| ossimNitfEmbeddedRpfDes () |
virtual void | parseStream (std::istream &in) |
virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Print method that outputs a key/value type format adding prefix to keys. More...
| ossimNitfRegisteredTag () |
| default constructor More...
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) |
| Constructor that takes name and size. More...
virtual | ~ossimNitfRegisteredTag () |
| destructor More...
virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More...
virtual const std::string & | getTagName () const |
virtual void | setTagName (const std::string &tagName) |
virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 | getTagLength () const |
virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More...
virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More...
virtual void | writeStream (ossim::ostream &out)=0 |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More...
virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
| Generic print method. More...
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
| ossimReferenced () |
| ossimReferenced (const ossimReferenced &) |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
| increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
void | unref () const |
| decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
void | unref_nodelete () const |
int | referenceCount () const |
| ossimPropertyInterface () |
virtual | ~ossimPropertyInterface () |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
Definition at line 20 of file ossimNitfEmbeddedRpfDes.h.
