Public Member Functions | Static Public Attributes | Private Member Functions | Private Attributes | List of all members
ossimNitfDataExtensionSegmentV2_0 Class Reference
#include <ossimNitfDataExtensionSegmentV2_0.h>
Inheritance diagram for ossimNitfDataExtensionSegmentV2_0:
ossimNitfDataExtensionSegment ossimPropertyInterface ossimObject ossimReferenced
 ossimNitfDataExtensionSegmentV2_0 ()
virtual ~ossimNitfDataExtensionSegmentV2_0 ()
virtual void parseStream (std::istream &in, ossim_uint64 dataLength)
 Generic print method. More...
virtual const std::vector< ossimNitfTagInformation > & getTagList () const
ossimRefPtr< ossimPropertygetProperty (const ossimString &name) const
void getPropertyNames (std::vector< ossimString > &propertyNames) const
- Public Member Functions inherited from ossimNitfDataExtensionSegment
 ossimNitfDataExtensionSegment ()
virtual ~ossimNitfDataExtensionSegment ()
 ossimPropertyInterface ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static const ossimString DESTAG_KW = "destag"
static const ossimString DESDWNG_KW = "desdwng"
static const ossimString DESDEVT_KW = "desdevt"
- Static Public Attributes inherited from ossimNitfDataExtensionSegment
static const ossimString DE_KW
static const ossimString DESVER_KW
static const ossimString DESOFLW_KW = "desoflw"
static const ossimString DESITEM_KW = "desitem"
static const ossimString DESSHL_KW = "desshl"
static const ossimString DESSHF_KW = "desshf"
static const ossimString DESDATA_KW = "desdata"
static const ossimString DECLAS_KW = "declas"
static const ossimString DESCODE_KW = "descode"
static const ossimString DESCTLH_KW = "desctlh"
static const ossimString DESREL_KW = "desrel"
static const ossimString DESCAUT_KW = "descaut"
static const ossimString DESCTLN_KW = "desctln"
void clearFields ()
Private Attributes
ossimNitfDataExtIdentSecurityChunkV2_0 theIdentSecurityChunk
char theOverflowedHeaderType [7]
char theDataItemOverflowed [4]
char theLengthOfUserDefinedSubheaderFields [5]
std::vector< unsigned char > theUserDefinedSubheaderFields
std::vector< unsigned char > theData
std::vector< ossimNitfTagInformationtheTagList
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 34 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ ossimNitfDataExtensionSegmentV2_0()
ossimNitfDataExtensionSegmentV2_0::ossimNitfDataExtensionSegmentV2_0 ( )
◆ ~ossimNitfDataExtensionSegmentV2_0()
ossimNitfDataExtensionSegmentV2_0::~ossimNitfDataExtensionSegmentV2_0 ( )
virtual
Definition at line 48 of file ossimNitfDataExtensionSegmentV2_0.cpp.
49 {
50 }
Member Function Documentation
◆ clearFields()
void ossimNitfDataExtensionSegmentV2_0::clearFields ( )
private
Definition at line 115 of file ossimNitfDataExtensionSegmentV2_0.cpp.
References theData, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtClassAuthority, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtCodewords, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtControlAndHand, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtDowngradingEvent, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtReleasingInst, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityClass, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityConNum, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityDowngrade, theDataItemOverflowed, ossimNitfDataExtIdentSecurityChunkV2_0::theFilePartType, theIdentSecurityChunk, theLengthOfUserDefinedSubheaderFields, theOverflowedHeaderType, theTagList, ossimNitfDataExtIdentSecurityChunkV2_0::theUniqueDataExtTypeId, theUserDefinedSubheaderFields, and ossimNitfDataExtIdentSecurityChunkV2_0::theVersionDataFieldDef.
Referenced by ossimNitfDataExtensionSegmentV2_0(), and parseStream().
116 {
117
118  memset(theIdentSecurityChunk.theFilePartType, ' ', 2); // 2 byte alpha
119  memset(theIdentSecurityChunk.theUniqueDataExtTypeId, ' ', 25); // 25 byte alpha numeric
120  memset(theIdentSecurityChunk.theVersionDataFieldDef, ' ', 2); // 2 byte numeric
121  memset(theIdentSecurityChunk.theDataExtSecurityClass, ' ', 1); // 1 byte alpha
122  memset(theIdentSecurityChunk.theDataExtCodewords, ' ', 40); // 40 byte alpha numeric
123  memset(theIdentSecurityChunk.theDataExtControlAndHand, ' ', 40); // 40 byte alpha numeric
124  memset(theIdentSecurityChunk.theDataExtReleasingInst, ' ', 40); // 40 byte alpha numeric
125  memset(theIdentSecurityChunk.theDataExtClassAuthority, ' ', 20); // 20 byte alph num
126  memset(theIdentSecurityChunk.theDataExtSecurityConNum, ' ', 20); // 20 byte alpha num
127  memset(theIdentSecurityChunk.theDataExtSecurityDowngrade, ' ', 6); // 6 byte alpha num
128  memset(theIdentSecurityChunk.theDataExtDowngradingEvent, ' ', 40); // 40 byte alpha num
129  memset(theOverflowedHeaderType, ' ', 6);
130  memset(theDataItemOverflowed, ' ', 3);
132
133  theIdentSecurityChunk.theFilePartType[2] = '\0'; // 2 byte alpha
134  theIdentSecurityChunk.theUniqueDataExtTypeId[25] = '\0'; // 25 byte alpha numeric
135  theIdentSecurityChunk.theVersionDataFieldDef[2] = '\0'; // 2 byte numeric
136  theIdentSecurityChunk.theDataExtSecurityClass[1] = '\0'; // 1 byte alpha
137  theIdentSecurityChunk.theDataExtCodewords[40] = '\0'; // 40 byte alpha numeric
138  theIdentSecurityChunk.theDataExtControlAndHand[40] = '\0'; // 40 byte alpha numeric
139  theIdentSecurityChunk.theDataExtReleasingInst[40] = '\0'; // 40 byte alpha numeric
140  theIdentSecurityChunk.theDataExtClassAuthority[20] = '\0'; // 20 byte alph num
141  theIdentSecurityChunk.theDataExtSecurityConNum[20] = '\0'; // 20 byte alpha num
142  theIdentSecurityChunk.theDataExtSecurityDowngrade[6] = '\0'; // 6 byte alpha num
143  theIdentSecurityChunk.theDataExtDowngradingEvent[40] = '\0'; // 40 byte alpha num
144  theOverflowedHeaderType[6] = '\0';
145  theDataItemOverflowed[3] = '\0';
147
149  theData.clear();
150  theTagList.clear();
151 }
std::vector< ossimNitfTagInformation > theTagList
◆ getProperty()
ossimRefPtr< ossimProperty > ossimNitfDataExtensionSegmentV2_0::getProperty ( const ossimString name) const
virtual
Reimplemented from ossimPropertyInterface.
Definition at line 169 of file ossimNitfDataExtensionSegmentV2_0.cpp.
References ossimNitfDataExtensionSegment::DE_KW, ossimNitfDataExtensionSegment::DECLAS_KW, ossimNitfDataExtensionSegment::DESCAUT_KW, ossimNitfDataExtensionSegment::DESCODE_KW, ossimNitfDataExtensionSegment::DESCTLH_KW, ossimNitfDataExtensionSegment::DESCTLN_KW, ossimNitfDataExtensionSegment::DESDATA_KW, DESDEVT_KW, DESDWNG_KW, ossimNitfDataExtensionSegment::DESITEM_KW, ossimNitfDataExtensionSegment::DESOFLW_KW, ossimNitfDataExtensionSegment::DESREL_KW, ossimNitfDataExtensionSegment::DESSHF_KW, ossimNitfDataExtensionSegment::DESSHL_KW, DESTAG_KW, ossimNitfDataExtensionSegment::DESVER_KW, theData, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtClassAuthority, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtCodewords, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtControlAndHand, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtDowngradingEvent, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtReleasingInst, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityClass, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityConNum, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityDowngrade, theDataItemOverflowed, ossimNitfDataExtIdentSecurityChunkV2_0::theFilePartType, theIdentSecurityChunk, theLengthOfUserDefinedSubheaderFields, theOverflowedHeaderType, ossimNitfDataExtIdentSecurityChunkV2_0::theUniqueDataExtTypeId, theUserDefinedSubheaderFields, ossimNitfDataExtIdentSecurityChunkV2_0::theVersionDataFieldDef, and ossimString::trim().
170 {
171  ossimProperty* property = 0;
172  if (name == DE_KW)
173  {
175  }
176  else if (name == DESTAG_KW)
177  {
179  }
180  else if (name == DESVER_KW)
181  {
183  }
184  else if (name == DECLAS_KW)
185  {
187  }
188  else if (name == DESCODE_KW)
189  {
191  }
192  else if (name == DESCTLH_KW)
193  {
195  }
196  else if (name == DESREL_KW)
197  {
199  }
200  else if (name == DESCAUT_KW)
201  {
203  }
204  else if (name == DESCTLN_KW)
205  {
207  }
208  else if (name == DESDWNG_KW)
209  {
211  }
212  else if (name == DESDEVT_KW)
213  {
215  }
216  else if (name == DESOFLW_KW)
217  {
218  property = new ossimStringProperty(name, ossimString(theOverflowedHeaderType).trim());
219  }
220  else if (name == DESITEM_KW)
221  {
222  property = new ossimStringProperty(name, ossimString(theDataItemOverflowed).trim());
223  }
224  else if (name == DESSHL_KW)
225  {
227  }
228  else if (name == DESSHF_KW)
229  {
231  }
232  else if (name == DESDATA_KW)
233  {
234  // Only valid if setTagList has not been called on this object.
235  property = new ossimBinaryDataProperty(name, theData);
236  }
237
238  return property;
239 }
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
◆ getPropertyNames()
void ossimNitfDataExtensionSegmentV2_0::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Reimplemented from ossimNitfDataExtensionSegment.
Definition at line 241 of file ossimNitfDataExtensionSegmentV2_0.cpp.
References DESDEVT_KW, DESDWNG_KW, DESTAG_KW, and ossimNitfDataExtensionSegment::getPropertyNames().
242 {
244  propertyNames.push_back(DESTAG_KW);
245  propertyNames.push_back(DESDWNG_KW);
246  propertyNames.push_back(DESDEVT_KW);
247 }
◆ getTagList()
virtual const std::vector<ossimNitfTagInformation>& ossimNitfDataExtensionSegmentV2_0::getTagList ( ) const
inlinevirtual
Implements ossimNitfDataExtensionSegment.
Definition at line 41 of file ossimNitfDataExtensionSegmentV2_0.h.
42  {
43  return theTagList;
44  }
◆ parseStream()
void ossimNitfDataExtensionSegmentV2_0::parseStream ( std::istream &  in,
virtual
Definition at line 52 of file ossimNitfDataExtensionSegmentV2_0.cpp.
References clearFields(), ossimNitfTagInformation::parseStream(), theData, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtClassAuthority, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtCodewords, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtControlAndHand, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtDowngradingEvent, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtReleasingInst, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityClass, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityConNum, ossimNitfDataExtIdentSecurityChunkV2_0::theDataExtSecurityDowngrade, theDataItemOverflowed, ossimNitfDataExtIdentSecurityChunkV2_0::theFilePartType, theIdentSecurityChunk, theLengthOfUserDefinedSubheaderFields, theOverflowedHeaderType, theTagList, ossimNitfDataExtIdentSecurityChunkV2_0::theUniqueDataExtTypeId, theUserDefinedSubheaderFields, ossimNitfDataExtIdentSecurityChunkV2_0::theVersionDataFieldDef, ossimString::toLong(), ossimString::trim(), and ossimString::upcase().
53 {
54  if(in)
55  {
56  clearFields();
57
58  in.read(theIdentSecurityChunk.theFilePartType, 2); // 2 byte alpha
59  in.read(theIdentSecurityChunk.theUniqueDataExtTypeId, 25); // 25 byte alpha numeric
60  in.read(theIdentSecurityChunk.theVersionDataFieldDef, 2); // 2 byte numeric
61  in.read(theIdentSecurityChunk.theDataExtSecurityClass, 1); // 1 byte alpha
62  in.read(theIdentSecurityChunk.theDataExtCodewords, 40); // 40 byte alpha numeric
63  in.read(theIdentSecurityChunk.theDataExtControlAndHand, 40); // 40 byte alpha numeric
64  in.read(theIdentSecurityChunk.theDataExtReleasingInst, 40); // 40 byte alpha numeric
65  in.read(theIdentSecurityChunk.theDataExtClassAuthority, 20); // 20 byte alph num
66  in.read(theIdentSecurityChunk.theDataExtSecurityConNum, 20); // 20 byte alpha num
67  in.read(theIdentSecurityChunk.theDataExtSecurityDowngrade, 6); // 6 byte alpha num
69  {
70  in.read(theIdentSecurityChunk.theDataExtDowngradingEvent, 40); // 40 byte alpha num
71  }
72
75  desTag = desTag.trim().upcase();
76  const bool overflow = (desTag == "REGISTERED EXTENSIONS" ||
77  desTag == "CONTROLLED EXTENSIONS");
78
79  if (overflow&&in.good())
80  {
81  in.read(theOverflowedHeaderType, 6);
82  in.read(theDataItemOverflowed, 3);
83  }
85  // look to see if there is any data and if so read the tag
86  // to see what it is
88  if (length > 0)
89  {
90  theUserDefinedSubheaderFields.resize(length);
91  in.read(reinterpret_cast<char*>(&theUserDefinedSubheaderFields.front()), theUserDefinedSubheaderFields.size());
92  }
93
94  if (dataLength != 0)
95  {
96  if (overflow)
97  {
98  istream::pos_type dataBegin = in.tellg();
99  istream::pos_type endData = dataBegin + static_cast<istream::pos_type>(dataLength);
100  while (in.good()&&(in.tellg() < endData))
101  {
103  tag.parseStream(in);
104  theTagList.push_back(tag);
105  }
106  if(!in.good()) in.clear();
107  in.seekg(dataBegin);
108  }
109  theData.resize(dataLength);
110  in.read(reinterpret_cast<char*>(&theData.front()), theData.size());
111  }
112  }
113 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
virtual void parseStream(ossim::istream &in)
long toLong() const
toLong&#39;s deprecated, please use the toInts...
◆ print()
std::ostream & ossimNitfDataExtensionSegmentV2_0::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Definition at line 154 of file ossimNitfDataExtensionSegmentV2_0.cpp.
References theDataItemOverflowed, theIdentSecurityChunk, theLengthOfUserDefinedSubheaderFields, theOverflowedHeaderType, and theTagList.
155 {
156  out << "theIdentSecurityChunk: "
158  << "\ntheOverflowedHeaderType: "
160  << "\ntheDataItemOverflowed: "
162  << "\ntheLengthOfUserDefinedSubheaderFields: "
164  << "\ntag count: "
165  << theTagList.size() << std::endl;
166  return out;
167 }
Member Data Documentation
◆ DESDEVT_KW
const ossimString ossimNitfDataExtensionSegmentV2_0::DESDEVT_KW = "desdevt"
static
Definition at line 51 of file ossimNitfDataExtensionSegmentV2_0.h.
Referenced by getProperty(), and getPropertyNames().
◆ DESDWNG_KW
const ossimString ossimNitfDataExtensionSegmentV2_0::DESDWNG_KW = "desdwng"
static
Definition at line 50 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ DESTAG_KW
const ossimString ossimNitfDataExtensionSegmentV2_0::DESTAG_KW = "destag"
static
Definition at line 49 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ theData
std::vector<unsigned char> ossimNitfDataExtensionSegmentV2_0::theData
private
This is an n-byte field, where n is found in the file header.
Definition at line 81 of file ossimNitfDataExtensionSegmentV2_0.h.
Referenced by clearFields(), getProperty(), and parseStream().
◆ theDataItemOverflowed
char ossimNitfDataExtensionSegmentV2_0::theDataItemOverflowed[4]
private
This is a 3 byte field
Definition at line 66 of file ossimNitfDataExtensionSegmentV2_0.h.
Referenced by clearFields(), getProperty(), parseStream(), and print().
◆ theIdentSecurityChunk
ossimNitfDataExtIdentSecurityChunkV2_0 ossimNitfDataExtensionSegmentV2_0::theIdentSecurityChunk
private
Definition at line 56 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ theLengthOfUserDefinedSubheaderFields
char ossimNitfDataExtensionSegmentV2_0::theLengthOfUserDefinedSubheaderFields[5]
private
This is a 4 byte field.
Definition at line 71 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ theOverflowedHeaderType
char ossimNitfDataExtensionSegmentV2_0::theOverflowedHeaderType[7]
private
This is a 6 byte field
Definition at line 61 of file ossimNitfDataExtensionSegmentV2_0.h.
◆ theTagList
std::vector<ossimNitfTagInformation> ossimNitfDataExtensionSegmentV2_0::theTagList
private
Definition at line 83 of file ossimNitfDataExtensionSegmentV2_0.h.
Referenced by clearFields(), parseStream(), and print().
◆ theUserDefinedSubheaderFields
std::vector<unsigned char> ossimNitfDataExtensionSegmentV2_0::theUserDefinedSubheaderFields
private
This is an n-byte field, where n is theLengthOfUserDefinedSubheaderFields.
Definition at line 76 of file ossimNitfDataExtensionSegmentV2_0.h.
