Public Member Functions | Static Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | Static Private Attributes | List of all members
ossimTraceManager Class Reference
#include <ossimTraceManager.h>
void setTracePattern (const ossimString &pattern)
 Sets "thePattern" to "pattern", then calls setTraceFlags(true). More...
void addTrace (ossimTrace *traceObj)
void removeTrace (ossimTrace *traceObj)
static ossimTraceManagerinstance ()
 ossimTraceManager ()
 Protected default constructor. More...
void setTraceFlags (bool flag)
 Loops through "theTraceList" and sets any trace object's enable flag to flag if it matches regular expression of "thePattern". More...
Private Attributes
ossimString thePattern
 The regular expression pattern like "ossimDynamic|ossimGdal". More...
std::vector< ossimTrace * > theTraceList
 The list of trace objects. More...
static ossimTraceManagertheInstance = 0
 The instance of this manager. More...
Detailed Description
Definition at line 22 of file ossimTraceManager.h.
◆ ossimTraceManager()
ossimTraceManager::ossimTraceManager ( )
protected
Definition at line 24 of file ossimTraceManager.cpp.
References theInstance.
Referenced by instance().
25 {
26  theInstance = this;
27 }
static ossimTraceManager * theInstance
Member Function Documentation
◆ addTrace()
void ossimTraceManager::addTrace ( ossimTrace traceObj)
Parameters
traceObjossimTrace* to add to "theTraceList".
Definition at line 45 of file ossimTraceManager.cpp.
References ossimString::c_str(), ossimRegExp::compile(), ossimRegExp::find(), ossimTrace::getTraceName(), ossimTrace::setTraceFlag(), ossimString::size(), thePattern, and theTraceList.
Referenced by ossimTrace::ossimTrace().
46 {
47  if(!traceObj)
48  {
49  return;
50  }
51
52  std::vector<ossimTrace*>::iterator iter = std::find(theTraceList.begin(),
53  theTraceList.end(),
54  traceObj);
55  if(iter == theTraceList.end())
56  {
57  theTraceList.push_back(traceObj);
58
59  if(thePattern.size())
60  {
61  ossimRegExp rxp;
62  rxp.compile(thePattern.c_str());
63  if(rxp.find(traceObj->getTraceName().c_str()))
64  {
65  // Found a match so set the flag and increment the counter.
66  traceObj->setTraceFlag(true);
67  }
68  else
69  {
70  traceObj->setTraceFlag(false);
71  }
72  }
73  else
74  {
75  traceObj->setTraceFlag(false);
76  }
77  }
78 }
std::string::size_type size() const
Definition: ossimString.h:405
ossimString getTraceName() const
Returns "theTraceName" as an ossimString.
Definition: ossimTrace.h:40
void compile(const char *)
const char * c_str() const
Definition: ossimString.h:396
void setTraceFlag(bool flag)
Sets "theEnabled" flag.
Definition: ossimTrace.h:48
bool find(const char *)
◆ instance()
ossimTraceManager * ossimTraceManager::instance ( )
static
Returns
ossimTraceManager* to instance of the ossim trace manager.
Definition at line 29 of file ossimTraceManager.cpp.
References ossimTraceManager(), and theInstance.
Referenced by ossimTrace::ossimTrace(), and ossimTrace::~ossimTrace().
30 {
31  if(!theInstance)
32  {
34  }
35
36  return theInstance;
37 }
ossimTraceManager()
◆ removeTrace()
void ossimTraceManager::removeTrace ( ossimTrace traceObj)
Parameters
traceObjossimTrace* to remove from "theTraceList".
Definition at line 80 of file ossimTraceManager.cpp.
References theTraceList.
Referenced by ossimTrace::~ossimTrace().
81 {
82  std::vector<ossimTrace*>::iterator iter = std::find(theTraceList.begin(),
83  theTraceList.end(),
84  traceObj);
85
86  if(iter != theTraceList.end())
87  {
88  theTraceList.erase(iter);
89  }
90 }
◆ setTraceFlags()
void ossimTraceManager::setTraceFlags ( bool  flag)
private
For trace objects not matching "thePattern" no action is taken.
Definition at line 92 of file ossimTraceManager.cpp.
References ossimString::c_str(), ossimRegExp::compile(), ossimRegExp::find(), thePattern, and theTraceList.
Referenced by setTracePattern().
93 {
94  ossimRegExp rxp;
95  rxp.compile(thePattern.c_str());
96
97  for(ossim_uint32 idx = 0; idx < theTraceList.size(); ++idx)
98  {
99  if (rxp.find(theTraceList[idx]->getTraceName().c_str()))
100  {
101  // Found a match so set the flag and increment the counter.
102  theTraceList[idx]->setTraceFlag(flag);
103  }
104  }
105 }
unsigned int ossim_uint32
◆ setTracePattern()
void ossimTraceManager::setTracePattern ( const ossimString pattern)
Parameters
patternRegular expression to enable trace for.
Definition at line 39 of file ossimTraceManager.cpp.
References setTraceFlags(), and thePattern.
40 {
41  thePattern = pattern;
42  setTraceFlags(true);
43 }
void setTraceFlags(bool flag)
Loops through "theTraceList" and sets any trace object&#39;s enable flag to flag if it matches regular ex...
Member Data Documentation
◆ theInstance
ossimTraceManager * ossimTraceManager::theInstance = 0
staticprivate
Definition at line 60 of file ossimTraceManager.h.
Referenced by instance(), and ossimTraceManager().
◆ thePattern
ossimString ossimTraceManager::thePattern
private
Definition at line 63 of file ossimTraceManager.h.
Referenced by addTrace(), setTraceFlags(), and setTracePattern().
◆ theTraceList
std::vector<ossimTrace*> ossimTraceManager::theTraceList
private
Definition at line 66 of file ossimTraceManager.h.
Referenced by addTrace(), removeTrace(), and setTraceFlags().
