Public Types | Public Member Functions | Protected Attributes | List of all members
ossimNitfUse00aTag Class Reference
#include <ossimNitfUse00aTag.h>
Inheritance diagram for ossimNitfUse00aTag:
ossimNitfRegisteredTag ossimObject ossimPropertyInterface ossimReferenced
Public Types
enum  {
  ANGLE_TO_NORTH_SIZE = 3, MEAN_GSD_SIZE = 5, FIELD3_SIZE = 1, DYNAMIC_RANGE_SIZE = 5,
  FIELD5_SIZE = 3, FIELD6_SIZE = 1, FIELD7_SIZE = 3, OBL_ANG_SIZE = 5,
  ROLL_ANG_SIZE = 6, FIELD10_SIZE = 12, FIELD11_SIZE = 15, FIELD12_SIZE = 4,
  FIELD13_SIZE = 1, FIELD14_SIZE = 3, FIELD15_SIZE = 1, FIELD16_SIZE = 1,
  N_REF_SIZE = 2, REV_NUM_SIZE = 5, N_SEG_SIZE = 3, MAX_LP_SEG_SIZE = 6,
  FIELD20_SIZE = 6, FIELD21_SIZE = 6, SUN_EL_SIZE = 5, SUN_AZ_SIZE = 5
 ossimNitfUse00aTag ()
virtual ~ossimNitfUse00aTag ()
virtual void parseStream (std::istream &in)
virtual void writeStream (std::ostream &out)
virtual void clearFields ()
void setAngleToNorth (const ossimString &angleToNorth)
ossimString getAngleToNorth () const
void setMeanGsd (const ossimString &meanGsd)
ossimString getMeanGsd () const
ossim_float64 getMeanGsdInMeters () const
void setField3 (const ossimString &field3)
ossimString getField3 () const
void setDynamicRange (const ossimString &dynamicRange)
ossimString getDynamicRange () const
void setField5 (const ossimString &field5)
ossimString getField5 () const
void setField6 (const ossimString &field6)
ossimString getField6 () const
void setField7 (const ossimString &field7)
ossimString getField7 () const
void setOblAng (const ossimString &oblAng)
ossimString getOblAng () const
void setRollAng (const ossimString &rollAng)
ossimString getRollAng () const
void setField10 (const ossimString &field10)
ossimString getField10 () const
void setField11 (const ossimString &field11)
ossimString getField11 () const
void setField12 (const ossimString &field12)
ossimString getField12 () const
void setField13 (const ossimString &field13)
ossimString getField13 () const
void setField14 (const ossimString &field14)
ossimString getField14 () const
void setField15 (const ossimString &field15)
ossimString getField15 () const
void setField16 (const ossimString &field16)
ossimString getField16 () const
void setNRef (const ossimString &nRef)
ossimString getNRef () const
void setRevNum (const ossimString &revNum)
ossimString getRevNum () const
void setNSeg (const ossimString &nSeg)
ossimString getNSeg () const
void setMaxLpSeg (const ossimString &maxLpSeg)
ossimString getMaxLpSeg () const
void setField20 (const ossimString &field20)
ossimString getField20 () const
void setField21 (const ossimString &field21)
ossimString getField21 () const
void setSunEl (const ossimString &sunEl)
ossimString getSunEl () const
void setSunAz (const ossimString &sunAz)
ossimString getSunAz () const
virtual std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 Print method that outputs a key/value type format adding prefix to keys. More...
- Public Member Functions inherited from ossimNitfRegisteredTag
 ossimNitfRegisteredTag ()
 default constructor More...
 ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength)
 Constructor that takes name and size. More...
virtual ~ossimNitfRegisteredTag ()
 destructor More...
virtual std::string getRegisterTagName () const
 This will return the name of the registered tag for this user defined header. More...
virtual const std::string & getTagName () const
virtual void setTagName (const std::string &tagName)
virtual ossim_uint32 getSizeInBytes () const
 Returns the length in bytes of the tag from the CEL or REL field. More...
virtual ossim_uint32 getTagLength () const
virtual void setTagLength (ossim_uint32 length)
 Set the tag length. More...
virtual void parseStream (ossim::istream &in)=0
 This will allow the user defined data to parse the stream. More...
virtual void writeStream (ossim::ostream &out)=0
virtual void getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const
 Default interface to populate keyword list with metadata. More...
virtual bool saveState (ossimKeywordlist &kwl, const ossimString &prefix) const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimPropertyInterface ()
char theAngleToNorth [ANGLE_TO_NORTH_SIZE+1]
 FIELD: ANGLETONORTH. More...
char theMeanGsd [MEAN_GSD_SIZE+1]
 FIELD: MEANGSD. More...
char theField3 [FIELD3_SIZE+1]
 FIELD: FIELD3. More...
char theDynamicRange [DYNAMIC_RANGE_SIZE+1]
 FIELD: DYNAMICRANGE. More...
char theField5 [FIELD5_SIZE+1]
 FIELD: FIELD5. More...
char theField6 [FIELD6_SIZE+1]
 FIELD: FIELD6. More...
char theField7 [FIELD7_SIZE+1]
 FIELD: FIELD7. More...
char theOblAng [OBL_ANG_SIZE+1]
 FIELD: OBLANG. More...
char theRollAng [ROLL_ANG_SIZE+1]
 FIELD: ROLLANG. More...
char theField10 [FIELD10_SIZE+1]
 FIELD: FIELD10. More...
char theField11 [FIELD11_SIZE+1]
 FIELD: FIELD11. More...
char theField12 [FIELD12_SIZE+1]
 FIELD: FIELD12. More...
char theField13 [FIELD13_SIZE+1]
 FIELD: FIELD13. More...
char theField14 [FIELD14_SIZE+1]
 FIELD: FIELD14. More...
char theField15 [FIELD15_SIZE+1]
 FIELD: FIELD15. More...
char theField16 [FIELD16_SIZE+1]
 FIELD: FIELD16. More...
char theNRef [N_REF_SIZE+1]
 FIELD: NREF. More...
char theRevNum [REV_NUM_SIZE+1]
 FIELD: REVNUM. More...
char theNSeg [N_SEG_SIZE+1]
 FIELD: NSEG. More...
char theMaxLpSeg [MAX_LP_SEG_SIZE+1]
 FIELD: MAXLPSEG. More...
char theField20 [FIELD20_SIZE+1]
 FIELD: FIELD20. More...
char theField21 [FIELD21_SIZE+1]
 FIELD: FIELD21. More...
char theSunEl [SUN_EL_SIZE+1]
 FIELD: SUNEL. More...
char theSunAz [SUN_AZ_SIZE+1]
 FIELD: SUNAZ. More...
- Protected Attributes inherited from ossimNitfRegisteredTag
std::string m_tagName
ossim_uint32 m_tagLength
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 19 of file ossimNitfUse00aTag.h.
◆ anonymous enum
anonymous enum
Enumerator
ANGLE_TO_NORTH_SIZE
MEAN_GSD_SIZE
FIELD3_SIZE
DYNAMIC_RANGE_SIZE
FIELD5_SIZE
FIELD6_SIZE
FIELD7_SIZE
OBL_ANG_SIZE
ROLL_ANG_SIZE
FIELD10_SIZE
FIELD11_SIZE
FIELD12_SIZE
FIELD13_SIZE
FIELD14_SIZE
FIELD15_SIZE
FIELD16_SIZE
N_REF_SIZE
REV_NUM_SIZE
N_SEG_SIZE
MAX_LP_SEG_SIZE
FIELD20_SIZE
FIELD21_SIZE
SUN_EL_SIZE
SUN_AZ_SIZE
Definition at line 23 of file ossimNitfUse00aTag.h.
24  {
26  MEAN_GSD_SIZE = 5,
27  FIELD3_SIZE = 1,
29  FIELD5_SIZE = 3,
30  FIELD6_SIZE = 1,
31  FIELD7_SIZE = 3,
32  OBL_ANG_SIZE = 5,
33  ROLL_ANG_SIZE = 6,
34  FIELD10_SIZE = 12,
35  FIELD11_SIZE = 15,
36  FIELD12_SIZE = 4,
37  FIELD13_SIZE = 1,
38  FIELD14_SIZE = 3,
39  FIELD15_SIZE = 1,
40  FIELD16_SIZE = 1,
41  N_REF_SIZE = 2,
42  REV_NUM_SIZE = 5,
43  N_SEG_SIZE = 3,
44  MAX_LP_SEG_SIZE = 6,
45  FIELD20_SIZE = 6,
46  FIELD21_SIZE = 6,
47  SUN_EL_SIZE = 5,
48  SUN_AZ_SIZE = 5
49  // -----
50  // 107 bytes
51  };
◆ ossimNitfUse00aTag()
ossimNitfUse00aTag::ossimNitfUse00aTag ( )
Definition at line 36 of file ossimNitfUse00aTag.cpp.
References clearFields().
37  : ossimNitfRegisteredTag(std::string("USE00A"), 107)
38 {
39  clearFields();
40 }
ossimNitfRegisteredTag()
default constructor
virtual void clearFields()
◆ ~ossimNitfUse00aTag()
ossimNitfUse00aTag::~ossimNitfUse00aTag ( )
virtual
Definition at line 42 of file ossimNitfUse00aTag.cpp.
43 {
44 }
Member Function Documentation
◆ clearFields()
void ossimNitfUse00aTag::clearFields ( )
virtual
Definition at line 104 of file ossimNitfUse00aTag.cpp.
References ANGLE_TO_NORTH_SIZE, DYNAMIC_RANGE_SIZE, FIELD10_SIZE, FIELD11_SIZE, FIELD12_SIZE, FIELD13_SIZE, FIELD14_SIZE, FIELD15_SIZE, FIELD16_SIZE, FIELD20_SIZE, FIELD21_SIZE, FIELD3_SIZE, FIELD5_SIZE, FIELD6_SIZE, FIELD7_SIZE, MAX_LP_SEG_SIZE, MEAN_GSD_SIZE, N_REF_SIZE, N_SEG_SIZE, OBL_ANG_SIZE, REV_NUM_SIZE, ROLL_ANG_SIZE, SUN_AZ_SIZE, SUN_EL_SIZE, theAngleToNorth, theDynamicRange, theField10, theField11, theField12, theField13, theField14, theField15, theField16, theField20, theField21, theField3, theField5, theField6, theField7, theMaxLpSeg, theMeanGsd, theNRef, theNSeg, theOblAng, theRevNum, theRollAng, theSunAz, and theSunEl.
Referenced by ossimNitfUse00aTag(), and parseStream().
105 {
106  memset(theAngleToNorth, ' ', ANGLE_TO_NORTH_SIZE);
107  memset(theMeanGsd, ' ', MEAN_GSD_SIZE);
108  memset(theField3, ' ', FIELD3_SIZE);
109  memset(theDynamicRange, ' ', DYNAMIC_RANGE_SIZE);
110  memset(theField5, ' ', FIELD5_SIZE);
111  memset(theField6, ' ', FIELD6_SIZE);
112  memset(theField7, ' ', FIELD7_SIZE);
113  memset(theOblAng, ' ', OBL_ANG_SIZE);
114  memset(theRollAng, ' ', ROLL_ANG_SIZE);
115  memset(theField10, ' ', FIELD10_SIZE);
116  memset(theField11, ' ', FIELD11_SIZE);
117  memset(theField12, ' ', FIELD12_SIZE);
118  memset(theField13, ' ', FIELD13_SIZE);
119  memset(theField14, ' ', FIELD14_SIZE);
120  memset(theField15, ' ', FIELD15_SIZE);
121  memset(theField16, ' ', FIELD16_SIZE);
122  memset(theNRef, ' ', N_REF_SIZE);
123  memset(theRevNum, ' ', REV_NUM_SIZE);
124  memset(theNSeg, ' ', N_SEG_SIZE);
125  memset(theMaxLpSeg, ' ', MAX_LP_SEG_SIZE);
126  memset(theField20, ' ', FIELD20_SIZE);
127  memset(theField21, ' ', FIELD21_SIZE);
128  memset(theSunEl, ' ', SUN_EL_SIZE);
129  memset(theSunAz, ' ', SUN_AZ_SIZE);
130
132  theMeanGsd[MEAN_GSD_SIZE] = '\0';
133  theField3[FIELD3_SIZE] = '\0';
135  theField5[FIELD5_SIZE] = '\0';
136  theField6[FIELD6_SIZE] = '\0';
137  theField7[FIELD7_SIZE] = '\0';
138  theOblAng[OBL_ANG_SIZE] = '\0';
139  theRollAng[ROLL_ANG_SIZE] = '\0';
140  theField10[FIELD10_SIZE] = '\0';
141  theField11[FIELD11_SIZE] = '\0';
142  theField12[FIELD12_SIZE] = '\0';
143  theField13[FIELD13_SIZE] = '\0';
144  theField14[FIELD14_SIZE] = '\0';
145  theField15[FIELD15_SIZE] = '\0';
146  theField16[FIELD16_SIZE] = '\0';
147  theNRef[N_REF_SIZE] = '\0';
148  theRevNum[REV_NUM_SIZE] = '\0';
149  theNSeg[N_SEG_SIZE] = '\0';
151  theField20[FIELD20_SIZE] = '\0';
152  theField21[FIELD21_SIZE] = '\0';
153  theSunEl[SUN_EL_SIZE] = '\0';
154  theSunAz[SUN_AZ_SIZE] = '\0';
155 }
char theNSeg[N_SEG_SIZE+1]
FIELD: NSEG.
char theMaxLpSeg[MAX_LP_SEG_SIZE+1]
FIELD: MAXLPSEG.
char theField15[FIELD15_SIZE+1]
FIELD: FIELD15.
char theRevNum[REV_NUM_SIZE+1]
FIELD: REVNUM.
char theField14[FIELD14_SIZE+1]
FIELD: FIELD14.
char theField3[FIELD3_SIZE+1]
FIELD: FIELD3.
char theNRef[N_REF_SIZE+1]
FIELD: NREF.
char theField12[FIELD12_SIZE+1]
FIELD: FIELD12.
char theField11[FIELD11_SIZE+1]
FIELD: FIELD11.
char theMeanGsd[MEAN_GSD_SIZE+1]
FIELD: MEANGSD.
char theField6[FIELD6_SIZE+1]
FIELD: FIELD6.
char theField13[FIELD13_SIZE+1]
FIELD: FIELD13.
char theField5[FIELD5_SIZE+1]
FIELD: FIELD5.
char theField7[FIELD7_SIZE+1]
FIELD: FIELD7.
char theField21[FIELD21_SIZE+1]
FIELD: FIELD21.
char theRollAng[ROLL_ANG_SIZE+1]
FIELD: ROLLANG.
char theField10[FIELD10_SIZE+1]
FIELD: FIELD10.
char theAngleToNorth[ANGLE_TO_NORTH_SIZE+1]
char theSunEl[SUN_EL_SIZE+1]
FIELD: SUNEL.
char theOblAng[OBL_ANG_SIZE+1]
FIELD: OBLANG.
char theDynamicRange[DYNAMIC_RANGE_SIZE+1]
char theField20[FIELD20_SIZE+1]
FIELD: FIELD20.
char theSunAz[SUN_AZ_SIZE+1]
FIELD: SUNAZ.
char theField16[FIELD16_SIZE+1]
FIELD: FIELD16.
◆ getAngleToNorth()
ossimString ossimNitfUse00aTag::getAngleToNorth ( ) const
Definition at line 157 of file ossimNitfUse00aTag.cpp.
References theAngleToNorth.
158 {
159  return theAngleToNorth;
160 }
◆ getDynamicRange()
ossimString ossimNitfUse00aTag::getDynamicRange ( ) const
Definition at line 207 of file ossimNitfUse00aTag.cpp.
References theDynamicRange.
208 {
209  return theDynamicRange;
210 }
◆ getField10()
ossimString ossimNitfUse00aTag::getField10 ( ) const
Definition at line 273 of file ossimNitfUse00aTag.cpp.
References theField10.
274 {
275  return theField10;
276 }
FIELD: FIELD10.
◆ getField11()
ossimString ossimNitfUse00aTag::getField11 ( ) const
Definition at line 284 of file ossimNitfUse00aTag.cpp.
References theField11.
285 {
286  return theField11;
287 }
FIELD: FIELD11.
◆ getField12()
ossimString ossimNitfUse00aTag::getField12 ( ) const
Definition at line 295 of file ossimNitfUse00aTag.cpp.
References theField12.
296 {
297  return theField12;
298 }
FIELD: FIELD12.
◆ getField13()
ossimString ossimNitfUse00aTag::getField13 ( ) const
Definition at line 306 of file ossimNitfUse00aTag.cpp.
References theField13.
307 {
308  return theField13;
309 }
FIELD: FIELD13.
◆ getField14()
ossimString ossimNitfUse00aTag::getField14 ( ) const
Definition at line 317 of file ossimNitfUse00aTag.cpp.
References theField14.
318 {
319  return theField14;
320 }
FIELD: FIELD14.
◆ getField15()
ossimString ossimNitfUse00aTag::getField15 ( ) const
Definition at line 328 of file ossimNitfUse00aTag.cpp.
References theField15.
329 {
330  return theField15;
331 }
FIELD: FIELD15.
◆ getField16()
ossimString ossimNitfUse00aTag::getField16 ( ) const
Definition at line 339 of file ossimNitfUse00aTag.cpp.
References theField16.
340 {
341  return theField16;
342 }
FIELD: FIELD16.
◆ getField20()
ossimString ossimNitfUse00aTag::getField20 ( ) const
Definition at line 394 of file ossimNitfUse00aTag.cpp.
References theField20.
395 {
396  return theField20;
397 }
FIELD: FIELD20.
◆ getField21()
ossimString ossimNitfUse00aTag::getField21 ( ) const
Definition at line 405 of file ossimNitfUse00aTag.cpp.
References theField21.
406 {
407  return theField21;
408 }
FIELD: FIELD21.
◆ getField3()
ossimString ossimNitfUse00aTag::getField3 ( ) const
Definition at line 196 of file ossimNitfUse00aTag.cpp.
References theField3.
197 {
198  return theField3;
199 }
FIELD: FIELD3.
◆ getField5()
ossimString ossimNitfUse00aTag::getField5 ( ) const
Definition at line 218 of file ossimNitfUse00aTag.cpp.
References theField5.
219 {
220  return theField5;
221 }
FIELD: FIELD5.
◆ getField6()
ossimString ossimNitfUse00aTag::getField6 ( ) const
Definition at line 229 of file ossimNitfUse00aTag.cpp.
References theField6.
230 {
231  return theField6;
232 }
FIELD: FIELD6.
◆ getField7()
ossimString ossimNitfUse00aTag::getField7 ( ) const
Definition at line 240 of file ossimNitfUse00aTag.cpp.
References theField7.
241 {
242  return theField7;
243 }
FIELD: FIELD7.
◆ getMaxLpSeg()
ossimString ossimNitfUse00aTag::getMaxLpSeg ( ) const
Definition at line 383 of file ossimNitfUse00aTag.cpp.
References theMaxLpSeg.
384 {
385  return theMaxLpSeg;
386 }
FIELD: MAXLPSEG.
◆ getMeanGsd()
ossimString ossimNitfUse00aTag::getMeanGsd ( ) const
Definition at line 168 of file ossimNitfUse00aTag.cpp.
References theMeanGsd.
169 {
170  return theMeanGsd;
171 }
FIELD: MEANGSD.
◆ getMeanGsdInMeters()
ossim_float64 ossimNitfUse00aTag::getMeanGsdInMeters ( ) const
Returns
MEANGSD field as a double converted to meters.
Note
Conversion used: gsd_in_meters = gsd / 12.0 * MTRS_PER_FT
Definition at line 173 of file ossimNitfUse00aTag.cpp.
References ossim::isnan(), MTRS_PER_FT, ossimString::size(), theMeanGsd, and ossimString::toFloat64().
174 {
175  ossim_float64 gsd = 0.0;
176
178  if (s.size())
179  {
180  ossim_float64 d = s.toFloat64();
181  if ( (d != 0.0) && (ossim::isnan(d) == false) )
182  {
183  gsd = d / 12.0 * MTRS_PER_FT;
184  }
185  }
186
187  return gsd;
188 }
FIELD: MEANGSD.
double ossim_float64
std::string::size_type size() const
Definition: ossimString.h:405
ossim_float64 toFloat64() const
#define MTRS_PER_FT
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ getNRef()
ossimString ossimNitfUse00aTag::getNRef ( ) const
Definition at line 350 of file ossimNitfUse00aTag.cpp.
References theNRef.
351 {
352  return theNRef;
353 }
FIELD: NREF.
◆ getNSeg()
ossimString ossimNitfUse00aTag::getNSeg ( ) const
Definition at line 372 of file ossimNitfUse00aTag.cpp.
References theNSeg.
373 {
374  return theNSeg;
375 }
FIELD: NSEG.
◆ getOblAng()
ossimString ossimNitfUse00aTag::getOblAng ( ) const
Definition at line 251 of file ossimNitfUse00aTag.cpp.
References theOblAng.
252 {
253  return theOblAng;
254 }
FIELD: OBLANG.
◆ getProperty()
ossimRefPtr< ossimProperty > ossimNitfUse00aTag::getProperty ( const ossimString name) const
virtual
Reimplemented from ossimNitfRegisteredTag.
Definition at line 468 of file ossimNitfUse00aTag.cpp.
469 {
470  ossimProperty* result = 0;
471
472  if(name == ANGLETONORTH_KW)
473  {
474  result = new ossimStringProperty(name, theAngleToNorth);
475  }
476  else if(name == MEANGSD_KW)
477  {
478  result = new ossimStringProperty(name, theMeanGsd);
479  }
480  else if(name == DYNAMICRANGE_KW)
481  {
482  result = new ossimStringProperty(name, theDynamicRange);
483  }
484  else if(name == OBLANG_KW)
485  {
486  result = new ossimStringProperty(name, theOblAng);
487  }
488  else if(name == ROLLANG_KW)
489  {
490  result = new ossimStringProperty(name, theRollAng);
491  }
492  else if(name == NREF_KW)
493  {
494  result = new ossimStringProperty(name, theNRef);
495  }
496  else if(name == REVNUM_KW)
497  {
498  result = new ossimStringProperty(name, theRevNum);
499  }
500  else if(name == NSEG_KW)
501  {
502  result = new ossimStringProperty(name, theNSeg);
503  }
504  else if(name == MAXLPSEG_KW)
505  {
506  result = new ossimStringProperty(name, theMaxLpSeg);
507  }
508  else if(name == SUNEL_KW)
509  {
510  result = new ossimStringProperty(name, theSunEl);
511  }
512  else if(name == SUNAZ_KW)
513  {
514  result = new ossimStringProperty(name, theSunAz);
515  }
516  else
517  {
519  }
520
521  return result;
522 }
FIELD: NSEG.
FIELD: MAXLPSEG.
FIELD: REVNUM.
FIELD: NREF.
FIELD: MEANGSD.
FIELD: ROLLANG.
FIELD: SUNEL.
FIELD: OBLANG.
FIELD: SUNAZ.
◆ getPropertyNames()
void ossimNitfUse00aTag::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 524 of file ossimNitfUse00aTag.cpp.
References ossimNitfRegisteredTag::getPropertyNames().
525 {
527
528  propertyNames.push_back(ANGLETONORTH_KW);
529  propertyNames.push_back(MEANGSD_KW);
530  propertyNames.push_back(DYNAMICRANGE_KW);
531  propertyNames.push_back(OBLANG_KW);
532  propertyNames.push_back(ROLLANG_KW);
533  propertyNames.push_back(NREF_KW);
534  propertyNames.push_back(REVNUM_KW);
535  propertyNames.push_back(NSEG_KW);
536  propertyNames.push_back(MAXLPSEG_KW);
537  propertyNames.push_back(SUNEL_KW);
538  propertyNames.push_back(SUNAZ_KW);
539 }
◆ getRevNum()
ossimString ossimNitfUse00aTag::getRevNum ( ) const
Definition at line 361 of file ossimNitfUse00aTag.cpp.
References theRevNum.
362 {
363  return theRevNum;
364 }
FIELD: REVNUM.
◆ getRollAng()
ossimString ossimNitfUse00aTag::getRollAng ( ) const
Definition at line 262 of file ossimNitfUse00aTag.cpp.
References theRollAng.
263 {
264  return theRollAng;
265 }
FIELD: ROLLANG.
◆ getSunAz()
ossimString ossimNitfUse00aTag::getSunAz ( ) const
Definition at line 427 of file ossimNitfUse00aTag.cpp.
References theSunAz.
428 {
429  return theSunAz;
430 }
FIELD: SUNAZ.
◆ getSunEl()
ossimString ossimNitfUse00aTag::getSunEl ( ) const
Definition at line 416 of file ossimNitfUse00aTag.cpp.
References theSunEl.
417 {
418  return theSunEl;
419 }
FIELD: SUNEL.
◆ parseStream()
void ossimNitfUse00aTag::parseStream ( std::istream &  in)
virtual
Definition at line 46 of file ossimNitfUse00aTag.cpp.
References ANGLE_TO_NORTH_SIZE, clearFields(), DYNAMIC_RANGE_SIZE, FIELD10_SIZE, FIELD11_SIZE, FIELD12_SIZE, FIELD13_SIZE, FIELD14_SIZE, FIELD15_SIZE, FIELD16_SIZE, FIELD20_SIZE, FIELD21_SIZE, FIELD3_SIZE, FIELD5_SIZE, FIELD6_SIZE, FIELD7_SIZE, MAX_LP_SEG_SIZE, MEAN_GSD_SIZE, N_REF_SIZE, N_SEG_SIZE, OBL_ANG_SIZE, REV_NUM_SIZE, ROLL_ANG_SIZE, SUN_AZ_SIZE, SUN_EL_SIZE, theAngleToNorth, theDynamicRange, theField10, theField11, theField12, theField13, theField14, theField15, theField16, theField20, theField21, theField3, theField5, theField6, theField7, theMaxLpSeg, theMeanGsd, theNRef, theNSeg, theOblAng, theRevNum, theRollAng, theSunAz, and theSunEl.
47 {
48  clearFields();
49
51  in.read(theMeanGsd, MEAN_GSD_SIZE);
52  in.read(theField3, FIELD3_SIZE);
54  in.read(theField5, FIELD5_SIZE);
55  in.read(theField6, FIELD6_SIZE);
56  in.read(theField7, FIELD7_SIZE);
57  in.read(theOblAng, OBL_ANG_SIZE);
58  in.read(theRollAng, ROLL_ANG_SIZE);
59  in.read(theField10, FIELD10_SIZE);
60  in.read(theField11, FIELD11_SIZE);
61  in.read(theField12, FIELD12_SIZE);
62  in.read(theField13, FIELD13_SIZE);
63  in.read(theField14, FIELD14_SIZE);
64  in.read(theField15, FIELD15_SIZE);
65  in.read(theField16, FIELD16_SIZE);
66  in.read(theNRef, N_REF_SIZE);
67  in.read(theRevNum, REV_NUM_SIZE);
68  in.read(theNSeg, N_SEG_SIZE);
69  in.read(theMaxLpSeg, MAX_LP_SEG_SIZE);
70  in.read(theField20, FIELD20_SIZE);
71  in.read(theField21, FIELD21_SIZE);
72  in.read(theSunEl, SUN_EL_SIZE);
73  in.read(theSunAz, SUN_AZ_SIZE);
74 }
FIELD: NSEG.
FIELD: MAXLPSEG.
FIELD: FIELD15.
FIELD: REVNUM.
FIELD: FIELD14.
FIELD: FIELD3.
FIELD: NREF.
FIELD: FIELD12.
FIELD: FIELD11.
FIELD: MEANGSD.
FIELD: FIELD6.
FIELD: FIELD13.
FIELD: FIELD5.
FIELD: FIELD7.
FIELD: FIELD21.
FIELD: ROLLANG.
FIELD: FIELD10.
FIELD: SUNEL.
FIELD: OBLANG.
FIELD: FIELD20.
FIELD: SUNAZ.
FIELD: FIELD16.
◆ print()
std::ostream & ossimNitfUse00aTag::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
virtual
Parameters
outStream to output to.
prefixPrefix added to key like "image0.";
Definition at line 438 of file ossimNitfUse00aTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theAngleToNorth, theDynamicRange, theMaxLpSeg, theMeanGsd, theNRef, theNSeg, theOblAng, theRevNum, theRollAng, theSunAz, and theSunEl.
440 {
441  std::string pfx = prefix;
442  pfx += getTagName();
443  pfx += ".";
444
445  out << setiosflags(std::ios::left)
446  << pfx << std::setw(24) << "CETAG:" << getTagName() << "\n"
447  << pfx << std::setw(24) << "CEL:" << getTagLength() << "\n"
448  << pfx << std::setw(24) << "ANGLETONORTH:" << theAngleToNorth << "\n"
449  << pfx << std::setw(24) << "MEANGSD:" << theMeanGsd << "\n"
450  << pfx << std::setw(24) << "DYNAMICRANGE:" << theDynamicRange << "\n"
451  << pfx << std::setw(24) << "OBLANG:" << theOblAng << "\n"
452  << pfx << std::setw(24) << "ROLLANG:" << theRollAng << "\n"
453  << pfx << std::setw(24) << "NREF:" << theNRef << "\n"
454  << pfx << std::setw(24) << "REVNUM:" << theRevNum << "\n"
455  << pfx << std::setw(24) << "NSEG:" << theNSeg << "\n"
456  << pfx << std::setw(24) << "MAXLPSEG:" << theMaxLpSeg << "\n"
457  << pfx << std::setw(24) << "SUNEL:" << theSunEl << "\n"
458  << pfx << std::setw(24) << "SUNAZ:" << theSunAz << "\n";
459
460  return out;
461 }
FIELD: NSEG.
virtual const std::string & getTagName() const
FIELD: MAXLPSEG.
FIELD: REVNUM.
FIELD: NREF.
FIELD: MEANGSD.
virtual ossim_uint32 getTagLength() const
FIELD: ROLLANG.
FIELD: SUNEL.
FIELD: OBLANG.
FIELD: SUNAZ.
◆ setAngleToNorth()
void ossimNitfUse00aTag::setAngleToNorth ( const ossimString angleToNorth)
Definition at line 162 of file ossimNitfUse00aTag.cpp.
References ANGLE_TO_NORTH_SIZE, ossimString::c_str(), ossimString::length(), min, and theAngleToNorth.
163 {
164  memset(theAngleToNorth, ' ', ANGLE_TO_NORTH_SIZE);
165  memcpy(theAngleToNorth, angleToNorth.c_str(), std::min((size_t)ANGLE_TO_NORTH_SIZE, angleToNorth.length()));
166 }
std::string::size_type length() const
Definition: ossimString.h:408
const char * c_str() const
Definition: ossimString.h:396
#define min(a, b)
Definition: auxiliary.h:75
◆ setDynamicRange()
void ossimNitfUse00aTag::setDynamicRange ( const ossimString dynamicRange)
Definition at line 212 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), DYNAMIC_RANGE_SIZE, ossimString::length(), min, and theDynamicRange.
213 {
214  memset(theDynamicRange, ' ', DYNAMIC_RANGE_SIZE);
215  memcpy(theDynamicRange, dynamicRange.c_str(), std::min((size_t)DYNAMIC_RANGE_SIZE, dynamicRange.length()));
216 }
#define min(a, b)
◆ setField10()
void ossimNitfUse00aTag::setField10 ( const ossimString field10)
Definition at line 278 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD10_SIZE, ossimString::length(), min, and theField10.
279 {
280  memset(theField10, ' ', FIELD10_SIZE);
281  memcpy(theField10, field10.c_str(), std::min((size_t)FIELD10_SIZE, field10.length()));
282 }
FIELD: FIELD10.
#define min(a, b)
◆ setField11()
void ossimNitfUse00aTag::setField11 ( const ossimString field11)
Definition at line 289 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD11_SIZE, ossimString::length(), min, and theField11.
290 {
291  memset(theField11, ' ', FIELD11_SIZE);
292  memcpy(theField11, field11.c_str(), std::min((size_t)FIELD11_SIZE, field11.length()));
293 }
FIELD: FIELD11.
#define min(a, b)
◆ setField12()
void ossimNitfUse00aTag::setField12 ( const ossimString field12)
Definition at line 300 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD12_SIZE, ossimString::length(), min, and theField12.
301 {
302  memset(theField12, ' ', FIELD12_SIZE);
303  memcpy(theField12, field12.c_str(), std::min((size_t)FIELD12_SIZE, field12.length()));
304 }
FIELD: FIELD12.
#define min(a, b)
◆ setField13()
void ossimNitfUse00aTag::setField13 ( const ossimString field13)
Definition at line 311 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD13_SIZE, ossimString::length(), min, and theField13.
312 {
313  memset(theField13, ' ', FIELD13_SIZE);
314  memcpy(theField13, field13.c_str(), std::min((size_t)FIELD13_SIZE, field13.length()));
315 }
FIELD: FIELD13.
#define min(a, b)
◆ setField14()
void ossimNitfUse00aTag::setField14 ( const ossimString field14)
Definition at line 322 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD14_SIZE, ossimString::length(), min, and theField14.
323 {
324  memset(theField14, ' ', FIELD14_SIZE);
325  memcpy(theField14, field14.c_str(), std::min((size_t)FIELD14_SIZE, field14.length()));
326 }
FIELD: FIELD14.
#define min(a, b)
◆ setField15()
void ossimNitfUse00aTag::setField15 ( const ossimString field15)
Definition at line 333 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD15_SIZE, ossimString::length(), min, and theField15.
334 {
335  memset(theField15, ' ', FIELD15_SIZE);
336  memcpy(theField15, field15.c_str(), std::min((size_t)FIELD15_SIZE, field15.length()));
337 }
FIELD: FIELD15.
#define min(a, b)
◆ setField16()
void ossimNitfUse00aTag::setField16 ( const ossimString field16)
Definition at line 344 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD16_SIZE, ossimString::length(), min, and theField16.
345 {
346  memset(theField16, ' ', FIELD16_SIZE);
347  memcpy(theField16, field16.c_str(), std::min((size_t)FIELD16_SIZE, field16.length()));
348 }
#define min(a, b)
FIELD: FIELD16.
◆ setField20()
void ossimNitfUse00aTag::setField20 ( const ossimString field20)
Definition at line 399 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD20_SIZE, ossimString::length(), min, and theField20.
400 {
401  memset(theField20, ' ', FIELD20_SIZE);
402  memcpy(theField20, field20.c_str(), std::min((size_t)FIELD20_SIZE, field20.length()));
403 }
FIELD: FIELD20.
#define min(a, b)
◆ setField21()
void ossimNitfUse00aTag::setField21 ( const ossimString field21)
Definition at line 410 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD21_SIZE, ossimString::length(), min, and theField21.
411 {
412  memset(theField21, ' ', FIELD21_SIZE);
413  memcpy(theField21, field21.c_str(), std::min((size_t)FIELD21_SIZE, field21.length()));
414 }
FIELD: FIELD21.
#define min(a, b)
◆ setField3()
void ossimNitfUse00aTag::setField3 ( const ossimString field3)
Definition at line 201 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD3_SIZE, ossimString::length(), min, and theField3.
202 {
203  memset(theField3, ' ', FIELD3_SIZE);
204  memcpy(theField3, field3.c_str(), std::min((size_t)FIELD3_SIZE, field3.length()));
205 }
FIELD: FIELD3.
#define min(a, b)
◆ setField5()
void ossimNitfUse00aTag::setField5 ( const ossimString field5)
Definition at line 223 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD5_SIZE, ossimString::length(), min, and theField5.
224 {
225  memset(theField5, ' ', FIELD5_SIZE);
226  memcpy(theField5, field5.c_str(), std::min((size_t)FIELD5_SIZE, field5.length()));
227 }
FIELD: FIELD5.
#define min(a, b)
◆ setField6()
void ossimNitfUse00aTag::setField6 ( const ossimString field6)
Definition at line 234 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD6_SIZE, ossimString::length(), min, and theField6.
235 {
236  memset(theField6, ' ', FIELD6_SIZE);
237  memcpy(theField6, field6.c_str(), std::min((size_t)FIELD6_SIZE, field6.length()));
238 }
FIELD: FIELD6.
#define min(a, b)
◆ setField7()
void ossimNitfUse00aTag::setField7 ( const ossimString field7)
Definition at line 245 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), FIELD7_SIZE, ossimString::length(), min, and theField7.
246 {
247  memset(theField7, ' ', FIELD7_SIZE);
248  memcpy(theField7, field7.c_str(), std::min((size_t)FIELD7_SIZE, field7.length()));
249 }
FIELD: FIELD7.
#define min(a, b)
◆ setMaxLpSeg()
void ossimNitfUse00aTag::setMaxLpSeg ( const ossimString maxLpSeg)
Definition at line 388 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), MAX_LP_SEG_SIZE, min, and theMaxLpSeg.
389 {
390  memset(theMaxLpSeg, ' ', MAX_LP_SEG_SIZE);
391  memcpy(theMaxLpSeg, maxLpSeg.c_str(), std::min((size_t)MAX_LP_SEG_SIZE, maxLpSeg.length()));
392 }
FIELD: MAXLPSEG.
#define min(a, b)
◆ setMeanGsd()
void ossimNitfUse00aTag::setMeanGsd ( const ossimString meanGsd)
Definition at line 190 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), MEAN_GSD_SIZE, min, and theMeanGsd.
191 {
192  memset(theMeanGsd, ' ', MEAN_GSD_SIZE);
193  memcpy(theMeanGsd, meanGsd.c_str(), std::min((size_t)MEAN_GSD_SIZE, meanGsd.length()));
194 }
FIELD: MEANGSD.
#define min(a, b)
◆ setNRef()
void ossimNitfUse00aTag::setNRef ( const ossimString nRef)
Definition at line 355 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, N_REF_SIZE, and theNRef.
356 {
357  memset(theNRef, ' ', N_REF_SIZE);
358  memcpy(theNRef, nRef.c_str(), std::min((size_t)N_REF_SIZE, nRef.length()));
359 }
FIELD: NREF.
#define min(a, b)
◆ setNSeg()
void ossimNitfUse00aTag::setNSeg ( const ossimString nSeg)
Definition at line 377 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, N_SEG_SIZE, and theNSeg.
378 {
379  memset(theNSeg, ' ', N_SEG_SIZE);
380  memcpy(theNSeg, nSeg.c_str(), std::min((size_t)N_SEG_SIZE, nSeg.length()));
381 }
FIELD: NSEG.
#define min(a, b)
◆ setOblAng()
void ossimNitfUse00aTag::setOblAng ( const ossimString oblAng)
Definition at line 256 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, OBL_ANG_SIZE, and theOblAng.
257 {
258  memset(theOblAng, ' ', OBL_ANG_SIZE);
259  memcpy(theOblAng, oblAng.c_str(), std::min((size_t)OBL_ANG_SIZE, oblAng.length()));
260 }
FIELD: OBLANG.
#define min(a, b)
◆ setProperty()
void ossimNitfUse00aTag::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 463 of file ossimNitfUse00aTag.cpp.
References ossimNitfRegisteredTag::setProperty().
464 {
466 }
◆ setRevNum()
void ossimNitfUse00aTag::setRevNum ( const ossimString revNum)
Definition at line 366 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, REV_NUM_SIZE, and theRevNum.
367 {
368  memset(theRevNum, ' ', REV_NUM_SIZE);
369  memcpy(theRevNum, revNum.c_str(), std::min((size_t)REV_NUM_SIZE, revNum.length()));
370 }
FIELD: REVNUM.
#define min(a, b)
◆ setRollAng()
void ossimNitfUse00aTag::setRollAng ( const ossimString rollAng)
Definition at line 267 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, ROLL_ANG_SIZE, and theRollAng.
268 {
269  memset(theRollAng, ' ', ROLL_ANG_SIZE);
270  memcpy(theRollAng, rollAng.c_str(), std::min((size_t)ROLL_ANG_SIZE, rollAng.length()));
271 }
FIELD: ROLLANG.
#define min(a, b)
◆ setSunAz()
void ossimNitfUse00aTag::setSunAz ( const ossimString sunAz)
Definition at line 432 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, SUN_AZ_SIZE, and theSunAz.
433 {
434  memset(theSunAz, ' ', SUN_AZ_SIZE);
435  memcpy(theSunAz, sunAz.c_str(), std::min((size_t)SUN_AZ_SIZE, sunAz.length()));
436 }
FIELD: SUNAZ.
#define min(a, b)
◆ setSunEl()
void ossimNitfUse00aTag::setSunEl ( const ossimString sunEl)
Definition at line 421 of file ossimNitfUse00aTag.cpp.
References ossimString::c_str(), ossimString::length(), min, SUN_EL_SIZE, and theSunEl.
422 {
423  memset(theSunEl, ' ', SUN_EL_SIZE);
424  memcpy(theSunEl, sunEl.c_str(), std::min((size_t)SUN_EL_SIZE, sunEl.length()));
425 }
FIELD: SUNEL.
#define min(a, b)
◆ writeStream()
void ossimNitfUse00aTag::writeStream ( std::ostream &  out)
virtual
Definition at line 76 of file ossimNitfUse00aTag.cpp.
77 {
79  out.write(theMeanGsd, MEAN_GSD_SIZE);
80  out.write(theField3, FIELD3_SIZE);
82  out.write(theField5, FIELD5_SIZE);
83  out.write(theField6, FIELD6_SIZE);
84  out.write(theField7, FIELD7_SIZE);
85  out.write(theOblAng, OBL_ANG_SIZE);
86  out.write(theRollAng, ROLL_ANG_SIZE);
87  out.write(theField10, FIELD10_SIZE);
88  out.write(theField11, FIELD11_SIZE);
89  out.write(theField12, FIELD12_SIZE);
90  out.write(theField13, FIELD13_SIZE);
91  out.write(theField14, FIELD14_SIZE);
92  out.write(theField15, FIELD15_SIZE);
93  out.write(theField16, FIELD16_SIZE);
94  out.write(theNRef, N_REF_SIZE);
95  out.write(theRevNum, REV_NUM_SIZE);
96  out.write(theNSeg, N_SEG_SIZE);
97  out.write(theMaxLpSeg, MAX_LP_SEG_SIZE);
98  out.write(theField20, FIELD20_SIZE);
99  out.write(theField21, FIELD21_SIZE);
100  out.write(theSunEl, SUN_EL_SIZE);
101  out.write(theSunAz, SUN_AZ_SIZE);
102 }
FIELD: NSEG.
FIELD: MAXLPSEG.
FIELD: FIELD15.
FIELD: REVNUM.
FIELD: FIELD14.
FIELD: FIELD3.
FIELD: NREF.
FIELD: FIELD12.
FIELD: FIELD11.
FIELD: MEANGSD.
FIELD: FIELD6.
FIELD: FIELD13.
FIELD: FIELD5.
FIELD: FIELD7.
FIELD: FIELD21.
FIELD: ROLLANG.
FIELD: FIELD10.
FIELD: SUNEL.
FIELD: OBLANG.
FIELD: FIELD20.
FIELD: SUNAZ.
FIELD: FIELD16.
Member Data Documentation
◆ theAngleToNorth
char ossimNitfUse00aTag::theAngleToNorth[ANGLE_TO_NORTH_SIZE+1]
protected
Definition at line 139 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getAngleToNorth(), parseStream(), print(), setAngleToNorth(), and writeStream().
◆ theDynamicRange
char ossimNitfUse00aTag::theDynamicRange[DYNAMIC_RANGE_SIZE+1]
protected
Definition at line 157 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getDynamicRange(), parseStream(), print(), setDynamicRange(), and writeStream().
◆ theField10
char ossimNitfUse00aTag::theField10[FIELD10_SIZE+1]
protected
FIELD: FIELD10.
Definition at line 193 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField10(), parseStream(), setField10(), and writeStream().
◆ theField11
char ossimNitfUse00aTag::theField11[FIELD11_SIZE+1]
protected
FIELD: FIELD11.
Definition at line 199 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField11(), parseStream(), setField11(), and writeStream().
◆ theField12
char ossimNitfUse00aTag::theField12[FIELD12_SIZE+1]
protected
FIELD: FIELD12.
Definition at line 205 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField12(), parseStream(), setField12(), and writeStream().
◆ theField13
char ossimNitfUse00aTag::theField13[FIELD13_SIZE+1]
protected
FIELD: FIELD13.
Definition at line 211 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField13(), parseStream(), setField13(), and writeStream().
◆ theField14
char ossimNitfUse00aTag::theField14[FIELD14_SIZE+1]
protected
FIELD: FIELD14.
Definition at line 217 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField14(), parseStream(), setField14(), and writeStream().
◆ theField15
char ossimNitfUse00aTag::theField15[FIELD15_SIZE+1]
protected
FIELD: FIELD15.
Definition at line 223 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField15(), parseStream(), setField15(), and writeStream().
◆ theField16
char ossimNitfUse00aTag::theField16[FIELD16_SIZE+1]
protected
FIELD: FIELD16.
Definition at line 229 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField16(), parseStream(), setField16(), and writeStream().
◆ theField20
char ossimNitfUse00aTag::theField20[FIELD20_SIZE+1]
protected
FIELD: FIELD20.
Definition at line 259 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField20(), parseStream(), setField20(), and writeStream().
◆ theField21
char ossimNitfUse00aTag::theField21[FIELD21_SIZE+1]
protected
FIELD: FIELD21.
Definition at line 265 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField21(), parseStream(), setField21(), and writeStream().
◆ theField3
char ossimNitfUse00aTag::theField3[FIELD3_SIZE+1]
protected
FIELD: FIELD3.
Definition at line 151 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField3(), parseStream(), setField3(), and writeStream().
◆ theField5
char ossimNitfUse00aTag::theField5[FIELD5_SIZE+1]
protected
FIELD: FIELD5.
Definition at line 163 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField5(), parseStream(), setField5(), and writeStream().
◆ theField6
char ossimNitfUse00aTag::theField6[FIELD6_SIZE+1]
protected
FIELD: FIELD6.
Definition at line 169 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField6(), parseStream(), setField6(), and writeStream().
◆ theField7
char ossimNitfUse00aTag::theField7[FIELD7_SIZE+1]
protected
FIELD: FIELD7.
Definition at line 175 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getField7(), parseStream(), setField7(), and writeStream().
◆ theMaxLpSeg
char ossimNitfUse00aTag::theMaxLpSeg[MAX_LP_SEG_SIZE+1]
protected
FIELD: MAXLPSEG.
Definition at line 253 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getMaxLpSeg(), parseStream(), print(), setMaxLpSeg(), and writeStream().
◆ theMeanGsd
char ossimNitfUse00aTag::theMeanGsd[MEAN_GSD_SIZE+1]
protected
FIELD: MEANGSD.
Definition at line 145 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getMeanGsd(), getMeanGsdInMeters(), parseStream(), print(), setMeanGsd(), and writeStream().
◆ theNRef
char ossimNitfUse00aTag::theNRef[N_REF_SIZE+1]
protected
FIELD: NREF.
Definition at line 235 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getNRef(), parseStream(), print(), setNRef(), and writeStream().
◆ theNSeg
char ossimNitfUse00aTag::theNSeg[N_SEG_SIZE+1]
protected
FIELD: NSEG.
Definition at line 247 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getNSeg(), parseStream(), print(), setNSeg(), and writeStream().
◆ theOblAng
char ossimNitfUse00aTag::theOblAng[OBL_ANG_SIZE+1]
protected
FIELD: OBLANG.
Definition at line 181 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getOblAng(), parseStream(), print(), setOblAng(), and writeStream().
◆ theRevNum
char ossimNitfUse00aTag::theRevNum[REV_NUM_SIZE+1]
protected
FIELD: REVNUM.
Definition at line 241 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getRevNum(), parseStream(), print(), setRevNum(), and writeStream().
◆ theRollAng
char ossimNitfUse00aTag::theRollAng[ROLL_ANG_SIZE+1]
protected
FIELD: ROLLANG.
Definition at line 187 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getRollAng(), parseStream(), print(), setRollAng(), and writeStream().
◆ theSunAz
char ossimNitfUse00aTag::theSunAz[SUN_AZ_SIZE+1]
protected
FIELD: SUNAZ.
Definition at line 277 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getSunAz(), parseStream(), print(), setSunAz(), and writeStream().
◆ theSunEl
char ossimNitfUse00aTag::theSunEl[SUN_EL_SIZE+1]
protected
FIELD: SUNEL.
Definition at line 271 of file ossimNitfUse00aTag.h.
Referenced by clearFields(), getSunEl(), parseStream(), print(), setSunEl(), and writeStream().
