The layout of RPC00B is the same as RPC00A. More...
#include <ossimNitfRpcATag.h>
ossimNitfRpcATag () | |
ossimNitfRpcBase () | |
default constructor More... | |
virtual void | parseStream (std::istream &in) |
Parse method. More... | |
virtual void | writeStream (std::ostream &out) |
Write method. More... | |
virtual void | clearFields () |
Clears all string fields within the record to some default nothingness. More... | |
virtual void | setRpcModelParams (ossimRefPtr< ossimRpcModel > rpc) |
For generating the RPC tag from existing RPC Model. More... | |
bool | getSuccess () const |
void | setSuccess (bool success) |
ossimString | getErrorBias () const |
void | setErrorBias (const ossim_float64 &errorBias) |
void | setErrorBias (const ossimString &errorBias) |
ossimString | getErrorRand () const |
void | setErrorRand (const ossim_float64 &errorRand) |
void | setErrorRand (const ossimString &errorRand) |
ossimString | getLineOffset () const |
void | setLineOffset (ossim_uint32 lineOffset) |
void | setLineOffset (const ossimString &lineOffset) |
ossimString | getSampleOffset () const |
void | setSampleOffset (ossim_uint32 sampleOffset) |
void | setSampleOffset (const ossimString &sampleOffset) |
ossimString | getGeodeticLatOffset () const |
void | setGeodeticLatOffset (const ossim_float64 &geodeticLatOffset) |
void | setGeodeticLatOffset (const ossimString &geodeticLatOffset) |
ossimString | getGeodeticLonOffset () const |
void | setGeodeticLonOffset (const ossim_float64 &geodeticLonOffset) |
void | setGeodeticLonOffset (const ossimString &geodeticLonOffset) |
ossimString | getGeodeticHeightOffset () const |
void | setGeodeticHeightOffset (ossim_int32 geodeticHeightOffset) |
void | setGeodeticHeightOffset (const ossimString &geodeticHeightOffset) |
ossimString | getLineScale () const |
void | setLineScale (ossim_uint32 lineScale) |
void | setLineScale (const ossimString &lineScale) |
ossimString | getSampleScale () const |
void | setSampleScale (ossim_uint32 sampleScale) |
void | setSampleScale (const ossimString &sampleScale) |
ossimString | getGeodeticLatScale () const |
void | setGeodeticLatScale (const ossim_float64 &geodeticLatScale) |
void | setGeodeticLatScale (const ossimString &geodeticLatScale) |
ossimString | getGeodeticLonScale () const |
void | setGeodeticLonScale (const ossim_float64 &geodeticLonScale) |
void | setGeodeticLonScale (const ossimString &geodeticLonScale) |
ossimString | getGeodeticHeightScale () const |
void | setGeodeticHeightScale (ossim_int32 geodeticHeightScale) |
void | setGeodeticHeightScale (const ossimString &geodeticHeightScale) |
ossimString | getLineNumeratorCoeff (ossim_uint32 idx) const |
void | setLineNumeratorCoeff (const std::vector< ossim_float64 > &coeff) |
void | setLineNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff) |
ossimString | getLineDenominatorCoeff (ossim_uint32 idx) const |
void | setLineDenominatorCoeff (const std::vector< ossim_float64 > &coeff) |
void | setLineDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff) |
ossimString | getSampleNumeratorCoeff (ossim_uint32 idx) const |
void | setSampleNumeratorCoeff (const std::vector< ossim_float64 > &coeff) |
void | setSampleNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff) |
ossimString | getSampleDenominatorCoeff (ossim_uint32 idx) const |
void | setSampleDenominatorCoeff (const std::vector< ossim_float64 > &coeff) |
void | setSampleDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff) |
virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
Print method that outputs a key/value type format adding prefix to keys. More... | |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
ossimNitfRegisteredTag () | |
ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
Constructor that takes name and size. More... | |
virtual | ~ossimNitfRegisteredTag () |
destructor More... | |
virtual std::string | getRegisterTagName () const |
This will return the name of the registered tag for this user defined header. More... | |
virtual const std::string & | getTagName () const |
virtual void | setTagName (const std::string &tagName) |
virtual ossim_uint32 | getSizeInBytes () const |
Returns the length in bytes of the tag from the CEL or REL field. More... | |
virtual ossim_uint32 | getTagLength () const |
virtual void | setTagLength (ossim_uint32 length) |
Set the tag length. More... | |
virtual void | parseStream (ossim::istream &in)=0 |
This will allow the user defined data to parse the stream. More... | |
virtual void | writeStream (ossim::ostream &out)=0 |
virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
Default interface to populate keyword list with metadata. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
The difference is how the coefficients are used; hence, all the code is in the ossimNitfRpcBase class.
Definition at line 24 of file ossimNitfRpcATag.h.
ossimNitfRpcATag::ossimNitfRpcATag | ( | ) |
Definition at line 19 of file ossimNitfRpcATag.cpp.
References ossimNitfRegisteredTag::setTagName().
