Public Types | Public Member Functions | Protected Attributes | List of all members
ossimNitfAimidbTag Class Reference
#include <ossimNitfAimidbTag.h>
Inheritance diagram for ossimNitfAimidbTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Public Types
enum  {
  CEL_SIZE = 89, ACQUISITION_DATE_SIZE = 14, MISSION_NO_SIZE = 4, MISSION_IDENTIFICATION_SIZE = 10,
  FLIGHT_NO_SIZE = 2, OP_NUM_SIZE = 3, CURRENT_SEGMENT_SIZE = 2, REPRO_NUM_SIZE = 2,
  REPLAY_SIZE = 3, RESERVED_1_SIZE = 1, START_TILE_COLUMN_SIZE = 3, START_TILE_ROW_SIZE = 5,
  END_SEGMENT_SIZE = 2, END_TILE_COLUMN_SIZE = 3, END_TILE_ROW_SIZE = 5, COUNTRY_SIZE = 2,
  RESERVED_2_SIZE = 4, LOCATION_SIZE = 11, RESERVED_3_SIZE = 13
 ossimNitfAimidbTag ()
 default constructor More...
virtual ~ossimNitfAimidbTag ()
 destructor More...
virtual void parseStream (ossim::istream &in)
 Method to parse data from stream. More...
virtual void writeStream (ossim::ostream &out)
 Method to write data to stream. More...
virtual void clearFields ()
 Method to clear all fields including null terminating. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Print method that outputs a key/value type format adding prefix to keys. More...
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char theAcquisitionDate [ACQUISITION_DATE_SIZE+1]
 Type R = Required Type <R> = BCS spaces allowed for entire field. More...
char theMissionNumber [MISSION_NO_SIZE+1]
 FIELD: MISSION_NO. More...
char theMissionIdentification [MISSION_IDENTIFICATION_SIZE+1]
 FIELD: MISSION_IDENTIFICATION. More...
char theFlightNo [FLIGHT_NO_SIZE+1]
 FIELD: FLIGHT_NO. More...
char theOpNum [OP_NUM_SIZE+1]
 FIELD: OP_NUM. More...
char theCurrentSegment [CURRENT_SEGMENT_SIZE+1]
 FIELD: CURRENT_SEGMENT. More...
char theReproNum [REPRO_NUM_SIZE+1]
 FIELD: REPRO_NUM. More...
char theReplay [REPLAY_SIZE+1]
 FIELD: REPLAY. More...
char theReserved1 [RESERVED_1_SIZE+1]
 FIELD: RESERVED_1. More...
char theStartTileColumn [START_TILE_COLUMN_SIZE+1]
 FIELD: START_TILE_COLUMN. More...
char theStartTileRow [START_TILE_ROW_SIZE+1]
 FIELD: START_TILE_ROW. More...
char theEndSegment [END_SEGMENT_SIZE+1]
 FIELD: END_SEGMENT. More...
char theTileColumn [END_TILE_COLUMN_SIZE+1]
 FIELD: END_TILE_COLUMN. More...
char theTileRow [END_TILE_ROW_SIZE+1]
 FIELD: END_TILE_ROW. More...
char theCountry [COUNTRY_SIZE+1]
 FIELD: COUNTRY. More...
char theReserved2 [RESERVED_2_SIZE+1]
 FIELD: RESERVED_2. More...
char theLocation [LOCATION_SIZE+1]
 FIELD: LOCATION. More...
char theReserved3 [RESERVED_3_SIZE+1]
 FIELD: RESERVED_3. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 22 of file ossimNitfAimidbTag.h.
◆ anonymous enum
anonymous enum
Enumerator
CEL_SIZE
MISSION_NO_SIZE
FLIGHT_NO_SIZE
OP_NUM_SIZE
REPRO_NUM_SIZE
REPLAY_SIZE
RESERVED_1_SIZE
START_TILE_ROW_SIZE
END_SEGMENT_SIZE
END_TILE_ROW_SIZE
COUNTRY_SIZE
RESERVED_2_SIZE
LOCATION_SIZE
RESERVED_3_SIZE
Definition at line 26 of file ossimNitfAimidbTag.h.
27  {
28  CEL_SIZE = 89,
30  MISSION_NO_SIZE = 4,
32  FLIGHT_NO_SIZE = 2,
33  OP_NUM_SIZE = 3,
35  REPRO_NUM_SIZE = 2,
36  REPLAY_SIZE = 3,
37  RESERVED_1_SIZE = 1,
40  END_SEGMENT_SIZE = 2,
43  COUNTRY_SIZE = 2,
44  RESERVED_2_SIZE = 4,
45  LOCATION_SIZE = 11,
46  RESERVED_3_SIZE = 13
47  };
◆ ossimNitfAimidbTag()
ossimNitfAimidbTag::ossimNitfAimidbTag ( )
default constructor
Definition at line 27 of file ossimNitfAimidbTag.cpp.
References clearFields().
28  : ossimNitfRegisteredTag(std::string("AIMIDB"), CEL_SIZE)
29 {
30  clearFields();
31 }
virtual void clearFields()
ossimNitfRegisteredTag()
default constructor
◆ ~ossimNitfAimidbTag()
ossimNitfAimidbTag::~ossimNitfAimidbTag ( )
virtual
destructor
Definition at line 33 of file ossimNitfAimidbTag.cpp.
34 {
35 }
Member Function Documentation
◆ clearFields()
void ossimNitfAimidbTag::clearFields ( )
virtual
Definition at line 83 of file ossimNitfAimidbTag.cpp.
References ACQUISITION_DATE_SIZE, COUNTRY_SIZE, CURRENT_SEGMENT_SIZE, END_SEGMENT_SIZE, END_TILE_COLUMN_SIZE, END_TILE_ROW_SIZE, FLIGHT_NO_SIZE, LOCATION_SIZE, MISSION_IDENTIFICATION_SIZE, MISSION_NO_SIZE, OP_NUM_SIZE, REPLAY_SIZE, REPRO_NUM_SIZE, RESERVED_1_SIZE, RESERVED_2_SIZE, RESERVED_3_SIZE, START_TILE_COLUMN_SIZE, START_TILE_ROW_SIZE, theAcquisitionDate, theCountry, theCurrentSegment, theEndSegment, theFlightNo, theLocation, theMissionIdentification, theMissionNumber, theOpNum, theReplay, theReproNum, theReserved1, theReserved2, theReserved3, theStartTileColumn, theStartTileRow, theTileColumn, and theTileRow.
Referenced by ossimNitfAimidbTag(), and parseStream().
84 {
85  // BCS-N's to '0's, BCS-A's to ' '(spaces)
86
87  // clear
89  memset(theMissionNumber, ' ', MISSION_NO_SIZE);
91  memset(theFlightNo, ' ', FLIGHT_NO_SIZE);
92  memset(theOpNum, ' ', OP_NUM_SIZE);
94  memset(theReproNum, ' ', REPRO_NUM_SIZE);
95  memset(theReplay, ' ', REPLAY_SIZE);
96  memset(theReserved1, ' ', RESERVED_1_SIZE);
99  memset(theEndSegment, ' ', END_SEGMENT_SIZE);
100  memset(theTileColumn, ' ', END_TILE_COLUMN_SIZE);
101  memset(theTileRow, ' ', END_TILE_ROW_SIZE);
102  memset(theCountry, ' ', COUNTRY_SIZE);
103  memset(theReserved2, ' ', RESERVED_2_SIZE);
104  memset(theLocation, ' ', LOCATION_SIZE);
105  memset(theReserved3, ' ', RESERVED_3_SIZE);
106
107  // null terminate
111  theFlightNo[FLIGHT_NO_SIZE] = '\0';
112  theOpNum[OP_NUM_SIZE] = '\0';
114  theReproNum[REPRO_NUM_SIZE] = '\0';
115  theReplay[REPLAY_SIZE] = '\0';
122  theCountry[COUNTRY_SIZE] = '\0';
124  theLocation[LOCATION_SIZE] = '\0';
126 }
char theLocation[LOCATION_SIZE+1]
FIELD: LOCATION.
char theReserved3[RESERVED_3_SIZE+1]
FIELD: RESERVED_3.
char theReplay[REPLAY_SIZE+1]
FIELD: REPLAY.
char theReserved2[RESERVED_2_SIZE+1]
FIELD: RESERVED_2.
char theEndSegment[END_SEGMENT_SIZE+1]
FIELD: END_SEGMENT.
char theCountry[COUNTRY_SIZE+1]
FIELD: COUNTRY.
char theMissionNumber[MISSION_NO_SIZE+1]
FIELD: MISSION_NO.
char theReserved1[RESERVED_1_SIZE+1]
FIELD: RESERVED_1.
char theOpNum[OP_NUM_SIZE+1]
FIELD: OP_NUM.
char theCurrentSegment[CURRENT_SEGMENT_SIZE+1]
char theStartTileColumn[START_TILE_COLUMN_SIZE+1]
char theAcquisitionDate[ACQUISITION_DATE_SIZE+1]
char theMissionIdentification[MISSION_IDENTIFICATION_SIZE+1]
char theFlightNo[FLIGHT_NO_SIZE+1]
FIELD: FLIGHT_NO.
char theTileColumn[END_TILE_COLUMN_SIZE+1]
char theReproNum[REPRO_NUM_SIZE+1]
FIELD: REPRO_NUM.
char theStartTileRow[START_TILE_ROW_SIZE+1]
char theTileRow[END_TILE_ROW_SIZE+1]
◆ parseStream()
void ossimNitfAimidbTag::parseStream ( ossim::istream in)
virtual
Implements ossimNitfRegisteredTag.
Definition at line 37 of file ossimNitfAimidbTag.cpp.
References ACQUISITION_DATE_SIZE, clearFields(), COUNTRY_SIZE, CURRENT_SEGMENT_SIZE, END_SEGMENT_SIZE, END_TILE_COLUMN_SIZE, END_TILE_ROW_SIZE, FLIGHT_NO_SIZE, LOCATION_SIZE, MISSION_IDENTIFICATION_SIZE, MISSION_NO_SIZE, OP_NUM_SIZE, REPLAY_SIZE, REPRO_NUM_SIZE, RESERVED_1_SIZE, RESERVED_2_SIZE, RESERVED_3_SIZE, START_TILE_COLUMN_SIZE, START_TILE_ROW_SIZE, theAcquisitionDate, theCountry, theCurrentSegment, theEndSegment, theFlightNo, theLocation, theMissionIdentification, theMissionNumber, theOpNum, theReplay, theReproNum, theReserved1, theReserved2, theReserved3, theStartTileColumn, theStartTileRow, theTileColumn, and theTileRow.
38 {
39  clearFields();
40
44  in.read(theFlightNo, FLIGHT_NO_SIZE);
45  in.read(theOpNum, OP_NUM_SIZE);
47  in.read(theReproNum, REPRO_NUM_SIZE);
48  in.read(theReplay, REPLAY_SIZE);
49  in.read(theReserved1, RESERVED_1_SIZE);
54  in.read(theTileRow, END_TILE_ROW_SIZE);
55  in.read(theCountry, COUNTRY_SIZE);
56  in.read(theReserved2, RESERVED_2_SIZE);
57  in.read(theLocation, LOCATION_SIZE);
58  in.read(theReserved3, RESERVED_3_SIZE);
59 }
FIELD: LOCATION.
FIELD: RESERVED_3.
FIELD: REPLAY.
FIELD: RESERVED_2.
FIELD: END_SEGMENT.
FIELD: COUNTRY.
FIELD: MISSION_NO.
FIELD: RESERVED_1.
FIELD: OP_NUM.
FIELD: FLIGHT_NO.
FIELD: REPRO_NUM.
◆ print()
std::ostream & ossimNitfAimidbTag::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Reimplemented from ossimNitfRegisteredTag.
Definition at line 128 of file ossimNitfAimidbTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theAcquisitionDate, theCountry, theCurrentSegment, theEndSegment, theFlightNo, theLocation, theMissionIdentification, theMissionNumber, theOpNum, theReplay, theReproNum, theStartTileColumn, theStartTileRow, theTileColumn, and theTileRow.
130 {
131  std::string pfx = prefix;
132  pfx += getTagName();
133  pfx += ".";
134
135  out << setiosflags(std::ios::left)
136  << pfx << std::setw(24) << "CETAG:"
137  << getTagName() << "\n"
138  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
139  << pfx << std::setw(24) << "ACQUISITION_DATE:"
140  << theAcquisitionDate << "\n"
141  << pfx << std::setw(24) << "MISSION_NO:"
142  << theMissionNumber << "\n"
143  << pfx << std::setw(24) << "MISSION_IDENTIFICATION:"
144  << theMissionIdentification<< "\n"
145  << pfx << std::setw(24) << "FLIGHT_NO:"
146  << theFlightNo << "\n"
147  << pfx << std::setw(24) << "OP_NUM:"
148  << theOpNum << "\n"
149  << pfx << std::setw(24) << "CURRENT_SEGMENT:"
150  << theCurrentSegment << "\n"
151  << pfx << std::setw(24) << "REPRO_NUM:"
152  << theReproNum<< "\n"
153  << pfx << std::setw(24) << "REPLAY:"
154  << theReplay<< "\n"
155  << pfx << std::setw(24) << "START_TILE_COLUMN:"
156  << theStartTileColumn << "\n"
157  << pfx << std::setw(24) << "START_TILE_ROW:"
158  << theStartTileRow << "\n"
159  << pfx << std::setw(24) << "END_SEGMENT:"
160  << theEndSegment << "\n"
161  << pfx << std::setw(24) << "END_TILE_COLUMN:"
162  << theTileColumn << "\n"
163  << pfx << std::setw(24) << "END_TILE_ROW:"
164  << theTileRow << "\n"
165  << pfx << std::setw(24) << "COUNTRY:"
166  << theCountry << "\n"
167  << pfx << std::setw(24) << "LOCATION:"
168  << theLocation << "\n";
169
170  return out;
171 }
virtual const std::string & getTagName() const
FIELD: LOCATION.
FIELD: REPLAY.
virtual ossim_uint32 getTagLength() const
FIELD: END_SEGMENT.
FIELD: COUNTRY.
FIELD: MISSION_NO.
FIELD: OP_NUM.
FIELD: FLIGHT_NO.
FIELD: REPRO_NUM.
◆ writeStream()
void ossimNitfAimidbTag::writeStream ( ossim::ostream out)
virtual
Definition at line 61 of file ossimNitfAimidbTag.cpp.
62 {
66  out.write(theFlightNo, FLIGHT_NO_SIZE);
67  out.write(theOpNum, OP_NUM_SIZE);
69  out.write(theReproNum, REPRO_NUM_SIZE);
70  out.write(theReplay, REPLAY_SIZE);
71  out.write(theReserved1, RESERVED_1_SIZE);
74  out.write(theEndSegment, END_SEGMENT_SIZE);
76  out.write(theTileRow, END_TILE_ROW_SIZE);
77  out.write(theCountry, COUNTRY_SIZE);
78  out.write(theReserved2, RESERVED_2_SIZE);
79  out.write(theLocation, LOCATION_SIZE);
80  out.write(theReserved3, RESERVED_3_SIZE);
81 }
FIELD: LOCATION.
FIELD: RESERVED_3.
FIELD: REPLAY.
FIELD: RESERVED_2.
FIELD: END_SEGMENT.
FIELD: COUNTRY.
FIELD: MISSION_NO.
FIELD: RESERVED_1.
FIELD: OP_NUM.
FIELD: FLIGHT_NO.
FIELD: REPRO_NUM.
Member Data Documentation
◆ theAcquisitionDate
char ossimNitfAimidbTag::theAcquisitionDate[ACQUISITION_DATE_SIZE+1]
protected
FIELD: ACQUISITION_DATE
TYPE: R
14 byte field
CCYYMMDDhhmmss
Definition at line 86 of file ossimNitfAimidbTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
◆ theCountry
char ossimNitfAimidbTag::theCountry[COUNTRY_SIZE+1]
protected
FIELD: COUNTRY.
TYPE: <R>
2 byte field
Country Code, AA to ZZ
Definition at line 240 of file ossimNitfAimidbTag.h.
◆ theCurrentSegment
char ossimNitfAimidbTag::theCurrentSegment[CURRENT_SEGMENT_SIZE+1]
protected
TYPE: R
2 byte field
Current Segment ID, AA to ZZ
Definition at line 141 of file ossimNitfAimidbTag.h.
◆ theEndSegment
char ossimNitfAimidbTag::theEndSegment[END_SEGMENT_SIZE+1]
protected
FIELD: END_SEGMENT.
TYPE: R
2 byte field
Ending Segment, 00, AA to ZZ
Definition at line 207 of file ossimNitfAimidbTag.h.
◆ theFlightNo
char ossimNitfAimidbTag::theFlightNo[FLIGHT_NO_SIZE+1]
protected
FIELD: FLIGHT_NO.
TYPE: R
2 byte field
Flight Number
Definition at line 119 of file ossimNitfAimidbTag.h.
◆ theLocation
char ossimNitfAimidbTag::theLocation[LOCATION_SIZE+1]
protected
FIELD: LOCATION.
TYPE: <R>
11 byte field
Location, ddmmXdddmmY, spaces
Definition at line 262 of file ossimNitfAimidbTag.h.
◆ theMissionIdentification
char ossimNitfAimidbTag::theMissionIdentification[MISSION_IDENTIFICATION_SIZE+1]
protected
TYPE: R
10 byte field
Name of the Mission.
Definition at line 108 of file ossimNitfAimidbTag.h.
◆ theMissionNumber
char ossimNitfAimidbTag::theMissionNumber[MISSION_NO_SIZE+1]
protected
FIELD: MISSION_NO.
TYPE: R
4 byte field
Mission Number
Definition at line 97 of file ossimNitfAimidbTag.h.
◆ theOpNum
char ossimNitfAimidbTag::theOpNum[OP_NUM_SIZE+1]
protected
FIELD: OP_NUM.
TYPE: R
3 byte field
Image Operation Number 000 to 999
Definition at line 130 of file ossimNitfAimidbTag.h.
◆ theReplay
char ossimNitfAimidbTag::theReplay[REPLAY_SIZE+1]
protected
FIELD: REPLAY.
TYPE: <R>
3 byte field
Replay
Definition at line 163 of file ossimNitfAimidbTag.h.
◆ theReproNum
char ossimNitfAimidbTag::theReproNum[REPRO_NUM_SIZE+1]
protected
FIELD: REPRO_NUM.
TYPE: R
2 byte field
Reprocess Number, 00 to 99
Definition at line 152 of file ossimNitfAimidbTag.h.
◆ theReserved1
char ossimNitfAimidbTag::theReserved1[RESERVED_1_SIZE+1]
protected
FIELD: RESERVED_1.
TYPE: R
1 byte field
1 space
Definition at line 174 of file ossimNitfAimidbTag.h.
Referenced by clearFields(), parseStream(), and writeStream().
◆ theReserved2
char ossimNitfAimidbTag::theReserved2[RESERVED_2_SIZE+1]
protected
FIELD: RESERVED_2.
TYPE: R
4 byte field
4 spaces
Definition at line 251 of file ossimNitfAimidbTag.h.
◆ theReserved3
char ossimNitfAimidbTag::theReserved3[RESERVED_3_SIZE+1]
protected
FIELD: RESERVED_3.
TYPE: R
13 byte field
13 spaces
Definition at line 273 of file ossimNitfAimidbTag.h.
◆ theStartTileColumn
char ossimNitfAimidbTag::theStartTileColumn[START_TILE_COLUMN_SIZE+1]
protected
TYPE: R
3 byte field
Starting Tile Column Number, 001 to 099
Definition at line 185 of file ossimNitfAimidbTag.h.
◆ theStartTileRow
char ossimNitfAimidbTag::theStartTileRow[START_TILE_ROW_SIZE+1]
protected
TYPE: R
5 byte field
Starting Tile Row Number, 00001 to 99999
Definition at line 196 of file ossimNitfAimidbTag.h.
◆ theTileColumn
char ossimNitfAimidbTag::theTileColumn[END_TILE_COLUMN_SIZE+1]
protected
TYPE: R
3 byte field
Ending Tile Column Number, 001 to 099
Definition at line 218 of file ossimNitfAimidbTag.h.
◆ theTileRow
char ossimNitfAimidbTag::theTileRow[END_TILE_ROW_SIZE+1]
protected
TYPE: R
5 byte field
Ending Tile Row Number, 00001 to 99999
Definition at line 229 of file ossimNitfAimidbTag.h.
