Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfFrameFileIndexSectionSubheader Class Reference
#include <ossimRpfFrameFileIndexSectionSubheader.h>
Inheritance diagram for ossimRpfFrameFileIndexSectionSubheader:
ossimReferenced
 ossimRpfFrameFileIndexSectionSubheader ()
 default constructor More...
 ossimRpfFrameFileIndexSectionSubheader (const ossimRpfFrameFileIndexSectionSubheader &obj)
 copy constructor More...
const ossimRpfFrameFileIndexSectionSubheaderoperator= (const ossimRpfFrameFileIndexSectionSubheader &rhs)
 assignment operator More...
virtual ~ossimRpfFrameFileIndexSectionSubheader ()
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
void writeStream (std::ostream &out)
 Write method. More...
std::ostream & print (std::ostream &out) const
 print method that outputs a key/value type format adding prefix to keys. More...
ossim_uint32 getOffset () const
ossim_uint32 getNumberOfIndexRecords () const
ossim_uint16 getNumberOfPathnameRecords () const
ossim_uint16 getIndexRecordLength () const
void setNumberOfIndexRecords (ossim_uint32 count)
void setNumberOfPathnameRecords (ossim_uint16 count)
void setIndexRecordLength (ossim_uint16 length)
void clearFields ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
char m_highestSecurityClassification
ossim_uint32 m_indexTableOffset
ossim_uint32 m_numberOfIndexRecords
ossim_uint16 m_numberOfPathnameRecords
ossim_uint16 m_indexRecordLength
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfFrameFileIndexSectionSubheader &data)
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 19 of file ossimRpfFrameFileIndexSectionSubheader.h.
◆ ossimRpfFrameFileIndexSectionSubheader() [1/2]
ossimRpfFrameFileIndexSectionSubheader::ossimRpfFrameFileIndexSectionSubheader ( )
◆ ossimRpfFrameFileIndexSectionSubheader() [2/2]
ossimRpfFrameFileIndexSectionSubheader::ossimRpfFrameFileIndexSectionSubheader ( const ossimRpfFrameFileIndexSectionSubheader obj)
◆ ~ossimRpfFrameFileIndexSectionSubheader()
ossimRpfFrameFileIndexSectionSubheader::~ossimRpfFrameFileIndexSectionSubheader ( )
virtual
Definition at line 63 of file ossimRpfFrameFileIndexSectionSubheader.cpp.
64 {
65 }
Member Function Documentation
◆ clearFields()
void ossimRpfFrameFileIndexSectionSubheader::clearFields ( )
◆ getIndexRecordLength()
ossim_uint16 ossimRpfFrameFileIndexSectionSubheader::getIndexRecordLength ( ) const
◆ getNumberOfIndexRecords()
ossim_uint32 ossimRpfFrameFileIndexSectionSubheader::getNumberOfIndexRecords ( ) const
◆ getNumberOfPathnameRecords()
ossim_uint16 ossimRpfFrameFileIndexSectionSubheader::getNumberOfPathnameRecords ( ) const
◆ getOffset()
ossim_uint32 ossimRpfFrameFileIndexSectionSubheader::getOffset ( ) const
◆ operator=()
const ossimRpfFrameFileIndexSectionSubheader & ossimRpfFrameFileIndexSectionSubheader::operator= ( const ossimRpfFrameFileIndexSectionSubheader rhs)
◆ parseStream()
ossimErrorCode ossimRpfFrameFileIndexSectionSubheader::parseStream ( std::istream &  in,
Definition at line 67 of file ossimRpfFrameFileIndexSectionSubheader.cpp.
References ossim::byteOrder(), m_highestSecurityClassification, m_indexRecordLength, m_indexTableOffset, m_numberOfIndexRecords, m_numberOfPathnameRecords, ossimErrorCodes::OSSIM_ERROR, and ossimEndian::swap().
Referenced by ossimRpfHeader::getNewFrameFileIndexSectionSubheader().
69 {
70  if(in)
71  {
72  in.read((char*)&m_highestSecurityClassification, 1);
73  in.read((char*)&m_indexTableOffset, 4);
74  in.read((char*)&m_numberOfIndexRecords, 4);
75  in.read((char*)&m_numberOfPathnameRecords, 2);
76  in.read((char*)&m_indexRecordLength, 2);
77
78  if( ossim::byteOrder() != byteOrder )
79  {
80  ossimEndian anEndian;
81  anEndian.swap(m_indexTableOffset);
82  anEndian.swap(m_numberOfIndexRecords);
84  anEndian.swap(m_indexRecordLength);
85  }
86  }
87  else
88  {
90  }
91
92  if ( traceDebug() )
93  {
95  }
96
98 }
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
std::ostream & print(std::ostream &out) const
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ print()
std::ostream & ossimRpfFrameFileIndexSectionSubheader::print ( std::ostream &  out) const
Parameters
outString to output to.
prefixThis will be prepended to key. e.g. Where prefix = "nitf." and key is "file_name" key becomes: "nitf.file_name:"
Returns
output stream.
Definition at line 128 of file ossimRpfFrameFileIndexSectionSubheader.cpp.
References m_highestSecurityClassification, m_indexRecordLength, m_indexTableOffset, m_numberOfIndexRecords, and m_numberOfPathnameRecords.
Referenced by operator<<().
129 {
130  out << "ossimRpfFrameFileIndexSectionSubheader DEBUG:"
131  << "\nHighestSecurityClassification: " << m_highestSecurityClassification
132  << "\nIndexTableOffset: " << m_indexTableOffset
133  << "\nNumberOfIndexRecords: " << m_numberOfIndexRecords
134  << "\nNumberOfPathnameRecords: " << m_numberOfPathnameRecords
135  << "\nIndexRecordLength: " << m_indexRecordLength
136  << std::endl;
137
138  return out;
139 }
◆ setIndexRecordLength()
void ossimRpfFrameFileIndexSectionSubheader::setIndexRecordLength ( ossim_uint16  length)
◆ setNumberOfIndexRecords()
void ossimRpfFrameFileIndexSectionSubheader::setNumberOfIndexRecords ( ossim_uint32  count)
◆ setNumberOfPathnameRecords()
void ossimRpfFrameFileIndexSectionSubheader::setNumberOfPathnameRecords ( ossim_uint16  count)
◆ writeStream()
void ossimRpfFrameFileIndexSectionSubheader::writeStream ( std::ostream &  out)
Write method.
Note always writes out in big endian at this point.
Parameters
outStream to write to.
Definition at line 100 of file ossimRpfFrameFileIndexSectionSubheader.cpp.
References ossim::byteOrder(), m_highestSecurityClassification, m_indexRecordLength, m_indexTableOffset, m_numberOfIndexRecords, m_numberOfPathnameRecords, OSSIM_BIG_ENDIAN, and ossimEndian::swap().
101 {
103  {
104  // Swap to big endian.
105  ossimEndian anEndian;
106  anEndian.swap(m_indexTableOffset);
107  anEndian.swap(m_numberOfIndexRecords);
109  anEndian.swap(m_indexRecordLength);
110  }
111
112  out.write((char*)&m_highestSecurityClassification, 1);
113  out.write((char*)&m_indexTableOffset, 4);
114  out.write((char*)&m_numberOfIndexRecords, 4);
115  out.write((char*)&m_numberOfPathnameRecords, 2);
116  out.write((char*)&m_indexRecordLength, 2);
117
119  {
120  // Swap back to native byte order.
121  ossimEndian anEndian;
122  anEndian.swap(m_indexTableOffset);
123  anEndian.swap(m_numberOfIndexRecords);
125  anEndian.swap(m_indexRecordLength);
126  }
127 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfFrameFileIndexSectionSubheader data
friend
Definition at line 23 of file ossimRpfFrameFileIndexSectionSubheader.cpp.
24 {
25  return data.print(out);
26 }
Member Data Documentation
◆ m_highestSecurityClassification
char ossimRpfFrameFileIndexSectionSubheader::m_highestSecurityClassification
private
◆ m_indexRecordLength
ossim_uint16 ossimRpfFrameFileIndexSectionSubheader::m_indexRecordLength
private
◆ m_indexTableOffset
ossim_uint32 ossimRpfFrameFileIndexSectionSubheader::m_indexTableOffset
private
◆ m_numberOfIndexRecords
ossim_uint32 ossimRpfFrameFileIndexSectionSubheader::m_numberOfIndexRecords
private
◆ m_numberOfPathnameRecords
ossim_uint16 ossimRpfFrameFileIndexSectionSubheader::m_numberOfPathnameRecords
private
