Public Member Functions | Private Attributes | List of all members
ossimRpfReplaceUpdateTable Class Reference
Holds a table of RPF replace/update section subheader records. More...
#include <ossimRpfReplaceUpdateTable.h>
Inheritance diagram for ossimRpfReplaceUpdateTable:
ossimReferenced
 ossimRpfReplaceUpdateTable ()
 default constructor More...
 ossimRpfReplaceUpdateTable (const ossimRpfReplaceUpdateTable &obj)
 copy constructor More...
const ossimRpfReplaceUpdateTableoperator= (const ossimRpfReplaceUpdateTable &rhs)
 assignment operator More...
void addRecord (const ossimRpfReplaceUpdateRecord &record)
 Method to add a record. More...
void clear ()
 Clears the table. More...
std::ostream & print (std::ostream &out, const std::string &prefix=std::string()) const
 print method that outputs a key/value type format adding prefix to keys. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
std::vector< ossimRpfReplaceUpdateRecordm_table
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
See MIL-STD-2411 for detailed information.
Definition at line 29 of file ossimRpfReplaceUpdateTable.h.
◆ ossimRpfReplaceUpdateTable() [1/2]
ossimRpfReplaceUpdateTable::ossimRpfReplaceUpdateTable ( )
default constructor
Definition at line 21 of file ossimRpfReplaceUpdateTable.cpp.
22  :
23  m_table(0)
24 {
25 }
std::vector< ossimRpfReplaceUpdateRecord > m_table
◆ ossimRpfReplaceUpdateTable() [2/2]
ossimRpfReplaceUpdateTable::ossimRpfReplaceUpdateTable ( const ossimRpfReplaceUpdateTable obj)
copy constructor
Definition at line 27 of file ossimRpfReplaceUpdateTable.cpp.
28  :
29  m_table(obj.m_table)
30 {
31 }
Member Function Documentation
◆ addRecord()
void ossimRpfReplaceUpdateTable::addRecord ( const ossimRpfReplaceUpdateRecord record)
Parameters
recordto add.
Definition at line 43 of file ossimRpfReplaceUpdateTable.cpp.
References m_table.
Referenced by ossimRpfFrame::populateReplaceUpdateTable().
44 {
45  m_table.push_back(record);
46 }
◆ clear()
void ossimRpfReplaceUpdateTable::clear ( )
Clears the table.
Definition at line 48 of file ossimRpfReplaceUpdateTable.cpp.
References m_table.
49 {
50  m_table.clear();
51 }
◆ operator=()
const ossimRpfReplaceUpdateTable & ossimRpfReplaceUpdateTable::operator= ( const ossimRpfReplaceUpdateTable rhs)
assignment operator
Definition at line 33 of file ossimRpfReplaceUpdateTable.cpp.
References m_table.
35 {
36  if ( this != &rhs )
37  {
38  m_table = rhs.m_table;
39  }
40  return *this;
41 }
◆ print()
std::ostream & ossimRpfReplaceUpdateTable::print ( std::ostream &  out,
const std::string &  prefix = std::string()
) const
Parameters
outStream to output to.
prefixThis will be prepended to key. e.g. Where prefix = "nitf.rpf." and key is "new_file" key becomes: "nitf.rpf.replace_update_record0.new_file:
Returns
output stream.
Definition at line 53 of file ossimRpfReplaceUpdateTable.cpp.
References m_table, and size.
55 {
56  ossim_uint32 size = static_cast<ossim_uint32>( m_table.size() );
57  for (ossim_uint32 i = 0; i < size; ++i)
58  {
59  m_table[i].print(out, prefix, i);
60  }
61  return out;
62 }
yy_size_t size
unsigned int ossim_uint32
Member Data Documentation
◆ m_table
std::vector<ossimRpfReplaceUpdateRecord> ossimRpfReplaceUpdateTable::m_table
private
Definition at line 65 of file ossimRpfReplaceUpdateTable.h.
Referenced by addRecord(), clear(), operator=(), and print().
