Info factory. More...
#include <ossimSqliteInfoFactory.h>
virtual | ~ossimSqliteInfoFactory () |
virtual destructor More... | |
virtual std::shared_ptr< ossimInfoBase > | create (const ossimFilename &file) const |
create method. More... | |
virtual std::shared_ptr< ossimInfoBase > | create (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) const |
ossimInfoFactoryInterface () | |
default constructor More... | |
virtual | ~ossimInfoFactoryInterface () |
static ossimSqliteInfoFactory * | instance () |
Private Member Functions | |
ossimSqliteInfoFactory () | |
hidden from use default constructor More... | |
ossimSqliteInfoFactory (const ossimSqliteInfoFactory &obj) | |
hidden from use copy constructor More... | |
const ossimSqliteInfoFactory & | operator= (const ossimSqliteInfoFactory &rhs) |
hidden from use operator = More... | |
Info factory.
Definition at line 26 of file ossimSqliteInfoFactory.h.
private |
private |
create method.
file | Some file you want info for. |
Implements ossimInfoFactoryInterface.
Definition at line 31 of file ossimSqliteInfoFactory.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimString::string().
Definition at line 48 of file ossimSqliteInfoFactory.cpp.
static |
Definition at line 24 of file ossimSqliteInfoFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
private |
Definition at line 64 of file ossimSqliteInfoFactory.cpp.
