#include <ossimNitfRsmecaTag.h>
Public Types | |
enum | { IID_SIZE = 80, EDITION_SIZE = 40, TID_SIZE = 40, INCLIC_SIZE = 1, INCLUC_SIZE = 1, NPAR_SIZE = 2, NPARO_SIZE = 2, IGN_SIZE = 2, CVDATE_SIZE = 8, FLOAT21_SIZE = 21, IR_SIZE = 2, IC_SIZE = 2, G_SIZE = 2, NUMOPG_SIZE = 2, TCDF_SIZE = 1, NCSEG_SIZE = 1, UNCSR_SIZE = 1, UNCSC_SIZE = 1 } |
ossimNitfRsmecaTag () | |
virtual void | parseStream (std::istream &in) |
virtual void | writeStream (std::ostream &out) |
virtual void | clearFields () |
virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
Pure virtual print method that outputs a key/value type format adding prefix to keys. More... | |
ossimString | getIid () const |
ossimString | getEdition () const |
ossimString | getTid () const |
ossimString | getInclic () const |
ossimString | getIncluc () const |
ossimString | getNpar () const |
ossimString | getNparo () const |
ossimString | getIgn () const |
ossimString | getCvdate () const |
ossimString | getXuol () const |
ossimString | getYuol () const |
ossimString | getZuol () const |
ossimString | getXuxl () const |
ossimString | getXuyl () const |
ossimString | getXuzl () const |
ossimString | getYuxl () const |
ossimString | getYuyl () const |
ossimString | getYuzl () const |
ossimString | getZuxl () const |
ossimString | getZuyl () const |
ossimString | getZuzl () const |
ossimString | getIro () const |
ossimString | getIrx () const |
ossimString | getIry () const |
ossimString | getIrz () const |
ossimString | getIrxx () const |
ossimString | getIrxy () const |
ossimString | getIrxz () const |
ossimString | getIryy () const |
ossimString | getIryz () const |
ossimString | getIrzz () const |
ossimString | getIco () const |
ossimString | getIcx () const |
ossimString | getIcy () const |
ossimString | getIcz () const |
ossimString | getIcxx () const |
ossimString | getIcxy () const |
ossimString | getIcxz () const |
ossimString | getIcyy () const |
ossimString | getIcyz () const |
ossimString | getIczz () const |
ossimString | getGxo () const |
ossimString | getGyo () const |
ossimString | getGzo () const |
ossimString | getGxr () const |
ossimString | getGyr () const |
ossimString | getGzr () const |
ossimString | getGs () const |
ossimString | getGxx () const |
ossimString | getGxy () const |
ossimString | getGxz () const |
ossimString | getGyx () const |
ossimString | getGyy () const |
ossimString | getGyz () const |
ossimString | getGzx () const |
ossimString | getGzy () const |
ossimString | getGzz () const |
ossimNitfRsmecaIsg | getIsg (ossim_uint32 index) const |
ossimString | getMap (ossim_uint32 index) const |
ossimString | getUrr () const |
ossimString | getUrc () const |
ossimString | getUcc () const |
ossimString | getUncsr () const |
ossimString | getUcorsr (ossim_uint32 index) const |
ossimString | getUtausr (ossim_uint32 index) const |
ossimString | getUncsc () const |
ossimString | getUcorsc (ossim_uint32 index) const |
ossimString | getUtausc (ossim_uint32 index) const |
bool | getInclicFlag () const |
bool | getInclucFlag () const |
ossimString | getIgnNum () const |
ossimString | getMapNum () const |
ossimString | getRowCorSegNum () const |
ossimString | getColCorSegNum () const |
ossimNitfRegisteredTag () | |
default constructor More... | |
ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
Constructor that takes name and size. More... | |
virtual | ~ossimNitfRegisteredTag () |
destructor More... | |
virtual std::string | getRegisterTagName () const |
This will return the name of the registered tag for this user defined header. More... | |
virtual const std::string & | getTagName () const |
virtual void | setTagName (const std::string &tagName) |
virtual ossim_uint32 | getSizeInBytes () const |
Returns the length in bytes of the tag from the CEL or REL field. More... | |
virtual ossim_uint32 | getTagLength () const |
virtual void | setTagLength (ossim_uint32 length) |
Set the tag length. More... | |
virtual void | parseStream (ossim::istream &in)=0 |
This will allow the user defined data to parse the stream. More... | |
virtual void | writeStream (ossim::ostream &out)=0 |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
Default interface to populate keyword list with metadata. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
virtual | ~ossimReferenced () |
Definition at line 56 of file ossimNitfRsmecaTag.h.
anonymous enum |
Enumerator | |
IID_SIZE | |
EDITION_SIZE | |
TID_SIZE | |
INCLIC_SIZE | |
INCLUC_SIZE | |
NPAR_SIZE | |
NPARO_SIZE | |
IGN_SIZE | |
CVDATE_SIZE | |
FLOAT21_SIZE | |
IR_SIZE | |
IC_SIZE | |
G_SIZE | |
NUMOPG_SIZE | |
TCDF_SIZE | |
NCSEG_SIZE | |
UNCSR_SIZE | |
UNCSC_SIZE |
Definition at line 59 of file ossimNitfRsmecaTag.h.
ossimNitfRsmecaTag::ossimNitfRsmecaTag | ( | ) |
Definition at line 169 of file ossimNitfRsmecaTag.cpp.
Definition at line 593 of file ossimNitfRsmecaTag.cpp.
ossimString ossimNitfRsmecaTag::getColCorSegNum | ( | ) | const |
Definition at line 1157 of file ossimNitfRsmecaTag.cpp.
References m_colCorSegNum.
ossimString ossimNitfRsmecaTag::getCvdate | ( | ) | const |
Definition at line 755 of file ossimNitfRsmecaTag.cpp.
References m_cvdate.
ossimString ossimNitfRsmecaTag::getEdition | ( | ) | const |
Definition at line 720 of file ossimNitfRsmecaTag.cpp.
References m_edition.
ossimString ossimNitfRsmecaTag::getGs | ( | ) | const |
Definition at line 949 of file ossimNitfRsmecaTag.cpp.
References m_gs.
ossimString ossimNitfRsmecaTag::getGxo | ( | ) | const |
Definition at line 919 of file ossimNitfRsmecaTag.cpp.
References m_gxo.
ossimString ossimNitfRsmecaTag::getGxr | ( | ) | const |
Definition at line 934 of file ossimNitfRsmecaTag.cpp.
References m_gxr.
ossimString ossimNitfRsmecaTag::getGxx | ( | ) | const |
Definition at line 954 of file ossimNitfRsmecaTag.cpp.
References m_gxx.
ossimString ossimNitfRsmecaTag::getGxy | ( | ) | const |
Definition at line 959 of file ossimNitfRsmecaTag.cpp.
References m_gxy.
ossimString ossimNitfRsmecaTag::getGxz | ( | ) | const |
Definition at line 964 of file ossimNitfRsmecaTag.cpp.
References m_gxz.
ossimString ossimNitfRsmecaTag::getGyo | ( | ) | const |
Definition at line 924 of file ossimNitfRsmecaTag.cpp.
References m_gyo.
ossimString ossimNitfRsmecaTag::getGyr | ( | ) | const |
Definition at line 939 of file ossimNitfRsmecaTag.cpp.
References m_gyr.
ossimString ossimNitfRsmecaTag::getGyx | ( | ) | const |
Definition at line 969 of file ossimNitfRsmecaTag.cpp.
References m_gyx.
ossimString ossimNitfRsmecaTag::getGyy | ( | ) | const |
Definition at line 974 of file ossimNitfRsmecaTag.cpp.
References m_gyy.
ossimString ossimNitfRsmecaTag::getGyz | ( | ) | const |
Definition at line 979 of file ossimNitfRsmecaTag.cpp.
References m_gyz.
ossimString ossimNitfRsmecaTag::getGzo | ( | ) | const |
Definition at line 929 of file ossimNitfRsmecaTag.cpp.
References m_gzo.
ossimString ossimNitfRsmecaTag::getGzr | ( | ) | const |
Definition at line 944 of file ossimNitfRsmecaTag.cpp.
References m_gzr.
ossimString ossimNitfRsmecaTag::getGzx | ( | ) | const |
Definition at line 984 of file ossimNitfRsmecaTag.cpp.
References m_gzx.
ossimString ossimNitfRsmecaTag::getGzy | ( | ) | const |
Definition at line 989 of file ossimNitfRsmecaTag.cpp.
References m_gzy.
ossimString ossimNitfRsmecaTag::getGzz | ( | ) | const |
Definition at line 994 of file ossimNitfRsmecaTag.cpp.
References m_gzz.
ossimString ossimNitfRsmecaTag::getIco | ( | ) | const |
Definition at line 869 of file ossimNitfRsmecaTag.cpp.
References m_ico.
ossimString ossimNitfRsmecaTag::getIcx | ( | ) | const |
Definition at line 874 of file ossimNitfRsmecaTag.cpp.
References m_icx.
ossimString ossimNitfRsmecaTag::getIcxx | ( | ) | const |
Definition at line 889 of file ossimNitfRsmecaTag.cpp.
References m_icxx.
ossimString ossimNitfRsmecaTag::getIcxy | ( | ) | const |
Definition at line 894 of file ossimNitfRsmecaTag.cpp.
References m_icxy.
ossimString ossimNitfRsmecaTag::getIcxz | ( | ) | const |
Definition at line 899 of file ossimNitfRsmecaTag.cpp.
References m_icxz.
ossimString ossimNitfRsmecaTag::getIcy | ( | ) | const |
Definition at line 879 of file ossimNitfRsmecaTag.cpp.
References m_icy.
ossimString ossimNitfRsmecaTag::getIcyy | ( | ) | const |
Definition at line 904 of file ossimNitfRsmecaTag.cpp.
References m_icyy.
ossimString ossimNitfRsmecaTag::getIcyz | ( | ) | const |
Definition at line 909 of file ossimNitfRsmecaTag.cpp.
References m_icyz.
ossimString ossimNitfRsmecaTag::getIcz | ( | ) | const |
Definition at line 884 of file ossimNitfRsmecaTag.cpp.
References m_icz.
ossimString ossimNitfRsmecaTag::getIczz | ( | ) | const |
Definition at line 914 of file ossimNitfRsmecaTag.cpp.
References m_iczz.
ossimString ossimNitfRsmecaTag::getIgn | ( | ) | const |
Definition at line 750 of file ossimNitfRsmecaTag.cpp.
References m_ign.
ossimString ossimNitfRsmecaTag::getIgnNum | ( | ) | const |
Definition at line 1142 of file ossimNitfRsmecaTag.cpp.
References m_ignNum.
ossimString ossimNitfRsmecaTag::getIid | ( | ) | const |
Definition at line 715 of file ossimNitfRsmecaTag.cpp.
References m_iid.
ossimString ossimNitfRsmecaTag::getInclic | ( | ) | const |
Definition at line 730 of file ossimNitfRsmecaTag.cpp.
References m_inclic.
bool ossimNitfRsmecaTag::getInclicFlag | ( | ) | const |
ossimString ossimNitfRsmecaTag::getIncluc | ( | ) | const |
Definition at line 735 of file ossimNitfRsmecaTag.cpp.
References m_incluc.
bool ossimNitfRsmecaTag::getInclucFlag | ( | ) | const |
ossimString ossimNitfRsmecaTag::getIro | ( | ) | const |
Definition at line 820 of file ossimNitfRsmecaTag.cpp.
References m_iro.
ossimString ossimNitfRsmecaTag::getIrx | ( | ) | const |
Definition at line 825 of file ossimNitfRsmecaTag.cpp.
References m_irx.
ossimString ossimNitfRsmecaTag::getIrxx | ( | ) | const |
Definition at line 839 of file ossimNitfRsmecaTag.cpp.
References m_irxx.
ossimString ossimNitfRsmecaTag::getIrxy | ( | ) | const |
Definition at line 844 of file ossimNitfRsmecaTag.cpp.
References m_irxy.
ossimString ossimNitfRsmecaTag::getIrxz | ( | ) | const |
Definition at line 849 of file ossimNitfRsmecaTag.cpp.
References m_irxz.
ossimString ossimNitfRsmecaTag::getIry | ( | ) | const |
Definition at line 829 of file ossimNitfRsmecaTag.cpp.
References m_iry.
ossimString ossimNitfRsmecaTag::getIryy | ( | ) | const |
Definition at line 854 of file ossimNitfRsmecaTag.cpp.
References m_iryy.
ossimString ossimNitfRsmecaTag::getIryz | ( | ) | const |
Definition at line 859 of file ossimNitfRsmecaTag.cpp.
References m_iryz.
ossimString ossimNitfRsmecaTag::getIrz | ( | ) | const |
Definition at line 834 of file ossimNitfRsmecaTag.cpp.
References m_irz.
ossimString ossimNitfRsmecaTag::getIrzz | ( | ) | const |
Definition at line 864 of file ossimNitfRsmecaTag.cpp.
References m_irzz.
ossimNitfRsmecaIsg ossimNitfRsmecaTag::getIsg | ( | ossim_uint32 | index | ) | const |
Definition at line 999 of file ossimNitfRsmecaTag.cpp.
References m_isg.
ossimString ossimNitfRsmecaTag::getMap | ( | ossim_uint32 | index | ) | const |
Definition at line 1017 of file ossimNitfRsmecaTag.cpp.
References m_map.
ossimString ossimNitfRsmecaTag::getMapNum | ( | ) | const |
Definition at line 1147 of file ossimNitfRsmecaTag.cpp.
References m_mapNum.
ossimString ossimNitfRsmecaTag::getNpar | ( | ) | const |
Definition at line 740 of file ossimNitfRsmecaTag.cpp.
References m_npar.
ossimString ossimNitfRsmecaTag::getNparo | ( | ) | const |
Definition at line 745 of file ossimNitfRsmecaTag.cpp.
References m_nparo.
ossimString ossimNitfRsmecaTag::getRowCorSegNum | ( | ) | const |
Definition at line 1152 of file ossimNitfRsmecaTag.cpp.
References m_rowCorSegNum.
ossimString ossimNitfRsmecaTag::getTid | ( | ) | const |
Definition at line 725 of file ossimNitfRsmecaTag.cpp.
References m_tid.
ossimString ossimNitfRsmecaTag::getUcc | ( | ) | const |
Definition at line 1045 of file ossimNitfRsmecaTag.cpp.
References m_ucc.
ossimString ossimNitfRsmecaTag::getUcorsc | ( | ossim_uint32 | index | ) | const |
Definition at line 1096 of file ossimNitfRsmecaTag.cpp.
References m_ucorsc.
ossimString ossimNitfRsmecaTag::getUcorsr | ( | ossim_uint32 | index | ) | const |
Definition at line 1055 of file ossimNitfRsmecaTag.cpp.
References m_ucorsr.
ossimString ossimNitfRsmecaTag::getUncsc | ( | ) | const |
Definition at line 1091 of file ossimNitfRsmecaTag.cpp.
References m_uncsr.
ossimString ossimNitfRsmecaTag::getUncsr | ( | ) | const |
Definition at line 1050 of file ossimNitfRsmecaTag.cpp.
References m_uncsr.
ossimString ossimNitfRsmecaTag::getUrc | ( | ) | const |
Definition at line 1040 of file ossimNitfRsmecaTag.cpp.
References m_urc.
ossimString ossimNitfRsmecaTag::getUrr | ( | ) | const |
Definition at line 1035 of file ossimNitfRsmecaTag.cpp.
References m_urr.
ossimString ossimNitfRsmecaTag::getUtausc | ( | ossim_uint32 | index | ) | const |
Definition at line 1114 of file ossimNitfRsmecaTag.cpp.
References m_utausc.
ossimString ossimNitfRsmecaTag::getUtausr | ( | ossim_uint32 | index | ) | const |
Definition at line 1073 of file ossimNitfRsmecaTag.cpp.
References m_utausr.
ossimString ossimNitfRsmecaTag::getXuol | ( | ) | const |
Definition at line 760 of file ossimNitfRsmecaTag.cpp.
References m_xuol.
ossimString ossimNitfRsmecaTag::getXuxl | ( | ) | const |
Definition at line 775 of file ossimNitfRsmecaTag.cpp.
References m_xuxl.
ossimString ossimNitfRsmecaTag::getXuyl | ( | ) | const |
Definition at line 780 of file ossimNitfRsmecaTag.cpp.
References m_xuyl.
ossimString ossimNitfRsmecaTag::getXuzl | ( | ) | const |
Definition at line 785 of file ossimNitfRsmecaTag.cpp.
References m_xuzl.
ossimString ossimNitfRsmecaTag::getYuol | ( | ) | const |
Definition at line 765 of file ossimNitfRsmecaTag.cpp.
References m_yuol.
ossimString ossimNitfRsmecaTag::getYuxl | ( | ) | const |
Definition at line 790 of file ossimNitfRsmecaTag.cpp.
References m_yuxl.
ossimString ossimNitfRsmecaTag::getYuyl | ( | ) | const |
Definition at line 795 of file ossimNitfRsmecaTag.cpp.
References m_yuyl.
ossimString ossimNitfRsmecaTag::getYuzl | ( | ) | const |
Definition at line 800 of file ossimNitfRsmecaTag.cpp.
References m_yuzl.
ossimString ossimNitfRsmecaTag::getZuol | ( | ) | const |
Definition at line 770 of file ossimNitfRsmecaTag.cpp.
References m_zuol.
ossimString ossimNitfRsmecaTag::getZuxl | ( | ) | const |
Definition at line 805 of file ossimNitfRsmecaTag.cpp.
References m_zuxl.
ossimString ossimNitfRsmecaTag::getZuyl | ( | ) | const |
Definition at line 810 of file ossimNitfRsmecaTag.cpp.
References m_zuyl.
ossimString ossimNitfRsmecaTag::getZuzl | ( | ) | const |
Definition at line 815 of file ossimNitfRsmecaTag.cpp.
References m_zuzl.
Definition at line 252 of file ossimNitfRsmecaTag.cpp.
References CVDATE_SIZE, EDITION_SIZE, FLOAT21_SIZE, G_SIZE, IC_SIZE, IGN_SIZE, IID_SIZE, INCLIC_SIZE, INCLUC_SIZE, IR_SIZE, m_cvdate, m_edition, m_gs, m_gxo, m_gxr, m_gxx, m_gxy, m_gxz, m_gyo, m_gyr, m_gyx, m_gyy, m_gyz, m_gzo, m_gzr, m_gzx, m_gzy, m_gzz, m_ico, m_icx, m_icxx, m_icxy, m_icxz, m_icy, m_icyy, m_icyz, m_icz, m_iczz, m_ign, m_ignNum, m_iid, m_inclic, m_inclicFlag, m_incluc, m_inclucFlag, m_iro, m_irx, m_irxx, m_irxy, m_irxz, m_iry, m_iryy, m_iryz, m_irz, m_irzz, m_isg, m_map, m_mapNum, m_npar, m_nparo, m_tid, m_xuol, m_xuxl, m_xuyl, m_xuzl, m_yuol, m_yuxl, m_yuyl, m_yuzl, m_zuol, m_zuxl, m_zuyl, m_zuzl, NPAR_SIZE, NPARO_SIZE, TID_SIZE, and ossimString::toUInt32().
Reimplemented from ossimNitfRegisteredTag.
Definition at line 597 of file ossimNitfRsmecaTag.cpp.
References ossimNitfRegisteredTag::getSizeInBytes(), ossimNitfRegisteredTag::getTagName(), m_colCorSegNum, m_cvdate, m_edition, m_gs, m_gxo, m_gxr, m_gxx, m_gxy, m_gxz, m_gyo, m_gyr, m_gyx, m_gyy, m_gyz, m_gzo, m_gzr, m_gzx, m_gzy, m_gzz, m_ico, m_icx, m_icxx, m_icxy, m_icxz, m_icy, m_icyy, m_icyz, m_icz, m_iczz, m_ign, m_ignNum, m_iid, m_inclic, m_inclicFlag, m_incluc, m_inclucFlag, m_iro, m_irx, m_irxx, m_irxy, m_irxz, m_iry, m_iryy, m_iryz, m_irz, m_irzz, m_isg, m_map, m_mapNum, m_npar, m_nparo, m_rowCorSegNum, m_tid, m_ucc, m_ucorsc, m_ucorsr, m_uncsr, m_urc, m_urr, m_utausc, m_utausr, m_xuol, m_xuxl, m_xuyl, m_xuzl, m_yuol, m_yuxl, m_yuyl, m_yuzl, m_zuol, m_zuxl, m_zuyl, m_zuzl, and ossimString::toString().
Definition at line 500 of file ossimNitfRsmecaTag.cpp.
References CVDATE_SIZE, EDITION_SIZE, FLOAT21_SIZE, G_SIZE, IC_SIZE, IGN_SIZE, IID_SIZE, INCLIC_SIZE, INCLUC_SIZE, IR_SIZE, m_colCorSegNum, m_cvdate, m_edition, m_gs, m_gxo, m_gxr, m_gxx, m_gxy, m_gxz, m_gyo, m_gyr, m_gyx, m_gyy, m_gyz, m_gzo, m_gzr, m_gzx, m_gzy, m_gzz, m_ico, m_icx, m_icxx, m_icxy, m_icxz, m_icy, m_icyy, m_icyz, m_icz, m_iczz, m_ign, m_ignNum, m_iid, m_inclic, m_inclicFlag, m_incluc, m_inclucFlag, m_iro, m_irx, m_irxx, m_irxy, m_irxz, m_iry, m_iryy, m_iryz, m_irz, m_irzz, m_isg, m_map, m_mapNum, m_npar, m_nparo, m_rowCorSegNum, m_tid, m_ucc, m_ucorsc, m_ucorsr, m_uncsc, m_uncsr, m_urc, m_urr, m_utausc, m_utausr, m_xuol, m_xuxl, m_xuyl, m_xuzl, m_yuol, m_yuxl, m_yuyl, m_yuzl, m_zuol, m_zuxl, m_zuyl, m_zuzl, NPAR_SIZE, NPARO_SIZE, and TID_SIZE.
protected |
Definition at line 246 of file ossimNitfRsmecaTag.h.
Referenced by getColCorSegNum(), print(), and writeStream().
protected |
Definition at line 178 of file ossimNitfRsmecaTag.h.
Referenced by getCvdate(), parseStream(), print(), and writeStream().
protected |
Definition at line 171 of file ossimNitfRsmecaTag.h.
Referenced by getEdition(), parseStream(), print(), and writeStream().
protected |
Definition at line 217 of file ossimNitfRsmecaTag.h.
Referenced by getGs(), parseStream(), print(), and writeStream().
protected |
Definition at line 211 of file ossimNitfRsmecaTag.h.
Referenced by getGxo(), parseStream(), print(), and writeStream().
protected |
Definition at line 214 of file ossimNitfRsmecaTag.h.
Referenced by getGxr(), parseStream(), print(), and writeStream().
protected |
Definition at line 218 of file ossimNitfRsmecaTag.h.
Referenced by getGxx(), parseStream(), print(), and writeStream().
protected |
Definition at line 219 of file ossimNitfRsmecaTag.h.
Referenced by getGxy(), parseStream(), print(), and writeStream().
protected |
Definition at line 220 of file ossimNitfRsmecaTag.h.
Referenced by getGxz(), parseStream(), print(), and writeStream().
protected |
Definition at line 212 of file ossimNitfRsmecaTag.h.
Referenced by getGyo(), parseStream(), print(), and writeStream().
protected |
Definition at line 215 of file ossimNitfRsmecaTag.h.
Referenced by getGyr(), parseStream(), print(), and writeStream().
protected |
Definition at line 221 of file ossimNitfRsmecaTag.h.
Referenced by getGyx(), parseStream(), print(), and writeStream().
protected |
Definition at line 222 of file ossimNitfRsmecaTag.h.
Referenced by getGyy(), parseStream(), print(), and writeStream().
protected |
Definition at line 223 of file ossimNitfRsmecaTag.h.
Referenced by getGyz(), parseStream(), print(), and writeStream().
protected |
Definition at line 213 of file ossimNitfRsmecaTag.h.
Referenced by getGzo(), parseStream(), print(), and writeStream().
protected |
Definition at line 216 of file ossimNitfRsmecaTag.h.
Referenced by getGzr(), parseStream(), print(), and writeStream().
protected |
Definition at line 224 of file ossimNitfRsmecaTag.h.
Referenced by getGzx(), parseStream(), print(), and writeStream().
protected |
Definition at line 225 of file ossimNitfRsmecaTag.h.
Referenced by getGzy(), parseStream(), print(), and writeStream().
protected |
Definition at line 226 of file ossimNitfRsmecaTag.h.
Referenced by getGzz(), parseStream(), print(), and writeStream().
protected |
Definition at line 201 of file ossimNitfRsmecaTag.h.
Referenced by getIco(), parseStream(), print(), and writeStream().
protected |
Definition at line 202 of file ossimNitfRsmecaTag.h.
Referenced by getIcx(), parseStream(), print(), and writeStream().
protected |
Definition at line 205 of file ossimNitfRsmecaTag.h.
Referenced by getIcxx(), parseStream(), print(), and writeStream().
protected |
Definition at line 206 of file ossimNitfRsmecaTag.h.
Referenced by getIcxy(), parseStream(), print(), and writeStream().
protected |
Definition at line 207 of file ossimNitfRsmecaTag.h.
Referenced by getIcxz(), parseStream(), print(), and writeStream().
protected |
Definition at line 203 of file ossimNitfRsmecaTag.h.
Referenced by getIcy(), parseStream(), print(), and writeStream().
protected |
Definition at line 208 of file ossimNitfRsmecaTag.h.
Referenced by getIcyy(), parseStream(), print(), and writeStream().
protected |
Definition at line 209 of file ossimNitfRsmecaTag.h.
Referenced by getIcyz(), parseStream(), print(), and writeStream().
protected |
Definition at line 204 of file ossimNitfRsmecaTag.h.
Referenced by getIcz(), parseStream(), print(), and writeStream().
protected |
Definition at line 210 of file ossimNitfRsmecaTag.h.
Referenced by getIczz(), parseStream(), print(), and writeStream().
protected |
Definition at line 177 of file ossimNitfRsmecaTag.h.
Referenced by getIgn(), parseStream(), print(), and writeStream().
protected |
Definition at line 243 of file ossimNitfRsmecaTag.h.
Referenced by getIgnNum(), parseStream(), print(), and writeStream().
protected |
Definition at line 170 of file ossimNitfRsmecaTag.h.
Referenced by getIid(), parseStream(), print(), and writeStream().
protected |
Definition at line 173 of file ossimNitfRsmecaTag.h.
Referenced by getInclic(), parseStream(), print(), and writeStream().
protected |
Definition at line 241 of file ossimNitfRsmecaTag.h.
Referenced by getInclicFlag(), parseStream(), print(), and writeStream().
protected |
Definition at line 174 of file ossimNitfRsmecaTag.h.
Referenced by getIncluc(), parseStream(), print(), and writeStream().
protected |
Definition at line 242 of file ossimNitfRsmecaTag.h.
Referenced by getInclucFlag(), parseStream(), print(), and writeStream().
protected |
Definition at line 191 of file ossimNitfRsmecaTag.h.
Referenced by getIro(), parseStream(), print(), and writeStream().
protected |
Definition at line 192 of file ossimNitfRsmecaTag.h.
Referenced by getIrx(), parseStream(), print(), and writeStream().
protected |
Definition at line 195 of file ossimNitfRsmecaTag.h.
Referenced by getIrxx(), parseStream(), print(), and writeStream().
protected |
Definition at line 196 of file ossimNitfRsmecaTag.h.
Referenced by getIrxy(), parseStream(), print(), and writeStream().
protected |
Definition at line 197 of file ossimNitfRsmecaTag.h.
Referenced by getIrxz(), parseStream(), print(), and writeStream().
protected |
Definition at line 193 of file ossimNitfRsmecaTag.h.
Referenced by getIry(), parseStream(), print(), and writeStream().
protected |
Definition at line 198 of file ossimNitfRsmecaTag.h.
Referenced by getIryy(), parseStream(), print(), and writeStream().
protected |
Definition at line 199 of file ossimNitfRsmecaTag.h.
Referenced by getIryz(), parseStream(), print(), and writeStream().
protected |
Definition at line 194 of file ossimNitfRsmecaTag.h.
Referenced by getIrz(), parseStream(), print(), and writeStream().
protected |
Definition at line 200 of file ossimNitfRsmecaTag.h.
Referenced by getIrzz(), parseStream(), print(), and writeStream().
protected |
Definition at line 228 of file ossimNitfRsmecaTag.h.
Referenced by getIsg(), parseStream(), print(), and writeStream().
protected |
Definition at line 229 of file ossimNitfRsmecaTag.h.
Referenced by getMap(), parseStream(), print(), and writeStream().
protected |
Definition at line 244 of file ossimNitfRsmecaTag.h.
Referenced by getMapNum(), parseStream(), print(), and writeStream().
protected |
Definition at line 175 of file ossimNitfRsmecaTag.h.
Referenced by getNpar(), parseStream(), print(), and writeStream().
protected |
Definition at line 176 of file ossimNitfRsmecaTag.h.
Referenced by getNparo(), parseStream(), print(), and writeStream().
protected |
Definition at line 245 of file ossimNitfRsmecaTag.h.
Referenced by getRowCorSegNum(), print(), and writeStream().
protected |
Definition at line 172 of file ossimNitfRsmecaTag.h.
Referenced by getTid(), parseStream(), print(), and writeStream().
protected |
Definition at line 233 of file ossimNitfRsmecaTag.h.
Referenced by getUcc(), print(), and writeStream().
protected |
Definition at line 238 of file ossimNitfRsmecaTag.h.
Referenced by getUcorsc(), print(), and writeStream().
protected |
Definition at line 235 of file ossimNitfRsmecaTag.h.
Referenced by getUcorsr(), print(), and writeStream().
protected |
Definition at line 237 of file ossimNitfRsmecaTag.h.
Referenced by writeStream().
protected |
Definition at line 234 of file ossimNitfRsmecaTag.h.
Referenced by getUncsc(), getUncsr(), print(), and writeStream().
protected |
Definition at line 232 of file ossimNitfRsmecaTag.h.
Referenced by getUrc(), print(), and writeStream().
protected |
Definition at line 231 of file ossimNitfRsmecaTag.h.
Referenced by getUrr(), print(), and writeStream().
protected |
Definition at line 239 of file ossimNitfRsmecaTag.h.
Referenced by getUtausc(), print(), and writeStream().
protected |
Definition at line 236 of file ossimNitfRsmecaTag.h.
Referenced by getUtausr(), print(), and writeStream().
protected |
Definition at line 179 of file ossimNitfRsmecaTag.h.
Referenced by getXuol(), parseStream(), print(), and writeStream().
protected |
Definition at line 182 of file ossimNitfRsmecaTag.h.
Referenced by getXuxl(), parseStream(), print(), and writeStream().
protected |
Definition at line 183 of file ossimNitfRsmecaTag.h.
Referenced by getXuyl(), parseStream(), print(), and writeStream().
protected |
Definition at line 184 of file ossimNitfRsmecaTag.h.
Referenced by getXuzl(), parseStream(), print(), and writeStream().
protected |
Definition at line 180 of file ossimNitfRsmecaTag.h.
Referenced by getYuol(), parseStream(), print(), and writeStream().
protected |
Definition at line 185 of file ossimNitfRsmecaTag.h.
Referenced by getYuxl(), parseStream(), print(), and writeStream().
protected |
Definition at line 186 of file ossimNitfRsmecaTag.h.
Referenced by getYuyl(), parseStream(), print(), and writeStream().
protected |
Definition at line 187 of file ossimNitfRsmecaTag.h.
Referenced by getYuzl(), parseStream(), print(), and writeStream().
protected |
Definition at line 181 of file ossimNitfRsmecaTag.h.
Referenced by getZuol(), parseStream(), print(), and writeStream().
protected |
Definition at line 188 of file ossimNitfRsmecaTag.h.
Referenced by getZuxl(), parseStream(), print(), and writeStream().
protected |
Definition at line 189 of file ossimNitfRsmecaTag.h.
Referenced by getZuyl(), parseStream(), print(), and writeStream().
protected |
Definition at line 190 of file ossimNitfRsmecaTag.h.
Referenced by getZuzl(), parseStream(), print(), and writeStream().
