Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimNmeaMessage Class Reference
#include <ossimNmeaMessage.h>
Inheritance diagram for ossimNmeaMessage:
ossimReferenced
Public Types
typedef std::vector< ossimStringFieldListType
 ossimNmeaMessage (const std::string &acceptedStartingCharacters="!$")
virtual void parseMessage (std::istream &in) throw (ossimException)
 Parses a standard formatted NMEA message. More...
virtual bool valid () const
bool validCheckSum () const
ossim_uint32 numberOfFields () const
const std::string & getField (ossim_uint32 idx)
const std::string & operator[] (int idx) const
void setStartChars (const std::string &acceptedStartingCharacters="!$")
virtual void reset ()
const std::string & message () const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossim_uint32 checksum (std::string::const_iterator start, std::string::const_iterator end)
virtual void setFields (std::string::const_iterator start, std::string::const_iterator end)
bool isValidStartChar (char c) const
virtual ~ossimReferenced ()
std::string m_message
FieldListType m_fields
bool m_validCheckSum
std::string m_startChars
Detailed Description
Definition at line 26 of file ossimNmeaMessage.h.
Member Typedef Documentation
◆ FieldListType
Definition at line 29 of file ossimNmeaMessage.h.
◆ ossimNmeaMessage()
ossimNmeaMessage::ossimNmeaMessage ( const std::string &  acceptedStartingCharacters = "!$")
inline
Definition at line 31 of file ossimNmeaMessage.h.
31 :m_startChars(acceptedStartingCharacters){}
Member Function Documentation
◆ checksum()
ossim_uint32 ossimNmeaMessage::checksum ( std::string::const_iterator  start,
static
Definition at line 18 of file ossimNmeaMessage.cpp.
19 {
20  ossim_uint32 sum = 0;
21
22  while(start!=end&&((*start)!='*'))
23  {
24  sum ^= ((*start)%128);
25  ++start;
26  }
27  return sum;
28 }
unsigned int ossim_uint32
◆ getField()
const std::string& ossimNmeaMessage::getField ( ossim_uint32  idx)
inline
Definition at line 45 of file ossimNmeaMessage.h.
46  {
47  static ossimString empty="";
48
49  if(idx < m_fields.size()) return m_fields[idx];
50
51  return empty;
52  }
◆ isValidStartChar()
bool ossimNmeaMessage::isValidStartChar ( char  c) const
protected
Definition at line 53 of file ossimNmeaMessage.cpp.
References m_startChars.
54 {
55  std::string::const_iterator iter = std::find(m_startChars.begin(), m_startChars.end(), c);
56  return (iter != m_startChars.end());
57 }
◆ message()
const std::string& ossimNmeaMessage::message ( ) const
inline
Definition at line 69 of file ossimNmeaMessage.h.
69 {return m_message;}
◆ numberOfFields()
ossim_uint32 ossimNmeaMessage::numberOfFields ( ) const
inline
Definition at line 43 of file ossimNmeaMessage.h.
43 {return m_fields.size();}
◆ operator[]()
const std::string& ossimNmeaMessage::operator[] ( int  idx) const
inline
Definition at line 53 of file ossimNmeaMessage.h.
54  {
55  static ossimString empty="";
56
57  if ( idx < static_cast<int>( m_fields.size() ) ) return m_fields[idx];
58
59  return empty;
60  }
◆ parseMessage()
void ossimNmeaMessage::parseMessage ( std::istream &  in)
virtual
No exceptions are created for checksums. The checksum needs to be checked after parsing by calling validCheckSum().
Definition at line 60 of file ossimNmeaMessage.cpp.
References ossimString::downcase(), and ossim::skipws().
Referenced by ossimNmeaMessageSequencer::next().
61 {
62  ossim::skipws(in);
63  m_validCheckSum = false;
64  m_message = "";
65  if(!isValidStartChar(static_cast<char>(in.peek())))
66  {
67  throw ossimException(ossimString("Starting NMEA message indicator not found, expected one of ") +
68  m_startChars + " but found " +
69  ossimString((char)in.peek()));
70  }
71
72  char c = static_cast<char>(in.get());
73  while(((c!='\n')&&(c!='\r'))&&
74  !in.eof()&&!in.bad())
75  {
76  m_message += c;
77  c = static_cast<char>(in.get());
78  }
79  std::string::iterator iter = std::find(m_message.begin(), m_message.end(), '*');
80
81  if(iter != m_message.end())
82  {
83  setFields(m_message.begin()+1, m_message.end());
84  ossim_uint32 check = checksum(m_message.begin()+1, iter);
86  out << std::setw(2) << std::setfill('0') << std::hex << check;
87  std::string::iterator endChecksumIter = iter+1;
88  while((endChecksumIter!= m_message.end())&&(*endChecksumIter!=',')) ++endChecksumIter;
89  if(out.str() == ossimString(iter+1, endChecksumIter).downcase())
90  {
91  m_validCheckSum = true;
92  }
93  }
94  else
95  {
96  throw ossimException("Terminating * indicator for cbecksum not found in NMEA message format");
97  }
98 }
static ossim_uint32 checksum(std::string::const_iterator start, std::string::const_iterator end)
bool isValidStartChar(char c) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
OSSIM_DLL std::istream & skipws(std::istream &in)
Definition: ossimCommon.cpp:38
virtual void setFields(std::string::const_iterator start, std::string::const_iterator end)
◆ reset()
virtual void ossimNmeaMessage::reset ( void  )
inlinevirtual
Definition at line 63 of file ossimNmeaMessage.h.
64  {
65  m_fields.clear();
66  m_message = "";
67  m_validCheckSum = false;
68  }
◆ setFields()
void ossimNmeaMessage::setFields ( std::string::const_iterator  start,
protectedvirtual
Definition at line 30 of file ossimNmeaMessage.cpp.
References m_fields.
31 {
32  m_fields.clear();
33  ossim_uint32 idx = 0;
34  while(start != end)
35  {
36  m_fields.push_back("");
37
38  while((start!=end)&&
39  (*start!=','))
40  {
41  m_fields[idx]+=*start;
42  ++start;
43  }
44
45  if(start!=end)
46  {
47  ++start;
48  }
49  ++idx;
50  }
51 }
◆ setStartChars()
void ossimNmeaMessage::setStartChars ( const std::string &  acceptedStartingCharacters = "!$")
inline
Definition at line 61 of file ossimNmeaMessage.h.
61 {m_startChars = acceptedStartingCharacters;}
◆ valid()
virtual bool ossimNmeaMessage::valid ( ) const
inlinevirtual
Definition at line 39 of file ossimNmeaMessage.h.
39 {return validCheckSum();}
bool validCheckSum() const
◆ validCheckSum()
bool ossimNmeaMessage::validCheckSum ( ) const
inline
Definition at line 40 of file ossimNmeaMessage.h.
40 {return m_validCheckSum;}
Member Data Documentation
◆ m_fields
FieldListType ossimNmeaMessage::m_fields
protected
Definition at line 79 of file ossimNmeaMessage.h.
Referenced by setFields().
◆ m_message
std::string ossimNmeaMessage::m_message
protected
Definition at line 78 of file ossimNmeaMessage.h.
◆ m_startChars
std::string ossimNmeaMessage::m_startChars
protected
Definition at line 82 of file ossimNmeaMessage.h.
Referenced by isValidStartChar().
◆ m_validCheckSum
bool ossimNmeaMessage::m_validCheckSum
protected
Definition at line 81 of file ossimNmeaMessage.h.
