Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfColorGrayscaleTable Class Reference
#include <ossimRpfColorGrayscaleTable.h>
 ossimRpfColorGrayscaleTable ()
 ossimRpfColorGrayscaleTable (const ossimRpfColorGrayscaleTable &rhs)
virtual ~ossimRpfColorGrayscaleTable ()
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
void setTableData (unsigned short id, unsigned long numberOfElements)
const ossimRpfColorGrayscaleTableoperator= (const ossimRpfColorGrayscaleTable &)
const unsigned char * getData () const
const unsigned char * getStartOfData (unsigned long entry) const
unsigned short getTableId () const
unsigned long getNumberOfElements () const
Private Attributes
unsigned long theNumberOfElements
unsigned long theTotalNumberOfBytes
unsigned short theTableId
unsigned char * theData
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfColorGrayscaleTable &data)
Detailed Description
Definition at line 8 of file ossimRpfColorGrayscaleTable.h.
◆ ossimRpfColorGrayscaleTable() [1/2]
ossimRpfColorGrayscaleTable::ossimRpfColorGrayscaleTable ( )
◆ ossimRpfColorGrayscaleTable() [2/2]
ossimRpfColorGrayscaleTable::ossimRpfColorGrayscaleTable ( const ossimRpfColorGrayscaleTable rhs)
Definition at line 24 of file ossimRpfColorGrayscaleTable.cpp.
27  theTableId(0),
28  theData(NULL)
29 {
30  *this = rhs;
31 }
◆ ~ossimRpfColorGrayscaleTable()
ossimRpfColorGrayscaleTable::~ossimRpfColorGrayscaleTable ( )
virtual
Definition at line 34 of file ossimRpfColorGrayscaleTable.cpp.
References theData.
35 {
36  if(theData)
37  {
38  delete [] theData;
39  theData = NULL;
40  }
41 }
Member Function Documentation
◆ getData()
const unsigned char* ossimRpfColorGrayscaleTable::getData ( ) const
inline
Definition at line 25 of file ossimRpfColorGrayscaleTable.h.
References theData.
25 {return theData;}
◆ getNumberOfElements()
unsigned long ossimRpfColorGrayscaleTable::getNumberOfElements ( ) const
inline
Definition at line 28 of file ossimRpfColorGrayscaleTable.h.
References theNumberOfElements.
◆ getStartOfData()
const unsigned char * ossimRpfColorGrayscaleTable::getStartOfData ( unsigned long  entry) const
Definition at line 61 of file ossimRpfColorGrayscaleTable.cpp.
References theData, and theTableId.
62 {
63  unsigned long offset = 0;
64
65  switch(theTableId)
66  {
67  case 1: // this is in format RGB
68  {
69  offset = 3*entry;
70  break;
71  }
72  case 2: // format RGBM
73  case 4: // format CMYK
74  {
75  offset = 4*entry;
76  break;
77  }
78  case 3: // format M
79  {
80  offset = entry;
81  break;
82  }
83  }
84
85  return (const unsigned char*)(theData + offset);
86 }
◆ getTableId()
unsigned short ossimRpfColorGrayscaleTable::getTableId ( ) const
inline
Definition at line 27 of file ossimRpfColorGrayscaleTable.h.
References theTableId.
◆ operator=()
const ossimRpfColorGrayscaleTable & ossimRpfColorGrayscaleTable::operator= ( const ossimRpfColorGrayscaleTable rhs)
Definition at line 131 of file ossimRpfColorGrayscaleTable.cpp.
References theData, theNumberOfElements, theTableId, and theTotalNumberOfBytes.
132 {
133
134  if(&rhs != this)
135  {
138  theTableId = rhs.theTableId;
139  if(theData)
140  {
141  delete theData;
142  theData = NULL;
143  }
145  {
146  theData = new unsigned char[theTotalNumberOfBytes];
147
148  memcpy(theData, rhs.theData, theTotalNumberOfBytes);
149  }
150  }
151
152  return *this;
153 }
◆ parseStream()
ossimErrorCode ossimRpfColorGrayscaleTable::parseStream ( std::istream &  in,
Definition at line 43 of file ossimRpfColorGrayscaleTable.cpp.
References ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, theData, and theTotalNumberOfBytes.
45 {
46  if(in)
47  {
49  {
50  in.read((char*)theData, theTotalNumberOfBytes);
51  }
52  }
53  else
54  {
56  }
57
59 }
static const ossimErrorCode OSSIM_OK
static const ossimErrorCode OSSIM_ERROR
◆ setTableData()
void ossimRpfColorGrayscaleTable::setTableData ( unsigned short  id,
Definition at line 88 of file ossimRpfColorGrayscaleTable.cpp.
90 {
91  if(theData)
92  {
93  delete theData;
94  theData = NULL;
95  }
96
97  unsigned long totalBytes = 0;
98
99  switch(id)
100  {
101  case 1: // this is in format RGB
102  {
103  totalBytes = 3*numberOfElements;
104  break;
105  }
106  case 2: // format RGBM
107  case 4: // format CMYK
108  {
109  totalBytes = 4*numberOfElements;
110  break;
111  }
112  case 3: // format M
113  {
114  totalBytes = numberOfElements;
115  break;
116  }
117  }
118
119  if(totalBytes > 0)
120  {
121  theTableId = id;
122  theNumberOfElements = numberOfElements;
123  theTotalNumberOfBytes = totalBytes;
124
125  theData = new unsigned char[totalBytes];
126  }
127 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfColorGrayscaleTable data
friend
Definition at line 6 of file ossimRpfColorGrayscaleTable.cpp.
8 {
9  out << "theNumberOfElements: " << data.theNumberOfElements
10  << "\ntheTotalNumberOfBytes: " << data.theTotalNumberOfBytes
11  << "\ntheTableId: " << data.theTableId;
12
13  return out;
14 }
Member Data Documentation
◆ theData
unsigned char* ossimRpfColorGrayscaleTable::theData
private
◆ theNumberOfElements
unsigned long ossimRpfColorGrayscaleTable::theNumberOfElements
private
◆ theTableId
unsigned short ossimRpfColorGrayscaleTable::theTableId
private
This will not be parsed from the stream. This is set when reading the offset record for this table. The id defines the format of the data buffer. if the id is :
1 then the buffer is in the format of RGB 2 "" RGBM 3 "" M 4 "" CMYK
Definition at line 45 of file ossimRpfColorGrayscaleTable.h.
Referenced by getStartOfData(), getTableId(), operator<<(), operator=(), and setTableData().
◆ theTotalNumberOfBytes
unsigned long ossimRpfColorGrayscaleTable::theTotalNumberOfBytes
private
Definition at line 33 of file ossimRpfColorGrayscaleTable.h.
Referenced by operator<<(), operator=(), parseStream(), and setTableData().
