Public Member Functions | Protected Attributes | List of all members
ossimNitfStreobTag Class Reference
#include <ossimNitfStreobTag.h>
Inheritance diagram for ossimNitfStreobTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
 ossimNitfStreobTag ()
 default constructor More...
virtual ~ossimNitfStreobTag ()
 destructor More...
virtual void parseStream (std::istream &in)
 Method to parse data from stream. More...
virtual void writeStream (std::ostream &out)
 Method to write data to stream. More...
virtual void clearFields ()
 Method to clear all fields including null terminating. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix) const
 Print method that outputs a key/value type format adding prefix to keys. More...
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char m_stdId [61]
 FIELD: ST_ID. More...
char n_nMates [2]
 FIELD: N_MATES. More...
char m_mateInstance [2]
 FIELD: MATE_INSTANCE. More...
char m_bConv [6]
 FIELD: B_CONV. More...
char m_eConv [6]
 FIELD: E_CONV. More...
char m_bAsym [6]
 FIELD: B_ASYM. More...
char m_eAsym [6]
 FIELD: E_ASYM. More...
char m_bBie [7]
 FIELD: B_BIE. More...
char m_eBie [7]
 FIELD: E_BIE. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 20 of file ossimNitfStreobTag.h.
◆ ossimNitfStreobTag()
ossimNitfStreobTag::ossimNitfStreobTag ( )
default constructor
Definition at line 25 of file ossimNitfStreobTag.cpp.
References clearFields().
26  : ossimNitfRegisteredTag(std::string("STREOB"), 94)
27 {
28  clearFields();
29 }
virtual void clearFields()
ossimNitfRegisteredTag()
default constructor
◆ ~ossimNitfStreobTag()
ossimNitfStreobTag::~ossimNitfStreobTag ( )
virtual
destructor
Definition at line 31 of file ossimNitfStreobTag.cpp.
32 {
33 }
Member Function Documentation
◆ clearFields()
void ossimNitfStreobTag::clearFields ( )
virtual
Definition at line 63 of file ossimNitfStreobTag.cpp.
References m_bAsym, m_bBie, m_bConv, m_eAsym, m_eConv, m_mateInstance, m_stdId, and n_nMates.
Referenced by ossimNitfStreobTag(), and parseStream().
64 {
65  // BCS-N's to '0's, BCS-A's to ' '(spaces)
66
67  memset(m_stdId, '\0', 61);
68  memset(n_nMates, '\0', 2);
69  memset(m_mateInstance, '\0', 2);
70  memset(m_bConv, '\0', 6);
71  memset(m_eConv, '\0', 6);
72  memset(m_bAsym, '\0', 6);
73  memset(m_eAsym, '\0', 7);
74  memset(m_bBie, '\0', 7);
75 }
char m_eConv[6]
FIELD: E_CONV.
char m_bBie[7]
FIELD: B_BIE.
char m_eAsym[6]
FIELD: E_ASYM.
char m_mateInstance[2]
char m_stdId[61]
FIELD: ST_ID.
char m_bAsym[6]
FIELD: B_ASYM.
char m_bConv[6]
FIELD: B_CONV.
char n_nMates[2]
FIELD: N_MATES.
◆ parseStream()
void ossimNitfStreobTag::parseStream ( std::istream &  in)
virtual
Definition at line 35 of file ossimNitfStreobTag.cpp.
References clearFields(), m_bAsym, m_bBie, m_bConv, m_eAsym, m_eBie, m_eConv, m_mateInstance, m_stdId, and n_nMates.
36 {
37  clearFields();
38
39  in.read(m_stdId, 60);
40  in.read(n_nMates, 1);
41  in.read(m_mateInstance, 1);
42  in.read(m_bConv, 5);
43  in.read(m_eConv, 5);
44  in.read(m_bAsym, 5);
45  in.read(m_eAsym, 5);
46  in.read(m_bBie, 6);
47  in.read(m_eBie, 6);
48 }
char m_eConv[6]
FIELD: E_CONV.
char m_bBie[7]
FIELD: B_BIE.
char m_eBie[7]
FIELD: E_BIE.
char m_eAsym[6]
FIELD: E_ASYM.
char m_stdId[61]
FIELD: ST_ID.
char m_bAsym[6]
FIELD: B_ASYM.
char m_bConv[6]
FIELD: B_CONV.
char n_nMates[2]
FIELD: N_MATES.
◆ print()
std::ostream & ossimNitfStreobTag::print ( std::ostream &  out,
const std::string &  prefix
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Reimplemented from ossimNitfRegisteredTag.
Definition at line 77 of file ossimNitfStreobTag.cpp.
References ossimNitfRegisteredTag::getTagName(), m_bAsym, m_bBie, m_bConv, m_eAsym, m_eConv, m_mateInstance, m_stdId, and n_nMates.
79 {
80  std::string pfx = prefix;
81  pfx += getTagName();
82  pfx += ".";
83
84  out << setiosflags(std::ios::left)
85  << pfx << std::setw(24) << "CETAG:"
86  << getTagName() << "\n"
87  << pfx << std::setw(24) << "ST_ID:" << m_stdId << "\n"
88  << pfx << std::setw(24) << "N_MATES:" << n_nMates << "\n"
89  << pfx << std::setw(24) << "MATE_INSTANCE:" << m_mateInstance << "\n"
90  << pfx << std::setw(24) << "B_CONV:" << m_bConv << "\n"
91  << pfx << std::setw(24) << "E_CONV:" << m_eConv << "\n"
92  << pfx << std::setw(24) << "B_ASYM:" << m_bAsym << "\n"
93  << pfx << std::setw(24) << "E_ASYM:" << m_eAsym << "\n"
94  << pfx << std::setw(24) << "B_BIE:" << m_bBie << "\n";
95
96  return out;
97 }
virtual const std::string & getTagName() const
char m_eConv[6]
FIELD: E_CONV.
char m_bBie[7]
FIELD: B_BIE.
char m_eAsym[6]
FIELD: E_ASYM.
char m_stdId[61]
FIELD: ST_ID.
char m_bAsym[6]
FIELD: B_ASYM.
char m_bConv[6]
FIELD: B_CONV.
char n_nMates[2]
FIELD: N_MATES.
◆ writeStream()
void ossimNitfStreobTag::writeStream ( std::ostream &  out)
virtual
Definition at line 50 of file ossimNitfStreobTag.cpp.
References m_bAsym, m_bBie, m_bConv, m_eAsym, m_eBie, m_eConv, m_mateInstance, m_stdId, and n_nMates.
51 {
52  out.write(m_stdId, 60);
53  out.write(n_nMates, 1);
54  out.write(m_mateInstance, 1);
55  out.write(m_bConv, 5);
56  out.write(m_eConv, 5);
57  out.write(m_bAsym, 5);
58  out.write(m_eAsym, 5);
59  out.write(m_bBie, 6);
60  out.write(m_eBie, 6);
61 }
char m_eConv[6]
FIELD: E_CONV.
char m_bBie[7]
FIELD: B_BIE.
char m_eBie[7]
FIELD: E_BIE.
char m_eAsym[6]
FIELD: E_ASYM.
char m_stdId[61]
FIELD: ST_ID.
char m_bAsym[6]
FIELD: B_ASYM.
char m_bConv[6]
FIELD: B_CONV.
char n_nMates[2]
FIELD: N_MATES.
Member Data Documentation
◆ m_bAsym
char ossimNitfStreobTag::m_bAsym[6]
protected
FIELD: B_ASYM.
5 byte field
Values: 00.00 to 90.00
Beginning Asymmetry Angle defined at the first lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the first line of the fore and the last line of the aft shall be used.
Definition at line 132 of file ossimNitfStreobTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
◆ m_bBie
char ossimNitfStreobTag::m_bBie[7]
protected
FIELD: B_BIE.
6 byte field
Values: +- 90.00
Beginning BIE less Convergence Angle of Stereo Mate, defined at the first lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the first line of the fore and the last line of the aft shall be used.
Definition at line 160 of file ossimNitfStreobTag.h.
◆ m_bConv
char ossimNitfStreobTag::m_bConv[6]
protected
FIELD: B_CONV.
5 byte field in degrees
Value: 00.00 to 90.00
Beginning Convergence Angle defined at the first lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the first line of the fore and the last line of the aft shall be used.
Definition at line 104 of file ossimNitfStreobTag.h.
◆ m_eAsym
char ossimNitfStreobTag::m_eAsym[6]
protected
FIELD: E_ASYM.
5 byte field
Ending Asymmetry Angle defined at the last lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the last line of the fore and the first line of the aft shall be used.
Definition at line 146 of file ossimNitfStreobTag.h.
◆ m_eBie
char ossimNitfStreobTag::m_eBie[7]
protected
FIELD: E_BIE.
6 byte field
Values: +- 90.00
Ending BIE less Convergence Angle of Stereo Mate, defined at the last lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the last line of the fore and the first line of the aft shall be used.
Definition at line 175 of file ossimNitfStreobTag.h.
Referenced by parseStream(), and writeStream().
◆ m_eConv
char ossimNitfStreobTag::m_eConv[6]
protected
FIELD: E_CONV.
Ending Convergence Angle defined at the last lines of the fore/left and aft/right images, unless those images are more than 90 degrees apart. If the images are more than 90 degrees apart, the last line of the fore and the first line of the aft shall be used.
Definition at line 118 of file ossimNitfStreobTag.h.
◆ m_mateInstance
char ossimNitfStreobTag::m_mateInstance[2]
protected
1 byte integer
values: 1 to 3
Mate Instance identifies which stereo mate is described in that extension. For example, this field contains a 2 for the second stereo mate.
Definition at line 88 of file ossimNitfStreobTag.h.
◆ m_stdId
char ossimNitfStreobTag::m_stdId[61]
protected
FIELD: ST_ID.
60 byte field string
alphanumeric
The image ID of the first stereo mate. The fields ACQUISITION_DATE through END_ROW in the STDIDC tag constitute the image ID
Definition at line 60 of file ossimNitfStreobTag.h.
◆ n_nMates
char ossimNitfStreobTag::n_nMates[2]
protected
FIELD: N_MATES.
1 byte integer
values: 1 to 3
Number of Stereo Mates. If there are no stereo mates, there will not be any STREOB (TBR) extensions in the file. If there is a STREOB (TBR) extension, then there will be at least 1 stereo mate.
Definition at line 74 of file ossimNitfStreobTag.h.
