Public Member Functions | Public Attributes | List of all members
ossimJpipMessageHeader Class Reference
#include <ossimJpipMessageHeader.h>
Inheritance diagram for ossimJpipMessageHeader:
ossimReferenced
 ossimJpipMessageHeader ()
void reset ()
ossimString toString () const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Public Attributes
bool m_isLastByte
 Bin-ID = [BinIdIndicator, completeDataBin, InClassIdentifier]. More...
ossim_int64 m_inClassIdentifier
ossim_int32 m_classIdentifier
 If present, provides a message class identifier. More...
ossim_int32 m_CSn
 If present, identifies the index (stating from 0) of the codestream to which the data-bin belongs. More...
ossim_int64 m_msgOffset
 Identifies the offset of the data in the message from the start of the data-bin. More...
ossim_int64 m_msgLength
 Identifies the total number of bytes in the body of the message. More...
ossim_int64 m_aux
 If present, it represents a non-negative integer value, formed by concatenating the least significant 7 bits of each byte in the VBAS in big-endian order. More...
bool m_isEOR
 Indicates if this JPIP Message is an End of Response Message. More...
int m_EORCode
 Definition in CADI.Common.Network.JPIP.EORCodes. More...
ossimString m_EORReasonMessage
 It is and reason message associated with the EORReasonCode. More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 14 of file ossimJpipMessageHeader.h.
◆ ossimJpipMessageHeader()
ossimJpipMessageHeader::ossimJpipMessageHeader ( )
inline
Definition at line 17 of file ossimJpipMessageHeader.h.
18  :m_isLastByte(true),
21  m_CSn(-1),
22  m_msgOffset(-1),
23  m_msgLength(-1),
24  m_aux(-1),
25  m_isEOR(false),
26  m_EORCode(-1),
28  {
29
30  }
ossim_int32 m_CSn
If present, identifies the index (stating from 0) of the codestream to which the data-bin belongs...
int m_EORCode
bool m_isEOR
bool m_isLastByte
ossim_int64 m_aux
If present, it represents a non-negative integer value, formed by concatenating the least significant...
Member Function Documentation
◆ reset()
void ossimJpipMessageHeader::reset ( void  )
inline
Definition at line 31 of file ossimJpipMessageHeader.h.
Referenced by ossimJpipMessage::reset().
32  {
33  m_isLastByte = true;
35  m_classIdentifier = -1;
36  m_CSn = -1;
37  m_msgOffset = -1;
38  m_msgLength = -1;
39  m_aux = -1;
40  m_isEOR = false;
41  m_EORCode = -1;
42  m_EORReasonMessage = "";
43  }
ossim_int32 m_CSn
int m_EORCode
bool m_isEOR
bool m_isLastByte
ossim_int64 m_aux
◆ toString()
ossimString ossimJpipMessageHeader::toString ( ) const
inline
Definition at line 44 of file ossimJpipMessageHeader.h.
References ossimString::toString().
45  {
47
48  out << "m_isLastByte: " << ossimString::toString(m_isLastByte) << "\n"
49  << "m_inClassIdentifier: " << m_inClassIdentifier << "\n"
50  << "m_classIdentifier: " << m_classIdentifier << "\n"
51  << "m_CSn: " << m_CSn << "\n"
52  << "m_msgOffset: " << m_msgOffset << "\n"
53  << "m_msgLength: " << m_msgLength << "\n"
54  << "m_aux: " << m_aux << "\n"
55  << "m_isEOR: " << m_isEOR << "\n"
56  << "m_EORCode: " << m_EORCode << "\n"
57  << "m_EORReasonMessage: " << m_EORReasonMessage << "\n";
58
59  return ossimString(out.str());
60  }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
Numeric to string methods.
ossim_int32 m_CSn
int m_EORCode
bool m_isEOR
bool m_isLastByte
ossim_int64 m_aux
Member Data Documentation
◆ m_aux
ossim_int64 ossimJpipMessageHeader::m_aux
Its presence and meaning if present, is determined by the message class identifier found within the Bin-ID VBAS.
Definition at line 210 of file ossimJpipMessageHeader.h.
Referenced by ossimJpipMessageDecoder::readMessage().
◆ m_classIdentifier
ossim_int32 ossimJpipMessageHeader::m_classIdentifier
The message class identifier is a non-negative integer, formed by concatenating the least significant 7 bits of each byte of the VBAS in big-endian order. If no present, the message class identifier is unchanged form that associated with the previous message. If the Class VBAS is not present and there is no previous message, the message class identifier is 0.
Class identifier Message class Data-bin class Stream type
0 Precinct data-bin message Precinct data-bin JPP-stream only
1 Extended precinct data-bin message Precinct data-bin JPP-stream only
2 Tile header data-bin message Tile header data-bin JPP-stream only
4 Tile data-bin message Tile data-bin JPT-stream only
5 Extended precinct data-bin message Tile data-bin JPT-stream only
6 Main header data-bin message Main heaer data-bin JPP- and JPT-stream
8 Metadata-bin message Metadata-bin JPP and JPT-stream
Allowed values, see CADI.Common.Network.JPIP.ClassIdentifiers.
Definition at line 176 of file ossimJpipMessageHeader.h.
◆ m_CSn
ossim_int32 ossimJpipMessageHeader::m_CSn
The codestream index is formed by concatenating the leas significant 7 bits of each byte of the VBAS in big-endian order. If the CSn VBAS is no present, the codestream index is unchanged from the previous message. If CSn VBAS is no present and there is no previous message, the codestream index is 0.
Definition at line 186 of file ossimJpipMessageHeader.h.
◆ m_EORCode
int ossimJpipMessageHeader::m_EORCode
Further information, see ISO/IEC 15444-9 sect. D.3
Definition at line 222 of file ossimJpipMessageHeader.h.
Referenced by ossimJpipMessageDecoder::readEORMessage().
◆ m_EORReasonMessage
ossimString ossimJpipMessageHeader::m_EORReasonMessage
It is an optional attribute.
Definition at line 229 of file ossimJpipMessageHeader.h.
◆ m_inClassIdentifier
ossim_int64 ossimJpipMessageHeader::m_inClassIdentifier
Definition at line 112 of file ossimJpipMessageHeader.h.
◆ m_isEOR
bool ossimJpipMessageHeader::m_isEOR
Definition at line 215 of file ossimJpipMessageHeader.h.
◆ m_isLastByte
bool ossimJpipMessageHeader::m_isLastByte
Bin-ID format:
<samp> MSB LSB 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0
|a|b b|c|d d d d| |a|d d d d d d d| |a|d d d d d d d| .....
</samp>
Bits 6 and 5 of the first, BinIDIndicator, byte indicate whether the Class and CSn VBASs are present in the message header. Next table defines the bit values and its meaning
Indicator Meaning
0 Prohibited
1 No Class or CSn VBAS is present in message header
2 Class VBAS is present but CSn is no present in message header
3 Class and CSn VBAS are both present in the message header
Bit 4, completeDataBin, of the first byte of the Bin-ID indicates whether or not this message contains the last byte in the asociated data-bin: '0' means it is not the last byte in the data-bin; '1' inidates tat it is the last byte in the data-bin.
The remaining 4 bits of the first byte and the 7 low order bits of any remaining bytes in the Bin-ID VBAS form an "in-class identifier".
Definition at line 111 of file ossimJpipMessageHeader.h.
◆ m_msgLength
ossim_int64 ossimJpipMessageHeader::m_msgLength
It is a non-negative integer value, formed by concatenating the least significant 7 bits of each byte in the VBAS in big-endian order.
Definition at line 200 of file ossimJpipMessageHeader.h.
Referenced by ossimJpipMessageDecoder::readEORMessage(), and ossimJpipMessageDecoder::readMessage().
◆ m_msgOffset
ossim_int64 ossimJpipMessageHeader::m_msgOffset
Definition at line 193 of file ossimJpipMessageHeader.h.
The documentation for this class was generated from the following file:
