Public Member Functions | Static Public Member Functions | Private Member Functions | List of all members
ossimKakaduJpipInfoFactory Class Reference
#include <ossimKakaduJpipInfoFactory.h>
Inheritance diagram for ossimKakaduJpipInfoFactory:
ossimInfoFactoryInterface
virtual ~ossimKakaduJpipInfoFactory ()
 virtual destructor More...
virtual std::shared_ptr< ossimInfoBasecreate (const ossimFilename &file) const
 create method. More...
virtual std::shared_ptr< ossimInfoBasecreate (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) const
- Public Member Functions inherited from ossimInfoFactoryInterface
 ossimInfoFactoryInterface ()
 default constructor More...
virtual ~ossimInfoFactoryInterface ()
static ossimKakaduJpipInfoFactoryinstance ()
 hidden from use default constructor More...
 ossimKakaduJpipInfoFactory (const ossimKakaduJpipInfoFactory &obj)
 hidden from use copy constructor More...
const ossimKakaduJpipInfoFactoryoperator= (const ossimKakaduJpipInfoFactory &rhs)
 hidden from use operator = More...
Detailed Description
Definition at line 5 of file ossimKakaduJpipInfoFactory.h.
◆ ~ossimKakaduJpipInfoFactory()
ossimKakaduJpipInfoFactory::~ossimKakaduJpipInfoFactory ( )
virtual
virtual destructor
Definition at line 7 of file ossimKakaduJpipInfoFactory.cpp.
8 {
9 }
◆ ossimKakaduJpipInfoFactory() [1/2]
ossimKakaduJpipInfoFactory::ossimKakaduJpipInfoFactory ( )
private
Definition at line 36 of file ossimKakaduJpipInfoFactory.cpp.
37 {
38 }
◆ ossimKakaduJpipInfoFactory() [2/2]
ossimKakaduJpipInfoFactory::ossimKakaduJpipInfoFactory ( const ossimKakaduJpipInfoFactory obj)
private
Definition at line 41 of file ossimKakaduJpipInfoFactory.cpp.
42 {
43
44 }
Member Function Documentation
◆ create() [1/2]
std::shared_ptr< ossimInfoBase > ossimKakaduJpipInfoFactory::create ( const ossimFilename file) const
virtual
create method.
Parameters
fileSome file you want info for.
Returns
ossimInfoBase* on success 0 on failure. Caller is responsible for memory.
Implements ossimInfoFactoryInterface.
Definition at line 17 of file ossimKakaduJpipInfoFactory.cpp.
18 {
19
20  std::shared_ptr<ossimInfoBase> jpipInfo = std::make_shared<ossimKakaduJpipInfo>();
21  if(!jpipInfo->open(file))
22  {
23  jpipInfo.reset();
24  }
25  return jpipInfo;
26 }
◆ create() [2/2]
std::shared_ptr< ossimInfoBase > ossimKakaduJpipInfoFactory::create ( std::shared_ptr< ossim::istream > &  str,
const std::string &  connectionString
) const
virtual
Definition at line 28 of file ossimKakaduJpipInfoFactory.cpp.
30 {
31  std::shared_ptr<ossimInfoBase> jpipInfo;
32
33  return jpipInfo;
34 }
◆ instance()
ossimKakaduJpipInfoFactory * ossimKakaduJpipInfoFactory::instance ( )
static
Definition at line 11 of file ossimKakaduJpipInfoFactory.cpp.
Referenced by ossimSharedLibraryInitialize().
12 {
13  static ossimKakaduJpipInfoFactory inst;
14  return &inst;
15 }
◆ operator=()
const ossimKakaduJpipInfoFactory & ossimKakaduJpipInfoFactory::operator= ( const ossimKakaduJpipInfoFactory rhs)
private
Definition at line 47 of file ossimKakaduJpipInfoFactory.cpp.
48 {
49  return *this;
50 }
