
private
theCols specifies the number of lon increments
Definition at line 74 of file ossimGeoidNgsHeader.h.
Referenced by getHeightDelta(), initialize(), operator<<(), and pointWithin().
◆ theDataType
int ossimGeoidNgsHeader::theDataType
private
Specifies the datatype. if this is 1 then the data that follows is 4 byte floats.
Definition at line 80 of file ossimGeoidNgsHeader.h.
Referenced by initialize(), and operator<<().
◆ theFilename
ossimFilename ossimGeoidNgsHeader::theFilename
private
Definition at line 45 of file ossimGeoidNgsHeader.h.
Referenced by getHeightDelta(), initialize(), and operator<<().
◆ theLatDelta
double ossimGeoidNgsHeader::theLatDelta
private
Specifies the spacing of the latitude direction.
Definition at line 59 of file ossimGeoidNgsHeader.h.
◆ theLonDelta
double ossimGeoidNgsHeader::theLonDelta
private
longitude spacing.
Definition at line 64 of file ossimGeoidNgsHeader.h.
◆ theRows
int ossimGeoidNgsHeader::theRows
private
theRows specifies the number of lat increments
Definition at line 69 of file ossimGeoidNgsHeader.h.
Referenced by initialize(), operator<<(), and pointWithin().
◆ theSouthernMostLatitude
double ossimGeoidNgsHeader::theSouthernMostLatitude
private
Definition at line 47 of file ossimGeoidNgsHeader.h.
◆ theWesternMostLongitude
double ossimGeoidNgsHeader::theWesternMostLongitude
private
Important: The geoid.bin files expresses this as a possitive value.
example: -90.0 is 270 degrees.
Definition at line 54 of file ossimGeoidNgsHeader.h.
