Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfReplaceUpdateSectionSubheader Class Reference
RPF replace/update section subheader record. More...
#include <ossimRpfReplaceUpdateSectionSubheader.h>
Inheritance diagram for ossimRpfReplaceUpdateSectionSubheader:
ossimReferenced
 ossimRpfReplaceUpdateSectionSubheader ()
 default constructor More...
 ossimRpfReplaceUpdateSectionSubheader (const ossimRpfReplaceUpdateSectionSubheader &obj)
 copy constructor More...
const ossimRpfReplaceUpdateSectionSubheaderoperator= (const ossimRpfReplaceUpdateSectionSubheader &rhs)
 assignment operator More...
virtual ~ossimRpfReplaceUpdateSectionSubheader ()
 virtual destructor More...
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
 Method to parse the record. More...
void writeStream (std::ostream &out)
 Write method. More...
std::ostream & print (std::ostream &out) const
 print method that outputs a key/value type format adding prefix to keys. More...
ossim_uint32 getOffset () const
ossim_uint16 getNumberOfRecords () const
ossim_uint16 getRecordLength () const
void setNumberOfRecords (ossim_uint16 count)
 Sets number of records. More...
void setRecordLength (ossim_uint16 length)
void clearFields ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
ossim_uint32 m_tableOffset
ossim_uint16 m_numberOfRecords
ossim_uint16 m_recordLength
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfReplaceUpdateSectionSubheader &data)
 Convenience output operator. More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
See MIL-STD-2411 for detailed information.
Definition at line 27 of file ossimRpfReplaceUpdateSectionSubheader.h.
◆ ossimRpfReplaceUpdateSectionSubheader() [1/2]
ossimRpfReplaceUpdateSectionSubheader::ossimRpfReplaceUpdateSectionSubheader ( )
◆ ossimRpfReplaceUpdateSectionSubheader() [2/2]
ossimRpfReplaceUpdateSectionSubheader::ossimRpfReplaceUpdateSectionSubheader ( const ossimRpfReplaceUpdateSectionSubheader obj)
◆ ~ossimRpfReplaceUpdateSectionSubheader()
ossimRpfReplaceUpdateSectionSubheader::~ossimRpfReplaceUpdateSectionSubheader ( )
virtual
virtual destructor
Definition at line 62 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
63 {
64 }
Member Function Documentation
◆ clearFields()
void ossimRpfReplaceUpdateSectionSubheader::clearFields ( )
◆ getNumberOfRecords()
ossim_uint16 ossimRpfReplaceUpdateSectionSubheader::getNumberOfRecords ( ) const
Returns
Number of records.
Definition at line 136 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References m_numberOfRecords.
Referenced by ossimRpfFrame::populateReplaceUpdateTable().
◆ getOffset()
ossim_uint32 ossimRpfReplaceUpdateSectionSubheader::getOffset ( ) const
Returns
Offset to first record.
Definition at line 131 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References m_tableOffset.
◆ getRecordLength()
ossim_uint16 ossimRpfReplaceUpdateSectionSubheader::getRecordLength ( ) const
Returns
Length of one record.
Definition at line 141 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References m_recordLength.
◆ operator=()
const ossimRpfReplaceUpdateSectionSubheader & ossimRpfReplaceUpdateSectionSubheader::operator= ( const ossimRpfReplaceUpdateSectionSubheader rhs)
◆ parseStream()
ossimErrorCode ossimRpfReplaceUpdateSectionSubheader::parseStream ( std::istream &  in,
Parameters
inStream sitting at record.
byteOrderByte order of system.
Definition at line 66 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References ossim::byteOrder(), m_numberOfRecords, m_recordLength, m_tableOffset, ossimErrorCodes::OSSIM_ERROR, and ossimEndian::swap().
68 {
69  if(in)
70  {
71  in.read((char*)&m_tableOffset, 4);
72  in.read((char*)&m_numberOfRecords, 2);
73  in.read((char*)&m_recordLength, 2);
74
75  if( ossim::byteOrder() != byteOrder )
76  {
77  ossimEndian anEndian;
78  anEndian.swap(m_tableOffset);
79  anEndian.swap(m_numberOfRecords);
80  anEndian.swap(m_recordLength);
81  }
82  }
83  else
84  {
86  }
87
88  if ( traceDebug() )
89  {
91  }
92
94 }
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
std::ostream & print(std::ostream &out) const
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ print()
std::ostream & ossimRpfReplaceUpdateSectionSubheader::print ( std::ostream &  out) const
Parameters
outString to output to.
prefixThis will be prepended to key. e.g. Where prefix = "nitf." and key is "file_name" key becomes: "nitf.file_name:"
Returns
output stream.
Definition at line 120 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References m_numberOfRecords, m_recordLength, and m_tableOffset.
Referenced by operator<<().
121 {
122  out << "ossimRpfReplaceUpdateSectionSubheader DEBUG:"
123  << "\ntable_offset: " << m_tableOffset
124  << "\nnumber_of_records: " << m_numberOfRecords
125  << "\nrecord_length: " << m_recordLength
126  << std::endl;
127
128  return out;
129 }
◆ setNumberOfRecords()
void ossimRpfReplaceUpdateSectionSubheader::setNumberOfRecords ( ossim_uint16  count)
Parameters
count
Definition at line 146 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
◆ setRecordLength()
void ossimRpfReplaceUpdateSectionSubheader::setRecordLength ( ossim_uint16  length)
Definition at line 151 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
◆ writeStream()
void ossimRpfReplaceUpdateSectionSubheader::writeStream ( std::ostream &  out)
Write method.
Note always writes out in big endian at this point.
Parameters
outStream to write to.
Definition at line 96 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
References ossim::byteOrder(), m_numberOfRecords, m_recordLength, m_tableOffset, OSSIM_BIG_ENDIAN, and ossimEndian::swap().
97 {
99  {
100  // Swap to big endian.
101  ossimEndian anEndian;
102  anEndian.swap(m_tableOffset);
103  anEndian.swap(m_numberOfRecords);
104  anEndian.swap(m_recordLength);
105  }
106
107  out.write((char*)&m_tableOffset, 4);
108  out.write((char*)&m_numberOfRecords, 2);
109  out.write((char*)&m_recordLength, 2);
110
112  {
113  // Swap back to native byte order.
114  ossimEndian anEndian;
115  anEndian.swap(m_tableOffset);
116  anEndian.swap(m_numberOfRecords);
117  anEndian.swap(m_recordLength);
118  }
119 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfReplaceUpdateSectionSubheader data
friend
Definition at line 28 of file ossimRpfReplaceUpdateSectionSubheader.cpp.
29 {
30  return data.print(out);
31 }
Member Data Documentation
◆ m_numberOfRecords
ossim_uint16 ossimRpfReplaceUpdateSectionSubheader::m_numberOfRecords
private
◆ m_recordLength
ossim_uint16 ossimRpfReplaceUpdateSectionSubheader::m_recordLength
private
◆ m_tableOffset
ossim_uint32 ossimRpfReplaceUpdateSectionSubheader::m_tableOffset
private
