Public Member Functions | Protected Attributes | List of all members
ossimNitfCscrnaTag Class Reference
#include <ossimNitfCscrnaTag.h>
Inheritance diagram for ossimNitfCscrnaTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
 ossimNitfCscrnaTag ()
 default constructor More...
virtual ~ossimNitfCscrnaTag ()
 destructor More...
virtual void parseStream (std::istream &in)
 Method to parse data from stream. More...
virtual void writeStream (std::ostream &out)
 Method to write data to stream. More...
virtual void clearFields ()
 Method to clear all fields including null terminating. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix) const
 Print method that outputs a key/value type format adding prefix to keys. More...
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char thePredictedCornerFlag [2]
 FIELD: PREDICT_CORNERS. More...
char theUlLat [10]
 FIELD: ULCRN_LAT. More...
char theUlLon [11]
 FIELD: ULCRN_LON. More...
char theUlHt [9]
 FIELD: ULCRN_HT. More...
char theUrLat [10]
 FIELD: URCRN_LAT. More...
char theUrLon [11]
 FIELD: URCRN_LON. More...
char theUrHt [9]
 FIELD: URCRN_HT. More...
char theLrLat [10]
 FIELD: LRCRN_LAT. More...
char theLrLon [11]
 FIELD: LRCRN_LON. More...
char theLrHt [9]
 FIELD: LRCRN_HT. More...
char theLlLat [10]
 FIELD: LLCRN_LAT. More...
char theLlLon [11]
 FIELD: LLCRN_LON. More...
char theLlHt [9]
 FIELD: LLCRN_HT. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 22 of file ossimNitfCscrnaTag.h.
◆ ossimNitfCscrnaTag()
ossimNitfCscrnaTag::ossimNitfCscrnaTag ( )
default constructor
Definition at line 28 of file ossimNitfCscrnaTag.cpp.
References clearFields().
29  : ossimNitfRegisteredTag(std::string("CSCRNA"), 109)
30 {
31  clearFields();
32 }
ossimNitfRegisteredTag()
default constructor
virtual void clearFields()
◆ ~ossimNitfCscrnaTag()
ossimNitfCscrnaTag::~ossimNitfCscrnaTag ( )
virtual
destructor
Definition at line 34 of file ossimNitfCscrnaTag.cpp.
35 {
36 }
Member Function Documentation
◆ clearFields()
void ossimNitfCscrnaTag::clearFields ( )
virtual
Definition at line 82 of file ossimNitfCscrnaTag.cpp.
References theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
Referenced by ossimNitfCscrnaTag(), and parseStream().
83 {
84  // BCS-N's to '0's, BCS-A's to ' '(spaces)
85  memset(thePredictedCornerFlag, ' ', 1);
86
87  memset(theUlLat, 0, 9);
88  memset(theUlLon, 0, 10);
89  memset(theUlHt, 0, 8);
90
91  memset(theUrLat, 0, 9);
92  memset(theUrLon, 0, 10);
93  memset(theUrHt, 0, 8);
94
95  memset(theLrLat, 0, 9);
96  memset(theLrLon, 0, 10);
97  memset(theLrHt, 0, 8);
98
99  memset(theLlLat, 0, 9);
100  memset(theLlLon, 0, 10);
101  memset(theLlHt, 0, 8);
102
103  thePredictedCornerFlag[1] = '\0';
104
105  theUlLat[9] = '\0';
106  theUlLon[10] = '\0';
107  theUlHt[8] = '\0';
108
109  theUrLat[9] = '\0';
110  theUrLon[10] = '\0';
111  theUrHt[8] = '\0';
112
113  theLrLat[9] = '\0';
114  theLrLon[10] = '\0';
115  theLrHt[8] = '\0';
116
117  theLlLat[9] = '\0';
118  theLlLon[10] = '\0';
119  theLlHt[8] = '\0';
120 }
char theLrLon[11]
FIELD: LRCRN_LON.
char theUlHt[9]
FIELD: ULCRN_HT.
char thePredictedCornerFlag[2]
char theLlLon[11]
FIELD: LLCRN_LON.
char theLlHt[9]
FIELD: LLCRN_HT.
char theUlLat[10]
FIELD: ULCRN_LAT.
char theUlLon[11]
FIELD: ULCRN_LON.
char theUrHt[9]
FIELD: URCRN_HT.
char theUrLat[10]
FIELD: URCRN_LAT.
char theLlLat[10]
FIELD: LLCRN_LAT.
char theUrLon[11]
FIELD: URCRN_LON.
char theLrLat[10]
FIELD: LRCRN_LAT.
char theLrHt[9]
FIELD: LRCRN_HT.
◆ parseStream()
void ossimNitfCscrnaTag::parseStream ( std::istream &  in)
virtual
Definition at line 38 of file ossimNitfCscrnaTag.cpp.
References clearFields(), theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
39 {
40  clearFields();
41
42  in.read(thePredictedCornerFlag, 1);
43
44  in.read(theUlLat, 9);
45  in.read(theUlLon, 10);
46  in.read(theUlHt, 8);
47
48  in.read(theUrLat, 9);
49  in.read(theUrLon, 10);
50  in.read(theUrHt, 8);
51
52  in.read(theLrLat, 9);
53  in.read(theLrLon, 10);
54  in.read(theLrHt, 8);
55
56  in.read(theLlLat, 9);
57  in.read(theLlLon, 10);
58  in.read(theLlHt, 8);
59 }
char theLrLon[11]
FIELD: LRCRN_LON.
char theUlHt[9]
FIELD: ULCRN_HT.
char theLlLon[11]
FIELD: LLCRN_LON.
char theLlHt[9]
FIELD: LLCRN_HT.
char theUlLat[10]
FIELD: ULCRN_LAT.
char theUlLon[11]
FIELD: ULCRN_LON.
char theUrHt[9]
FIELD: URCRN_HT.
char theUrLat[10]
FIELD: URCRN_LAT.
char theLlLat[10]
FIELD: LLCRN_LAT.
char theUrLon[11]
FIELD: URCRN_LON.
char theLrLat[10]
FIELD: LRCRN_LAT.
char theLrHt[9]
FIELD: LRCRN_HT.
◆ print()
std::ostream & ossimNitfCscrnaTag::print ( std::ostream &  out,
const std::string &  prefix
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Reimplemented from ossimNitfRegisteredTag.
Definition at line 122 of file ossimNitfCscrnaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
124 {
125  std::string pfx = prefix;
126  pfx += getTagName();
127  pfx += ".";
128
129  out << setiosflags(std::ios::left)
130  << pfx << std::setw(24) << "CETAG:"
131  << getTagName() << "\n"
132  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
133
134  << pfx << std::setw(24) << "PREDICT_CORNERS:"
135  << thePredictedCornerFlag << "\n"
136
137  << pfx << std::setw(24) << "ULCRN_LAT:" << theUlLat << "\n"
138  << pfx << std::setw(24) << "ULCRN_LON:" << theUlLon << "\n"
139  << pfx << std::setw(24) << "ULCRN_HT:" << theUlHt << "\n"
140
141  << pfx << std::setw(24) << "URCRN_LAT:" << theUrLat << "\n"
142  << pfx << std::setw(24) << "URCRN_LON:" << theUrLon << "\n"
143  << pfx << std::setw(24) << "URCRN_HT:" << theUrHt << "\n"
144
145  << pfx << std::setw(24) << "LRCRN_LAT:" << theLrLat << "\n"
146  << pfx << std::setw(24) << "LRCRN_LON:" << theLrLon << "\n"
147  << pfx << std::setw(24) << "LRCRN_HT:" << theLrHt << "\n"
148
149  << pfx << std::setw(24) << "LLCRN_LAT:" << theLlLat << "\n"
150  << pfx << std::setw(24) << "LLCRN_LON:" << theLlLon << "\n"
151  << pfx << std::setw(24) << "LLCRN_HT:" << theLlHt << "\n";
152
153  return out;
154 }
virtual const std::string & getTagName() const
char theLrLon[11]
FIELD: LRCRN_LON.
char theUlHt[9]
FIELD: ULCRN_HT.
char theLlLon[11]
FIELD: LLCRN_LON.
char theLlHt[9]
FIELD: LLCRN_HT.
virtual ossim_uint32 getTagLength() const
char theUlLat[10]
FIELD: ULCRN_LAT.
char theUlLon[11]
FIELD: ULCRN_LON.
char theUrHt[9]
FIELD: URCRN_HT.
char theUrLat[10]
FIELD: URCRN_LAT.
char theLlLat[10]
FIELD: LLCRN_LAT.
char theUrLon[11]
FIELD: URCRN_LON.
char theLrLat[10]
FIELD: LRCRN_LAT.
char theLrHt[9]
FIELD: LRCRN_HT.
◆ writeStream()
void ossimNitfCscrnaTag::writeStream ( std::ostream &  out)
virtual
Definition at line 61 of file ossimNitfCscrnaTag.cpp.
62 {
63  out.write(thePredictedCornerFlag, 1);
64
65  out.write(theUlLat, 9);
66  out.write(theUlLon, 10);
67  out.write(theUlHt, 8);
68
69  out.write(theUrLat, 9);
70  out.write(theUrLon, 10);
71  out.write(theUrHt, 8);
72
73  out.write(theLrLat, 9);
74  out.write(theLrLon, 10);
75  out.write(theLrHt, 8);
76
77  out.write(theLlLat, 9);
78  out.write(theLlLon, 10);
79  out.write(theLlHt, 8);
80 }
char theLrLon[11]
FIELD: LRCRN_LON.
char theUlHt[9]
FIELD: ULCRN_HT.
char theLlLon[11]
FIELD: LLCRN_LON.
char theLlHt[9]
FIELD: LLCRN_HT.
char theUlLat[10]
FIELD: ULCRN_LAT.
char theUlLon[11]
FIELD: ULCRN_LON.
char theUrHt[9]
FIELD: URCRN_HT.
char theUrLat[10]
FIELD: URCRN_LAT.
char theLlLat[10]
FIELD: LLCRN_LAT.
char theUrLon[11]
FIELD: URCRN_LON.
char theLrLat[10]
FIELD: LRCRN_LAT.
char theLrHt[9]
FIELD: LRCRN_HT.
Member Data Documentation
◆ theLlHt
char ossimNitfCscrnaTag::theLlHt[9]
protected
FIELD: LLCRN_HT.
8 byte field BCS-N Meters
Height referenced to the reference ellipsoid.
-00610.0 to +10668.0
Definition at line 179 of file ossimNitfCscrnaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
◆ theLlLat
char ossimNitfCscrnaTag::theLlLat[10]
protected
FIELD: LLCRN_LAT.
9 byte field BCS-N Degrees
-90.000000 ti +90.000000
Definition at line 159 of file ossimNitfCscrnaTag.h.
◆ theLlLon
char ossimNitfCscrnaTag::theLlLon[11]
protected
FIELD: LLCRN_LON.
10 byte field BCS-N Degrees
-179.999999 ti +180.000000
Definition at line 168 of file ossimNitfCscrnaTag.h.
◆ theLrHt
char ossimNitfCscrnaTag::theLrHt[9]
protected
FIELD: LRCRN_HT.
Definition at line 150 of file ossimNitfCscrnaTag.h.
◆ theLrLat
char ossimNitfCscrnaTag::theLrLat[10]
protected
FIELD: LRCRN_LAT.
Definition at line 130 of file ossimNitfCscrnaTag.h.
◆ theLrLon
char ossimNitfCscrnaTag::theLrLon[11]
protected
FIELD: LRCRN_LON.
Definition at line 139 of file ossimNitfCscrnaTag.h.
◆ thePredictedCornerFlag
char ossimNitfCscrnaTag::thePredictedCornerFlag[2]
protected
1 byte field BCS-A
Y = predicted, N = actual
Definition at line 63 of file ossimNitfCscrnaTag.h.
◆ theUlHt
char ossimNitfCscrnaTag::theUlHt[9]
protected
FIELD: ULCRN_HT.
Definition at line 92 of file ossimNitfCscrnaTag.h.
◆ theUlLat
char ossimNitfCscrnaTag::theUlLat[10]
protected
FIELD: ULCRN_LAT.
Definition at line 72 of file ossimNitfCscrnaTag.h.
◆ theUlLon
char ossimNitfCscrnaTag::theUlLon[11]
protected
FIELD: ULCRN_LON.
Definition at line 81 of file ossimNitfCscrnaTag.h.
◆ theUrHt
char ossimNitfCscrnaTag::theUrHt[9]
protected
FIELD: URCRN_HT.
Definition at line 121 of file ossimNitfCscrnaTag.h.
◆ theUrLat
char ossimNitfCscrnaTag::theUrLat[10]
protected
FIELD: URCRN_LAT.
Definition at line 101 of file ossimNitfCscrnaTag.h.
◆ theUrLon
char ossimNitfCscrnaTag::theUrLon[11]
protected
FIELD: URCRN_LON.
Definition at line 110 of file ossimNitfCscrnaTag.h.
