Public Attributes | List of all members
ossimNitfEngrdaTag::ossimEngDataElement Class Reference
Container class for an Engineering Data Element Record. More...
#include <ossimNitfEngrdaTag.h>
Public Attributes
char m_engLn [ENGLN_SIZE+1]
 FIELD: ENGLN. More...
std::string m_engLbl
 FIELD: ENGLBL. More...
char m_engMtxC [ENGMTXC_SIZE+1]
 FIELD: ENGMTXC. More...
char m_engMtxR [ENGMTXR_SIZE+1]
 FIELD: ENGMTXR. More...
char m_engTyp
 FIELD: ENGTYP. More...
char m_engDts
 FIELD: ENGDTS. More...
char m_engDatU [ENGDATU_SIZE+1]
 FIELD: ENGDATU. More...
char m_engDatC [ENGDATC_SIZE+1]
 FIELD: ENGDATC. More...
std::vector< ossim_uint8m_engDat
 ENGDATA - data. More...
Detailed Description
Definition at line 69 of file ossimNitfEngrdaTag.h.
Member Data Documentation
◆ m_engDat
std::vector<ossim_uint8> ossimNitfEngrdaTag::ossimEngDataElement::m_engDat
ENGDATA - data.
Definition at line 160 of file ossimNitfEngrdaTag.h.
Referenced by ossimNitfEngrdaTag::parseStream(), and ossimNitfEngrdaTag::printData().
◆ m_engDatC
char ossimNitfEngrdaTag::ossimEngDataElement::m_engDatC[ENGDATC_SIZE+1]
FIELD: ENGDATC.
TYPE: BCS-N
8 byte field
Engineering Data Count
Definition at line 157 of file ossimNitfEngrdaTag.h.
Referenced by ossimNitfEngrdaTag::parseStream().
◆ m_engDatU
char ossimNitfEngrdaTag::ossimEngDataElement::m_engDatU[ENGDATU_SIZE+1]
FIELD: ENGDATU.
TYPE: BCS-A
2 byte field
Engineering Data Units
Definition at line 146 of file ossimNitfEngrdaTag.h.
◆ m_engDts
char ossimNitfEngrdaTag::ossimEngDataElement::m_engDts
FIELD: ENGDTS.
TYPE: BCS-N
1 byte field
Engineering Data Element Size
Definition at line 135 of file ossimNitfEngrdaTag.h.
◆ m_engLbl
std::string ossimNitfEngrdaTag::ossimEngDataElement::m_engLbl
FIELD: ENGLBL.
TYPE: BCS-A
Engineering Label - variable length
Definition at line 91 of file ossimNitfEngrdaTag.h.
◆ m_engLn
char ossimNitfEngrdaTag::ossimEngDataElement::m_engLn[ENGLN_SIZE+1]
FIELD: ENGLN.
TYPE: BCS-N
2 byte field
Engineering Data Label Length 01 - 99
Definition at line 82 of file ossimNitfEngrdaTag.h.
◆ m_engMtxC
char ossimNitfEngrdaTag::ossimEngDataElement::m_engMtxC[ENGMTXC_SIZE+1]
FIELD: ENGMTXC.
TYPE: BCS-N
4 byte field
Engineering Matrix Data Column Count 0001 - 9999
Definition at line 102 of file ossimNitfEngrdaTag.h.
◆ m_engMtxR
char ossimNitfEngrdaTag::ossimEngDataElement::m_engMtxR[ENGMTXR_SIZE+1]
FIELD: ENGMTXR.
TYPE: BCS-N
4 byte field
Engineering Matrix Data Row Count 0001 - 9999
Definition at line 113 of file ossimNitfEngrdaTag.h.
◆ m_engTyp
char ossimNitfEngrdaTag::ossimEngDataElement::m_engTyp
FIELD: ENGTYP.
TYPE: BCS
1 byte field
Value Type of Engineering Data Element
Definition at line 124 of file ossimNitfEngrdaTag.h.
The documentation for this class was generated from the following file:
