ossimNitfUnknownTag Class Reference
#include <ossimNitfUnknownTag.h>
Inheritance diagram for ossimNitfUnknownTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimNitfUnknownTag ()
 default constructor More...
virtual ~ossimNitfUnknownTag ()
 destructor More...
virtual void parseStream (std::istream &in)
 Parse method. More...
virtual void writeStream (std::ostream &out)
 Write method. More...
virtual void clearFields ()
 Clears all string fields within the record to some default nothingness. More...
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 print method that outputs a key/value type format adding prefix to keys. More...
virtual void setTagLength (ossim_uint32 length)
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
Protected Member Functions
bool tagDataIsAscii () const
bool tagDataIsXml () const
virtual ~ossimReferenced ()
Protected Attributes
char * m_tagData
 Holds entire tag data(theTagLength) plus one byte for null terminator. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Detailed Description
Definition at line 21 of file ossimNitfUnknownTag.h.
◆ ossimNitfUnknownTag()
ossimNitfUnknownTag::ossimNitfUnknownTag ( )
default constructor
Definition at line 26 of file ossimNitfUnknownTag.cpp.
27  : m_tagData(0)
28 {
29 }
char * m_tagData
◆ ~ossimNitfUnknownTag()
ossimNitfUnknownTag::~ossimNitfUnknownTag ( )
virtual
destructor
Definition at line 31 of file ossimNitfUnknownTag.cpp.
References m_tagData.
32 {
33  if (m_tagData)
34  {
35  delete [] m_tagData;
36  m_tagData = 0;
37  }
38 }
char * m_tagData
Member Function Documentation
◆ clearFields()
void ossimNitfUnknownTag::clearFields ( )
virtual
Definition at line 65 of file ossimNitfUnknownTag.cpp.
66 {
67  if (m_tagData)
68  {
69  delete [] m_tagData;
70  m_tagData = 0;
71  }
72 }
char * m_tagData
◆ parseStream()
void ossimNitfUnknownTag::parseStream ( std::istream &  in)
virtual
Parse method.
Parameters
inStream to parse. This will read the entire tag length into an array.
Definition at line 40 of file ossimNitfUnknownTag.cpp.
References m_tagData, and ossimNitfRegisteredTag::m_tagLength.
41 {
42  if (m_tagLength)
43  {
44  if (m_tagData)
45  {
46  delete [] m_tagData;
47  }
48
49  m_tagData = new char[m_tagLength+1];
50
51  in.read(m_tagData, m_tagLength);
52
53  m_tagData[m_tagLength] = '\0';
54  }
55 }
char * m_tagData
◆ print()
std::ostream & ossimNitfUnknownTag::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
virtual
Reimplemented from ossimNitfRegisteredTag.
Definition at line 74 of file ossimNitfUnknownTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), m_tagData, tagDataIsAscii(), and tagDataIsXml().
76 {
77  std::string pfx = prefix;
78  pfx += getTagName();
79  pfx += ".";
80
81  out << setiosflags(std::ios::left)
82  << pfx << std::setw(24) << "CETAG:" << getTagName() << "\n"
83  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
84  << pfx << std::setw(24) << "unformatted_tag_data: ";
85
86  if (tagDataIsAscii())
87  {
88  if (tagDataIsXml())
89  out << "<![CDATA[" << m_tagData << "]]>" << "\n";
90  else
91  out << m_tagData << "\n";
92  }
93  else
94  {
95  out << "binary not displayed\n";
96  }
97
98  return out;
99 }
virtual const std::string & getTagName() const
char * m_tagData
virtual ossim_uint32 getTagLength() const
◆ setTagLength()
void ossimNitfUnknownTag::setTagLength ( ossim_uint32  length)
virtual
Parameters
lengthLength of tag.
Note
The tag length must be set prior to calling "parseStream".
Since you must have a length to read theTagData, if theTagData exist it will be deleted by this method. Subsequent "parseStream" calls will allocate theTagData as needed.
Definition at line 115 of file ossimNitfUnknownTag.cpp.
116 {
117  if (m_tagData)
118  {
119  delete [] m_tagData;
120  m_tagData = 0;
121  }
122  m_tagLength = length;
123 }
char * m_tagData
◆ tagDataIsAscii()
bool ossimNitfUnknownTag::tagDataIsAscii ( ) const
protected
Returns
true if all characters in theTagData are printable.
Definition at line 125 of file ossimNitfUnknownTag.cpp.
Referenced by print().
126 {
127  if ( (m_tagLength == 0) || !m_tagData )
128  {
129  return false;
130  }
131
132  for (ossim_uint32 i = 0; i < m_tagLength; ++i)
133  {
134  int c = m_tagData[i];
135  if (isascii(c) == false)
136  {
137  return false;
138  }
139  }
140
141  return true;
142 }
char * m_tagData
unsigned int ossim_uint32
◆ tagDataIsXml()
bool ossimNitfUnknownTag::tagDataIsXml ( ) const
protected
Definition at line 101 of file ossimNitfUnknownTag.cpp.
References ossimString::length(), m_tagData, ossimNitfRegisteredTag::m_tagLength, and ossimString::substr().
102 {
103  ossimString xmlTest = "<?xml";
104  ossim_uint32 len = xmlTest.length();
105  if ( (m_tagLength < len) || !m_tagData )
106  {
107  return false;
108  }
109
110  ossimString tagDataString = ossimString(m_tagData).substr(0, len);
111  if (tagDataString == xmlTest) return true;
112  return false;
113 }
char * m_tagData
std::string::size_type length() const
Definition: ossimString.h:408
std::string substr(std::string::size_type pos=0, std::string::size_type n=std::string::npos) const
Equivalent to basic_string(*this, pos, n).
Definition: ossimString.h:910
◆ writeStream()
void ossimNitfUnknownTag::writeStream ( std::ostream &  out)
virtual
Write method.
Parameters
outStream to write to.
Definition at line 57 of file ossimNitfUnknownTag.cpp.
58 {
59  if (m_tagLength && m_tagData)
60  {
61  out.write(m_tagData, m_tagLength);
62  }
63 }
char * m_tagData
Member Data Documentation
◆ m_tagData
char* ossimNitfUnknownTag::m_tagData
protected
Definition at line 79 of file ossimNitfUnknownTag.h.
Referenced by clearFields(), parseStream(), print(), setTagLength(), tagDataIsAscii(), tagDataIsXml(), writeStream(), and ~ossimNitfUnknownTag().
