Public Member Functions | List of all members
ossimNitfRpcBTag Class Reference
The layout of RPC00B is the same as RPC00A. More...
#include <ossimNitfRpcBTag.h>
Inheritance diagram for ossimNitfRpcBTag:
ossimNitfRpcBase ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
 ossimNitfRpcBTag ()
- Public Member Functions inherited from ossimNitfRpcBase
 ossimNitfRpcBase ()
 default constructor More...
virtual void parseStream (std::istream &in)
 Parse method. More...
virtual void writeStream (std::ostream &out)
 Write method. More...
virtual void clearFields ()
 Clears all string fields within the record to some default nothingness. More...
virtual void setRpcModelParams (ossimRefPtr< ossimRpcModel > rpc)
 For generating the RPC tag from existing RPC Model. More...
bool getSuccess () const
void setSuccess (bool success)
ossimString getErrorBias () const
void setErrorBias (const ossim_float64 &errorBias)
void setErrorBias (const ossimString &errorBias)
ossimString getErrorRand () const
void setErrorRand (const ossim_float64 &errorRand)
void setErrorRand (const ossimString &errorRand)
ossimString getLineOffset () const
void setLineOffset (ossim_uint32 lineOffset)
void setLineOffset (const ossimString &lineOffset)
ossimString getSampleOffset () const
void setSampleOffset (ossim_uint32 sampleOffset)
void setSampleOffset (const ossimString &sampleOffset)
ossimString getGeodeticLatOffset () const
void setGeodeticLatOffset (const ossim_float64 &geodeticLatOffset)
void setGeodeticLatOffset (const ossimString &geodeticLatOffset)
ossimString getGeodeticLonOffset () const
void setGeodeticLonOffset (const ossim_float64 &geodeticLonOffset)
void setGeodeticLonOffset (const ossimString &geodeticLonOffset)
ossimString getGeodeticHeightOffset () const
void setGeodeticHeightOffset (ossim_int32 geodeticHeightOffset)
void setGeodeticHeightOffset (const ossimString &geodeticHeightOffset)
ossimString getLineScale () const
void setLineScale (ossim_uint32 lineScale)
void setLineScale (const ossimString &lineScale)
ossimString getSampleScale () const
void setSampleScale (ossim_uint32 sampleScale)
void setSampleScale (const ossimString &sampleScale)
ossimString getGeodeticLatScale () const
void setGeodeticLatScale (const ossim_float64 &geodeticLatScale)
void setGeodeticLatScale (const ossimString &geodeticLatScale)
ossimString getGeodeticLonScale () const
void setGeodeticLonScale (const ossim_float64 &geodeticLonScale)
void setGeodeticLonScale (const ossimString &geodeticLonScale)
ossimString getGeodeticHeightScale () const
void setGeodeticHeightScale (ossim_int32 geodeticHeightScale)
void setGeodeticHeightScale (const ossimString &geodeticHeightScale)
ossimString getLineNumeratorCoeff (ossim_uint32 idx) const
void setLineNumeratorCoeff (const std::vector< ossim_float64 > &coeff)
void setLineNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff)
ossimString getLineDenominatorCoeff (ossim_uint32 idx) const
void setLineDenominatorCoeff (const std::vector< ossim_float64 > &coeff)
void setLineDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff)
ossimString getSampleNumeratorCoeff (ossim_uint32 idx) const
void setSampleNumeratorCoeff (const std::vector< ossim_float64 > &coeff)
void setSampleNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff)
ossimString getSampleDenominatorCoeff (ossim_uint32 idx) const
void setSampleDenominatorCoeff (const std::vector< ossim_float64 > &coeff)
void setSampleDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff)
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Print method that outputs a key/value type format adding prefix to keys. More...
bool loadState (const ossimKeywordlist &kwl, const char *prefix)
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
Additional Inherited Members
- Public Types inherited from ossimNitfRpcBase
enum  {
  SUCCESS_SIZE = 1, ERROR_BIAS_SIZE = 7, ERR_RAND_SIZE = 7, LINE_OFFSET_SIZE = 6,
  SAMPLE_OFFSET_SIZE = 5, GEODETIC_LAT_OFFSET_SIZE = 8, GEODETIC_LON_OFFSET_SIZE = 9, GEODETIC_HEIGHT_OFFSET_SIZE = 5,
  LINE_SCALE_SIZE = 6, SAMPLE_SCALE_SIZE = 5, GEODETIC_LAT_SCALE_SIZE = 8, GEODETIC_LON_SCALE_SIZE = 9,
  GEODETIC_HEIGHT_SCALE_SIZE = 5, LINE_NUMERATOR_COEFFICIENT_SIZE = 12, LINE_NUMERATOR_COEFFICIENT_COUNT = 20, LINE_DENOMINATOR_COEFFICIENT_SIZE = 12,
  LINE_DENOMINATOR_COEFFICIENT_COUNT = 20, SAMPLE_NUMERATOR_COEFFICIENT_SIZE = 12, SAMPLE_NUMERATOR_COEFFICIENT_COUNT = 20, SAMPLE_DENOMINATOR_COEFFICIENT_SIZE = 12,
  SAMPLE_DENOMINATOR_COEFFICIENT_COUNT = 20
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimNitfRpcBase
char theSuccess [SUCCESS_SIZE+1]
 FIELD: SUCCESS. More...
char theErrorBias [ERROR_BIAS_SIZE+1]
 FIELD: ERR_BIAS. More...
char theErrRand [ERR_RAND_SIZE+1]
 FIELD ERR_RAND. More...
char theLineOffset [LINE_OFFSET_SIZE+1]
 FIELD: LINE_OFF. More...
char theSampleOffset [SAMPLE_OFFSET_SIZE+1]
 FIELD: SAMP_OFF. More...
char theGeodeticLatOffset [GEODETIC_LAT_OFFSET_SIZE+1]
 FIELD: LAT_OFF. More...
char theGeodeticLonOffset [GEODETIC_LON_OFFSET_SIZE+1]
 FIELD: LONG_OFF. More...
char theGeodeticHeightOffset [GEODETIC_HEIGHT_OFFSET_SIZE+1]
 FIELD: HEIGHT_OFF. More...
char theLineScale [LINE_SCALE_SIZE+1]
 FIELD: LINE_SCALE. More...
char theSampleScale [SAMPLE_SCALE_SIZE+1]
 FIELD: SAMP_SCALE. More...
char theGeodeticLatScale [GEODETIC_LAT_SCALE_SIZE+1]
 FIELD: LAT_SCALE. More...
char theGeodeticLonScale [GEODETIC_LON_SCALE_SIZE+1]
 FIELD: LON_SCALE. More...
char theGeodeticHeightScale [GEODETIC_HEIGHT_SCALE_SIZE+1]
 FIELD: HEIGHT_SCALE. More...
std::vector< ossimStringtheLineNumeratorCoefficient
 FIELD: LINE_NUM_COEFF_1 through LINE_NUM_COEFF_20. More...
std::vector< ossimStringtheLineDenominatorCoefficient
 FIELD: LINE_DEN_COEFF_1 through LINE_DEN_COEFF_20. More...
std::vector< ossimStringtheSampleNumeratorCoefficient
 FIELD: SAMP_NUM_COEFF_1 through SAMP_NUM_COEFF_20. More...
std::vector< ossimStringtheSampleDenominatorCoefficient
 FIELD: SAMP_DEN_COEFF_1 through SAMP_DEN_COEFF_20. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Detailed Description
The difference is how the coefficients are used; hence, all the code is in the ossimNitfRpcBase class.
Definition at line 22 of file ossimNitfRpcBTag.h.
◆ ossimNitfRpcBTag()
ossimNitfRpcBTag::ossimNitfRpcBTag ( )
Definition at line 17 of file ossimNitfRpcBTag.cpp.
References ossimNitfRegisteredTag::setTagName().
19 {
20  // Set the tag name in base.
21  setTagName(std::string("RPC00B"));
22 }
ossimNitfRpcBase()
default constructor
virtual void setTagName(const std::string &tagName)
