Public Member Functions | Protected Attributes | List of all members
ossimNitfProjectionParameterTag Class Reference
#include <ossimNitfProjectionParameterTag.h>
Inheritance diagram for ossimNitfProjectionParameterTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
 ossimNitfProjectionParameterTag ()
virtual ~ossimNitfProjectionParameterTag ()
virtual void parseStream (std::istream &in)
virtual void writeStream (std::ostream &out)
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Print method that outputs a key/value type format adding prefix to keys. More...
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual void clearFields ()
virtual void clearParameters ()
virtual void addParameter (const ossimString &param)
virtual void addParameter (const ossim_float64 &param)
void setName (const ossimString &name)
void setCode (const ossimString &code)
ossimString getName () const
ossimString getCode () const
void setFalseX (double falseX)
void setFalseY (double falseY)
double getFalseX () const
double getFalseY () const
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 default constructor More...
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char theProjectionName [81]
 FIELD: PRN. More...
char theProjectionCode [3]
 FIELD: PCO. More...
char theNumberOfParameters [2]
 FIELD: NUM_PRJ. More...
std::vector< ossimStringtheProjectionParameters
 FIELD(S): PRJn. More...
char theFalseXOrigin [16]
 FIELD: XOR. More...
char theFalseYOrigin [16]
 FIELD: YOR. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 18 of file ossimNitfProjectionParameterTag.h.
◆ ossimNitfProjectionParameterTag()
ossimNitfProjectionParameterTag::ossimNitfProjectionParameterTag ( )
Definition at line 16 of file ossimNitfProjectionParameterTag.cpp.
References clearFields().
17  :ossimNitfRegisteredTag(std::string("PRJPSB"), 0 )
18 {
19  clearFields();
20 }
ossimNitfRegisteredTag()
default constructor
◆ ~ossimNitfProjectionParameterTag()
ossimNitfProjectionParameterTag::~ossimNitfProjectionParameterTag ( )
virtual
Definition at line 22 of file ossimNitfProjectionParameterTag.cpp.
23 {
24 }
Member Function Documentation
◆ addParameter() [1/2]
void ossimNitfProjectionParameterTag::addParameter ( const ossimString param)
virtual
Definition at line 134 of file ossimNitfProjectionParameterTag.cpp.
References ossimString::c_str(), and theProjectionParameters.
Referenced by addParameter().
135 {
136  std::ostringstream out;
137
138  out << std::setw(15)
139  << std::setfill('0')
140  << param.c_str();
141
142  theProjectionParameters.push_back(out.str());
143 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
std::vector< ossimString > theProjectionParameters
FIELD(S): PRJn.
const char * c_str() const
Definition: ossimString.h:396
◆ addParameter() [2/2]
void ossimNitfProjectionParameterTag::addParameter ( const ossim_float64 param)
virtual
Definition at line 145 of file ossimNitfProjectionParameterTag.cpp.
References addParameter(), and ossimString::toString().
146 {
148 }
Numeric to string methods.
virtual void addParameter(const ossimString &param)
◆ clearFields()
void ossimNitfProjectionParameterTag::clearFields ( )
virtual
Definition at line 108 of file ossimNitfProjectionParameterTag.cpp.
References ossimNitfRegisteredTag::setTagLength(), theFalseXOrigin, theFalseYOrigin, theNumberOfParameters, theProjectionCode, theProjectionName, and theProjectionParameters.
Referenced by ossimNitfProjectionParameterTag(), and parseStream().
109 {
110  theProjectionParameters.clear();
111
112  memset(theProjectionName, ' ', 80);
113  memset(theProjectionCode, ' ', 2);
114  memset(theNumberOfParameters, '0', 1);
115  memset(theFalseXOrigin, '0', 15);
116  memset(theFalseYOrigin, '0', 15);
117
118  theProjectionName[80] = '\0';
119  theProjectionCode[2] = '\0';
120  theNumberOfParameters[1] = '\0';
121  theFalseXOrigin[15] = '\0';
122  theFalseYOrigin[15] = '\0';
123
124  // Set the base tag length.
125  setTagLength( 0 );
126 }
FIELD(S): PRJn.
virtual void setTagLength(ossim_uint32 length)
Set the tag length.
◆ clearParameters()
void ossimNitfProjectionParameterTag::clearParameters ( )
virtual
Definition at line 128 of file ossimNitfProjectionParameterTag.cpp.
References theNumberOfParameters, and theProjectionParameters.
129 {
130  theProjectionParameters.clear();
131  theNumberOfParameters[0] = '0';
132 }
FIELD(S): PRJn.
◆ getCode()
ossimString ossimNitfProjectionParameterTag::getCode ( ) const
Definition at line 177 of file ossimNitfProjectionParameterTag.cpp.
References theProjectionCode, and ossimString::trim().
178 {
180 }
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
◆ getFalseX()
double ossimNitfProjectionParameterTag::getFalseX ( ) const
Definition at line 204 of file ossimNitfProjectionParameterTag.cpp.
References theFalseXOrigin, and ossimString::toDouble().
205 {
207 }
double toDouble() const
◆ getFalseY()
double ossimNitfProjectionParameterTag::getFalseY ( ) const
Definition at line 209 of file ossimNitfProjectionParameterTag.cpp.
References theFalseYOrigin, and ossimString::toDouble().
210 {
212 }
◆ getName()
ossimString ossimNitfProjectionParameterTag::getName ( ) const
Definition at line 172 of file ossimNitfProjectionParameterTag.cpp.
References theProjectionName, and ossimString::trim().
173 {
175 }
◆ getSizeInBytes()
ossim_uint32 ossimNitfProjectionParameterTag::getSizeInBytes ( ) const
virtual
Note
Depricated use: getTagLength()
The entire TRE length is 11 plus this(the size of the CEL or REL field).
Returns
Length of REDATA or CEDATA.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 74 of file ossimNitfProjectionParameterTag.cpp.
References theProjectionParameters.
Referenced by parseStream().
75 {
76  return (113 + (ossim_uint32)theProjectionParameters.size()*15);
77 }
FIELD(S): PRJn.
unsigned int ossim_uint32
◆ parseStream()
void ossimNitfProjectionParameterTag::parseStream ( std::istream &  in)
virtual
Definition at line 26 of file ossimNitfProjectionParameterTag.cpp.
References clearFields(), getSizeInBytes(), ossimNitfRegisteredTag::setTagLength(), theFalseXOrigin, theFalseYOrigin, theNumberOfParameters, theProjectionCode, theProjectionName, theProjectionParameters, and ossimString::toUInt32().
27 {
28  clearFields();
29
30  in.read(theProjectionName, 80);
31  in.read(theProjectionCode, 2);
32  in.read(theNumberOfParameters, 1);
33
35
36  for(ossim_uint32 i = 0; i < numberOfParameters; ++i)
37  {
38  char param[15];
39
40  in.read(param, 15);
41  theProjectionParameters.push_back(ossimString(param,
42  param + 15));
43  }
44  in.read(theFalseXOrigin, 15);
45  in.read(theFalseYOrigin, 15);
46
47  // Set the base tag length.
49 }
FIELD(S): PRJn.
ossim_uint32 toUInt32() const
Set the tag length.
virtual ossim_uint32 getSizeInBytes() const
◆ print()
std::ostream & ossimNitfProjectionParameterTag::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Definition at line 79 of file ossimNitfProjectionParameterTag.cpp.
References ossimNitfRegisteredTag::getRegisterTagName(), ossimNitfRegisteredTag::getTagLength(), theFalseXOrigin, theFalseYOrigin, theNumberOfParameters, theProjectionCode, theProjectionName, theProjectionParameters, and ossimString::toString().
81 {
82  std::string pfx = prefix;
83  pfx += getRegisterTagName();
84  pfx += ".";
85
86  out << setiosflags(std::ios::left)
87  << pfx << std::setw(24) << "CETAG:" << getRegisterTagName() << "\n"
88  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
89  << pfx << std::setw(24) << "PRN:" << theProjectionName << "\n"
90  << pfx << std::setw(24) << "PCO:" << theProjectionCode << "\n"
91  << pfx << std::setw(24) << "NUM_PRJ:" << theNumberOfParameters << "\n";
92
93  for (ossim_uint32 i = 0; i < theProjectionParameters.size(); ++i)
94  {
95  ossimString s = "PRJ";
96  s += ossimString::toString(i);
97  s += ":";
98  out << pfx << std::setw(24) << s
99  << theProjectionParameters[i] << "\n";
100  }
101
102  out << pfx << std::setw(24) << "XOR:" <<theFalseXOrigin << "\n"
103  << pfx << std::setw(24) << "YOR:" <<theFalseYOrigin << std::endl;
104
105  return out;
106 }
virtual std::string getRegisterTagName() const
FIELD(S): PRJn.
virtual ossim_uint32 getTagLength() const
◆ setCode()
void ossimNitfProjectionParameterTag::setCode ( const ossimString code)
Definition at line 161 of file ossimNitfProjectionParameterTag.cpp.
References ossimString::c_str(), and theProjectionCode.
162 {
163  std::ostringstream out;
164
165  out << std::setw(2)
166  << std::setfill(' ')
167  << code.c_str();
168
169  memcpy(theProjectionCode, out.str().c_str(), 2);
170 }
◆ setFalseX()
void ossimNitfProjectionParameterTag::setFalseX ( double  falseX)
Definition at line 182 of file ossimNitfProjectionParameterTag.cpp.
References theFalseXOrigin.
183 {
184  std::ostringstream out;
185  out << std::setw(15)
186  << std::setprecision(15)
187  << std::setfill('0')
188  << falseX;
189
190  memcpy(theFalseXOrigin, out.str().c_str(), 15);
191 }
◆ setFalseY()
void ossimNitfProjectionParameterTag::setFalseY ( double  falseY)
Definition at line 193 of file ossimNitfProjectionParameterTag.cpp.
References theFalseYOrigin.
194 {
195  std::ostringstream out;
196  out << std::setw(15)
197  << std::setprecision(15)
198  << std::setfill('0')
199  << falseY;
200
201  memcpy(theFalseYOrigin, out.str().c_str(), 15);
202 }
◆ setName()
void ossimNitfProjectionParameterTag::setName ( const ossimString name)
Definition at line 150 of file ossimNitfProjectionParameterTag.cpp.
References ossimString::c_str(), and theProjectionName.
151 {
152  std::ostringstream out;
153
154  out << std::setw(80)
155  << std::setfill(' ')
156  << name.c_str();
157
158  memcpy(theProjectionName, out.str().c_str(), 80);
159 }
◆ writeStream()
void ossimNitfProjectionParameterTag::writeStream ( std::ostream &  out)
virtual
Definition at line 51 of file ossimNitfProjectionParameterTag.cpp.
References theFalseXOrigin, theFalseYOrigin, theNumberOfParameters, theProjectionCode, theProjectionName, theProjectionParameters, and ossimString::toUInt32().
52 {
53  out.write(theProjectionName, 80);
54  out.write(theProjectionCode, 2);
55
56  {
57  std::ostringstream tempOut;
58
59  tempOut << std::setw(1)
60  << theProjectionParameters.size();
61  theNumberOfParameters[0] = *(tempOut.str().c_str());
62  }
63  out.write(theNumberOfParameters, 1);
65
66  for(ossim_uint32 i = 0; i < numberOfParameters; ++i)
67  {
68  out.write(theProjectionParameters[i].c_str(), 15);
69  }
70  out.write(theFalseXOrigin, 15);
71  out.write(theFalseYOrigin, 15);
72 }
FIELD(S): PRJn.
Member Data Documentation
◆ theFalseXOrigin
char ossimNitfProjectionParameterTag::theFalseXOrigin[16]
protected
FIELD: XOR.
required 15 byte field.
Projection False X (Easting) Origin
This field shall contain the projection false X (easting) origin. The default value is 000000000000000, which implies that there is no projection false X origin.
Definition at line 314 of file ossimNitfProjectionParameterTag.h.
Referenced by clearFields(), getFalseX(), parseStream(), print(), setFalseX(), and writeStream().
◆ theFalseYOrigin
char ossimNitfProjectionParameterTag::theFalseYOrigin[16]
protected
FIELD: YOR.
Projection False Y (Northing) Origin
This field shall contain the projection false Y (northing) origin. The default value is 000000000000000, which implies that there is no projection false Y origin.
Definition at line 329 of file ossimNitfProjectionParameterTag.h.
Referenced by clearFields(), getFalseY(), parseStream(), print(), setFalseY(), and writeStream().
◆ theNumberOfParameters
char ossimNitfProjectionParameterTag::theNumberOfParameters[2]
protected
FIELD: NUM_PRJ.
required 1 byte field ranging from 0-9
Number of Projection Parameters
This field shall contain the number of projection parameters. The PRJ Field should be repeated as necessary depending on the projection code (see Part 3-6). If the number of projection parameters provided is lower than specified in Part 3-6, the missing parameters value is 0.
Definition at line 290 of file ossimNitfProjectionParameterTag.h.
Referenced by clearFields(), clearParameters(), parseStream(), print(), and writeStream().
◆ theProjectionCode
char ossimNitfProjectionParameterTag::theProjectionCode[3]
protected
FIELD: PCO.
required 2 byte field.
Projection Code
This field shall contain the code of the projection to which the Image Segment refers. The default value is TC.
Code values:
AC Albers Equal-Area Conic Parameters:
  1. Longitude of origin
  2. std. parallel nearer to equator
  3. std parallel farther from equator
  4. latitude of origin
AK (Lambert) Azimuthal Equal-Area Parameters:
  2. Latitude of origin
AL Azimuthal Equidistant Parameters:
BF Bonne Parameters:
  3. Scale factor at projection origin
CC Equidistant Conic with 1 Standard Parallel Parameters:
  3. Latitude of Std. Parallel
CP Equirectangular Parameters:
  1. Longitude of central meridian
  2. Latitude of true scale
  3. Radius of sphere
CS Cassini-Soldner Parameters:
ED Eckert VI Parameters:
  2. Radius of sphere
EF Eckert IV Parameters:
  2. Radius of sphere
GN Gnomonic Parameters:
HX Hotine Oblique Mercator based on 2 Points Parameters:
  1. Scale factor at projection origin
  2. latitude of projection origin
  3. longitude of first point defining center line
  4. latitude of fist point defining center line
KA Equidistant Conic with 2 Standard Parallels Parameters:
  3. Latitude of standard parallel Nearer to equator
  4. Latitude of standard parallel farther from equator
LA Laborde Parameters:
  3. Scale factor at proj origin
  4. Azimuth at origin of axis of constant scale
LE Lambert Conformal Conic Parameters:
  3. std. parallel farther from equator
  4. Latitude of origin
LI Cylindrical Equal Area Parameters:
LJ Lambert Equal-Area Meridional Parameters:
MC Mercator Parameters:
  3. Latitude of reference origin
MH Miller Cylindrical Parameters:
  2. Radius of sphere
MJ French Lambert Parameters:
MP Mollweide Parameters:
  2. Radius of sphere
NT New Zealand Map Grid Parameters:
OC Oblique Mercator Parameters:
  3. Azimuth
  4. radius of sphere
OD Orthographic Parameters:
  3. Radius of sphere
PG Polar Stereographic Parameters:
  1. Latitude of true scale
PH Polyconic Parameters:
RS or RB Hotine Oblique Mercator (Rectified Skew Orthomorphic) Parameters:
  3. Azimuth East of North for Central Line (Skew X-Axis at Proj. origin)
  4. Scale factor at proj origin
RX Robinson Parameters:
  2. Radius of sphere
SA Sinusoidal Parameters:
  2. Radius of sphere
SD Oblique Stereographic Parameters:
  3. Scale factor at origin
SX Space Oblique Mercator Parameters:
  1. Application code: 1 = Landsat, USGS equations 2 = Landsat, EOSAT equations
  2. Vehicle number
  3. Orbital path number
TC Transverse Mercator Parameters:
  2. Central Scale Factor
  3. Latitude of origin
TX Transverse Cylindrical Equal Area Parameters:
  3. Scale factor along central meridian
VA Van der Grinten Parameters:
  2. Radius of sphere
VX General Vertical NearSide Perspective Parameters:
  3. Heigh of perspective map above surface
ZY Other Known Projection
Definition at line 274 of file ossimNitfProjectionParameterTag.h.
Referenced by clearFields(), getCode(), parseStream(), print(), setCode(), and writeStream().
◆ theProjectionName
char ossimNitfProjectionParameterTag::theProjectionName[81]
protected
FIELD: PRN.
required 80 byte field.
Projection Name
This field shall contain the name of the projection to which the Image Segment refers. The default value is Transverse Mercator.
Definition at line 61 of file ossimNitfProjectionParameterTag.h.
Referenced by clearFields(), getName(), parseStream(), print(), setName(), and writeStream().
◆ theProjectionParameters
std::vector<ossimString> ossimNitfProjectionParameterTag::theProjectionParameters
protected
FIELD(S): PRJn.
Conditional 15 byte field each.
Projection Parameter Each occurrence of this field provides an appropriate parameter to accurately describe the projection. See Part 3-6 to know the kind of parameters needed for each projection code. 15 BCS-N C
Definition at line 301 of file ossimNitfProjectionParameterTag.h.
Referenced by addParameter(), clearFields(), clearParameters(), getSizeInBytes(), parseStream(), print(), and writeStream().
