Public Member Functions | Protected Attributes | List of all members
ossimJobCallback Class Reference
This is the job callback interface It allows one to attach and listen for different states of the job and if properties have changed. More...
#include <ossimJob.h>
Inheritance diagram for ossimJobCallback:
ossimFileWalker::ossimFileWalkerJobCallback ossimMultiThreadSequencer::ossimGetTileCallback
 ossimJobCallback (std::shared_ptr< ossimJobCallback > nextCallback=0)
virtual void ready (std::shared_ptr< ossimJob > job)
virtual void started (std::shared_ptr< ossimJob > job)
virtual void finished (std::shared_ptr< ossimJob > job)
virtual void canceled (std::shared_ptr< ossimJob > job)
virtual void nameChanged (const ossimString &name, std::shared_ptr< ossimJob > job)
virtual void descriptionChanged (const ossimString &description, std::shared_ptr< ossimJob > job)
virtual void idChanged (const ossimString &id, std::shared_ptr< ossimJob > job)
virtual void percentCompleteChanged (double percentValue, std::shared_ptr< ossimJob > job)
void setCallback (std::shared_ptr< ossimJobCallback > c)
std::shared_ptr< ossimJobCallbackcallback ()
std::shared_ptr< ossimJobCallbackm_nextCallback
Detailed Description
// Put your includes here:
// System includes:
#include <memory>
#include <iostream>
class TestJob : public ossimJob
public:
TestJob(){}
protected:
virtual void run()
std:cout << "Running Job\n";
std::cout << "Finished Running Job\n";
class MyCallback : public ossimJobCallback
public:
MyCallback(){}
virtual void started(std::shared_ptr<ossimJob> job)
std::cout << "Started job\n";
virtual void finished(std::shared_ptr<ossimJob> job)
std::cout << "Finished job\n";
int main(int argc, char *argv[])
std::shared_ptr<TestJob> job = std::make_shared<TestJob>();
job->setCallback(std::make_shared<MyCallback>());
job->start();
return 0;
Definition at line 68 of file ossimJob.h.
◆ ossimJobCallback()
ossimJobCallback::ossimJobCallback ( std::shared_ptr< ossimJobCallback nextCallback = 0)
inline
Definition at line 71 of file ossimJob.h.
71 :m_nextCallback(nextCallback){}
std::shared_ptr< ossimJobCallback > m_nextCallback
Definition: ossimJob.h:94
Member Function Documentation
◆ callback()
std::shared_ptr<ossimJobCallback> ossimJobCallback::callback ( )
inline
Definition at line 91 of file ossimJob.h.
91 {return m_nextCallback;}
◆ canceled()
virtual void ossimJobCallback::canceled ( std::shared_ptr< ossimJob job)
inlinevirtual
Reimplemented in ossimFileWalker::ossimFileWalkerJobCallback.
Definition at line 76 of file ossimJob.h.
Referenced by ossimFileWalker::ossimFileWalkerJobCallback::canceled().
76 {if(m_nextCallback) m_nextCallback->canceled(job);}
◆ descriptionChanged()
virtual void ossimJobCallback::descriptionChanged ( const ossimString description,
inlinevirtual
Definition at line 81 of file ossimJob.h.
82  {if(m_nextCallback) m_nextCallback->descriptionChanged(description, job);}
◆ finished()
virtual void ossimJobCallback::finished ( std::shared_ptr< ossimJob job)
inlinevirtual
Reimplemented in ossimFileWalker::ossimFileWalkerJobCallback, and ossimMultiThreadSequencer::ossimGetTileCallback.
Definition at line 75 of file ossimJob.h.
Referenced by ossimFileWalker::ossimFileWalkerJobCallback::finished().
75 {if(m_nextCallback) m_nextCallback->finished(job);}
◆ idChanged()
virtual void ossimJobCallback::idChanged ( const ossimString id,
inlinevirtual
Definition at line 84 of file ossimJob.h.
85  {if(m_nextCallback) m_nextCallback->idChanged(id, job);}
◆ nameChanged()
virtual void ossimJobCallback::nameChanged ( const ossimString name,
inlinevirtual
Definition at line 78 of file ossimJob.h.
79  {if(m_nextCallback) m_nextCallback->nameChanged(name, job);}
◆ percentCompleteChanged()
virtual void ossimJobCallback::percentCompleteChanged ( double  percentValue,
inlinevirtual
Definition at line 87 of file ossimJob.h.
88  {if(m_nextCallback) m_nextCallback->percentCompleteChanged(percentValue, job);}
◆ ready()
virtual void ossimJobCallback::ready ( std::shared_ptr< ossimJob job)
inlinevirtual
Definition at line 73 of file ossimJob.h.
73 {if(m_nextCallback) m_nextCallback->ready(job); }
◆ setCallback()
void ossimJobCallback::setCallback ( std::shared_ptr< ossimJobCallback c)
inline
Definition at line 90 of file ossimJob.h.
90 {m_nextCallback = c;}
◆ started()
virtual void ossimJobCallback::started ( std::shared_ptr< ossimJob job)
inlinevirtual
Definition at line 74 of file ossimJob.h.
Referenced by ossimFileWalker::ossimFileWalkerJobCallback::started().
74 {if(m_nextCallback) m_nextCallback->started(job); }
Member Data Documentation
◆ m_nextCallback
std::shared_ptr<ossimJobCallback> ossimJobCallback::m_nextCallback
protected
Definition at line 94 of file ossimJob.h.
The documentation for this class was generated from the following file:
