Classes | Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimNitfJ2klraTag Class Reference
#include <ossimNitfJ2klraTag.h>
Inheritance diagram for ossimNitfJ2klraTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Classes
class  ossimJ2klraLayer
Public Types
enum  {
  ORIG_SIZE = 1, NLEVELS_O_SIZE = 2, NBANDS_O_SIZE = 5, NLAYERS_O_SIZE = 3,
  LAYER_ID_SIZE = 3, BITRATE_SIZE = 9, NLEVELS_I_SIZE = 2, NBANDS_I_SIZE = 5,
  NLAYERS_I_SIZE = 3
 ossimNitfJ2klraTag ()
 default constructor More...
virtual void parseStream (std::istream &in)
 Parse method. More...
virtual void writeStream (std::ostream &out)
 Write method. More...
virtual ossim_uint32 getSizeInBytes () const
virtual void clearFields ()
 Clears all string fields within the record to some default nothingness. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix) const
 Print method that outputs a key/value type format adding prefix to keys. More...
ossim_uint32 getOriginNumber () const
ossim_uint32 getNumberOfLayersOriginal () const
bool setOrigin (ossim_uint32 origin)
 Sets origin: More...
bool setLevelsO (ossim_uint32 levels)
 Sets the number of wavelet levels in the original image. More...
bool setBandsO (ossim_uint32 bands)
 Sets the number of bands in the original image. More...
bool setLayersO (ossim_uint32 layers)
 Sets the number of layers in the original image. More...
bool setLevelsI (ossim_uint32 levels)
 Sets the number of wavelet levels in this image. More...
bool setBandsI (ossim_uint32 bands)
 Sets the number of bands in this image. More...
bool setLayersI (ossim_uint32 layers)
 Sets the number of layers in this image. More...
bool setLayerId (ossim_uint32 index, ossim_uint32 id)
 Sets the layer id for index. More...
bool setLayerBitRate (ossim_uint32 index, ossim_float64 bitRate)
 Sets the bitrate from index. More...
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getTagLength () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
bool isParsed () const
virtual ~ossimReferenced ()
char m_orig [ORIG_SIZE+1]
 FIELD: ORIG. More...
char m_levels_o [NLEVELS_O_SIZE+1]
 FIELD: NLEVELS_O required 2 bytes 00 - 32 Number of wavelet levels in original image. More...
char m_bands_o [NBANDS_O_SIZE+1]
 FIELD: NBANDS_O required 5 bytes 00000 - 16384 Number of bands in original image. More...
char m_layers_o [NLAYERS_O_SIZE+1]
 FIELD: NLAYERS_O required 3 bytes 000 - 999 Number of layers in original image. More...
std::vector< ossimJ2klraLayerm_layer
 repeating fields More...
char m_nlevels_i [NLEVELS_I_SIZE+1]
 FIELD: NLEVELS_I Conditional 2 bytes if ORIG=1, 3, or 9. More...
char m_nbands_i [NBANDS_I_SIZE+1]
 FIELD: NBANDS_I Conditional 5 bytes if ORIG=1, 3,or 9. More...
char m_nlayers_i [NLAYERS_I_SIZE+1]
 FIELD: NLAYERS_I Conditional 3 bytes if ORIG=1, 3, or 9. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Detailed Description
Definition at line 26 of file ossimNitfJ2klraTag.h.
◆ anonymous enum
anonymous enum
Enumerator
ORIG_SIZE
NLEVELS_O_SIZE
NBANDS_O_SIZE
NLAYERS_O_SIZE
LAYER_ID_SIZE
BITRATE_SIZE
NLEVELS_I_SIZE
NBANDS_I_SIZE
NLAYERS_I_SIZE
Definition at line 29 of file ossimNitfJ2klraTag.h.
◆ ossimNitfJ2klraTag()
ossimNitfJ2klraTag::ossimNitfJ2klraTag ( )
default constructor
Definition at line 30 of file ossimNitfJ2klraTag.cpp.
References clearFields().
31  : ossimNitfRegisteredTag(std::string("J2KLRA"), 0),
32  m_layer(1)
33 {
34  clearFields();
35 }
virtual void clearFields()
std::vector< ossimJ2klraLayer > m_layer
repeating fields
ossimNitfRegisteredTag()
default constructor
Member Function Documentation
◆ clearFields()
void ossimNitfJ2klraTag::clearFields ( )
virtual
Definition at line 114 of file ossimNitfJ2klraTag.cpp.
References m_bands_o, m_layer, m_layers_o, m_levels_o, m_nbands_i, m_nlayers_i, m_nlevels_i, m_orig, NBANDS_I_SIZE, NBANDS_O_SIZE, NLAYERS_I_SIZE, NLAYERS_O_SIZE, NLEVELS_I_SIZE, NLEVELS_O_SIZE, ORIG_SIZE, and ossimNitfRegisteredTag::setTagLength().
Referenced by ossimNitfJ2klraTag(), and parseStream().
115 {
116  memset(m_orig, 0, ORIG_SIZE);
117
118  memset(m_levels_o, 0, NLEVELS_O_SIZE);
119  memset(m_bands_o, 0, NBANDS_O_SIZE);
120  memset(m_layers_o, 0, NLAYERS_O_SIZE);
121
122  m_layer.clear();
123
124  memset(m_nlevels_i, 0, NLEVELS_I_SIZE);
125  memset(m_nbands_i, 0, NBANDS_I_SIZE);
126  memset(m_nlayers_i, 0, NLAYERS_I_SIZE);
127
128  m_orig[ORIG_SIZE]= '\0';
129
130  m_levels_o[NLEVELS_O_SIZE]= '\0';
131  m_bands_o[NBANDS_O_SIZE]= '\0';
132  m_layers_o[NLAYERS_O_SIZE]= '\0';
133
135  m_nbands_i[NBANDS_I_SIZE] = '\0';
136  m_nlayers_i[NLAYERS_I_SIZE] = '\0';
137
138  // Set the base tag length.
139  setTagLength( 0 );
140 }
char m_levels_o[NLEVELS_O_SIZE+1]
char m_orig[ORIG_SIZE+1]
FIELD: ORIG.
repeating fields
virtual void setTagLength(ossim_uint32 length)
Set the tag length.
char m_nbands_i[NBANDS_I_SIZE+1]
char m_bands_o[NBANDS_O_SIZE+1]
FIELD: NBANDS_O required 5 bytes 00000 - 16384 Number of bands in original image. ...
char m_layers_o[NLAYERS_O_SIZE+1]
char m_nlayers_i[NLAYERS_I_SIZE+1]
char m_nlevels_i[NLEVELS_I_SIZE+1]
◆ getNumberOfLayersOriginal()
ossim_uint32 ossimNitfJ2klraTag::getNumberOfLayersOriginal ( ) const
Returns
NLAYERS_O field as a number.
Definition at line 180 of file ossimNitfJ2klraTag.cpp.
References m_layers_o, and ossimString::toUInt32().
Referenced by parseStream().
181 {
182  return ossimString(m_layers_o).toUInt32();
183 }
ossim_uint32 toUInt32() const
◆ getOriginNumber()
ossim_uint32 ossimNitfJ2klraTag::getOriginNumber ( ) const
Returns
ORIG field as a number.
Definition at line 175 of file ossimNitfJ2klraTag.cpp.
References m_orig, and ossimString::toUInt32().
Referenced by getSizeInBytes(), and isParsed().
176 {
177  return ossimString(m_orig).toUInt32();
178 }
FIELD: ORIG.
◆ getSizeInBytes()
ossim_uint32 ossimNitfJ2klraTag::getSizeInBytes ( ) const
virtual
Returns
The size of this record in bytes (123) within a nitf file.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 98 of file ossimNitfJ2klraTag.cpp.
References getOriginNumber(), and m_layer.
99 {
100  ossim_uint32 result = 11 + (m_layer.size() * 12);
101
102  // Conditional:
103  ossim_uint32 orig = getOriginNumber();
104  if ( orig )
105  {
106  if ( orig % 2 ) // Odd origins are "parsed".
107  {
108  result += 10;
109  }
110  }
111  return result;
112 }
repeating fields
ossim_uint32 getOriginNumber() const
unsigned int ossim_uint32
◆ isParsed()
bool ossimNitfJ2klraTag::isParsed ( ) const
protected
Returns
true if origin byte is parsed; false if not.
Definition at line 325 of file ossimNitfJ2klraTag.cpp.
References getOriginNumber().
Referenced by parseStream(), print(), and writeStream().
326 {
327  bool result = false;
328  ossim_uint32 orig = getOriginNumber();
329  if ( orig )
330  {
331  /*
332  * 0 - Original NPJE
333  * 1 – Parsed NPJE
334  * 2 – Original EPJE
335  * 3 – Parsed EPJE*
336  * 4 - Original TPJE
337  * 5 - Parsed TPJE
338  * 6 - Original LPJE
339  * 7 - Parsed LPJE
340  * 8 – Original other
341  * 9 – Parsed other
342  */
343  if ( orig % 2 ) // Odd origins are "parsed".
344  {
345  result = true;
346  }
347  }
348  return result;
349 }
◆ parseStream()
void ossimNitfJ2klraTag::parseStream ( std::istream &  in)
virtual
Parse method.
Parameters
inStream to parse.
Definition at line 37 of file ossimNitfJ2klraTag.cpp.
References BITRATE_SIZE, clearFields(), getNumberOfLayersOriginal(), getSizeInBytes(), isParsed(), LAYER_ID_SIZE, m_bands_o, m_layer, m_layers_o, m_levels_o, m_nbands_i, m_nlayers_i, m_nlevels_i, m_orig, NBANDS_I_SIZE, NBANDS_O_SIZE, NLAYERS_I_SIZE, NLAYERS_O_SIZE, NLEVELS_I_SIZE, NLEVELS_O_SIZE, ORIG_SIZE, and ossimNitfRegisteredTag::setTagLength().
38 {
39  clearFields();
40
41  in.read(m_orig, ORIG_SIZE);
42  in.read(m_levels_o, NLEVELS_O_SIZE);
43  in.read(m_bands_o, NBANDS_O_SIZE);
44  in.read(m_layers_o, NLAYERS_O_SIZE);
45
47  if ( layers && (layers < 1000) ) // 999 max
48  {
49  m_layer.resize(layers);
50  for ( ossim_uint32 i = 0; i < layers; ++i )
51  {
52  in.read(m_layer[i].m_layer_id, LAYER_ID_SIZE);
53  in.read(m_layer[i].m_bitrate, BITRATE_SIZE);
54  m_layer[i].m_layer_id[LAYER_ID_SIZE] = '\0';
55  m_layer[i].m_bitrate[BITRATE_SIZE] = '\0';
56  }
57  }
58  else
59  {
60  m_layer.clear();
61  }
62
63  // Conditional:
64  if ( isParsed() )
65  {
66  in.read(m_nlevels_i, NLEVELS_I_SIZE);
67  in.read(m_nbands_i, NBANDS_I_SIZE);
68  in.read(m_nlayers_i, NLAYERS_I_SIZE);
69  }
70
71  // Set the base tag length.
73 }
FIELD: ORIG.
virtual ossim_uint32 getSizeInBytes() const
repeating fields
Set the tag length.
ossim_uint32 getNumberOfLayersOriginal() const
◆ print()
std::ostream & ossimNitfJ2klraTag::print ( std::ostream &  out,
const std::string &  prefix
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Definition at line 142 of file ossimNitfJ2klraTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), isParsed(), m_bands_o, m_layer, m_layers_o, m_levels_o, m_nbands_i, m_nlayers_i, m_nlevels_i, m_orig, and size.
144 {
145  std::string pfx = prefix;
146  pfx += getTagName();
147  pfx += ".";
148
149  out << setiosflags(ios::left)
150  << pfx << std::setw(24) << "CETAG:" << getTagName() << "\n"
151  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
152  << pfx << std::setw(24) << "ORIG:" << m_orig << "\n"
153  << pfx << std::setw(24) << "NLEVELS_O:" << m_levels_o << "\n"
154  << pfx << std::setw(24) << "NBANDS_O:" << m_bands_o << "\n"
155  << pfx << std::setw(24) << "NLAYERS_O:" << m_layers_o << "\n";
156
157  ossim_uint32 size = m_layer.size();
158  for ( ossim_uint32 i = 0; i < size; ++i )
159  {
160  out << pfx << "LAYER_ID[" << i << std::setw(14) << "]:" << m_layer[i].m_layer_id << "\n"
161  << pfx << "BITRATE[" << i << std::setw(15) << "]:" << m_layer[i].m_bitrate << "\n";
162  }
163
164  // Conditional:
165  if ( isParsed() )
166  {
167  out << pfx << std::setw(24) << "NLEVELS_I:" << m_nlevels_i << "\n"
168  << pfx << std::setw(24) << "NBANDS_I_SIZE:" << m_nbands_i << "\n"
169  << pfx << std::setw(24) << "NLAYERS_I:" << m_nlayers_i << "\n";
170  }
171
172  return out;
173 }
virtual const std::string & getTagName() const
FIELD: ORIG.
repeating fields
virtual ossim_uint32 getTagLength() const
yy_size_t size
◆ setBandsI()
bool ossimNitfJ2klraTag::setBandsI ( ossim_uint32  bands)
Range: 00001 to 16384
Parameters
levels
Returns
true on success, false if out of range.
Definition at line 264 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_nbands_i, NBANDS_I_SIZE, ossimString::size(), and ossimString::string().
265 {
266  bool result = false;
267  if ( ( bands >= 1 ) && ( bands <= 16384 ) )
268  {
270  if ( os.size() == NBANDS_I_SIZE )
271  {
272  strncpy( m_nbands_i, os.string().c_str(), NBANDS_I_SIZE );
273  result = true;
274  }
275  }
276  return result;
277 }
std::string::size_type size() const
Definition: ossimString.h:405
static ossimString convertToUIntString(ossim_uint32 aValue, ossim_uint32 size)
This method takes a value and converts to a string of size with with a &#39;0&#39; fill.
const std::string & string() const
Definition: ossimString.h:414
◆ setBandsO()
bool ossimNitfJ2klraTag::setBandsO ( ossim_uint32  bands)
Parameters
levels
Returns
Definition at line 215 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_bands_o, NBANDS_O_SIZE, ossimString::size(), and ossimString::string().
216 {
217  bool result = false;
218  if ( ( bands >= 1 ) && ( bands <= 16384 ) )
219  {
221  if ( os.size() == NBANDS_O_SIZE )
222  {
223  strncpy( m_bands_o, os.string().c_str(), NBANDS_O_SIZE );
224  result = true;
225  }
226  }
227  return result;
228 }
◆ setLayerBitRate()
bool ossimNitfJ2klraTag::setLayerBitRate ( ossim_uint32  index,
Range: 00.000000 – 37.000000
Note
Requires call to "setLayersO" prior to this to size the container m_layer.
Parameters
index
id
Returns
Definition at line 309 of file ossimNitfJ2klraTag.cpp.
References BITRATE_SIZE, ossimNitfCommon::convertToDoubleString(), m_layer, ossimString::size(), and ossimString::string().
Referenced by ossimKakaduCompressor::initialize().
310 {
311  bool result = false;
312  if ( index < m_layer.size() && ( bitRate >= 0.0 ) && ( bitRate <= 37.0 ) )
313  {
314  // 00.000000 – 37.000000
316  if ( os.size() == BITRATE_SIZE)
317  {
318  strncpy( m_layer[index].m_bitrate, os.string().c_str(), BITRATE_SIZE);
319  result = true;
320  }
321  }
322  return result;
323 }
repeating fields
static ossimString convertToDoubleString(const ossim_float64 &aValue, ossim_uint32 precision, ossim_uint32 size)
This method takes a value and converts to a string of size with requested precision with a &#39;0&#39; fill...
◆ setLayerId()
bool ossimNitfJ2klraTag::setLayerId ( ossim_uint32  index,
ossim_uint32  id
Range: 001 to 999
Note
Parameters
index
id
Returns
Definition at line 294 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), LAYER_ID_SIZE, m_layer, ossimString::size(), and ossimString::string().
295 {
296  bool result = false;
297  if ( index < m_layer.size() && ( id <= 998 ) )
298  {
300  if ( os.size() == LAYER_ID_SIZE)
301  {
302  strncpy( m_layer[index].m_layer_id, os.string().c_str(), LAYER_ID_SIZE );
303  result = true;
304  }
305  }
306  return result;
307 }
repeating fields
◆ setLayersI()
bool ossimNitfJ2klraTag::setLayersI ( ossim_uint32  layers)
Range: 001 to 999
Parameters
levels
Returns
Definition at line 279 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_nlayers_i, NLAYERS_I_SIZE, ossimString::size(), and ossimString::string().
280 {
281  bool result = false;
282  if ( ( layers >= 1 ) && ( layers <= 999 ) )
283  {
285  if ( os.size() == NLAYERS_I_SIZE )
286  {
287  strncpy( m_nlayers_i, os.string().c_str(), NLAYERS_I_SIZE );
288  result = true;
289  }
290  }
291  return result;
292 }
◆ setLayersO()
bool ossimNitfJ2klraTag::setLayersO ( ossim_uint32  layers)
Range: 001 to 999
Parameters
levels
Returns
Definition at line 230 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_layer, m_layers_o, NLAYERS_O_SIZE, ossimString::size(), and ossimString::string().
231 {
232  bool result = false;
233  if ( ( layers >= 1 ) && ( layers <= 999 ) )
234  {
236  if ( os.size() == NLAYERS_O_SIZE )
237  {
238  strncpy( m_layers_o, os.string().c_str(), NLAYERS_O_SIZE );
239
240  // Conditional repeating field:
241  m_layer.resize( layers );
242
243  result = true;
244  }
245  }
246  return result;
247 }
repeating fields
◆ setLevelsI()
bool ossimNitfJ2klraTag::setLevelsI ( ossim_uint32  levels)
Range: 00 to 32
Parameters
levels
Returns
Definition at line 249 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_nlevels_i, NLEVELS_I_SIZE, ossimString::size(), and ossimString::string().
250 {
251  bool result = false;
252  if ( levels <= 32 )
253  {
255  if ( os.size() == NLEVELS_I_SIZE )
256  {
257  strncpy( m_nlevels_i, os.string().c_str(), NLEVELS_I_SIZE );
258  result = true;
259  }
260  }
261  return result;
262 }
◆ setLevelsO()
bool ossimNitfJ2klraTag::setLevelsO ( ossim_uint32  levels)
Range: 00 to 32
Parameters
levels
Returns
Definition at line 200 of file ossimNitfJ2klraTag.cpp.
References ossimNitfCommon::convertToUIntString(), m_levels_o, NLEVELS_O_SIZE, ossimString::size(), and ossimString::string().
201 {
202  bool result = false;
203  if ( levels <= 32 )
204  {
206  if ( os.size() == NLEVELS_O_SIZE )
207  {
208  strncpy( m_levels_o, os.string().c_str(), NLEVELS_O_SIZE );
209  result = true;
210  }
211  }
212  return result;
213 }
◆ setOrigin()
bool ossimNitfJ2klraTag::setOrigin ( ossim_uint32  origin)
Sets origin:
Range is 0 to 9
0 - Original NPJE 1 – Parsed NPJE 2 – Original EPJE 3 – Parsed EPJE* 4 - Original TPJE 5 - Parsed TPJE 6 - Original LPJE 7 - Parsed LPJE 8 – Original other 9 – Parsed other
Parameters
origin0 to 9
Returns
Definition at line 185 of file ossimNitfJ2klraTag.cpp.
References m_orig.
186 {
187  bool result = true;
188  if ( origin <= 9 )
189  {
190  // Ascii 0 to 9
191  m_orig[0] = 0x30 + origin;
192  }
193  else
194  {
195  result = false;
196  }
197  return result;
198 }
FIELD: ORIG.
◆ writeStream()
void ossimNitfJ2klraTag::writeStream ( std::ostream &  out)
virtual
Write method.
Parameters
outStream to write to.
Definition at line 75 of file ossimNitfJ2klraTag.cpp.
References BITRATE_SIZE, isParsed(), LAYER_ID_SIZE, m_bands_o, m_layer, m_layers_o, m_levels_o, m_nbands_i, m_nlayers_i, m_nlevels_i, m_orig, NBANDS_I_SIZE, NBANDS_O_SIZE, NLAYERS_I_SIZE, NLAYERS_O_SIZE, NLEVELS_I_SIZE, NLEVELS_O_SIZE, ORIG_SIZE, and size.
76 {
77  out.write(m_orig, ORIG_SIZE);
78  out.write(m_levels_o, NLEVELS_O_SIZE);
79  out.write(m_bands_o, NBANDS_O_SIZE);
80  out.write(m_layers_o, NLAYERS_O_SIZE);
81
82  ossim_uint32 size = m_layer.size();
83  for ( ossim_uint32 i = 0; i < size; ++i )
84  {
85  out.write(m_layer[i].m_layer_id, LAYER_ID_SIZE);
86  out.write(m_layer[i].m_bitrate, BITRATE_SIZE);
87  }
88
89  // Conditional:
90  if ( isParsed() )
91  {
92  out.write(m_nlevels_i, NLEVELS_I_SIZE);
93  out.write(m_nbands_i, NBANDS_I_SIZE);
94  out.write(m_nlayers_i, NLAYERS_I_SIZE);
95  }
96 }
FIELD: ORIG.
repeating fields
yy_size_t size
Member Data Documentation
◆ m_bands_o
char ossimNitfJ2klraTag::m_bands_o[NBANDS_O_SIZE+1]
protected
Definition at line 256 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), parseStream(), print(), setBandsO(), and writeStream().
◆ m_layer
std::vector<ossimJ2klraLayer> ossimNitfJ2klraTag::m_layer
protected
◆ m_layers_o
char ossimNitfJ2klraTag::m_layers_o[NLAYERS_O_SIZE+1]
protected
Definition at line 264 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), getNumberOfLayersOriginal(), parseStream(), print(), setLayersO(), and writeStream().
◆ m_levels_o
char ossimNitfJ2klraTag::m_levels_o[NLEVELS_O_SIZE+1]
protected
Definition at line 248 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), parseStream(), print(), setLevelsO(), and writeStream().
◆ m_nbands_i
char ossimNitfJ2klraTag::m_nbands_i[NBANDS_I_SIZE+1]
protected
00000 = 16384 Number of bands in this image.
Definition at line 283 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), parseStream(), print(), setBandsI(), and writeStream().
◆ m_nlayers_i
char ossimNitfJ2klraTag::m_nlayers_i[NLAYERS_I_SIZE+1]
protected
000 - 999 Number of Layers in this image.
Definition at line 291 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), parseStream(), print(), setLayersI(), and writeStream().
◆ m_nlevels_i
char ossimNitfJ2klraTag::m_nlevels_i[NLEVELS_I_SIZE+1]
protected
00 - 32 Number of wavelet levels in this image.
Definition at line 275 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), parseStream(), print(), setLevelsI(), and writeStream().
◆ m_orig
char ossimNitfJ2klraTag::m_orig[ORIG_SIZE+1]
protected
FIELD: ORIG.
Required 1 byte.
Original compressed data.
Definition at line 240 of file ossimNitfJ2klraTag.h.
Referenced by clearFields(), getOriginNumber(), parseStream(), print(), setOrigin(), and writeStream().
