Public Types | Public Member Functions | Protected Attributes | List of all members
ossimNitfPiaimcTag Class Reference
#include <ossimNitfPiaimcTag.h>
Inheritance diagram for ossimNitfPiaimcTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Public Types
enum  {
  CLOUDCVR_SIZE = 3, SRP_SIZE = 1, SENSMODE_SIZE = 12, SENSNAME_SIZE = 18,
  SOURCE_SIZE = 255, COMGEN_SIZE = 2, SUBQUAL_SIZE = 1, PIAMSNNUM_SIZE = 7,
  CAMSPECS_SIZE = 32, PROJID_SIZE = 2, GENERATION_SIZE = 1, ESD_SIZE = 1,
  OTHERCOND_SIZE = 2, MEANGSD_SIZE = 7, IDATUM_SIZE = 3, IELLIP_SIZE = 3,
  PREPROC_SIZE = 2, IPROJ_SIZE = 2, SATTRACK_SIZE = 8
 ossimNitfPiaimcTag ()
 default constructor More...
virtual void parseStream (std::istream &in)
 Parse method. More...
virtual void writeStream (std::ostream &out)
 Write method. More...
virtual void clearFields ()
 Clears all string fields within the record to some default nothingness. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix) const
 Print method that outputs a key/value type format adding prefix to keys. More...
ossimString getCloudcvrString () const
ossimString getSrpString () const
ossimString getSensmodeString () const
ossimString getSensnameString () const
ossimString getSourceString () const
ossimString getComgenString () const
ossimString getSubqualString () const
ossimString getPiamsnnumString () const
ossimString getString () const
ossimString getCamspecsString () const
ossimString getProjidString () const
ossimString getGenerationString () const
ossimString getEsdString () const
ossimString getOthercondString () const
ossimString getMeadGsdString () const
ossim_float64 getMeanGsdInMeters () const
ossimString getIdatumString () const
ossimString getIellipString () const
ossimString getPreprocString () const
ossimString getIprojString () const
ossimString getSattrackString () const
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char theCloudcvr [CLOUDCVR_SIZE+1]
 FIELD: CLOUDCVR. More...
char theSrp [SRP_SIZE+1]
 FIELD: SRP. More...
char thesSensmode [SENSMODE_SIZE+1]
 FIELD: SENSMODE. More...
char theSensname [SENSNAME_SIZE+1]
 FIELD: SENSNAME. More...
char theSource [SOURCE_SIZE+1]
 FIELD: SOURCE. More...
char theComgen [COMGEN_SIZE+1]
 FIELD: COMGEN. More...
char theSubqual [SUBQUAL_SIZE+1]
 FIELD: SUBQUAL. More...
char thePiamsnnum [PIAMSNNUM_SIZE+1]
 FIELD: PIAMSNNUM. More...
char theCamspecs [CAMSPECS_SIZE+1]
 FIELD: CAMSPECS. More...
char theProjid [PROJID_SIZE+1]
 FIELD: PROJID. More...
char theGeneration [GENERATION_SIZE+1]
 FIELD: GENERATION. More...
char theEsd [ESD_SIZE+1]
 FIELD: ESD. More...
char theOthercond [OTHERCOND_SIZE+1]
 FIELD: OTHERCOND. More...
char theMeanGsd [MEANGSD_SIZE+1]
 FIELD: MEANGSD. More...
char theIdatum [IDATUM_SIZE+1]
 FIELD: IDATUM. More...
char theIellip [IELLIP_SIZE+1]
 FIELD: IELLIP. More...
char thePreproc [PREPROC_SIZE+1]
 FIELD: PREPROC. More...
char theIproj [IPROJ_SIZE+1]
 FIELD: IPROJ. More...
char theSattrack [SATTRACK_SIZE+1]
 FIELD: SATTRACK. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 27 of file ossimNitfPiaimcTag.h.
◆ anonymous enum
anonymous enum
Enumerator
CLOUDCVR_SIZE
SRP_SIZE
SENSMODE_SIZE
SENSNAME_SIZE
SOURCE_SIZE
COMGEN_SIZE
SUBQUAL_SIZE
PIAMSNNUM_SIZE
CAMSPECS_SIZE
PROJID_SIZE
GENERATION_SIZE
ESD_SIZE
OTHERCOND_SIZE
MEANGSD_SIZE
IDATUM_SIZE
IELLIP_SIZE
PREPROC_SIZE
IPROJ_SIZE
SATTRACK_SIZE
Definition at line 30 of file ossimNitfPiaimcTag.h.
31  {
32  CLOUDCVR_SIZE = 3,
33  SRP_SIZE = 1,
34  SENSMODE_SIZE = 12,
35  SENSNAME_SIZE = 18,
36  SOURCE_SIZE = 255,
37  COMGEN_SIZE = 2,
38  SUBQUAL_SIZE = 1,
39  PIAMSNNUM_SIZE = 7,
40  CAMSPECS_SIZE = 32,
41  PROJID_SIZE = 2,
42  GENERATION_SIZE = 1,
43  ESD_SIZE = 1,
44  OTHERCOND_SIZE = 2,
45  MEANGSD_SIZE = 7,
46  IDATUM_SIZE = 3,
47  IELLIP_SIZE = 3,
48  PREPROC_SIZE = 2,
49  IPROJ_SIZE = 2,
50  SATTRACK_SIZE = 8
51  // -------
52  // 362
53  };
◆ ossimNitfPiaimcTag()
ossimNitfPiaimcTag::ossimNitfPiaimcTag ( )
default constructor
Definition at line 53 of file ossimNitfPiaimcTag.cpp.
References clearFields().
54  : ossimNitfRegisteredTag(std::string("PIAIMC"), 362)
55 {
56  clearFields();
57 }
virtual void clearFields()
ossimNitfRegisteredTag()
default constructor
Member Function Documentation
◆ clearFields()
void ossimNitfPiaimcTag::clearFields ( )
virtual
Definition at line 107 of file ossimNitfPiaimcTag.cpp.
References CAMSPECS_SIZE, CLOUDCVR_SIZE, COMGEN_SIZE, ESD_SIZE, GENERATION_SIZE, IDATUM_SIZE, IELLIP_SIZE, IPROJ_SIZE, MEANGSD_SIZE, OTHERCOND_SIZE, PIAMSNNUM_SIZE, PREPROC_SIZE, PROJID_SIZE, SATTRACK_SIZE, SENSMODE_SIZE, SENSNAME_SIZE, SOURCE_SIZE, SRP_SIZE, SUBQUAL_SIZE, theCamspecs, theCloudcvr, theComgen, theEsd, theGeneration, theIdatum, theIellip, theIproj, theMeanGsd, theOthercond, thePiamsnnum, thePreproc, theProjid, theSattrack, theSensname, theSource, theSrp, thesSensmode, and theSubqual.
Referenced by ossimNitfPiaimcTag(), and parseStream().
108 {
109  memcpy(theCloudcvr, "999", CLOUDCVR_SIZE);
110  memset(theSrp, ' ', SRP_SIZE);
111  memset(thesSensmode, ' ', SENSMODE_SIZE);
112  memset(theSensname, ' ', SENSNAME_SIZE);
113  memset(theSource, ' ', SOURCE_SIZE);
114  memset(theComgen, ' ', COMGEN_SIZE);
115  memset(theSubqual, ' ', SUBQUAL_SIZE);
116  memset(thePiamsnnum, ' ', PIAMSNNUM_SIZE);
117  memset(theCamspecs, ' ', CAMSPECS_SIZE);
118  memset(theProjid, ' ', PROJID_SIZE);
119  memset(theGeneration, ' ', GENERATION_SIZE);
120  memset(theEsd, ' ', ESD_SIZE);
121  memset(theOthercond, ' ', OTHERCOND_SIZE);
122  memset(theMeanGsd, ' ', MEANGSD_SIZE);
123  memset(theIdatum, ' ', IDATUM_SIZE);
124  memset(theIellip, ' ', IELLIP_SIZE);
125  memset(thePreproc, ' ', PREPROC_SIZE);
126  memset(theIproj, ' ', IPROJ_SIZE);
127  memset(theSattrack, ' ', SATTRACK_SIZE);
128
129  theCloudcvr[CLOUDCVR_SIZE] = '\0';
130  theSrp[SRP_SIZE] = '\0';
131  thesSensmode[SENSMODE_SIZE] = '\0';
132  theSensname[SENSNAME_SIZE] = '\0';
133  theSource[SOURCE_SIZE] = '\0';
134  theComgen[COMGEN_SIZE] = '\0';
135  theSubqual[SUBQUAL_SIZE] = '\0';
137  theCamspecs[CAMSPECS_SIZE] = '\0';
138  theProjid[PROJID_SIZE] = '\0';
140  theEsd[ESD_SIZE] = '\0';
142  theMeanGsd[MEANGSD_SIZE] = '\0';
143  theIdatum[IDATUM_SIZE] = '\0';
144  theIellip[IELLIP_SIZE] = '\0';
145  thePreproc[PREPROC_SIZE] = '\0';
146  theIproj[IPROJ_SIZE] = '\0';
147  theSattrack[SATTRACK_SIZE] = '\0';
148 }
char theSensname[SENSNAME_SIZE+1]
FIELD: SENSNAME.
char thePiamsnnum[PIAMSNNUM_SIZE+1]
FIELD: PIAMSNNUM.
char theIellip[IELLIP_SIZE+1]
FIELD: IELLIP.
char theSattrack[SATTRACK_SIZE+1]
FIELD: SATTRACK.
char thesSensmode[SENSMODE_SIZE+1]
FIELD: SENSMODE.
char theIproj[IPROJ_SIZE+1]
FIELD: IPROJ.
char theProjid[PROJID_SIZE+1]
FIELD: PROJID.
char theSubqual[SUBQUAL_SIZE+1]
FIELD: SUBQUAL.
char theSrp[SRP_SIZE+1]
FIELD: SRP.
char thePreproc[PREPROC_SIZE+1]
FIELD: PREPROC.
char theIdatum[IDATUM_SIZE+1]
FIELD: IDATUM.
char theComgen[COMGEN_SIZE+1]
FIELD: COMGEN.
char theCloudcvr[CLOUDCVR_SIZE+1]
FIELD: CLOUDCVR.
char theSource[SOURCE_SIZE+1]
FIELD: SOURCE.
char theMeanGsd[MEANGSD_SIZE+1]
FIELD: MEANGSD.
char theOthercond[OTHERCOND_SIZE+1]
FIELD: OTHERCOND.
char theCamspecs[CAMSPECS_SIZE+1]
FIELD: CAMSPECS.
char theGeneration[GENERATION_SIZE+1]
FIELD: GENERATION.
char theEsd[ESD_SIZE+1]
FIELD: ESD.
◆ getCamspecsString()
ossimString ossimNitfPiaimcTag::getCamspecsString ( ) const
Returns
CAMSPECS field as an ossimString.
Definition at line 223 of file ossimNitfPiaimcTag.cpp.
References theCamspecs.
224 {
225  return ossimString(theCamspecs);
226 }
FIELD: CAMSPECS.
◆ getCloudcvrString()
ossimString ossimNitfPiaimcTag::getCloudcvrString ( ) const
Returns
CLOUDCVR field as an ossimString.
Definition at line 183 of file ossimNitfPiaimcTag.cpp.
References theCloudcvr.
184 {
185  return ossimString(theCloudcvr);
186 }
FIELD: CLOUDCVR.
◆ getComgenString()
ossimString ossimNitfPiaimcTag::getComgenString ( ) const
Returns
COMGEN field as an ossimString.
Definition at line 208 of file ossimNitfPiaimcTag.cpp.
References theComgen.
209 {
210  return ossimString(theComgen);
211 }
FIELD: COMGEN.
◆ getEsdString()
ossimString ossimNitfPiaimcTag::getEsdString ( ) const
Returns
ESD field as an ossimString.
Definition at line 238 of file ossimNitfPiaimcTag.cpp.
References theEsd.
239 {
240  return ossimString(theEsd);
241 }
FIELD: ESD.
◆ getGenerationString()
ossimString ossimNitfPiaimcTag::getGenerationString ( ) const
Returns
GENERATION field as an ossimString.
Definition at line 233 of file ossimNitfPiaimcTag.cpp.
References theGeneration.
234 {
235  return ossimString(theGeneration);
236 }
FIELD: GENERATION.
◆ getIdatumString()
ossimString ossimNitfPiaimcTag::getIdatumString ( ) const
Returns
IDATUM field as an ossimString.
Definition at line 270 of file ossimNitfPiaimcTag.cpp.
References theIdatum.
271 {
272  return ossimString(theIdatum);
273 }
FIELD: IDATUM.
◆ getIellipString()
ossimString ossimNitfPiaimcTag::getIellipString ( ) const
Returns
IELLIP field as an ossimString.
Definition at line 275 of file ossimNitfPiaimcTag.cpp.
References theIellip.
276 {
277  return ossimString(theIellip);
278 }
FIELD: IELLIP.
◆ getIprojString()
ossimString ossimNitfPiaimcTag::getIprojString ( ) const
Returns
IPROJ field as an ossimString.
Definition at line 285 of file ossimNitfPiaimcTag.cpp.
References theIproj.
286 {
287  return ossimString(theIproj);
288 }
FIELD: IPROJ.
◆ getMeadGsdString()
ossimString ossimNitfPiaimcTag::getMeadGsdString ( ) const
Returns
MEANGSD field as an ossimString.
Definition at line 248 of file ossimNitfPiaimcTag.cpp.
References theMeanGsd.
249 {
250  return ossimString(theMeanGsd);
251 }
FIELD: MEANGSD.
◆ getMeanGsdInMeters()
ossim_float64 ossimNitfPiaimcTag::getMeanGsdInMeters ( ) const
Returns
MEANGSD field as a double converted to meters.
Note
Conversion used: gsd_in_meters = gsd / 12.0 * MTRS_PER_FT
Definition at line 253 of file ossimNitfPiaimcTag.cpp.
References ossim::isnan(), MTRS_PER_FT, ossimString::size(), theMeanGsd, and ossimString::toFloat64().
254 {
255  ossim_float64 gsd = 0.0;
256
258  if (s.size())
259  {
260  ossim_float64 d = s.toFloat64();
261  if ( (d != 0.0) && (ossim::isnan(d) == false) )
262  {
263  gsd = d / 12.0 * MTRS_PER_FT;
264  }
265  }
266
267  return gsd;
268 }
double ossim_float64
std::string::size_type size() const
Definition: ossimString.h:405
ossim_float64 toFloat64() const
#define MTRS_PER_FT
FIELD: MEANGSD.
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ getOthercondString()
ossimString ossimNitfPiaimcTag::getOthercondString ( ) const
Returns
OTHERCONDfield as an ossimString.
Definition at line 243 of file ossimNitfPiaimcTag.cpp.
References theOthercond.
244 {
245  return ossimString(theOthercond);
246 }
FIELD: OTHERCOND.
◆ getPiamsnnumString()
ossimString ossimNitfPiaimcTag::getPiamsnnumString ( ) const
Returns
PIAMSNNUM field as an ossimString.
Definition at line 218 of file ossimNitfPiaimcTag.cpp.
References thePiamsnnum.
219 {
220  return ossimString(thePiamsnnum);
221 }
FIELD: PIAMSNNUM.
◆ getPreprocString()
ossimString ossimNitfPiaimcTag::getPreprocString ( ) const
Returns
PREPROC field as an ossimString.
Definition at line 280 of file ossimNitfPiaimcTag.cpp.
References thePreproc.
281 {
282  return ossimString(thePreproc);
283 }
FIELD: PREPROC.
◆ getProjidString()
ossimString ossimNitfPiaimcTag::getProjidString ( ) const
Returns
PROJID field as an ossimString.
Definition at line 228 of file ossimNitfPiaimcTag.cpp.
References theProjid.
229 {
230  return ossimString(theProjid);
231 }
FIELD: PROJID.
◆ getProperty()
ossimRefPtr< ossimProperty > ossimNitfPiaimcTag::getProperty ( const ossimString name) const
virtual
Reimplemented from ossimNitfRegisteredTag.
Definition at line 300 of file ossimNitfPiaimcTag.cpp.
301 {
302  ossimProperty* result = 0;
303
304  if(name == CLOUDCVR_KW)
305  {
306  result = new ossimStringProperty(name, theCloudcvr);
307  }
308  else if(name == SRP_KW)
309  {
310  result = new ossimStringProperty(name, theSrp);
311  }
312  else if(name == SENSMODE_KW)
313  {
314  result = new ossimStringProperty(name, thesSensmode);
315  }
316  else if(name == SENSNAME_KW)
317  {
318  result = new ossimStringProperty(name, theSensname);
319  }
320  else if(name == SOURCE_KW)
321  {
322  result = new ossimStringProperty(name, theSource);
323  }
324  else if(name == COMGEN_KW)
325  {
326  result = new ossimStringProperty(name, theComgen);
327  }
328  else if(name == SUBQUAL_KW)
329  {
330  result = new ossimStringProperty(name, theSubqual);
331  }
332  else if(name == PIAMSNNUM_KW)
333  {
334  result = new ossimStringProperty(name, thePiamsnnum);
335  }
336  else if(name == CAMSPECS_KW)
337  {
338  result = new ossimStringProperty(name, theCamspecs);
339  }
340  else if(name == PROJID_KW)
341  {
342  result = new ossimStringProperty(name, theProjid);
343  }
344  else if(name == GENERATION_KW)
345  {
346  result = new ossimStringProperty(name, theGeneration);
347  }
348  else if(name == ESD_KW)
349  {
350  result = new ossimStringProperty(name, theEsd);
351  }
352  else if(name == OTHERCOND_KW)
353  {
354  result = new ossimStringProperty(name, theOthercond);
355  }
356  else if(name == MEANGSD_KW)
357  {
358  result = new ossimStringProperty(name, theMeanGsd);
359  }
360  else if(name == IDATUM_KW)
361  {
362  result = new ossimStringProperty(name, theIdatum);
363  }
364  else if(name == IELLIP_KW)
365  {
366  result = new ossimStringProperty(name, theIellip);
367  }
368  else if(name == PREPROC_KW)
369  {
370  result = new ossimStringProperty(name, thePreproc);
371  }
372  else if(name == IPROJ_KW)
373  {
374  result = new ossimStringProperty(name, theIproj);
375  }
376  else if(name == SATTRACK_KW)
377  {
378  result = new ossimStringProperty(name, theSattrack);
379  }
380  else
381  {
383  }
384
385  return result;
386 }
FIELD: SENSNAME.
FIELD: PIAMSNNUM.
FIELD: IELLIP.
FIELD: SATTRACK.
FIELD: SENSMODE.
FIELD: IPROJ.
FIELD: PROJID.
FIELD: SUBQUAL.
FIELD: SRP.
FIELD: PREPROC.
FIELD: IDATUM.
FIELD: COMGEN.
FIELD: CLOUDCVR.
FIELD: SOURCE.
FIELD: MEANGSD.
FIELD: OTHERCOND.
FIELD: CAMSPECS.
FIELD: GENERATION.
FIELD: ESD.
◆ getPropertyNames()
void ossimNitfPiaimcTag::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 388 of file ossimNitfPiaimcTag.cpp.
References ossimNitfRegisteredTag::getPropertyNames().
389 {
391
392  propertyNames.push_back(CLOUDCVR_KW);
393  propertyNames.push_back(SRP_KW);
394  propertyNames.push_back(SENSMODE_KW);
395  propertyNames.push_back(SENSNAME_KW);
396  propertyNames.push_back(SOURCE_KW);
397  propertyNames.push_back(COMGEN_KW);
398  propertyNames.push_back(SUBQUAL_KW);
399  propertyNames.push_back(PIAMSNNUM_KW);
400  propertyNames.push_back(CAMSPECS_KW);
401  propertyNames.push_back(PROJID_KW);
402  propertyNames.push_back(GENERATION_KW);
403  propertyNames.push_back(ESD_KW);
404  propertyNames.push_back(OTHERCOND_KW);
405  propertyNames.push_back(MEANGSD_KW);
406  propertyNames.push_back(IDATUM_KW);
407  propertyNames.push_back(IELLIP_KW);
408  propertyNames.push_back(PREPROC_KW);
409  propertyNames.push_back(IPROJ_KW);
410  propertyNames.push_back(SATTRACK_KW);
411 }
◆ getSattrackString()
ossimString ossimNitfPiaimcTag::getSattrackString ( ) const
Returns
SATTRACK field as an ossimString.
Definition at line 290 of file ossimNitfPiaimcTag.cpp.
References theSattrack.
291 {
292  return ossimString(theSattrack);
293 }
FIELD: SATTRACK.
◆ getSensmodeString()
ossimString ossimNitfPiaimcTag::getSensmodeString ( ) const
Returns
SENSMODE field as an ossimString.
Definition at line 193 of file ossimNitfPiaimcTag.cpp.
References thesSensmode.
194 {
195  return ossimString(thesSensmode);
196 }
FIELD: SENSMODE.
◆ getSensnameString()
ossimString ossimNitfPiaimcTag::getSensnameString ( ) const
Returns
SENSNAME field as an ossimString.
Definition at line 198 of file ossimNitfPiaimcTag.cpp.
References theSensname.
199 {
200  return ossimString(theSensname);
201 }
FIELD: SENSNAME.
◆ getSourceString()
ossimString ossimNitfPiaimcTag::getSourceString ( ) const
Returns
SOURCE field as an ossimString.
Definition at line 203 of file ossimNitfPiaimcTag.cpp.
References theSource.
204 {
205  return ossimString(theSource);
206 }
FIELD: SOURCE.
◆ getSrpString()
ossimString ossimNitfPiaimcTag::getSrpString ( ) const
Returns
SRP field as an ossimString.
Definition at line 188 of file ossimNitfPiaimcTag.cpp.
References theSrp.
189 {
190  return ossimString(theSrp);
191 }
FIELD: SRP.
◆ getString()
ossimString ossimNitfPiaimcTag::getString ( ) const
Returns
◆ getSubqualString()
ossimString ossimNitfPiaimcTag::getSubqualString ( ) const
Returns
SUBQUAL field as an ossimString.
Definition at line 213 of file ossimNitfPiaimcTag.cpp.
References theSubqual.
214 {
215  return ossimString(theSubqual);
216 }
FIELD: SUBQUAL.
◆ parseStream()
void ossimNitfPiaimcTag::parseStream ( std::istream &  in)
virtual
Parse method.
Parameters
inStream to parse.
Definition at line 59 of file ossimNitfPiaimcTag.cpp.
References CAMSPECS_SIZE, clearFields(), CLOUDCVR_SIZE, COMGEN_SIZE, ESD_SIZE, GENERATION_SIZE, IDATUM_SIZE, IELLIP_SIZE, IPROJ_SIZE, MEANGSD_SIZE, OTHERCOND_SIZE, PIAMSNNUM_SIZE, PREPROC_SIZE, PROJID_SIZE, SATTRACK_SIZE, SENSMODE_SIZE, SENSNAME_SIZE, SOURCE_SIZE, SRP_SIZE, SUBQUAL_SIZE, theCamspecs, theCloudcvr, theComgen, theEsd, theGeneration, theIdatum, theIellip, theIproj, theMeanGsd, theOthercond, thePiamsnnum, thePreproc, theProjid, theSattrack, theSensname, theSource, theSrp, thesSensmode, and theSubqual.
60 {
61  clearFields();
62
63  in.read(theCloudcvr, CLOUDCVR_SIZE);
64  in.read(theSrp, SRP_SIZE);
65  in.read(thesSensmode, SENSMODE_SIZE);
66  in.read(theSensname, SENSNAME_SIZE);
67  in.read(theSource, SOURCE_SIZE);
68  in.read(theComgen, COMGEN_SIZE);
69  in.read(theSubqual, SUBQUAL_SIZE);
70  in.read(thePiamsnnum, PIAMSNNUM_SIZE);
71  in.read(theCamspecs, CAMSPECS_SIZE);
72  in.read(theProjid, PROJID_SIZE);
74  in.read(theEsd, ESD_SIZE);
75  in.read(theOthercond, OTHERCOND_SIZE);
76  in.read(theMeanGsd, MEANGSD_SIZE);
77  in.read(theIdatum, IDATUM_SIZE);
78  in.read(theIellip, IELLIP_SIZE);
79  in.read(thePreproc, PREPROC_SIZE);
80  in.read(theIproj, IPROJ_SIZE);
81  in.read(theSattrack, SATTRACK_SIZE);
82 }
FIELD: SENSNAME.
FIELD: PIAMSNNUM.
FIELD: IELLIP.
FIELD: SATTRACK.
FIELD: SENSMODE.
FIELD: IPROJ.
FIELD: PROJID.
FIELD: SUBQUAL.
FIELD: SRP.
FIELD: PREPROC.
FIELD: IDATUM.
FIELD: COMGEN.
FIELD: CLOUDCVR.
FIELD: SOURCE.
FIELD: MEANGSD.
FIELD: OTHERCOND.
FIELD: CAMSPECS.
FIELD: GENERATION.
FIELD: ESD.
◆ print()
std::ostream & ossimNitfPiaimcTag::print ( std::ostream &  out,
const std::string &  prefix
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Definition at line 150 of file ossimNitfPiaimcTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theCamspecs, theCloudcvr, theComgen, theEsd, theGeneration, theIdatum, theIellip, theIproj, theMeanGsd, theOthercond, thePiamsnnum, thePreproc, theProjid, theSattrack, theSensname, theSource, theSrp, thesSensmode, and theSubqual.
152 {
153  std::string pfx = prefix;
154  pfx += getTagName();
155  pfx += ".";
156
157  out << setiosflags(std::ios::left)
158  << pfx << std::setw(24) << "CETAG:" << getTagName() << "\n"
159  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
160  << pfx << std::setw(24) << "CLOUDCVR:" << theCloudcvr << "\n"
161  << pfx << std::setw(24) << "SRP:" << theSrp << "\n"
162  << pfx << std::setw(24) << "SENSMODE:" << thesSensmode << "\n"
163  << pfx << std::setw(24) << "SENSNAME:" << theSensname << "\n"
164  << pfx << std::setw(24) << "SOURCE:" << theSource << "\n"
165  << pfx << std::setw(24) << "COMGEN:" << theComgen << "\n"
166  << pfx << std::setw(24) << "SUBQUAL:" << theSubqual << "\n"
167  << pfx << std::setw(24) << "PIAMSNNUM:" << thePiamsnnum << "\n"
168  << pfx << std::setw(24) << "CAMSPECS:" << theCamspecs << "\n"
169  << pfx << std::setw(24) << "PROJID:" << theProjid << "\n"
170  << pfx << std::setw(24) << "GENERATION:" << theGeneration << "\n"
171  << pfx << std::setw(24) << "ESD:" << theEsd << "\n"
172  << pfx << std::setw(24) << "OTHERCOND:" << theOthercond << "\n"
173  << pfx << std::setw(24) << "MEANGSD:" << theMeanGsd << "\n"
174  << pfx << std::setw(24) << "IDATUM:" << theIdatum << "\n"
175  << pfx << std::setw(24) << "IELLIP:" << theIellip << "\n"
176  << pfx << std::setw(24) << "PREPROC:" << thePreproc << "\n"
177  << pfx << std::setw(24) << "IPROJ:" << theIproj << "\n"
178  << pfx << std::setw(24) << "SATTRACK:" << theSattrack << "\n";
179
180  return out;
181 }
FIELD: SENSNAME.
FIELD: PIAMSNNUM.
virtual const std::string & getTagName() const
FIELD: IELLIP.
FIELD: SATTRACK.
FIELD: SENSMODE.
FIELD: IPROJ.
FIELD: PROJID.
FIELD: SUBQUAL.
FIELD: SRP.
virtual ossim_uint32 getTagLength() const
FIELD: PREPROC.
FIELD: IDATUM.
FIELD: COMGEN.
FIELD: CLOUDCVR.
FIELD: SOURCE.
FIELD: MEANGSD.
FIELD: OTHERCOND.
FIELD: CAMSPECS.
FIELD: GENERATION.
FIELD: ESD.
◆ setProperty()
void ossimNitfPiaimcTag::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 295 of file ossimNitfPiaimcTag.cpp.
References ossimNitfRegisteredTag::setProperty().
296 {
298 }
◆ writeStream()
void ossimNitfPiaimcTag::writeStream ( std::ostream &  out)
virtual
Write method.
Parameters
outStream to write to.
Definition at line 84 of file ossimNitfPiaimcTag.cpp.
85 {
86  out.write(theCloudcvr, CLOUDCVR_SIZE);
87  out.write(theSrp, SRP_SIZE);
88  out.write(thesSensmode, SENSMODE_SIZE);
89  out.write(theSensname, SENSNAME_SIZE);
90  out.write(theSource, SOURCE_SIZE);
91  out.write(theComgen, COMGEN_SIZE);
92  out.write(theSubqual, SUBQUAL_SIZE);
93  out.write(thePiamsnnum, PIAMSNNUM_SIZE);
94  out.write(theCamspecs, CAMSPECS_SIZE);
95  out.write(theProjid, PROJID_SIZE);
96  out.write(theGeneration, GENERATION_SIZE);
97  out.write(theEsd, ESD_SIZE);
98  out.write(theOthercond, OTHERCOND_SIZE);
99  out.write(theMeanGsd, MEANGSD_SIZE);
100  out.write(theIdatum, IDATUM_SIZE);
101  out.write(theIellip, IELLIP_SIZE);
102  out.write(thePreproc, PREPROC_SIZE);
103  out.write(theIproj, IPROJ_SIZE);
104  out.write(theSattrack, SATTRACK_SIZE);
105 }
FIELD: SENSNAME.
FIELD: PIAMSNNUM.
FIELD: IELLIP.
FIELD: SATTRACK.
FIELD: SENSMODE.
FIELD: IPROJ.
FIELD: PROJID.
FIELD: SUBQUAL.
FIELD: SRP.
FIELD: PREPROC.
FIELD: IDATUM.
FIELD: COMGEN.
FIELD: CLOUDCVR.
FIELD: SOURCE.
FIELD: MEANGSD.
FIELD: OTHERCOND.
FIELD: CAMSPECS.
FIELD: GENERATION.
FIELD: ESD.
Member Data Documentation
◆ theCamspecs
char ossimNitfPiaimcTag::theCamspecs[CAMSPECS_SIZE+1]
protected
FIELD: CAMSPECS.
32 byte field
Specifies the brand name of the camera used and the focal length of the lens.
alphanumeric
Definition at line 297 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getCamspecsString(), parseStream(), print(), and writeStream().
◆ theCloudcvr
char ossimNitfPiaimcTag::theCloudcvr[CLOUDCVR_SIZE+1]
protected
FIELD: CLOUDCVR.
3 byte field
Indicates the precentage of the image that is obscured by cloud. A value os 999 indicates an unknown condition.
000 to 100, or 999
Definition at line 208 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getCloudcvrString(), parseStream(), print(), and writeStream().
◆ theComgen
char ossimNitfPiaimcTag::theComgen[COMGEN_SIZE+1]
protected
FIELD: COMGEN.
2 byte field
Compression Generation.
00 to 99
Definition at line 263 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getComgenString(), parseStream(), print(), and writeStream().
◆ theEsd
char ossimNitfPiaimcTag::theEsd[ESD_SIZE+1]
protected
FIELD: ESD.
1 byte field
Indicates whether or not Exploitation Support Data is available and contained withing the product data.
Y,N
Definition at line 332 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getEsdString(), parseStream(), print(), and writeStream().
◆ theGeneration
char ossimNitfPiaimcTag::theGeneration[GENERATION_SIZE+1]
protected
FIELD: GENERATION.
1 byte field
Specifies the number of image generations of the product. The number(0) is reserved for the original product.
0 to 9
Definition at line 320 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getGenerationString(), parseStream(), print(), and writeStream().
◆ theIdatum
char ossimNitfPiaimcTag::theIdatum[IDATUM_SIZE+1]
protected
FIELD: IDATUM.
3 byte field
Identifies the mathematical representation of the earth used to geo-correct/or to rectify the image. (Identifies the Datum assiciated with IGEOLO.)
Horizontal_Reference_Datum_Code(refer to DDDS element)
Definition at line 368 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getIdatumString(), parseStream(), print(), and writeStream().
◆ theIellip
char ossimNitfPiaimcTag::theIellip[IELLIP_SIZE+1]
protected
FIELD: IELLIP.
3 byte field
Identifies the mathematical representation of the earth used to geo-correct/or to rectify the image. (Identifies the Ellipsoid assiciated with IGEOLO.)
Definition at line 379 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getIellipString(), parseStream(), print(), and writeStream().
◆ theIproj
char ossimNitfPiaimcTag::theIproj[IPROJ_SIZE+1]
protected
FIELD: IPROJ.
2 byte field
Identifies the 2D-map projection used by commercial vendors to geo-correct/or to rectify the image.
DIGEST, Part 3 table 6-1
Definition at line 403 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getIprojString(), parseStream(), print(), and writeStream().
◆ theMeanGsd
char ossimNitfPiaimcTag::theMeanGsd[MEANGSD_SIZE+1]
protected
FIELD: MEANGSD.
7 byte field
The geometric mean of the across and along scan center-to-center distance between contiguous ground samples.
00000.0 to 99999.9 Expressed in inches, accuracy=10%
Definition at line 355 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getMeadGsdString(), getMeanGsdInMeters(), parseStream(), print(), and writeStream().
◆ theOthercond
char ossimNitfPiaimcTag::theOthercond[OTHERCOND_SIZE+1]
protected
FIELD: OTHERCOND.
2 byte field
Indicates other conditions that affect the imagery over the target.
EARS 1.1 page 4 to 28
Definition at line 343 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getOthercondString(), parseStream(), print(), and writeStream().
◆ thePiamsnnum
char ossimNitfPiaimcTag::thePiamsnnum[PIAMSNNUM_SIZE+1]
protected
FIELD: PIAMSNNUM.
7 byte field
Indicates the mission number assigned to the reconnaissance mission.
EARS 1.1 page 4-28
Definition at line 285 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getPiamsnnumString(), parseStream(), print(), and writeStream().
◆ thePreproc
char ossimNitfPiaimcTag::thePreproc[PREPROC_SIZE+1]
protected
FIELD: PREPROC.
2 byte field
Identifies the level of radiometric and geometric processing applied to the product by the commercial vendor.
USIGS DM, IMAGEDATASET Processing Level Code.
Definition at line 391 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getPreprocString(), parseStream(), print(), and writeStream().
◆ theProjid
char ossimNitfPiaimcTag::theProjid[PROJID_SIZE+1]
protected
FIELD: PROJID.
2 byte field
Indentifies collection platform project identifier code.
EARS Appendix 9
Definition at line 308 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getProjidString(), parseStream(), print(), and writeStream().
◆ theSattrack
char ossimNitfPiaimcTag::theSattrack[SATTRACK_SIZE+1]
protected
FIELD: SATTRACK.
8 byte field
Identifies location of an image acquired by LANDSAT or SPOT (only) along the satellite path.
Minimum values: PATH(J)=0001 ROW(K) =0001 Maximum values: PATH(J)=9999 ROW(K) =9999
Recorded as PATH/ROW 00010001
Definition at line 422 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSattrackString(), parseStream(), print(), and writeStream().
◆ theSensname
char ossimNitfPiaimcTag::theSensname[SENSNAME_SIZE+1]
protected
FIELD: SENSNAME.
18 byte field
Indentifies the name of sensor used in capturing the image.
USIGS DM, SENSORTYPE Name
Definition at line 241 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSensnameString(), parseStream(), print(), and writeStream().
◆ theSource
char ossimNitfPiaimcTag::theSource[SOURCE_SIZE+1]
protected
FIELD: SOURCE.
18 byte field
Indicated where the image came from.
alphanumeric
Definition at line 252 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSourceString(), parseStream(), print(), and writeStream().
◆ theSrp
char ossimNitfPiaimcTag::theSrp[SRP_SIZE+1]
protected
FIELD: SRP.
1 byte field
Indicates whether or not standard radiometric product data is available.
Y,N
Definition at line 219 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSrpString(), parseStream(), print(), and writeStream().
◆ thesSensmode
char ossimNitfPiaimcTag::thesSensmode[SENSMODE_SIZE+1]
protected
FIELD: SENSMODE.
12 byte field
Indentifies the sensor mode used in capturing the image.
WHISKBROOM, PUSHROOM, FRAMING, SPOT, SWATH, TBD
Definition at line 230 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSensmodeString(), parseStream(), print(), and writeStream().
◆ theSubqual
char ossimNitfPiaimcTag::theSubqual[SUBQUAL_SIZE+1]
protected
FIELD: SUBQUAL.
1 byte field
Subjective Quality
P-Poor, G-Good, E-Excellent, F-Fair
Definition at line 274 of file ossimNitfPiaimcTag.h.
Referenced by clearFields(), getSubqualString(), parseStream(), print(), and writeStream().
