Public Member Functions | Private Member Functions | Private Attributes | Friends | List of all members
ossimRpfMaskSubheader Class Reference
#include <ossimRpfMaskSubheader.h>
 ossimRpfMaskSubheader ()
virtual ~ossimRpfMaskSubheader ()
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
void print (std::ostream &out) const
void clearFields ()
Private Attributes
unsigned short theSubframeSequenceRecordLength
unsigned short theTransparencySequenceRecordLength
unsigned short theTransparentOutputPixelCodeLength
unsigned char * theOutputPixelCodeBitString
long theNumberOfBytes
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfMaskSubheader &data)
Detailed Description
Definition at line 9 of file ossimRpfMaskSubheader.h.
◆ ossimRpfMaskSubheader()
ossimRpfMaskSubheader::ossimRpfMaskSubheader ( )
◆ ~ossimRpfMaskSubheader()
ossimRpfMaskSubheader::~ossimRpfMaskSubheader ( )
virtual
Definition at line 23 of file ossimRpfMaskSubheader.cpp.
References theOutputPixelCodeBitString.
24 {
26  {
29  }
30 }
Member Function Documentation
◆ clearFields()
void ossimRpfMaskSubheader::clearFields ( )
private
◆ parseStream()
ossimErrorCode ossimRpfMaskSubheader::parseStream ( std::istream &  in,
Definition at line 32 of file ossimRpfMaskSubheader.cpp.
References ossim::byteOrder(), clearFields(), ossimEndian::getSystemEndianType(), ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, ossimEndian::swap(), theNumberOfBytes, theOutputPixelCodeBitString, theSubframeSequenceRecordLength, theTransparencySequenceRecordLength, and theTransparentOutputPixelCodeLength.
Referenced by ossimRpfMaskSubsection::parseStream(), and ossimRpfFrame::populateImageSection().
34 {
35  if(in)
36  {
37  clearFields();
38
39  in.read((char*)&theSubframeSequenceRecordLength, 2);
40  in.read((char*)&theTransparencySequenceRecordLength, 2);
41  in.read((char*)&theTransparentOutputPixelCodeLength, 2);
42  ossimEndian anEndian;
43
44  if(anEndian.getSystemEndianType() != byteOrder)
45  {
49
50  }
52  {
54  theOutputPixelCodeBitString = new unsigned char[theNumberOfBytes];
56  }
57  }
58  else
59  {
61  }
62
64 }
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ print()
void ossimRpfMaskSubheader::print ( std::ostream &  out) const
Definition at line 66 of file ossimRpfMaskSubheader.cpp.
References theNumberOfBytes, theOutputPixelCodeBitString, theSubframeSequenceRecordLength, theTransparencySequenceRecordLength, and theTransparentOutputPixelCodeLength.
Referenced by operator<<().
67 {
68  out << "theSubframeSequenceRecordLength: "
70  << "\ntheTransparencySequenceRecordLength: "
72  << "\ntheTransparentOutputPixelCodeLength: "
74  << "\ntheNumberOfBytes: "
76  << "\ntheOutputPixelCodeBitString: ";
77
78  // display the pixel code as a bit pattern.
79  for(long index = theNumberOfBytes-1;
80  index >=0;
81  --index)
82  {
83  unsigned long temp = theOutputPixelCodeBitString[index];
84  out << ((temp>>7)&1)
85  << ((temp>>6)&1)
86  << ((temp>>5)&1)
87  << ((temp>>4)&1)
88  << ((temp>>3)&1)
89  << ((temp>>2)&1)
90  << ((temp>>1)&1)
91  << (temp&1);
92  }
93  out << std::endl;
94 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfMaskSubheader data
friend
Definition at line 6 of file ossimRpfMaskSubheader.cpp.
8 {
9  data.print(out);
10  return out;
11 }
void print(std::ostream &out) const
Member Data Documentation
◆ theNumberOfBytes
long ossimRpfMaskSubheader::theNumberOfBytes
private
This is just a working variable and is not part of the Rpf fields. this is the number of bytes of the output pixel code length. It divides by 8 and then does the ceiling of the theTransparentOutputPixelCodeLength.
Definition at line 37 of file ossimRpfMaskSubheader.h.
Referenced by clearFields(), parseStream(), and print().
◆ theOutputPixelCodeBitString
unsigned char* ossimRpfMaskSubheader::theOutputPixelCodeBitString
private
Definition at line 28 of file ossimRpfMaskSubheader.h.
Referenced by clearFields(), parseStream(), print(), and ~ossimRpfMaskSubheader().
◆ theSubframeSequenceRecordLength
unsigned short ossimRpfMaskSubheader::theSubframeSequenceRecordLength
private
Definition at line 25 of file ossimRpfMaskSubheader.h.
◆ theTransparencySequenceRecordLength
unsigned short ossimRpfMaskSubheader::theTransparencySequenceRecordLength
private
Definition at line 26 of file ossimRpfMaskSubheader.h.
◆ theTransparentOutputPixelCodeLength
unsigned short ossimRpfMaskSubheader::theTransparentOutputPixelCodeLength
private
Definition at line 27 of file ossimRpfMaskSubheader.h.
