Public Member Functions | Protected Attributes | List of all members
ossimNitfLocalCartographicTag Class Reference
#include <ossimNitfLocalCartographicTag.h>
Inheritance diagram for ossimNitfLocalCartographicTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
 ossimNitfLocalCartographicTag ()
virtual ~ossimNitfLocalCartographicTag ()
virtual void parseStream (std::istream &in)
virtual void writeStream (std::ostream &out)
virtual void clearFields ()
void setLengthUnits (const ossimString &units)
void setEastingInterval (ossim_uint32 eastingInterval)
void setNorthingInterval (ossim_uint32 northingInterval)
void setEastingReferenceOrigin (ossim_float64 east)
void setNorthingReferenceOrigin (ossim_float64 north)
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 default constructor More...
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Pure virtual print method that outputs a key/value type format adding prefix to keys. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char theLengthUnits [4]
 FIELD: UNILOA. More...
char theEastingInterval [6]
 FIELD: LOD. More...
char theNorthingInterval [6]
 FIELD: LAD. More...
char theEastingReferenceOrigin [16]
 FIELD: LSO. More...
char theNorthingReferenceOrigin [16]
 FIELD: PSO. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 5 of file ossimNitfLocalCartographicTag.h.
◆ ossimNitfLocalCartographicTag()
ossimNitfLocalCartographicTag::ossimNitfLocalCartographicTag ( )
Definition at line 20 of file ossimNitfLocalCartographicTag.cpp.
21  : ossimNitfRegisteredTag(std::string("MAPLOB"), 43)
22 {
23 }
ossimNitfRegisteredTag()
default constructor
◆ ~ossimNitfLocalCartographicTag()
ossimNitfLocalCartographicTag::~ossimNitfLocalCartographicTag ( )
virtual
Definition at line 25 of file ossimNitfLocalCartographicTag.cpp.
26 {
27 }
Member Function Documentation
◆ clearFields()
void ossimNitfLocalCartographicTag::clearFields ( )
virtual
Definition at line 49 of file ossimNitfLocalCartographicTag.cpp.
References theEastingInterval, theEastingReferenceOrigin, theLengthUnits, theNorthingInterval, and theNorthingReferenceOrigin.
Referenced by parseStream().
50 {
51  memset(theLengthUnits, ' ', 3);
52  memset(theEastingInterval, '0', 5);
53  memset(theNorthingInterval, '0', 5);
54  memset(theEastingReferenceOrigin, '0', 15);
55  memset(theNorthingReferenceOrigin, '0', 15);
56
57  theLengthUnits[3] = '\0';
58  theEastingInterval[5] = '\0';
59  theNorthingInterval[5] = '\0';
60  theEastingReferenceOrigin[15] = '\0';
61  theNorthingReferenceOrigin[15] = '\0';
62 }
◆ parseStream()
void ossimNitfLocalCartographicTag::parseStream ( std::istream &  in)
virtual
◆ setEastingInterval()
void ossimNitfLocalCartographicTag::setEastingInterval ( ossim_uint32  eastingInterval)
Definition at line 76 of file ossimNitfLocalCartographicTag.cpp.
References theEastingInterval.
77 {
78  ossim_uint32 temp = eastingInterval;
79
80  if(temp > 99999)
81  {
82  temp = 99999;
83  }
84
86
87  out << std::setw(5)
88  << std::setfill('0')
89  << temp;
90
91  memcpy(theEastingInterval, out.str().c_str(), 5);
92 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
unsigned int ossim_uint32
◆ setEastingReferenceOrigin()
void ossimNitfLocalCartographicTag::setEastingReferenceOrigin ( ossim_float64  east)
Definition at line 112 of file ossimNitfLocalCartographicTag.cpp.
References theEastingReferenceOrigin.
113 {
114  std::ostringstream out;
115
116  out << std::setw(15)
117  << std::setfill(' ')
118  << std::setprecision(1)
119  << std::setiosflags(std::ios::fixed)
120  << east;
121
122  memcpy(theEastingReferenceOrigin, out.str().c_str(), 15);
123
124 }
◆ setLengthUnits()
void ossimNitfLocalCartographicTag::setLengthUnits ( const ossimString units)
Definition at line 64 of file ossimNitfLocalCartographicTag.cpp.
References ossimString::c_str(), theLengthUnits, ossimString::trim(), and ossimString::upcase().
65 {
66  ossimString temp = ossimString(units).trim().upcase();
68
69  out << std::setw(3)
70  << std::setfill(' ')
71  << temp.c_str();
72
73  memcpy(theLengthUnits, out.str().c_str(), 3);
74 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
const char * c_str() const
Definition: ossimString.h:396
◆ setNorthingInterval()
void ossimNitfLocalCartographicTag::setNorthingInterval ( ossim_uint32  northingInterval)
Definition at line 94 of file ossimNitfLocalCartographicTag.cpp.
References theNorthingInterval.
95 {
96  ossim_uint32 temp = northingInterval;
97
98  if(temp > 99999)
99  {
100  temp = 99999;
101  }
102
103  std::ostringstream out;
104
105  out << std::setw(5)
106  << std::setfill('0')
107  << temp;
108
109  memcpy(theNorthingInterval, out.str().c_str(), 5);
110 }
◆ setNorthingReferenceOrigin()
void ossimNitfLocalCartographicTag::setNorthingReferenceOrigin ( ossim_float64  north)
Definition at line 126 of file ossimNitfLocalCartographicTag.cpp.
References theNorthingReferenceOrigin.
127 {
128  std::ostringstream out;
129
130  out << std::setw(15)
131  << std::setfill(' ')
132  << std::setprecision(1)
133  << std::setiosflags(std::ios::fixed)
134  << north;
135
136  memcpy(theNorthingReferenceOrigin, out.str().c_str(), 15);
137 }
◆ writeStream()
void ossimNitfLocalCartographicTag::writeStream ( std::ostream &  out)
virtual
Definition at line 40 of file ossimNitfLocalCartographicTag.cpp.
41 {
42  out.write(theLengthUnits, 3);
43  out.write(theEastingInterval, 5);
44  out.write(theNorthingInterval, 5);
45  out.write(theEastingReferenceOrigin, 15);
46  out.write(theNorthingReferenceOrigin, 15);
47 }
Member Data Documentation
◆ theEastingInterval
char ossimNitfLocalCartographicTag::theEastingInterval[6]
protected
FIELD: LOD.
required 5 byte field
Easting interval
This field shall contain the data density in E-W direction that is the column width of an image pixel. 5 BCS-N positive integer 00001 to 99999 R
Definition at line 48 of file ossimNitfLocalCartographicTag.h.
Referenced by clearFields(), parseStream(), setEastingInterval(), and writeStream().
◆ theEastingReferenceOrigin
char ossimNitfLocalCartographicTag::theEastingReferenceOrigin[16]
protected
FIELD: LSO.
required 15 byte field
Easting of Reference Origin
This field shall contain the easting of the origin pixel (row number 0, column number 0) in the absolute coordinate system. 15 BCS-N ±mmmmmmmmmmmm.m
Definition at line 74 of file ossimNitfLocalCartographicTag.h.
Referenced by clearFields(), parseStream(), setEastingReferenceOrigin(), and writeStream().
◆ theLengthUnits
char ossimNitfLocalCartographicTag::theLengthUnits[4]
protected
FIELD: UNILOA.
required 3 byte field
Length units
This field shall contain the unit of measure used for easting (LOD) and northing (LAD) intervals. The default value is M. 3BCS-A See Part 3- 7 R
Definition at line 35 of file ossimNitfLocalCartographicTag.h.
Referenced by clearFields(), parseStream(), setLengthUnits(), and writeStream().
◆ theNorthingInterval
char ossimNitfLocalCartographicTag::theNorthingInterval[6]
protected
FIELD: LAD.
Northing interval
Definition at line 61 of file ossimNitfLocalCartographicTag.h.
Referenced by clearFields(), parseStream(), setNorthingInterval(), and writeStream().
◆ theNorthingReferenceOrigin
char ossimNitfLocalCartographicTag::theNorthingReferenceOrigin[16]
protected
FIELD: PSO.
Northing of Reference Origin
This field shall contain the northing of the origin pixel (row number 0, column number 0) in the absolute coordinate system. 15 BCS-N ±mmmmmmmmmmmm.m
Definition at line 87 of file ossimNitfLocalCartographicTag.h.
Referenced by clearFields(), parseStream(), setNorthingReferenceOrigin(), and writeStream().
