Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimPotraceToolFactory Class Reference
#include <ossimPotraceToolFactory.h>
Inheritance diagram for ossimPotraceToolFactory:
ossimToolFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimPotraceToolFactory ()
virtual ossimToolcreateTool (const std::string &typeName) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
virtual void getCapabilities (std::map< std::string, std::string > &capabilities) const
 Appends map with available utilities along with descriptions as <name, decription> pairs. More...
virtual std::map< std::string, std::string > getCapabilities () const
- Public Member Functions inherited from ossimToolFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimToolcreateTool (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimPotraceToolFactoryinstance ()
 ossimPotraceToolFactory (const ossimPotraceToolFactory &)
void operator= (const ossimPotraceToolFactory &)
virtual ~ossimReferenced ()
static ossimPotraceToolFactorys_instance = 0
 static instance of this class More...
Detailed Description
Definition at line 19 of file ossimPotraceToolFactory.h.
◆ ~ossimPotraceToolFactory()
ossimPotraceToolFactory::~ossimPotraceToolFactory ( )
virtual
Definition at line 27 of file ossimPotraceToolFactory.cpp.
References ossimToolRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
28 {
30 }
static ossimToolRegistry * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
◆ ossimPotraceToolFactory() [1/2]
ossimPotraceToolFactory::ossimPotraceToolFactory ( )
protected
Definition at line 23 of file ossimPotraceToolFactory.cpp.
24 {
25 }
◆ ossimPotraceToolFactory() [2/2]
ossimPotraceToolFactory::ossimPotraceToolFactory ( const ossimPotraceToolFactory )
protected
Member Function Documentation
◆ createTool()
ossimTool * ossimPotraceToolFactory::createTool ( const std::string &  typeName) const
virtual
Implements ossimToolFactoryBase.
Definition at line 32 of file ossimPotraceToolFactory.cpp.
References ossimString::downcase().
33 {
34  ossimString utilName (argName);
35  utilName.downcase();
36
37  if ((utilName == "potrace") || (argName == "ossimPotraceTool"))
38  return new ossimPotraceTool;
39
40  return 0;
41 }
◆ getCapabilities() [1/2]
void ossimPotraceToolFactory::getCapabilities ( std::map< std::string, std::string > &  capabilities) const
virtual
The names are the human-readable name of the utility/service, typically the utility's class name without the "ossim" prefix nor "Util" suffix, all lowercase.
Definition at line 43 of file ossimPotraceToolFactory.cpp.
References ossimPotraceTool::DESCRIPTION.
44 {
45  capabilities.insert(pair<string, string>("potrace", ossimPotraceTool::DESCRIPTION));
46 }
static const char * DESCRIPTION
◆ getCapabilities() [2/2]
std::map< std::string, std::string > ossimPotraceToolFactory::getCapabilities ( ) const
virtual
Definition at line 48 of file ossimPotraceToolFactory.cpp.
49 {
50  std::map<std::string, std::string> result;
51  getCapabilities(result);
52  return result;
53 }
virtual std::map< std::string, std::string > getCapabilities() const
◆ getTypeNameList()
void ossimPotraceToolFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 55 of file ossimPotraceToolFactory.cpp.
56 {
57  typeList.push_back("ossimPotraceTool");
58 }
◆ instance()
ossimPotraceToolFactory * ossimPotraceToolFactory::instance ( )
static
Definition at line 16 of file ossimPotraceToolFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
17 {
18  if (!s_instance)
20  return s_instance;
21 }
static ossimPotraceToolFactory * s_instance
◆ operator=()
void ossimPotraceToolFactory::operator= ( const ossimPotraceToolFactory )
protected
Member Data Documentation
◆ s_instance
ossimPotraceToolFactory * ossimPotraceToolFactory::s_instance = 0
staticprotected
Definition at line 36 of file ossimPotraceToolFactory.h.
