Public Types | Public Member Functions | Protected Attributes | List of all members
ossimNitfCsccgaTag Class Reference
All comments in this document were taken from the online resource found at: More...
#include <ossimNitfCsccgaTag.h>
Inheritance diagram for ossimNitfCsccgaTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Public Types
enum  {
  CCG_SOURCE_SIZE = 18, REG_SENSOR_SIZE = 6, ORIGIN_LINE_SIZE = 7, ORIGIN_SAMPLE_SIZE = 5,
  AS_CELL_SIZE_SIZE = 7, CS_CELL_SIZE_SIZE = 5, CCG_MAX_LINE_SIZE = 7, CCG_MAX_SAMPLE_SIZE = 5,
  CEL_SIZE = 60
 ossimNitfCsccgaTag ()
virtual void parseStream (ossim::istream &in)
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Pure virtual print method that outputs a key/value type format adding prefix to keys. More...
virtual void clearFields ()
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 default constructor More...
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char m_ccgSource [CCG_SOURCE_SIZE+1]
 Field: CCG_SOURCE. More...
char m_regSensor [REG_SENSOR_SIZE+1]
Field: REG_SENSOR More...
char m_originLine [ORIGIN_LINE_SIZE+1]
 Field: ORIGIN_LINE. More...
char m_originSample [ORIGIN_SAMPLE_SIZE+1]
 Field: ORIGIN_SAMPLE. More...
char m_asCellSize [AS_CELL_SIZE_SIZE+1]
 Field: AS_CELL_SIZE. More...
char m_csCellSize [CS_CELL_SIZE_SIZE+1]
 Field: CS_CELL_SIZE. More...
char m_ccgMaxLine [CCG_MAX_LINE_SIZE+1]
 Field: CCG_MAX_LINE. More...
char m_ccgMaxSample [CCG_MAX_SAMPLE_SIZE+1]
 Field: CCG_MAX_SAMPLE. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
http://jitc.fhu.disa.mil/nitf/tag_reg
The Cloud Cover Grid Data TRE (CSCCGA) provides support data that identifies which image segment and sensors were used to create the cloud grid. CSCCGA also geometrically registers the cloud grid to the pixel grid of one of the image segments.
  1. The format and content of the CSCCGA TRE shall be as detailed in Table 3.1-1.
  2. When cloud cover information is included in the dataset (see Section 2.1.4.2 for an exception) both the CSCCGA TRE and the Cloud Cover Shapefile DES (Section 2.6.2) shall be included in each dataset even though they both express similar information.
Definition at line 27 of file ossimNitfCsccgaTag.h.
◆ anonymous enum
anonymous enum
◆ ossimNitfCsccgaTag()
ossimNitfCsccgaTag::ossimNitfCsccgaTag ( )
Definition at line 15 of file ossimNitfCsccgaTag.cpp.
References clearFields().
16  : ossimNitfRegisteredTag(std::string("CSCCGA"), CEL_SIZE)
17 {
18  clearFields();
19 }
ossimNitfRegisteredTag()
default constructor
virtual void clearFields()
Member Function Documentation
◆ clearFields()
void ossimNitfCsccgaTag::clearFields ( )
virtual
Definition at line 67 of file ossimNitfCsccgaTag.cpp.
References AS_CELL_SIZE_SIZE, CCG_MAX_LINE_SIZE, CCG_MAX_SAMPLE_SIZE, CCG_SOURCE_SIZE, CS_CELL_SIZE_SIZE, m_asCellSize, m_ccgMaxLine, m_ccgMaxSample, m_ccgSource, m_csCellSize, m_originLine, m_originSample, m_regSensor, ORIGIN_LINE_SIZE, ORIGIN_SAMPLE_SIZE, and REG_SENSOR_SIZE.
Referenced by ossimNitfCsccgaTag().
68 {
69  memset(m_ccgSource,' ', CCG_SOURCE_SIZE);
70  memset(m_regSensor, ' ', REG_SENSOR_SIZE);
71  memset(m_originLine, 0, ORIGIN_LINE_SIZE);
73  memset(m_asCellSize, 0, AS_CELL_SIZE_SIZE);
74  memset(m_csCellSize, 0, CS_CELL_SIZE_SIZE);
75  memset(m_ccgMaxLine, 0, CCG_MAX_LINE_SIZE);
77
86 }
char m_originLine[ORIGIN_LINE_SIZE+1]
Field: ORIGIN_LINE.
char m_ccgMaxSample[CCG_MAX_SAMPLE_SIZE+1]
char m_regSensor[REG_SENSOR_SIZE+1]
Field: REG_SENSOR
char m_asCellSize[AS_CELL_SIZE_SIZE+1]
char m_originSample[ORIGIN_SAMPLE_SIZE+1]
char m_csCellSize[CS_CELL_SIZE_SIZE+1]
char m_ccgMaxLine[CCG_MAX_LINE_SIZE+1]
char m_ccgSource[CCG_SOURCE_SIZE+1]
Field: CCG_SOURCE.
◆ parseStream()
void ossimNitfCsccgaTag::parseStream ( ossim::istream in)
virtual
Implements ossimNitfRegisteredTag.
Definition at line 21 of file ossimNitfCsccgaTag.cpp.
22 {
23  in.read(m_ccgSource, CCG_SOURCE_SIZE);
24  in.read(m_regSensor, REG_SENSOR_SIZE);
31 }
Field: ORIGIN_LINE.
Field: REG_SENSOR
Field: CCG_SOURCE.
◆ print()
std::ostream & ossimNitfCsccgaTag::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
virtual
Reimplemented from ossimNitfRegisteredTag.
Definition at line 45 of file ossimNitfCsccgaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), m_asCellSize, m_ccgMaxLine, m_ccgMaxSample, m_ccgSource, m_csCellSize, m_originLine, m_originSample, and m_regSensor.
47 {
48  std::string pfx = prefix;
49  pfx += getTagName();
50  pfx += ".";
51  out << setiosflags(ios::left)
52  << pfx << std::setw(24) << "CETAG:" << getTagName() << "\n"
53  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
54  << pfx << std::setw(24) << "CCG_SOURCE:" << m_ccgSource << "\n"
55  << pfx << std::setw(24) << "CCG_SOURCE:" << m_regSensor << "\n"
56  << pfx << std::setw(24) << "ORIGIN_LINE:" << m_originLine << "\n"
57  << pfx << std::setw(24) << "ORIGIN_SAMPLE:" << m_originSample << "\n"
58  << pfx << std::setw(24) << "AS_CELL_SIZE:" << m_asCellSize << "\n"
59  << pfx << std::setw(24) << "CS_CELL_SIZE:" << m_csCellSize << "\n"
60  << pfx << std::setw(24) << "CCG_MAX_LINE:" << m_ccgMaxLine << "\n"
61  << pfx << std::setw(24) << "CCG_MAX_SAMPLE:" << m_ccgMaxSample << "\n";
62
63
64  return out;
65 }
virtual const std::string & getTagName() const
Field: ORIGIN_LINE.
Field: REG_SENSOR
virtual ossim_uint32 getTagLength() const
Field: CCG_SOURCE.
◆ writeStream()
void ossimNitfCsccgaTag::writeStream ( ossim::ostream out)
virtual
Definition at line 33 of file ossimNitfCsccgaTag.cpp.
34 {
35  out.write(m_ccgSource, CCG_SOURCE_SIZE);
36  out.write(m_regSensor, REG_SENSOR_SIZE);
37  out.write(m_originLine, ORIGIN_LINE_SIZE);
39  out.write(m_asCellSize, AS_CELL_SIZE_SIZE);
40  out.write(m_csCellSize, CS_CELL_SIZE_SIZE);
41  out.write(m_ccgMaxLine, CCG_MAX_LINE_SIZE);
43 }
Field: ORIGIN_LINE.
Field: REG_SENSOR
Field: CCG_SOURCE.
Member Data Documentation
◆ m_asCellSize
char ossimNitfCsccgaTag::m_asCellSize[AS_CELL_SIZE_SIZE+1]
protected
BCS-N 7 bytes
Value Range: 0000001 - 9999999
Along Scan Cell Size – Lines (Cloud Cover Grid spacing in registered image segment lines)
Definition at line 111 of file ossimNitfCsccgaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
◆ m_ccgMaxLine
char ossimNitfCsccgaTag::m_ccgMaxLine[CCG_MAX_LINE_SIZE+1]
protected
BCS-N 7 bytes
Number of Rows in CC Grid (Number of Cells in "lines" direction)
Definition at line 134 of file ossimNitfCsccgaTag.h.
◆ m_ccgMaxSample
char ossimNitfCsccgaTag::m_ccgMaxSample[CCG_MAX_SAMPLE_SIZE+1]
protected
BCS-N 5 bytes
Value Range: 00001 - 99999
Number of Columns in CC Grid (Number of Cells in "sample" direction)
Definition at line 145 of file ossimNitfCsccgaTag.h.
◆ m_ccgSource
char ossimNitfCsccgaTag::m_ccgSource[CCG_SOURCE_SIZE+1]
protected
Field: CCG_SOURCE.
BCS-A 18 byte field.
Values: PAN or MS or PAN, MS
Source of Grid Concatenation of all sensors used to create cloud cover grid separated by commas
Definition at line 63 of file ossimNitfCsccgaTag.h.
◆ m_csCellSize
char ossimNitfCsccgaTag::m_csCellSize[CS_CELL_SIZE_SIZE+1]
protected
BCS-N 5 bytes
Cross Scan Cell Size – Samples (Cloud Cover Grid spacing in registered image segment samples)
Definition at line 123 of file ossimNitfCsccgaTag.h.
◆ m_originLine
char ossimNitfCsccgaTag::m_originLine[ORIGIN_LINE_SIZE+1]
protected
Field: ORIGIN_LINE.
BCS-N 7 bytes.
Values: 0000001
Cloud Cover Grid Origin – Line (Corresponding line in registered image segment)
Definition at line 87 of file ossimNitfCsccgaTag.h.
◆ m_originSample
char ossimNitfCsccgaTag::m_originSample[ORIGIN_SAMPLE_SIZE+1]
protected
BCS-N 5 bytes
Values: 00001
Cloud Cover Grid Origin – Sample (Corresponding sample in registered image segment)
Definition at line 99 of file ossimNitfCsccgaTag.h.
◆ m_regSensor
char ossimNitfCsccgaTag::m_regSensor[REG_SENSOR_SIZE+1]
protected
Field: REG_SENSOR
BCS-A 6 bytes.
Values: PAN or MS
Image Segment Sensor to which Cloud Cover Grid is registered (CCG is always registered to the synthetic array)
Definition at line 75 of file ossimNitfCsccgaTag.h.
